  4. Diskussion zum HowTo nodejs-Installation und upgrade
    1.0k
    6.1k
nodejs
844 Beiträge 91 Kommentatoren 309.2k Aufrufe 63 Beobachtet
    @ma
    iob stop
    iob fix
    iob nodejs-update
    ma
    #621
    @thomas-braun bin doch noch auf ein problem gestoßen ich kann aktuell keine adapter mehr updaten
    $ iobroker upgrade telegram@2.0.1
    host.iobroker Adapter "system.adapter.telegram.0" is stopped.
    host.iobroker Adapter "system.adapter.telegram.1" is stopped.
    Installing iobroker.telegram@2.0.1... (System call)
    host.iobroker Cannot install iobroker.telegram@2.0.1: 217
    ERROR: Process exited with code 25
    $ iobroker upgrade shelly@6.6.1
    Update shelly from @6.4.5 to @6.6.1
    Installing iobroker.shelly@6.6.1... (System call)
    Try to solve ENOTEMPTY error automaticallyInstalling iobroker.shelly@6.6.1... (System call)
    host.iobroker deleted npm temp directory: ".bindings-4WLiqHNJ")
    host.iobroker Cannot install iobroker.shelly@6.6.1: 217
    NPM version: 9.8.1
    Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@75lb/deep-mergenpm ERR! dest /opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLAnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@75lb/deep-merge' -> '/opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_04_36_193Z-debug-0.loghost.iobroker Cannot install iobroker.shelly@6.6.1: 217
    • M ma
      NPM version: 9.8.1
      ma
      #622
      @ma
      $ iobroker upgrade fullybrowser@2.2.0
      Update fullybrowser from @2.1.2 to @2.2.0
      Installing iobroker.fullybrowser@2.2.0... (System call)
      Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@alcalzone/jsonl-dbnpm ERR! dest /opt/iobroker/node_modules/@alcalzone/.jsonl-db-koHBLxk9npm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@alcalzone/jsonl-db' -> '/opt/iobroker/node_modules/@alcalzone/.jsonl-db-koHBLxk9'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_27_01_858Z-debug-0.loghost.iobroker Cannot install iobroker.fullybrowser@2.2.0: 217
      • M ma
        @ma
        #623
        @ma
        iob stop
        iob fix
        iob start
          @ma
          iob stop
          iob fix
          iob start
          ma
          #624
          @thomas-braun schon probiert leider keine Besserung
          • M ma
            #625
            @ma
            Dann mit --debug-Option installieren.
            iob update
            sagt?
              @ma
              iob update
              sagt?
              ma
              #626
              iob update
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alarm"        : 3.4.0    , installed 3.4.0
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
              Adapter    "bring"        : 1.8.4    , installed 1.8.4
              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
              Adapter    "countdown"    : 2.2.0    , installed 2.2.0
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "device-watcher": 2.9.4   , installed 2.9.4
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
              Adapter    "email"        : 1.2.0    , installed 1.2.0
              Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "fritzdect"    : 2.3.1    , installed 2.5.8
              Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
              Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "homekit-controller": 0.5.8, installed 0.5.8
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "icons-material-png": 0.1.0, installed 0.1.0
              Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
              Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "info"         : 2.0.0    , installed 2.0.0
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
              Adapter    "nut"          : 1.6.0    , installed 1.6.0
              Adapter    "oekofen-json" : 1.0.5    , installed 1.0.5
              Adapter    "openweathermap": 0.3.9   , installed 0.3.9
              Adapter    "operating-hours": 1.0.4  , installed 1.0.4
              Adapter    "parser"       : 1.3.2    , installed 1.3.2
              Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
              Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
              Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
              Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
              Adapter    "scenes"       : 2.3.9    , installed 2.3.9
              Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
              Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
              Adapter    "sonos"        : 2.3.1    , installed 2.3.1
              Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
              Adapter    "statistics"   : 2.3.0    , installed 2.3.0
              Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "unifi"        : 0.6.6    , installed 0.6.6
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
              Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
              Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.4    , installed 6.1.4
              Adapter    "windows-control": 0.1.5  , installed 0.1.5
              Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              iobroker upgrade shelly --debug
              This upgrade of "shelly" will introduce the following changes:
              -> 6.6.1:
              Fixed stop reason for Shelly 2.5 / Shelly 2
              Added humidity of Shelly Plus Addon
              Not all devices have external power
              -> 6.6.0:
              Added BLE devices as states to `shelly.0.ble.*` (Shelly Scripting required)
              -> 6.5.0:
              Added Shelly Plus Smoke
              Added Shelly Bluetooth Low Energy Gateway
              More Shelly TRV Datapoints
              Would you like to upgrade shelly from @6.4.5 to @6.6.1 now? [(y)es, (n)o]: y
              NPM version: 9.8.1
              npm ERR! errno -39
              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T06_39_34_733Z-debug-0.log
              npm ERR! errno -39
              • M ma
                iob update
                -> 6.6.1:
                -> 6.6.0:
                -> 6.5.0:
                NPM version: 9.8.1
                npm ERR! errno -39
                npm ERR! errno -39
                #627
                @ma
                Jag den
                iob fix
                drüber.
                  SiKo
                  #628
                  Hallo, hab schon versucht nodejs zu deinstallieren und neu installieren. Bekomme aber immer wieder diesen Fehler:
                  Was kann ich tun?
                  pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get full-upgrade
                  OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Holen:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
                  Fehl:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                  W: GPG-Fehler: https://deb.nodesource.com/node_18.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                  E: Das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« ist nicht signiert.
                  N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                  N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                  pi@raspberrypi:~ $
                    #629
                    @siko sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                    mach es mit iob nodejs-update
                    • S SiKo
                      Was kann ich tun?
                      pi@raspberrypi:~ $
                      #630
                      @siko
                      Da fehlen die Schlüssel.
                      Mach es mit
                      iob nodejs-update
                      dann passt es auch.
                        SiKo
                        #631
                        vielen Dank, Hat direkt funktioniert.
                        • S SiKo
                          #632
                          Natürlich... : 😊
                            @ma
                            Jag den
                            iob fix
                            drüber.
                            ma
                            #633
                            @thomas-braun der 2 durchlauf vom fix hat das problem gelößt leider nur bis gerade eben
                            $ iobroker upgrade sonos@3.0.0
                            Update sonos from @2.3.1 to @3.0.0
                            Installing iobroker.sonos@3.0.0... (System call)
                            host.iobroker deleted npm temp directory: ".acorn-jsx-zPgFNGpl")
                            host.iobroker deleted npm temp directory: ".alcalzone-shared-FgX40TmF")
                            host.iobroker deleted npm temp directory: ".all-package-names-BPhkNiF7")
                            host.iobroker deleted npm temp directory: ".ansi-colors-qAZfUuTD")
                            host.iobroker deleted npm temp directory: ".ansi-escapes-BuACp4PU")
                            host.iobroker deleted npm temp directory: ".any-observable-GucR4b7Z")
                            host.iobroker deleted npm temp directory: ".any-promise-GjCkSNL3")host.iobroker deleted npm temp directory: ".anymatch-7vz5qHmT")host.iobroker deleted npm temp directory: ".aproba-IIqIrfbB")
                            host.iobroker deleted npm temp directory: ".array-flatten-95xLgxGw")
                            host.iobroker deleted npm temp directory: ".array.prototype.findindex-JX1jwpiR")
                            host.iobroker deleted npm temp directory: ".boolbase-8130XECE")
                            host.iobroker deleted npm temp directory: ".bplist-parser-GTDOjzTC")
                            host.iobroker deleted npm temp directory: ".bundle-name-DjKLTayE")
                            host.iobroker deleted npm temp directory: ".busboy-A5FsP0CS")
                            host.iobroker deleted npm temp directory: ".chownr-E9JZijSA")
                            host.iobroker deleted npm temp directory: ".data-uri-to-buffer-GQ7HcaPL")
                            host.iobroker deleted npm temp directory: ".decamelize-keys-RDuJHe51")
                            host.iobroker deleted npm temp directory: ".decimal.js-A6TpPJWn")
                            host.iobroker deleted npm temp directory: ".dns-equal-TvMdkxWU")
                            host.iobroker deleted npm temp directory: ".es-shim-unscopables-lNCpEqsg")
                            host.iobroker deleted npm temp directory: ".esutils-1jlXlxlo")
                            host.iobroker deleted npm temp directory: ".follow-redirects-vRGWWNjd")
                            host.iobroker deleted npm temp directory: ".gopd-LUHsc2oq")
                            host.iobroker deleted npm temp directory: ".got-DFICjTYm")
                            host.iobroker deleted npm temp directory: ".graceful-fs-i6Qs7iN3")
                            host.iobroker deleted npm temp directory: ".indexof-m6nUtkW4")
                            host.iobroker deleted npm temp directory: ".inflight-pQph8mNF")
                            host.iobroker deleted npm temp directory: ".influx-JoUiD55Z")host.iobroker deleted npm temp directory: ".inherits-ffYUEA4n")host.iobroker deleted npm temp directory: ".ini-HiLT2lH8")host.iobroker deleted npm temp directory: ".inquirer-0PRKJaIm")
                            host.iobroker deleted npm temp directory: ".iobroker-adapter-helpers-za1UEIZc")
                            host.iobroker deleted npm temp directory: ".iobroker.alarm-g8jjAFg9")
                            host.iobroker deleted npm temp directory: ".iobroker.alias-manager-gHAtOr6e")
                            host.iobroker deleted npm temp directory: ".iobroker.bidirectional-counter-PzmaO0Aw")
                            host.iobroker deleted npm temp directory: ".iobroker.bring-ov1aPXwP")
                            host.iobroker deleted npm temp directory: ".iobroker.broadlink2-HDK4EOgs")
                            host.iobroker deleted npm temp directory: ".iobroker.coronavirus-statistics-Kxvay9Wy")
                            host.iobroker deleted npm temp directory: ".iobroker.countdown-M3o5XFv5")
                            host.iobroker deleted npm temp directory: ".iobroker.daswetter-1t9k5PAQ")
                            host.iobroker deleted npm temp directory: ".iobroker.device-watcher-JRkscZB5")
                            host.iobroker deleted npm temp directory: ".iobroker.devices-1FmykokK")
                            host.iobroker deleted npm temp directory: ".iobroker.discovery-Domn1CAP")
                            host.iobroker deleted npm temp directory: ".iobroker.doorbird-kwq4QU5M")
                            host.iobroker deleted npm temp directory: ".iobroker.dwd-SpnK64ht")
                            host.iobroker deleted npm temp directory: ".iobroker.email-7I7P5tNz")
                            host.iobroker deleted npm temp directory: ".iobroker.energiefluss-kJMU3Qwp")
                            host.iobroker deleted npm temp directory: ".iobroker.feiertage-WV2cxVZc")
                            host.iobroker deleted npm temp directory: ".iobroker.fullybrowser-g2Durliy")
                            host.iobroker deleted npm temp directory: ".iobroker.harmony-BDALdOzG")
                            host.iobroker deleted npm temp directory: ".iobroker.heatingcontrol-fFfpnmIZ")
                            host.iobroker deleted npm temp directory: ".iobroker.hm-rega-eDrPvalf")
                            host.iobroker deleted npm temp directory: ".iobroker.hm-rpc-6COQ5CUM")
                            host.iobroker deleted npm temp directory: ".iobroker.homekit-controller-sF0AM7Io")
                            host.iobroker deleted npm temp directory: ".iobroker.ical-rrBOhFW0")
                            host.iobroker deleted npm temp directory: ".iobroker.icons-icons8-F8SpNGzQ")
                            host.iobroker deleted npm temp directory: ".iobroker.icons-material-png-A0Zx2K4e")
                            host.iobroker deleted npm temp directory: ".iobroker.icons-material-svg-E2OoIK18")
                            host.iobroker deleted npm temp directory: ".iobroker.icons-mfd-svg-UK4n9spV")
                            host.iobroker deleted npm temp directory: ".iobroker.influxdb-mtpshsVk")
                            host.iobroker deleted npm temp directory: ".iobroker.info-OtqXm2hx")
                            host.iobroker deleted npm temp directory: ".iobroker.iqontrol-JG9EP64y")
                            host.iobroker deleted npm temp directory: ".iobroker.jarvis-Dfkzlr3d")
                            host.iobroker deleted npm temp directory: ".iobroker.javascript-5NZ432mn")
                            host.iobroker deleted npm temp directory: ".iobroker.js-controller-7Q8bmsba")
                            host.iobroker deleted npm temp directory: ".iobroker.linkeddevices-SudTlN7O")
                            host.iobroker deleted npm temp directory: ".iobroker.modbus-MRiPN8Jv")
                            host.iobroker deleted npm temp directory: ".iobroker.mqtt-R5v7g772")
                            host.iobroker deleted npm temp directory: ".iobroker.mqtt-client-AcZDMICZ")
                            host.iobroker deleted npm temp directory: ".iobroker.mytime-ALCjuXxL")
                            host.iobroker deleted npm temp directory: ".iobroker.nut-M42R6CUU")
                            host.iobroker deleted npm temp directory: ".iobroker.oekofen-json-AAGebuoM")
                            host.iobroker deleted npm temp directory: ".iobroker.openweathermap-uUPAAaq5")
                            host.iobroker deleted npm temp directory: ".iobroker.operating-hours-vFpZVs6M")
                            host.iobroker deleted npm temp directory: ".iobroker.parser-lf3ZX1wK")
                            host.iobroker deleted npm temp directory: ".iobroker.ping-OPzFiLFH")
                            host.iobroker deleted npm temp directory: ".iobroker.pushover-c2imyZua")
                            host.iobroker deleted npm temp directory: ".iobroker.pushsafer-akpid5GF")
                            host.iobroker deleted npm temp directory: ".iobroker.radar2-VVWJ5P6u")
                            host.iobroker deleted npm temp directory: ".iobroker.sayit-RsEZnXzS")
                            host.iobroker deleted npm temp directory: ".iobroker.scenes-9WoxMImK")
                            host.iobroker deleted npm temp directory: ".iobroker.shelly-wfXzBUin")
                            host.iobroker deleted npm temp directory: ".iobroker.shuttercontrol-msgqlVR3")
                            host.iobroker deleted npm temp directory: ".iobroker.simple-api-q4TJvC8n")
                            host.iobroker deleted npm temp directory: ".iobroker.smartcontrol-670ft8lY")
                            host.iobroker deleted npm temp directory: ".iobroker.smartmeter-OyPCR5Lj")
                            host.iobroker deleted npm temp directory: ".iobroker.socketio-0ZB5ejpX")
                            host.iobroker deleted npm temp directory: ".iobroker.sonoff-nQCcGLOb")
                            host.iobroker deleted npm temp directory: ".iobroker.sonos-8p9DbxUk")
                            host.iobroker deleted npm temp directory: ".iobroker.sourceanalytix-xH8dPE7Z")
                            host.iobroker deleted npm temp directory: ".iobroker.sprinklecontrol-jINmg3MW")
                            host.iobroker deleted npm temp directory: ".iobroker.statistics-nDtQT913")
                            host.iobroker deleted npm temp directory: ".iobroker.telegram-qJ3kkwRA")
                            host.iobroker deleted npm temp directory: ".iobroker.terminal-LQj2rBFR")
                            host.iobroker deleted npm temp directory: ".iobroker.text2command-XKgXlG9f")
                            host.iobroker deleted npm temp directory: ".iobroker.trashschedule-bVFlHcrS")
                            host.iobroker deleted npm temp directory: ".iobroker.unifi-YuUe0MFZ")
                            host.iobroker deleted npm temp directory: ".iobroker.upnp-XYJa4jHA")
                            host.iobroker deleted npm temp directory: ".iobroker.virtualpowermeter-aiSWB1CL")
                            host.iobroker deleted npm temp directory: ".iobroker.vis-hqwidgets-XOleJSph")
                            host.iobroker deleted npm temp directory: ".iobroker.vis-icontwo-ZE5SYXJL")
                            host.iobroker deleted npm temp directory: ".iobroker.weatherunderground-yjlWL8nH")
                            host.iobroker deleted npm temp directory: ".iobroker.web-qhxwcVTa")
                            host.iobroker deleted npm temp directory: ".iobroker.windows-control-m2ZZnHAV")
                            host.iobroker deleted npm temp directory: ".iobroker.wiobrowser-0FquAKud")
                            host.iobroker deleted npm temp directory: ".iobroker.ws-Ul5el1jB")
                            host.iobroker deleted npm temp directory: ".iobroker.yahka-5keTFK1G")
                            host.iobroker deleted npm temp directory: ".iobroker.zigbee-1JQaSLfT")
                            host.iobroker deleted npm temp directory: ".ipaddr.js-Cv8HUhd7")
                            host.iobroker deleted npm temp directory: ".is-array-buffer-jIv3kdDM")
                            host.iobroker deleted npm temp directory: ".is-bigint-opiLNorc")host.iobroker deleted npm temp directory: ".is-binary-path-T9bvCuQK")
                            host.iobroker deleted npm temp directory: ".is-core-module-3szSVmLC")
                            host.iobroker deleted npm temp directory: ".is-docker-diEaV9Js")
                            host.iobroker deleted npm temp directory: ".is-map-DnX0Tp2n")
                            host.iobroker deleted npm temp directory: ".is-name-taken-RA37aJNO")
                            host.iobroker deleted npm temp directory: ".is-npm-Tq5PXIR1")
                            host.iobroker deleted npm temp directory: ".is-obj-H9BCY1mC")
                            host.iobroker deleted npm temp directory: ".is-promise-TcPsCtHt")
                            host.iobroker deleted npm temp directory: ".is-symbol-DyzbAfPe")
                            host.iobroker deleted npm temp directory: ".is-utf8-XzPsDN8p")
                            host.iobroker deleted npm temp directory: ".is-weakref-3wPDZaCU")
                            host.iobroker deleted npm temp directory: ".is-wsl-67INiaF0")
                            host.iobroker deleted npm temp directory: ".is-yarn-global-z8J5xFQb")
                            host.iobroker deleted npm temp directory: ".javascript-natural-sort-BSvwVhzD")
                            host.iobroker deleted npm temp directory: ".js-sdsl-RiJhgh6j")
                            host.iobroker deleted npm temp directory: ".jsonc-parser-nbReDrcG")
                            host.iobroker deleted npm temp directory: ".jsonwebtoken-b9ysUQT0")
                            host.iobroker deleted npm temp directory: ".jsprim-QmUwRLNa")
                            host.iobroker deleted npm temp directory: ".jszip-r3fGcU4N")
                            host.iobroker deleted npm temp directory: ".kind-of-ZEKy7WZt")
                            host.iobroker deleted npm temp directory: ".layerr-GPEJIlGL")
                            host.iobroker deleted npm temp directory: ".lcid-SGsSRn9Q")
                            host.iobroker deleted npm temp directory: ".libsodium-wrappers-xQoQYz7T")
                            host.iobroker deleted npm temp directory: ".lines-and-columns-ohK2P2I1")
                            host.iobroker deleted npm temp directory: ".listr-SF1ph3tc")
                            host.iobroker deleted npm temp directory: ".listr-update-renderer-CSIQ7CWX")
                            host.iobroker deleted npm temp directory: ".load-json-file-5LcbUpDJ")
                            host.iobroker deleted npm temp directory: ".locate-path-t7OptBTV")
                            host.iobroker deleted npm temp directory: ".lodash-MxVnsAsD")
                            host.iobroker deleted npm temp directory: ".lodash.isnumber-P8M8GSmV")
                            host.iobroker deleted npm temp directory: ".log-symbols-rbtC1M9g")
                            host.iobroker deleted npm temp directory: ".log-update-SuSlKzSj")
                            host.iobroker deleted npm temp directory: ".logform-Bwy2bCcs")
                            host.iobroker deleted npm temp directory: ".loupe-hV7arrgu")
                            host.iobroker deleted npm temp directory: ".lru_map-uI07ZEOk")
                            host.iobroker deleted npm temp directory: ".macaddress-dlPdmBpu")
                            host.iobroker deleted npm temp directory: ".map-obj-FDgyUQwo")
                            host.iobroker deleted npm temp directory: ".map-stream-elIH4kVT")
                            host.iobroker deleted npm temp directory: ".md5-viMx30VF")
                            host.iobroker deleted npm temp directory: ".media-typer-kYaJhV1E")
                            host.iobroker deleted npm temp directory: ".mime-db-RKfcSKNg")
                            host.iobroker deleted npm temp directory: ".mimic-fn-hAcoKpm0")
                            host.iobroker deleted npm temp directory: ".minimist-options-qXL9cbTR")
                            host.iobroker deleted npm temp directory: ".minipass-FfE0ClCz")
                            host.iobroker deleted npm temp directory: ".mkdirp-classic-HAXMCI8y")
                            host.iobroker deleted npm temp directory: ".mkdirp-yMXn50Ac")
                            host.iobroker deleted npm temp directory: ".module-not-found-error-zFjQCtp1")
                            host.iobroker deleted npm temp directory: ".moment-YVTvHlwl")
                            host.iobroker deleted npm temp directory: ".moment-timezone-LVF6Tkme")
                            host.iobroker deleted npm temp directory: ".mp3-duration-121XpnWA")
                            host.iobroker deleted npm temp directory: ".mqtt-packet-9zhbF4Ks")
                            host.iobroker deleted npm temp directory: ".mz-vxKYAgCA")
                            host.iobroker deleted npm temp directory: ".nan-VJWFtQnQ")
                            host.iobroker deleted npm temp directory: ".napi-thread-safe-callback-z2DAzfv3")
                            host.iobroker deleted npm temp directory: ".netmask-9Rl4SU3k")
                            host.iobroker deleted npm temp directory: ".new-github-release-url-rEfy33Ln")
                            host.iobroker deleted npm temp directory: ".node-arp-exu75jRl")
                            host.iobroker deleted npm temp directory: ".node-ble-gjuzQuSp")
                            host.iobroker deleted npm temp directory: ".node-fetch-blvKKu2b")
                            host.iobroker deleted npm temp directory: ".node-forge-h7cGFpHY")
                            host.iobroker deleted npm temp directory: ".node-gyp-build-r457ov9R")
                            host.iobroker deleted npm temp directory: ".node-hkdf-sync-fknK7puz")
                            host.iobroker deleted npm temp directory: ".node-ical-qUo0I4Tm")
                            host.iobroker deleted npm temp directory: ".node-inspect-waaOWKUA")
                            host.iobroker deleted npm temp directory: ".node-persist-2EKJxgHF")
                            host.iobroker deleted npm temp directory: ".node-schedule-qQzDXhqu")
                            host.iobroker deleted npm temp directory: ".node-ssdp-m1VaQXdw")
                            host.iobroker deleted npm temp directory: ".node-telegram-bot-api-1etpN2K2")
                            host.iobroker deleted npm temp directory: ".node-unifi-3DHKBhgr")
                            host.iobroker deleted npm temp directory: ".node.extend-K6FJItiR")
                            host.iobroker deleted npm temp directory: ".nopt-H6aHmXjc")
                            host.iobroker deleted npm temp directory: ".normalize-path-OU9YSYPX")
                            host.iobroker deleted npm temp directory: ".normalize-url-SZTcDbe8")
                            host.iobroker deleted npm temp directory: ".np-rJ4MzeVW")
                            host.iobroker deleted npm temp directory: ".npmlog-BabU8SvR")
                            host.iobroker deleted npm temp directory: ".object-hash-mLu6dbUq")
                            host.iobroker deleted npm temp directory: ".on-finished-RsKM9iVb")
                            host.iobroker deleted npm temp directory: ".one-time-w9IAMdTx")
                            host.iobroker deleted npm temp directory: ".onedrive-api-P1aPRSY2")
                            host.iobroker deleted npm temp directory: ".open-QucUEWry")
                            host.iobroker deleted npm temp directory: ".optionator-PuhYgmIm")
                            host.iobroker deleted npm temp directory: ".os-tmpdir-1IsoZrn1")
                            host.iobroker deleted npm temp directory: ".p-limit-gOKrDIjV")
                            host.iobroker deleted npm temp directory: ".p-map-XQyfxwrm")
                            host.iobroker deleted npm temp directory: ".p-reflect-kbxyMQvX")
                            host.iobroker deleted npm temp directory: ".p-try-nDlwX8SY")
                            host.iobroker deleted npm temp directory: ".package-name-conflict-pgCDYPR4")
                            host.iobroker deleted npm temp directory: ".parse-json-RdQ2IyFU")
                            host.iobroker deleted npm temp directory: ".parse-listing-8te0aWIy")
                            host.iobroker deleted npm temp directory: ".parseuri-KPPXjLGZ")
                            host.iobroker deleted npm temp directory: ".parsexmlresponse-xx6pTUUG")
                            host.iobroker deleted npm temp directory: ".path-exists-ta4BL8U6")
                            host.iobroker deleted npm temp directory: ".path-parse-8gkiAjRV")
                            host.iobroker deleted npm temp directory: ".pdfkit-e7FwFah6")
                            host.iobroker deleted npm temp directory: ".pidtree-P86HYqqk")
                            host.iobroker deleted npm temp directory: ".pinkie-promise-zAO2ov7N")
                            host.iobroker deleted npm temp directory: ".png-js-diABWe2F")
                            host.iobroker deleted npm temp directory: ".portfinder-OSqONEX8")
                            host.iobroker deleted npm temp directory: ".prelude-ls-NDoRZxgk")
                            host.iobroker deleted npm temp directory: ".prepend-http-9s5cfVm0")
                            host.iobroker deleted npm temp directory: ".progress-Kac1LqJ7")host.iobroker deleted npm temp directory: ".promisify-child-process-qtJuXdmi")
                            host.iobroker deleted npm temp directory: ".proto-list-nfO8tqoz")
                            host.iobroker deleted npm temp directory: ".proxy-from-env-vcslNjmL")
                            host.iobroker deleted npm temp directory: ".pump-7uzcbBxQ")
                            host.iobroker deleted npm temp directory: ".pushover-notifications-hkCkDXkO")
                            host.iobroker deleted npm temp directory: ".pushsafer-notifications-kh9EJENe")
                            host.iobroker deleted npm temp directory: ".q-SKXE2OoR")
                            host.iobroker deleted npm temp directory: ".qs-zUtDfLzC")
                            host.iobroker deleted npm temp directory: ".read-file-safe-cjdRRRu9")
                            host.iobroker deleted npm temp directory: ".read-json-safe-laZsPfMf")
                            host.iobroker deleted npm temp directory: ".read-pkg-A2Az6mLS")
                            host.iobroker deleted npm temp directory: ".readdir-glob-uUrpbb1G")
                            host.iobroker deleted npm temp directory: ".readline-sync-OZdd0hqJ")
                            host.iobroker deleted npm temp directory: ".reinterval-wLApnByp")
                            host.iobroker deleted npm temp directory: ".request-promise-aj2YEifc")
                            host.iobroker deleted npm temp directory: ".request-promise-core-cNo6sLbS")
                            host.iobroker deleted npm temp directory: ".requires-port-Uktyik13")
                            host.iobroker deleted npm temp directory: ".resolve-alpn-RTKpuZSr")
                            host.iobroker deleted npm temp directory: ".resolve-from-j6Gv9Ebe")
                            host.iobroker deleted npm temp directory: ".rfdc-cHAORKEZ")
                            host.iobroker deleted npm temp directory: ".rimraf-eynkDvvy")
                            host.iobroker deleted npm temp directory: ".rrule-y9C9hovL")
                            host.iobroker deleted npm temp directory: ".run-parallel-DCURDW1N")
                            host.iobroker deleted npm temp directory: ".set-blocking-q9SMvfvB")
                            host.iobroker deleted npm temp directory: ".simple-swizzle-r4Lxbm1X")
                            host.iobroker deleted npm temp directory: ".sinon-chai-hl4FcWX3")host.iobroker deleted npm temp directory: ".sinon-vBaWPxBD")host.iobroker deleted npm temp directory: ".slash-R0a5JLyH")host.iobroker deleted npm temp directory: ".slice-ansi-eEa9CtYe")host.iobroker deleted npm temp directory: ".slip-OVBIyeXx")host.iobroker deleted npm temp directory: ".smartmeter-obis-KbLeNtYQ")host.iobroker deleted npm temp directory: ".socket.io-EtoLYra9")host.iobroker deleted npm temp directory: ".socket.io-adapter-tLg9dAuy")host.iobroker deleted npm temp directory: ".socket.io-client-ENiKueA5")host.iobroker deleted npm temp directory: ".socket.io-parser-hH5dvNyh")host.iobroker deleted npm temp directory: ".socksv5-3JzHnAms")host.iobroker deleted npm temp directory: ".sonos-discovery-Uazo0hAg")host.iobroker deleted npm temp directory: ".sorted-array-functions-vKv0t5Tc")host.iobroker deleted npm temp directory: ".source-map-SyGGTVk5")host.iobroker deleted npm temp directory: ".source-map-support-VomWiKMb")host.iobroker deleted npm temp directory: ".spdx-correct-TFUby1KY")host.iobroker deleted npm temp directory: ".spdx-exceptions-ft4zmrVV")host.iobroker deleted npm temp directory: ".spdx-expression-parse-Pekjrfn8")host.iobroker deleted npm temp directory: ".spdx-license-ids-7Yhp2ojQ")host.iobroker deleted npm temp directory: ".split-xwUwBTsG")host.iobroker deleted npm temp directory: ".split2-wyloIfG0")host.iobroker deleted npm temp directory: ".sshpk-cCL4zyMp")host.iobroker deleted npm temp directory: ".stack-trace-lNG2rObG")host.iobroker deleted npm temp directory: ".stampit-event-bus-xEgjX5b8")host.iobroker deleted npm temp directory: ".stampit-state-machine-aC9As91Z")
                            host.iobroker deleted npm temp directory: ".statuses-WEHZIwCf")
                            host.iobroker deleted npm temp directory: ".stream-read-all-kYFKG9vU")
                            host.iobroker deleted npm temp directory: ".string.prototype.trim-3h9X678k")
                            host.iobroker deleted npm temp directory: ".string.prototype.trimstart-ocxtG8ll")
                            host.iobroker deleted npm temp directory: ".strip-bom-2r41bWnk")
                            host.iobroker deleted npm temp directory: ".supermixer-2nesEymU")
                            host.iobroker deleted npm temp directory: ".symbol-observable-ffTkQjDe")
                            host.iobroker deleted npm temp directory: ".table-layout-eRPOhyPw")
                            host.iobroker deleted npm temp directory: ".tableify-6kfCgw4D")
                            host.iobroker deleted npm temp directory: ".tcp-ping-KW9OnocR")
                            host.iobroker deleted npm temp directory: ".through-GyJcvh09")
                            host.iobroker deleted npm temp directory: ".to-array-kzG8FZoy")
                            host.iobroker deleted npm temp directory: ".to-regex-range-iJFZCsex")
                            host.iobroker deleted npm temp directory: ".ts-api-utils-JmchtaEL")
                            host.iobroker deleted npm temp directory: ".tweetnacl-ldfAdbL9")
                            host.iobroker deleted npm temp directory: ".typed-array-byte-length-sOVOOL9g")
                            host.iobroker deleted npm temp directory: ".typed-function-lamN6wQc")
                            host.iobroker deleted npm temp directory: ".types-pkg-json-3UOXZDfJ")
                            host.iobroker deleted npm temp directory: ".typescript-rKKYB1QG")
                            host.iobroker deleted npm temp directory: ".typical-B01ZUP8W")
                            host.iobroker deleted npm temp directory: ".unbox-primitive-odeTH77h")
                            host.iobroker deleted npm temp directory: ".unicode-properties-Bg5RLVuQ")
                            host.iobroker deleted npm temp directory: ".untildify-2NFtYD13")
                            host.iobroker deleted npm temp directory: ".update-notifier-XWnvBRxV")
                            host.iobroker deleted npm temp directory: ".url-parse-pnENsky7")
                            host.iobroker deleted npm temp directory: ".url-template-XLjsNAfv")
                            host.iobroker deleted npm temp directory: ".usb-PqjvAhv3")
                            host.iobroker deleted npm temp directory: ".utils-merge-lRdITr83")
                            host.iobroker deleted npm temp directory: ".uuid-hFM3FfPu")
                            host.iobroker deleted npm temp directory: ".wake_on_lan-6cMB5f0e")
                            host.iobroker deleted npm temp directory: ".web-streams-polyfill-L6ofGwWB")
                            host.iobroker deleted npm temp directory: ".webidl-conversions-dJIVq13g")
                            host.iobroker deleted npm temp directory: ".websocket-stream-02UKbziB")
                            host.iobroker deleted npm temp directory: ".which-GGzfHdLT")
                            host.iobroker deleted npm temp directory: ".wide-align-CJ7lqbuZ")
                            host.iobroker deleted npm temp directory: ".widest-line-lhDznLKg")
                            host.iobroker deleted npm temp directory: ".winston-daily-rotate-file-tjvnY6ZU")
                            host.iobroker deleted npm temp directory: ".winston-syslog-rknbmCPQ")
                            host.iobroker deleted npm temp directory: ".workerpool-mqY76ZXw")
                            host.iobroker deleted npm temp directory: ".xdg-basedir-A6kKkuxL")
                            host.iobroker deleted npm temp directory: ".y18n-puq37lLA")
                            host.iobroker deleted npm temp directory: ".yallist-RyZDxIwA")
                            host.iobroker deleted npm temp directory: ".yaml-Re02D0MQ")
                            host.iobroker deleted npm temp directory: ".yargs-parser-sA7Dt5No")
                            host.iobroker deleted npm temp directory: ".yocto-queue-1wbR3uAZ")
                            host.iobroker deleted npm temp directory: ".zigbee-herdsman-KZGHBvfL")
                            host.iobroker deleted npm temp directory: ".zip-stream-qFO8RuhX")
                            host.iobroker Cannot install iobroker.sonos@3.0.0: 217
                              ma
                              #634
                              $ iobroker upgrade parser@2.0.7
                              Update parser from @1.3.2 to @2.0.7
                              Installing iobroker.parser@2.0.7... (System call)
                              npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/ursa-optional/node_modules/bindingsnpm ERR! dest /opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ursa-optional/node_modules/bindings' -> '/opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJ'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_07_22_021Z-debug-0.log
                              host.iobroker Cannot install iobroker.parser@2.0.7: 217
                                ma
                                #635
                                sonos update nochmal mit debug
                                iobroker upgrade sonos —debug
                                This upgrade of "sonos" will introduce the following changes:
                                -> 3.0.0:
                                Added support for the playing Sonos playlists (added new state `playlist_set`)
                                The minimal node.js version is 16
                                -> 2.3.3:
                                fixed cover url
                                -> 2.3.2:
                                store the cover file in files instead of binary states
                                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                Would you like to upgrade sonos from @2.3.1 to @3.0.0 now? [(y)es, (n)o]: y
                                NPM version: 9.8.1
                                npm ERR! errno -39
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_24_19_780Z-debug-0.log
                                host.iobroker Cannot install iobroker.sonos@3.0.0: 217```
                                  ma
                                  #636
                                  habe den fixer nochmal durchlaufen lassen danach nochmal das update von sonos und sonoff gestartet.
                                  Danach ist der iobroker garnicht mehr gestartet, konnte ich lösen indem ich den PC neugestartet habe.
                                  Nun starten die adapter garnicht mehr.
                                  sonoff.0 2023-11-19 02:44:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  sonoff.0 2023-11-19 02:44:31.857	info	terminating
                                  sonoff.0 2023-11-19 02:44:31.839	error	Cannot read properties of undefined (reading 'length')
                                  sonoff.0 2023-11-19 02:44:31.838	error	TypeError: Cannot read properties of undefined (reading 'length') at decrypt (/opt/iobroker/node_modules/iobroker.sonoff/main.js:25:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.sonoff/main.js:43:39) at processImmediate (node:internal/timers:478:21)
                                  sonoff.0 2023-11-19 02:44:31.837	error	uncaught exception: Cannot read properties of undefined (reading 'length')
                                  sonoff.0 2023-11-19 02:44:31.794	info	starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v18.18.2, js-controller: 5.0.12
                                  sonos.0
                                  	2023-11-19 02:52:04.672	warn	State "sonos.0.root.192_168_170_7.favorites_list_html" has no existing object, this might lead to an error in future versions
                                  sonos.0
                                  	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_5.favorites_list_html" has no existing object, this might lead to an error in future versions
                                  sonos.0
                                  	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_8.favorites_list_html" has no existing object, this might lead to an error in future versions
                                  sonos.0
                                  	2023-11-19 02:52:04.666	warn	State "sonos.0.root.192_168_170_5.current_track_number" has no existing object, this might lead to an error in future versions
                                  sonos.0
                                  	2023-11-19 02:52:04.646	error	Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
                                  sonos.0
                                  	2023-11-19 02:52:04.638	warn	State "sonos.0.root.192_168_170_7.current_track_number" has no existing object, this might lead to an error in future versions
                                  sonos.0
                                  	2023-11-19 02:52:04.623	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  sonos.0
                                  	2023-11-19 02:52:04.622	info	terminating
                                  sonos.0
                                  	2023-11-19 02:52:04.617	info	terminating
                                  sonos.0
                                  	2023-11-19 02:52:04.614	error	sonos is not an object of type "meta"
                                  sonos.0
                                  	2023-11-19 02:52:04.614	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:591:35) at ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:24) at AdapterClass.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4809:31) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.writeFileAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1456:31) at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1693:17) at SonosSystem.<anonymous> (/opt/iobroker/node_modules/iobroker.sonos/main.js:2105:13) at SonosSystem.emit (node:events:517:28)
                                  sonos.0
                                  	2023-11-19 02:52:04.611	error	unhandled promise rejection: sonos is not an object of type "meta"
                                  sonos.0
                                  	2023-11-19 02:52:04.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  sonos.0
                                  	2023-11-19 02:52:04.577	error	sonos is not an object of type "meta"
                                  sonos.0
                                  	2023-11-19 02:52:04.577	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:587:39) at runNextTicks (node:internal/process/task_queues:60:5) at process.processImmediate (node:internal/timers:447:9) at async ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:13)
                                  sonos.0
                                  	2023-11-19 02:52:04.575	error	unhandled promise rejection: sonos is not an object of type "meta"
                                  sonos.0
                                  	2023-11-19 02:52:04.575	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  sonos.0
                                  	2023-11-19 02:52:04.571	error	Cannot write file coverImage/192_168_170_5.png: sonos is not an object of type "meta"
                                  sonos.0
                                  	2023-11-19 02:52:04.538	error	Cannot write file coverImage/192_168_170_7.png: sonos is not an object of type "meta"
                                  sonos.0
                                  	2023-11-19 02:52:03.470	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.2, js-controller: 5.0.12
                                  brauche dazu eine lösung.
                                  vor dem update auf node v18 gab es da nie probleme
                                  R 1 Antwort Letzte Antwort
                                  • M ma
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    sonos.0
                                    reutli
                                    schrieb am zuletzt editiert von reutli
                                    #637
                                    @ma sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                    und das gemacht und dann nochmals Update gestartet?
                                    und da mal reingeschaut?
                                    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                    *Wer freundlich ist, dem wird freundlich geholfen *
                                    K 1 Antwort Letzte Antwort
                                    • R reutli
                                      kkickingereder
                                      schrieb am zuletzt editiert von kkickingereder
                                      #638
                                      Könnt ihr mir helfen bitte, bin noch auf 16.15.1
                                      nach
                                      iob stop
                                      iob fix (schon 2x)
                                      iob nodejs-update
                                      bekomme ich folgend Fehlermeldung
                                      You are running nodejs v16.15.1. Do you want to install recommended version 18.19.0?
                                      Press <y> to continue or any other key to quit
                                      Trying to update your installation now. Please be patient.
                                      find: '/run/user/1000/gvfs': Permission denied
                                      Waiting for ioBroker to shut down - Give me a minute...
                                      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                      W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                      W: Failed to fetch https://repos.influxdata.com/ubuntu/dists/bionic/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                                      E: Broken packages
                                      Installing the recommended nodejs version!
                                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                      E: Broken packages
                                      We tried our best to fix your nodejs. Please run iob diag again to verify.
                                      • K kkickingereder
                                        nach
                                        iob stop
                                        iob fix (schon 2x)
                                        iob nodejs-update
                                        E: Broken packages
                                        E: Broken packages
                                        #639
                                        @kkickingereder
                                        grafana und influx Repository müssen nochmal frisch angelegt werden.
                                        Das Ganze muss allerdings bereits geraume Zeit bei dir falsch laufen. Regelmäßiger das System pflegen!
                                        Und schalt den Desktop AUS!
                                        Und das google-Repo brauchst du vermutlich nicht.
                                        Alles rauswerfen, was nicht für den Serverbetrieb benötigt wird.
                                          @kkickingereder
                                          kkickingereder
                                          #640
                                          @thomas-braun vielen lieben Dank
                                          grafana und influx brauch ich eh nicht
                                          Hast du einen Tip wie ich sauber runter kriege?
                                          Was meinst du mit, schalt den Desktop aus?
