  4. Error Installation KNX Adapter Ver. 10.0.39
    6.7k
iobroker
71 Beiträge 3 Kommentatoren 6.1k Aufrufe 3 Beobachtet
  • T tobiii1810
    @Thomas-Braun
    Kann den Usernamen wahrscheinlich nicht ändern da ich mit ihm angemeldet bin oder?
    iobroker@IoBrokerThinClient:/$ sudo usermod -l tobi iobroker
    [sudo] Passwort für iobroker:
    usermod: user iobroker is currently used by process 776
    #41
    @tobiii1810
    Hatte ich mir fast gedacht.
    Dann halt so:
    sudo adduser tobi
    sorgfältig ausfüllen.
    Dann
    sudo usermod -a -G sudo tobi
    Dann als tobi anmelden.
    Danach
    sudo deluser iobroker
    Und dann den
    iobroker fix
      @tobiii1810
      Dann halt so:
      sudo adduser tobi
      Dann
      Danach
      Und dann den
      iobroker fix
      tobiii1810
      #42
      @Thomas-Braun
      tobi@IoBrokerThinClient:~$ iobroker add knx  --prefix "/opt/iobroker"
      host.IoBrokerThinClient install adapter knx
      npm install --loglevel error --production (System call) in "/node_modules/iobroker.knx"
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /node_modules/iobroker.knx
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.knx'
      npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.knx'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/node_modules/iobroker.knx'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T20_56_23_245Z-debug.log
      Cannot install iobroker.knx: 243
      • T tobiii1810
        @Thomas-Braun
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        #43
        @tobiii1810 Alles bei den Usern gerade gezogen?
        iobroker fix
        vorher ausgeführt?
        T 2 Antworten Letzte Antwort
          iobroker fix
          vorher ausgeführt?
          tobiii1810
          #44
          @Thomas-Braun
          tobi@IoBrokerThinClient:~$ sudo deluser iobroker
          [sudo] Passwort für tobi:
          Entferne Benutzer »iobroker« ...
          userdel: user iobroker is currently used by process 3645
          /usr/sbin/deluser: »/sbin/userdel iobroker« gab den Fehlercode 8 zurück. Programmende.
            iobroker fix
            vorher ausgeführt?
            tobiii1810
            #45
            @Thomas-Braun
            • T tobiii1810
              @Thomas-Braun
              #46
              @tobiii1810 Achso, vorher den iobroker stoppen.
              iobroker stop
                iobroker stop
                tobiii1810
                #47
                @Thomas-Braun
                tobi@IoBrokerThinClient:~$ iobroker stop
                userdel: Gruppe iobroker nicht entfernt, da sie noch andere Mitglieder hat.
                Fertig.
                • T tobiii1810
                  @Thomas-Braun
                  Fertig.
                  #48
                  @tobiii1810
                  cat /etc/group | grep iobroker
                    @tobiii1810
                    tobiii1810
                    #49
                    @Thomas-Braun
                    tobi@IoBrokerThinClient:~$ cat /etc/group | grep iobroker
                    iobroker:x:1000:tobi
                    • T tobiii1810
                      @Thomas-Braun
                      #50
                      @tobiii1810
                      id
                        @tobiii1810
                        id
                        tobiii1810
                        #51
                        @Thomas-Braun
                        uid=1001(tobi) gid=1001(tobi) Gruppen=1001(tobi),27(sudo),1000(iobroker)
                        • T tobiii1810
                          @Thomas-Braun
                          #52
                          @tobiii1810
                          sudo -u iobroker id
                            @tobiii1810
                            sudo -u iobroker id
                            tobiii1810
                            #53
                            @Thomas-Braun
                            sudo: Unbekannter Benutzer: iobroker
                            sudo: Regelwerks-Plugin konnte nicht initialisiert werden
                            • T tobiii1810
                              @Thomas-Braun
                              #54
                              @tobiii1810 Gut. Starte mal durch.
                              Kann sein, dass der iobroker dann klemmt.
                              Dann
                              iobroker stop
                              iobroker fix
                              iobroker start
                                Dann
                                iobroker stop
                                iobroker fix
                                iobroker start
                                tobiii1810
                                #55
                                @Thomas-Braun
                                Er hängt jetzt wie du sagtest
                                library: loaded
                                Library version=2020-06-12
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2020-06-15
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/3)
                                OK:1 http://security.debian.org/debian-security buster/updates InRelease
                                OK:2 http://deb.debian.org/debian buster InRelease
                                OK:3 http://deb.debian.org/debian buster-updates InRelease
                                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                Installed gcc-c++
                                    Checking ioBroker user and directory permissions (2/3)
                                useradd: Gruppe iobroker existiert - wenn Sie den Benutzer zur Gruppe hinzufügen
                                möchten, benutzen Sie -g.
                                User iobroker created
                                Created /etc/sudoers.d/iobroker
                                usermod: Benutzer »iobroker« ist nicht vorhanden.
                                chown: ungültiger Benutzer: „iobroker:iobroker“
                                    Checking autostart (3/3)
                                Enabling autostart...
                                Autostart enabled!
                                tobi@IoBrokerThinClient:~$ iobroker start
                                • T tobiii1810
                                  @Thomas-Braun
                                  library: loaded
                                  Installed gcc-c++
                                  Autostart enabled!
                                  #56
                                  @tobiii1810
                                  sudo -u iobroker groups
                                    @tobiii1810
                                    tobiii1810
                                    #57
                                    @Thomas-Braun
                                    tobi@IoBrokerThinClient:~$ sudo -u iobroker groups
                                    • T tobiii1810
                                      @Thomas-Braun
                                      #58
                                      @tobiii1810
                                      cat /etc/passwd | grep iobroker
                                        @tobiii1810
                                        tobiii1810
                                        #59
                                        @Thomas-Braun
                                        tobi@IoBrokerThinClient:~$ cat /etc/passwd | grep iobroker
                                        • T tobiii1810
                                          @Thomas-Braun
                                          #60
                                          @tobiii1810
                                          sudo useradd -m -s /usr/sbin/nologin iobroker
