  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 328.0k Aufrufe 63 Beobachtet
    ma
    #618
    @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
    iob nodejs-update
    gerade probiert
    ausgabe bei "iob nodejs-update"
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    • M ma
      iob nodejs-update
      gerade probiert
      iobroker [command]
      Commands:
      Options:
      #619
      @ma
      iob stop
      iob fix
      iob nodejs-update
        ma
        #620
        Hat funktioniert
        danke für die schnelle rückmeldung ☺
          @ma
          iob stop
          iob fix
          iob nodejs-update
          ma
          #621
          @thomas-braun bin doch noch auf ein problem gestoßen ich kann aktuell keine adapter mehr updaten
          $ iobroker upgrade telegram@2.0.1
          host.iobroker Adapter "system.adapter.telegram.0" is stopped.
          host.iobroker Adapter "system.adapter.telegram.1" is stopped.
          Installing iobroker.telegram@2.0.1... (System call)
          host.iobroker Cannot install iobroker.telegram@2.0.1: 217
          ERROR: Process exited with code 25
          $ iobroker upgrade shelly@6.6.1
          Update shelly from @6.4.5 to @6.6.1
          Installing iobroker.shelly@6.6.1... (System call)
          Try to solve ENOTEMPTY error automaticallyInstalling iobroker.shelly@6.6.1... (System call)
          host.iobroker deleted npm temp directory: ".bindings-4WLiqHNJ")
          host.iobroker Cannot install iobroker.shelly@6.6.1: 217
          NPM version: 9.8.1
          Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@75lb/deep-mergenpm ERR! dest /opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLAnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@75lb/deep-merge' -> '/opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_04_36_193Z-debug-0.loghost.iobroker Cannot install iobroker.shelly@6.6.1: 217
          • M ma
            NPM version: 9.8.1
            ma
            #622
            @ma
            $ iobroker upgrade fullybrowser@2.2.0
            Update fullybrowser from @2.1.2 to @2.2.0
            Installing iobroker.fullybrowser@2.2.0... (System call)
            Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@alcalzone/jsonl-dbnpm ERR! dest /opt/iobroker/node_modules/@alcalzone/.jsonl-db-koHBLxk9npm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@alcalzone/jsonl-db' -> '/opt/iobroker/node_modules/@alcalzone/.jsonl-db-koHBLxk9'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_27_01_858Z-debug-0.loghost.iobroker Cannot install iobroker.fullybrowser@2.2.0: 217
            • M ma
              @ma
              #623
              @ma
              iob stop
              iob fix
              iob start
                @ma
                iob stop
                iob fix
                iob start
                ma
                #624
                @thomas-braun schon probiert leider keine Besserung
                • M ma
                  #625
                  @ma
                  Dann mit --debug-Option installieren.
                  iob update
                  sagt?
                    @ma
                    iob update
                    sagt?
                    ma
                    #626
                    iob update
                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                    Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                    Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                    Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                    Adapter    "devices"      : 1.1.5    , installed 1.1.5
                    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
                    Adapter    "email"        : 1.2.0    , installed 1.2.0
                    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                    Adapter    "fritzdect"    : 2.3.1    , installed 2.5.8
                    Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "homekit-controller": 0.5.8, installed 0.5.8
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "oekofen-json" : 1.0.5    , installed 1.0.5
                    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                    Adapter    "operating-hours": 1.0.4  , installed 1.0.4
                    Adapter    "parser"       : 1.3.2    , installed 1.3.2
                    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                    Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
                    Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                    Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
                    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                    Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                    Adapter    "web"          : 6.1.4    , installed 6.1.4
                    Adapter    "windows-control": 0.1.5  , installed 0.1.5
                    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                    iobroker upgrade shelly --debug
                    This upgrade of "shelly" will introduce the following changes:
                    -> 6.6.1:
                    Fixed stop reason for Shelly 2.5 / Shelly 2
                    Added humidity of Shelly Plus Addon
                    Not all devices have external power
                    -> 6.6.0:
                    Added BLE devices as states to `shelly.0.ble.*` (Shelly Scripting required)
                    -> 6.5.0:
                    Added Shelly Plus Smoke
                    Added Shelly Bluetooth Low Energy Gateway
                    More Shelly TRV Datapoints
                    Would you like to upgrade shelly from @6.4.5 to @6.6.1 now? [(y)es, (n)o]: y
                    NPM version: 9.8.1
                    npm ERR! errno -39
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T06_39_34_733Z-debug-0.log
                    npm ERR! errno -39
                    • M ma
                      iob update
                      -> 6.6.1:
                      -> 6.6.0:
                      -> 6.5.0:
                      NPM version: 9.8.1
                      npm ERR! errno -39
                      npm ERR! errno -39
                      #627
                      @ma
                      Jag den
                      iob fix
                      drüber.
                        SiKo
                        #628
                        Hallo, hab schon versucht nodejs zu deinstallieren und neu installieren. Bekomme aber immer wieder diesen Fehler:
                        Was kann ich tun?
                        pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get full-upgrade
                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Holen:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
                        Fehl:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        W: GPG-Fehler: https://deb.nodesource.com/node_18.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        E: Das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« ist nicht signiert.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                        pi@raspberrypi:~ $
                          #629
                          @siko sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                          mach es mit iob nodejs-update
                          • S SiKo
                            Was kann ich tun?
                            pi@raspberrypi:~ $
                            #630
                            @siko
                            Da fehlen die Schlüssel.
                            Mach es mit
                            iob nodejs-update
                            dann passt es auch.
                              SiKo
                              #631
                              vielen Dank, Hat direkt funktioniert.
                              • S SiKo
                                #632
                                Natürlich... : 😊
                                  @ma
                                  Jag den
                                  iob fix
                                  drüber.
                                  ma
                                  #633
                                  @thomas-braun der 2 durchlauf vom fix hat das problem gelößt leider nur bis gerade eben
                                  $ iobroker upgrade sonos@3.0.0
                                  Update sonos from @2.3.1 to @3.0.0
                                  Installing iobroker.sonos@3.0.0... (System call)
                                  host.iobroker deleted npm temp directory: ".acorn-jsx-zPgFNGpl")
                                  host.iobroker deleted npm temp directory: ".alcalzone-shared-FgX40TmF")
                                  host.iobroker deleted npm temp directory: ".all-package-names-BPhkNiF7")
                                  host.iobroker deleted npm temp directory: ".ansi-colors-qAZfUuTD")
                                  host.iobroker deleted npm temp directory: ".ansi-escapes-BuACp4PU")
                                  host.iobroker deleted npm temp directory: ".any-observable-GucR4b7Z")
                                  host.iobroker deleted npm temp directory: ".any-promise-GjCkSNL3")host.iobroker deleted npm temp directory: ".anymatch-7vz5qHmT")host.iobroker deleted npm temp directory: ".aproba-IIqIrfbB")
                                  host.iobroker deleted npm temp directory: ".array-flatten-95xLgxGw")
                                  host.iobroker deleted npm temp directory: ".array.prototype.findindex-JX1jwpiR")
                                  host.iobroker deleted npm temp directory: ".boolbase-8130XECE")
                                  host.iobroker deleted npm temp directory: ".bplist-parser-GTDOjzTC")
                                  host.iobroker deleted npm temp directory: ".bundle-name-DjKLTayE")
                                  host.iobroker deleted npm temp directory: ".busboy-A5FsP0CS")
                                  host.iobroker deleted npm temp directory: ".chownr-E9JZijSA")
                                  host.iobroker deleted npm temp directory: ".data-uri-to-buffer-GQ7HcaPL")
                                  host.iobroker deleted npm temp directory: ".decamelize-keys-RDuJHe51")
                                  host.iobroker deleted npm temp directory: ".decimal.js-A6TpPJWn")
                                  host.iobroker deleted npm temp directory: ".dns-equal-TvMdkxWU")
                                  host.iobroker deleted npm temp directory: ".es-shim-unscopables-lNCpEqsg")
                                  host.iobroker deleted npm temp directory: ".esutils-1jlXlxlo")
                                  host.iobroker deleted npm temp directory: ".follow-redirects-vRGWWNjd")
                                  host.iobroker deleted npm temp directory: ".gopd-LUHsc2oq")
                                  host.iobroker deleted npm temp directory: ".got-DFICjTYm")
                                  host.iobroker deleted npm temp directory: ".graceful-fs-i6Qs7iN3")
                                  host.iobroker deleted npm temp directory: ".indexof-m6nUtkW4")
                                  host.iobroker deleted npm temp directory: ".inflight-pQph8mNF")
                                  host.iobroker deleted npm temp directory: ".influx-JoUiD55Z")host.iobroker deleted npm temp directory: ".inherits-ffYUEA4n")host.iobroker deleted npm temp directory: ".ini-HiLT2lH8")host.iobroker deleted npm temp directory: ".inquirer-0PRKJaIm")
                                  host.iobroker deleted npm temp directory: ".iobroker-adapter-helpers-za1UEIZc")
                                  host.iobroker deleted npm temp directory: ".iobroker.alarm-g8jjAFg9")
                                  host.iobroker deleted npm temp directory: ".iobroker.alias-manager-gHAtOr6e")
                                  host.iobroker deleted npm temp directory: ".iobroker.bidirectional-counter-PzmaO0Aw")
                                  host.iobroker deleted npm temp directory: ".iobroker.bring-ov1aPXwP")
                                  host.iobroker deleted npm temp directory: ".iobroker.broadlink2-HDK4EOgs")
                                  host.iobroker deleted npm temp directory: ".iobroker.coronavirus-statistics-Kxvay9Wy")
                                  host.iobroker deleted npm temp directory: ".iobroker.countdown-M3o5XFv5")
                                  host.iobroker deleted npm temp directory: ".iobroker.daswetter-1t9k5PAQ")
                                  host.iobroker deleted npm temp directory: ".iobroker.device-watcher-JRkscZB5")
                                  host.iobroker deleted npm temp directory: ".iobroker.devices-1FmykokK")
                                  host.iobroker deleted npm temp directory: ".iobroker.discovery-Domn1CAP")
                                  host.iobroker deleted npm temp directory: ".iobroker.doorbird-kwq4QU5M")
                                  host.iobroker deleted npm temp directory: ".iobroker.dwd-SpnK64ht")
                                  host.iobroker deleted npm temp directory: ".iobroker.email-7I7P5tNz")
                                  host.iobroker deleted npm temp directory: ".iobroker.energiefluss-kJMU3Qwp")
                                  host.iobroker deleted npm temp directory: ".iobroker.feiertage-WV2cxVZc")
                                  host.iobroker deleted npm temp directory: ".iobroker.fullybrowser-g2Durliy")
                                  host.iobroker deleted npm temp directory: ".iobroker.harmony-BDALdOzG")
                                  host.iobroker deleted npm temp directory: ".iobroker.heatingcontrol-fFfpnmIZ")
                                  host.iobroker deleted npm temp directory: ".iobroker.hm-rega-eDrPvalf")
                                  host.iobroker deleted npm temp directory: ".iobroker.hm-rpc-6COQ5CUM")
                                  host.iobroker deleted npm temp directory: ".iobroker.homekit-controller-sF0AM7Io")
                                  host.iobroker deleted npm temp directory: ".iobroker.ical-rrBOhFW0")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-icons8-F8SpNGzQ")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-material-png-A0Zx2K4e")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-material-svg-E2OoIK18")
                                  host.iobroker deleted npm temp directory: ".iobroker.icons-mfd-svg-UK4n9spV")
                                  host.iobroker deleted npm temp directory: ".iobroker.influxdb-mtpshsVk")
                                  host.iobroker deleted npm temp directory: ".iobroker.info-OtqXm2hx")
                                  host.iobroker deleted npm temp directory: ".iobroker.iqontrol-JG9EP64y")
                                  host.iobroker deleted npm temp directory: ".iobroker.jarvis-Dfkzlr3d")
                                  host.iobroker deleted npm temp directory: ".iobroker.javascript-5NZ432mn")
                                  host.iobroker deleted npm temp directory: ".iobroker.js-controller-7Q8bmsba")
                                  host.iobroker deleted npm temp directory: ".iobroker.linkeddevices-SudTlN7O")
                                  host.iobroker deleted npm temp directory: ".iobroker.modbus-MRiPN8Jv")
                                  host.iobroker deleted npm temp directory: ".iobroker.mqtt-R5v7g772")
                                  host.iobroker deleted npm temp directory: ".iobroker.mqtt-client-AcZDMICZ")
                                  host.iobroker deleted npm temp directory: ".iobroker.mytime-ALCjuXxL")
                                  host.iobroker deleted npm temp directory: ".iobroker.nut-M42R6CUU")
                                  host.iobroker deleted npm temp directory: ".iobroker.oekofen-json-AAGebuoM")
                                  host.iobroker deleted npm temp directory: ".iobroker.openweathermap-uUPAAaq5")
                                  host.iobroker deleted npm temp directory: ".iobroker.operating-hours-vFpZVs6M")
                                  host.iobroker deleted npm temp directory: ".iobroker.parser-lf3ZX1wK")
                                  host.iobroker deleted npm temp directory: ".iobroker.ping-OPzFiLFH")
                                  host.iobroker deleted npm temp directory: ".iobroker.pushover-c2imyZua")
                                  host.iobroker deleted npm temp directory: ".iobroker.pushsafer-akpid5GF")
                                  host.iobroker deleted npm temp directory: ".iobroker.radar2-VVWJ5P6u")
                                  host.iobroker deleted npm temp directory: ".iobroker.sayit-RsEZnXzS")
                                  host.iobroker deleted npm temp directory: ".iobroker.scenes-9WoxMImK")
                                  host.iobroker deleted npm temp directory: ".iobroker.shelly-wfXzBUin")
                                  host.iobroker deleted npm temp directory: ".iobroker.shuttercontrol-msgqlVR3")
                                  host.iobroker deleted npm temp directory: ".iobroker.simple-api-q4TJvC8n")
                                  host.iobroker deleted npm temp directory: ".iobroker.smartcontrol-670ft8lY")
                                  host.iobroker deleted npm temp directory: ".iobroker.smartmeter-OyPCR5Lj")
                                  host.iobroker deleted npm temp directory: ".iobroker.socketio-0ZB5ejpX")
                                  host.iobroker deleted npm temp directory: ".iobroker.sonoff-nQCcGLOb")
                                  host.iobroker deleted npm temp directory: ".iobroker.sonos-8p9DbxUk")
                                  host.iobroker deleted npm temp directory: ".iobroker.sourceanalytix-xH8dPE7Z")
                                  host.iobroker deleted npm temp directory: ".iobroker.sprinklecontrol-jINmg3MW")
                                  host.iobroker deleted npm temp directory: ".iobroker.statistics-nDtQT913")
                                  host.iobroker deleted npm temp directory: ".iobroker.telegram-qJ3kkwRA")
                                  host.iobroker deleted npm temp directory: ".iobroker.terminal-LQj2rBFR")
                                  host.iobroker deleted npm temp directory: ".iobroker.text2command-XKgXlG9f")
                                  host.iobroker deleted npm temp directory: ".iobroker.trashschedule-bVFlHcrS")
                                  host.iobroker deleted npm temp directory: ".iobroker.unifi-YuUe0MFZ")
                                  host.iobroker deleted npm temp directory: ".iobroker.upnp-XYJa4jHA")
                                  host.iobroker deleted npm temp directory: ".iobroker.virtualpowermeter-aiSWB1CL")
                                  host.iobroker deleted npm temp directory: ".iobroker.vis-hqwidgets-XOleJSph")
                                  host.iobroker deleted npm temp directory: ".iobroker.vis-icontwo-ZE5SYXJL")
                                  host.iobroker deleted npm temp directory: ".iobroker.weatherunderground-yjlWL8nH")
                                  host.iobroker deleted npm temp directory: ".iobroker.web-qhxwcVTa")
                                  host.iobroker deleted npm temp directory: ".iobroker.windows-control-m2ZZnHAV")
                                  host.iobroker deleted npm temp directory: ".iobroker.wiobrowser-0FquAKud")
                                  host.iobroker deleted npm temp directory: ".iobroker.ws-Ul5el1jB")
                                  host.iobroker deleted npm temp directory: ".iobroker.yahka-5keTFK1G")
                                  host.iobroker deleted npm temp directory: ".iobroker.zigbee-1JQaSLfT")
                                  host.iobroker deleted npm temp directory: ".ipaddr.js-Cv8HUhd7")
                                  host.iobroker deleted npm temp directory: ".is-array-buffer-jIv3kdDM")
                                  host.iobroker deleted npm temp directory: ".is-bigint-opiLNorc")host.iobroker deleted npm temp directory: ".is-binary-path-T9bvCuQK")
                                  host.iobroker deleted npm temp directory: ".is-core-module-3szSVmLC")
                                  host.iobroker deleted npm temp directory: ".is-docker-diEaV9Js")
                                  host.iobroker deleted npm temp directory: ".is-map-DnX0Tp2n")
                                  host.iobroker deleted npm temp directory: ".is-name-taken-RA37aJNO")
                                  host.iobroker deleted npm temp directory: ".is-npm-Tq5PXIR1")
                                  host.iobroker deleted npm temp directory: ".is-obj-H9BCY1mC")
                                  host.iobroker deleted npm temp directory: ".is-promise-TcPsCtHt")
                                  host.iobroker deleted npm temp directory: ".is-symbol-DyzbAfPe")
                                  host.iobroker deleted npm temp directory: ".is-utf8-XzPsDN8p")
                                  host.iobroker deleted npm temp directory: ".is-weakref-3wPDZaCU")
                                  host.iobroker deleted npm temp directory: ".is-wsl-67INiaF0")
                                  host.iobroker deleted npm temp directory: ".is-yarn-global-z8J5xFQb")
                                  host.iobroker deleted npm temp directory: ".javascript-natural-sort-BSvwVhzD")
                                  host.iobroker deleted npm temp directory: ".js-sdsl-RiJhgh6j")
                                  host.iobroker deleted npm temp directory: ".jsonc-parser-nbReDrcG")
                                  host.iobroker deleted npm temp directory: ".jsonwebtoken-b9ysUQT0")
                                  host.iobroker deleted npm temp directory: ".jsprim-QmUwRLNa")
                                  host.iobroker deleted npm temp directory: ".jszip-r3fGcU4N")
                                  host.iobroker deleted npm temp directory: ".kind-of-ZEKy7WZt")
                                  host.iobroker deleted npm temp directory: ".layerr-GPEJIlGL")
                                  host.iobroker deleted npm temp directory: ".lcid-SGsSRn9Q")
                                  host.iobroker deleted npm temp directory: ".libsodium-wrappers-xQoQYz7T")
                                  host.iobroker deleted npm temp directory: ".lines-and-columns-ohK2P2I1")
                                  host.iobroker deleted npm temp directory: ".listr-SF1ph3tc")
                                  host.iobroker deleted npm temp directory: ".listr-update-renderer-CSIQ7CWX")
                                  host.iobroker deleted npm temp directory: ".load-json-file-5LcbUpDJ")
                                  host.iobroker deleted npm temp directory: ".locate-path-t7OptBTV")
                                  host.iobroker deleted npm temp directory: ".lodash-MxVnsAsD")
                                  host.iobroker deleted npm temp directory: ".lodash.isnumber-P8M8GSmV")
                                  host.iobroker deleted npm temp directory: ".log-symbols-rbtC1M9g")
                                  host.iobroker deleted npm temp directory: ".log-update-SuSlKzSj")
                                  host.iobroker deleted npm temp directory: ".logform-Bwy2bCcs")
                                  host.iobroker deleted npm temp directory: ".loupe-hV7arrgu")
                                  host.iobroker deleted npm temp directory: ".lru_map-uI07ZEOk")
                                  host.iobroker deleted npm temp directory: ".macaddress-dlPdmBpu")
                                  host.iobroker deleted npm temp directory: ".map-obj-FDgyUQwo")
                                  host.iobroker deleted npm temp directory: ".map-stream-elIH4kVT")
                                  host.iobroker deleted npm temp directory: ".md5-viMx30VF")
                                  host.iobroker deleted npm temp directory: ".media-typer-kYaJhV1E")
                                  host.iobroker deleted npm temp directory: ".mime-db-RKfcSKNg")
                                  host.iobroker deleted npm temp directory: ".mimic-fn-hAcoKpm0")
                                  host.iobroker deleted npm temp directory: ".minimist-options-qXL9cbTR")
                                  host.iobroker deleted npm temp directory: ".minipass-FfE0ClCz")
                                  host.iobroker deleted npm temp directory: ".mkdirp-classic-HAXMCI8y")
                                  host.iobroker deleted npm temp directory: ".mkdirp-yMXn50Ac")
                                  host.iobroker deleted npm temp directory: ".module-not-found-error-zFjQCtp1")
                                  host.iobroker deleted npm temp directory: ".moment-YVTvHlwl")
                                  host.iobroker deleted npm temp directory: ".moment-timezone-LVF6Tkme")
                                  host.iobroker deleted npm temp directory: ".mp3-duration-121XpnWA")
                                  host.iobroker deleted npm temp directory: ".mqtt-packet-9zhbF4Ks")
                                  host.iobroker deleted npm temp directory: ".mz-vxKYAgCA")
                                  host.iobroker deleted npm temp directory: ".nan-VJWFtQnQ")
                                  host.iobroker deleted npm temp directory: ".napi-thread-safe-callback-z2DAzfv3")
                                  host.iobroker deleted npm temp directory: ".netmask-9Rl4SU3k")
                                  host.iobroker deleted npm temp directory: ".new-github-release-url-rEfy33Ln")
                                  host.iobroker deleted npm temp directory: ".node-arp-exu75jRl")
                                  host.iobroker deleted npm temp directory: ".node-ble-gjuzQuSp")
                                  host.iobroker deleted npm temp directory: ".node-fetch-blvKKu2b")
                                  host.iobroker deleted npm temp directory: ".node-forge-h7cGFpHY")
                                  host.iobroker deleted npm temp directory: ".node-gyp-build-r457ov9R")
                                  host.iobroker deleted npm temp directory: ".node-hkdf-sync-fknK7puz")
                                  host.iobroker deleted npm temp directory: ".node-ical-qUo0I4Tm")
                                  host.iobroker deleted npm temp directory: ".node-inspect-waaOWKUA")
                                  host.iobroker deleted npm temp directory: ".node-persist-2EKJxgHF")
                                  host.iobroker deleted npm temp directory: ".node-schedule-qQzDXhqu")
                                  host.iobroker deleted npm temp directory: ".node-ssdp-m1VaQXdw")
                                  host.iobroker deleted npm temp directory: ".node-telegram-bot-api-1etpN2K2")
                                  host.iobroker deleted npm temp directory: ".node-unifi-3DHKBhgr")
                                  host.iobroker deleted npm temp directory: ".node.extend-K6FJItiR")
                                  host.iobroker deleted npm temp directory: ".nopt-H6aHmXjc")
                                  host.iobroker deleted npm temp directory: ".normalize-path-OU9YSYPX")
                                  host.iobroker deleted npm temp directory: ".normalize-url-SZTcDbe8")
                                  host.iobroker deleted npm temp directory: ".np-rJ4MzeVW")
                                  host.iobroker deleted npm temp directory: ".npmlog-BabU8SvR")
                                  host.iobroker deleted npm temp directory: ".object-hash-mLu6dbUq")
                                  host.iobroker deleted npm temp directory: ".on-finished-RsKM9iVb")
                                  host.iobroker deleted npm temp directory: ".one-time-w9IAMdTx")
                                  host.iobroker deleted npm temp directory: ".onedrive-api-P1aPRSY2")
                                  host.iobroker deleted npm temp directory: ".open-QucUEWry")
                                  host.iobroker deleted npm temp directory: ".optionator-PuhYgmIm")
                                  host.iobroker deleted npm temp directory: ".os-tmpdir-1IsoZrn1")
                                  host.iobroker deleted npm temp directory: ".p-limit-gOKrDIjV")
                                  host.iobroker deleted npm temp directory: ".p-map-XQyfxwrm")
                                  host.iobroker deleted npm temp directory: ".p-reflect-kbxyMQvX")
                                  host.iobroker deleted npm temp directory: ".p-try-nDlwX8SY")
                                  host.iobroker deleted npm temp directory: ".package-name-conflict-pgCDYPR4")
                                  host.iobroker deleted npm temp directory: ".parse-json-RdQ2IyFU")
                                  host.iobroker deleted npm temp directory: ".parse-listing-8te0aWIy")
                                  host.iobroker deleted npm temp directory: ".parseuri-KPPXjLGZ")
                                  host.iobroker deleted npm temp directory: ".parsexmlresponse-xx6pTUUG")
                                  host.iobroker deleted npm temp directory: ".path-exists-ta4BL8U6")
                                  host.iobroker deleted npm temp directory: ".path-parse-8gkiAjRV")
                                  host.iobroker deleted npm temp directory: ".pdfkit-e7FwFah6")
                                  host.iobroker deleted npm temp directory: ".pidtree-P86HYqqk")
                                  host.iobroker deleted npm temp directory: ".pinkie-promise-zAO2ov7N")
                                  host.iobroker deleted npm temp directory: ".png-js-diABWe2F")
                                  host.iobroker deleted npm temp directory: ".portfinder-OSqONEX8")
                                  host.iobroker deleted npm temp directory: ".prelude-ls-NDoRZxgk")
                                  host.iobroker deleted npm temp directory: ".prepend-http-9s5cfVm0")
                                  host.iobroker deleted npm temp directory: ".progress-Kac1LqJ7")host.iobroker deleted npm temp directory: ".promisify-child-process-qtJuXdmi")
                                  host.iobroker deleted npm temp directory: ".proto-list-nfO8tqoz")
                                  host.iobroker deleted npm temp directory: ".proxy-from-env-vcslNjmL")
                                  host.iobroker deleted npm temp directory: ".pump-7uzcbBxQ")
                                  host.iobroker deleted npm temp directory: ".pushover-notifications-hkCkDXkO")
                                  host.iobroker deleted npm temp directory: ".pushsafer-notifications-kh9EJENe")
                                  host.iobroker deleted npm temp directory: ".q-SKXE2OoR")
                                  host.iobroker deleted npm temp directory: ".qs-zUtDfLzC")
                                  host.iobroker deleted npm temp directory: ".read-file-safe-cjdRRRu9")
                                  host.iobroker deleted npm temp directory: ".read-json-safe-laZsPfMf")
                                  host.iobroker deleted npm temp directory: ".read-pkg-A2Az6mLS")
                                  host.iobroker deleted npm temp directory: ".readdir-glob-uUrpbb1G")
                                  host.iobroker deleted npm temp directory: ".readline-sync-OZdd0hqJ")
                                  host.iobroker deleted npm temp directory: ".reinterval-wLApnByp")
                                  host.iobroker deleted npm temp directory: ".request-promise-aj2YEifc")
                                  host.iobroker deleted npm temp directory: ".request-promise-core-cNo6sLbS")
                                  host.iobroker deleted npm temp directory: ".requires-port-Uktyik13")
                                  host.iobroker deleted npm temp directory: ".resolve-alpn-RTKpuZSr")
                                  host.iobroker deleted npm temp directory: ".resolve-from-j6Gv9Ebe")
                                  host.iobroker deleted npm temp directory: ".rfdc-cHAORKEZ")
                                  host.iobroker deleted npm temp directory: ".rimraf-eynkDvvy")
                                  host.iobroker deleted npm temp directory: ".rrule-y9C9hovL")
                                  host.iobroker deleted npm temp directory: ".run-parallel-DCURDW1N")
                                  host.iobroker deleted npm temp directory: ".set-blocking-q9SMvfvB")
                                  host.iobroker deleted npm temp directory: ".simple-swizzle-r4Lxbm1X")
                                  host.iobroker deleted npm temp directory: ".sinon-chai-hl4FcWX3")host.iobroker deleted npm temp directory: ".sinon-vBaWPxBD")host.iobroker deleted npm temp directory: ".slash-R0a5JLyH")host.iobroker deleted npm temp directory: ".slice-ansi-eEa9CtYe")host.iobroker deleted npm temp directory: ".slip-OVBIyeXx")host.iobroker deleted npm temp directory: ".smartmeter-obis-KbLeNtYQ")host.iobroker deleted npm temp directory: ".socket.io-EtoLYra9")host.iobroker deleted npm temp directory: ".socket.io-adapter-tLg9dAuy")host.iobroker deleted npm temp directory: ".socket.io-client-ENiKueA5")host.iobroker deleted npm temp directory: ".socket.io-parser-hH5dvNyh")host.iobroker deleted npm temp directory: ".socksv5-3JzHnAms")host.iobroker deleted npm temp directory: ".sonos-discovery-Uazo0hAg")host.iobroker deleted npm temp directory: ".sorted-array-functions-vKv0t5Tc")host.iobroker deleted npm temp directory: ".source-map-SyGGTVk5")host.iobroker deleted npm temp directory: ".source-map-support-VomWiKMb")host.iobroker deleted npm temp directory: ".spdx-correct-TFUby1KY")host.iobroker deleted npm temp directory: ".spdx-exceptions-ft4zmrVV")host.iobroker deleted npm temp directory: ".spdx-expression-parse-Pekjrfn8")host.iobroker deleted npm temp directory: ".spdx-license-ids-7Yhp2ojQ")host.iobroker deleted npm temp directory: ".split-xwUwBTsG")host.iobroker deleted npm temp directory: ".split2-wyloIfG0")host.iobroker deleted npm temp directory: ".sshpk-cCL4zyMp")host.iobroker deleted npm temp directory: ".stack-trace-lNG2rObG")host.iobroker deleted npm temp directory: ".stampit-event-bus-xEgjX5b8")host.iobroker deleted npm temp directory: ".stampit-state-machine-aC9As91Z")
                                  host.iobroker deleted npm temp directory: ".statuses-WEHZIwCf")
                                  host.iobroker deleted npm temp directory: ".stream-read-all-kYFKG9vU")
                                  host.iobroker deleted npm temp directory: ".string.prototype.trim-3h9X678k")
                                  host.iobroker deleted npm temp directory: ".string.prototype.trimstart-ocxtG8ll")
                                  host.iobroker deleted npm temp directory: ".strip-bom-2r41bWnk")
                                  host.iobroker deleted npm temp directory: ".supermixer-2nesEymU")
                                  host.iobroker deleted npm temp directory: ".symbol-observable-ffTkQjDe")
                                  host.iobroker deleted npm temp directory: ".table-layout-eRPOhyPw")
                                  host.iobroker deleted npm temp directory: ".tableify-6kfCgw4D")
                                  host.iobroker deleted npm temp directory: ".tcp-ping-KW9OnocR")
                                  host.iobroker deleted npm temp directory: ".through-GyJcvh09")
                                  host.iobroker deleted npm temp directory: ".to-array-kzG8FZoy")
                                  host.iobroker deleted npm temp directory: ".to-regex-range-iJFZCsex")
                                  host.iobroker deleted npm temp directory: ".ts-api-utils-JmchtaEL")
                                  host.iobroker deleted npm temp directory: ".tweetnacl-ldfAdbL9")
                                  host.iobroker deleted npm temp directory: ".typed-array-byte-length-sOVOOL9g")
                                  host.iobroker deleted npm temp directory: ".typed-function-lamN6wQc")
                                  host.iobroker deleted npm temp directory: ".types-pkg-json-3UOXZDfJ")
                                  host.iobroker deleted npm temp directory: ".typescript-rKKYB1QG")
                                  host.iobroker deleted npm temp directory: ".typical-B01ZUP8W")
                                  host.iobroker deleted npm temp directory: ".unbox-primitive-odeTH77h")
                                  host.iobroker deleted npm temp directory: ".unicode-properties-Bg5RLVuQ")
                                  host.iobroker deleted npm temp directory: ".untildify-2NFtYD13")
                                  host.iobroker deleted npm temp directory: ".update-notifier-XWnvBRxV")
                                  host.iobroker deleted npm temp directory: ".url-parse-pnENsky7")
                                  host.iobroker deleted npm temp directory: ".url-template-XLjsNAfv")
                                  host.iobroker deleted npm temp directory: ".usb-PqjvAhv3")
                                  host.iobroker deleted npm temp directory: ".utils-merge-lRdITr83")
                                  host.iobroker deleted npm temp directory: ".uuid-hFM3FfPu")
                                  host.iobroker deleted npm temp directory: ".wake_on_lan-6cMB5f0e")
                                  host.iobroker deleted npm temp directory: ".web-streams-polyfill-L6ofGwWB")
                                  host.iobroker deleted npm temp directory: ".webidl-conversions-dJIVq13g")
                                  host.iobroker deleted npm temp directory: ".websocket-stream-02UKbziB")
                                  host.iobroker deleted npm temp directory: ".which-GGzfHdLT")
                                  host.iobroker deleted npm temp directory: ".wide-align-CJ7lqbuZ")
                                  host.iobroker deleted npm temp directory: ".widest-line-lhDznLKg")
                                  host.iobroker deleted npm temp directory: ".winston-daily-rotate-file-tjvnY6ZU")
                                  host.iobroker deleted npm temp directory: ".winston-syslog-rknbmCPQ")
                                  host.iobroker deleted npm temp directory: ".workerpool-mqY76ZXw")
                                  host.iobroker deleted npm temp directory: ".xdg-basedir-A6kKkuxL")
                                  host.iobroker deleted npm temp directory: ".y18n-puq37lLA")
                                  host.iobroker deleted npm temp directory: ".yallist-RyZDxIwA")
                                  host.iobroker deleted npm temp directory: ".yaml-Re02D0MQ")
                                  host.iobroker deleted npm temp directory: ".yargs-parser-sA7Dt5No")
                                  host.iobroker deleted npm temp directory: ".yocto-queue-1wbR3uAZ")
                                  host.iobroker deleted npm temp directory: ".zigbee-herdsman-KZGHBvfL")
                                  host.iobroker deleted npm temp directory: ".zip-stream-qFO8RuhX")
                                  host.iobroker Cannot install iobroker.sonos@3.0.0: 217
                                    ma
                                    #634
                                    $ iobroker upgrade parser@2.0.7
                                    Update parser from @1.3.2 to @2.0.7
                                    Installing iobroker.parser@2.0.7... (System call)
                                    npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/ursa-optional/node_modules/bindingsnpm ERR! dest /opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ursa-optional/node_modules/bindings' -> '/opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJ'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_07_22_021Z-debug-0.log
                                    host.iobroker Cannot install iobroker.parser@2.0.7: 217
                                      ma
                                      #635
                                      sonos update nochmal mit debug
                                      iobroker upgrade sonos —debug
                                      This upgrade of "sonos" will introduce the following changes:
                                      -> 3.0.0:
                                      Added support for the playing Sonos playlists (added new state `playlist_set`)
                                      The minimal node.js version is 16
                                      -> 2.3.3:
                                      fixed cover url
                                      -> 2.3.2:
                                      store the cover file in files instead of binary states
                                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                      Would you like to upgrade sonos from @2.3.1 to @3.0.0 now? [(y)es, (n)o]: y
                                      NPM version: 9.8.1
                                      npm ERR! errno -39
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_24_19_780Z-debug-0.log
                                      host.iobroker Cannot install iobroker.sonos@3.0.0: 217```
                                        ma
                                        #636
                                        habe den fixer nochmal durchlaufen lassen danach nochmal das update von sonos und sonoff gestartet.
                                        Danach ist der iobroker garnicht mehr gestartet, konnte ich lösen indem ich den PC neugestartet habe.
                                        Nun starten die adapter garnicht mehr.
                                        sonoff.0 2023-11-19 02:44:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        sonoff.0 2023-11-19 02:44:31.857	info	terminating
                                        sonoff.0 2023-11-19 02:44:31.839	error	Cannot read properties of undefined (reading 'length')
                                        sonoff.0 2023-11-19 02:44:31.838	error	TypeError: Cannot read properties of undefined (reading 'length') at decrypt (/opt/iobroker/node_modules/iobroker.sonoff/main.js:25:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.sonoff/main.js:43:39) at processImmediate (node:internal/timers:478:21)
                                        sonoff.0 2023-11-19 02:44:31.837	error	uncaught exception: Cannot read properties of undefined (reading 'length')
                                        sonoff.0 2023-11-19 02:44:31.794	info	starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v18.18.2, js-controller: 5.0.12
                                        sonos.0
                                        	2023-11-19 02:52:04.672	warn	State "sonos.0.root.192_168_170_7.favorites_list_html" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_5.favorites_list_html" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_8.favorites_list_html" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.666	warn	State "sonos.0.root.192_168_170_5.current_track_number" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.646	error	Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
                                        sonos.0
                                        	2023-11-19 02:52:04.638	warn	State "sonos.0.root.192_168_170_7.current_track_number" has no existing object, this might lead to an error in future versions
                                        sonos.0
                                        	2023-11-19 02:52:04.623	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        sonos.0
                                        	2023-11-19 02:52:04.622	info	terminating
                                        sonos.0
                                        	2023-11-19 02:52:04.617	info	terminating
                                        sonos.0
                                        	2023-11-19 02:52:04.614	error	sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.614	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:591:35) at ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:24) at AdapterClass.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4809:31) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.writeFileAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1456:31) at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1693:17) at SonosSystem.<anonymous> (/opt/iobroker/node_modules/iobroker.sonos/main.js:2105:13) at SonosSystem.emit (node:events:517:28)
                                        sonos.0
                                        	2023-11-19 02:52:04.611	error	unhandled promise rejection: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        sonos.0
                                        	2023-11-19 02:52:04.577	error	sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.577	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:587:39) at runNextTicks (node:internal/process/task_queues:60:5) at process.processImmediate (node:internal/timers:447:9) at async ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:13)
                                        sonos.0
                                        	2023-11-19 02:52:04.575	error	unhandled promise rejection: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.575	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        sonos.0
                                        	2023-11-19 02:52:04.571	error	Cannot write file coverImage/192_168_170_5.png: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:04.538	error	Cannot write file coverImage/192_168_170_7.png: sonos is not an object of type "meta"
                                        sonos.0
                                        	2023-11-19 02:52:03.470	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.2, js-controller: 5.0.12
                                        brauche dazu eine lösung.
                                        vor dem update auf node v18 gab es da nie probleme
                                        R 1 Antwort Letzte Antwort
                                        • M ma
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          sonos.0
                                          reutli
                                          schrieb am zuletzt editiert von reutli
                                          #637
                                          @ma sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                          und das gemacht und dann nochmals Update gestartet?
                                          und da mal reingeschaut?
                                          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                          *Wer freundlich ist, dem wird freundlich geholfen *
