  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.9k Aufrufe 78 Beobachtet
  • afuerhoffA afuerhoff
    @dominik-f
    Es müssten wenn , dann zwei neue Warnmeldungen kommen:
    • devicelist: ....
    • getAllFbObjects: Hostname is empty: .....
    Dominik F.D Offline
    Dominik F.D Offline
    Dominik F.
    #821
    @afuerhoff
    Das sind bisher alle Meldungen:
    fb-checkpresence.0
    2022-12-17 13:34:59.172	info	loop successfully started
    fb-checkpresence.0
    2022-12-17 13:34:59.171	info	states successfully subscribed
    fb-checkpresence.0
    2022-12-17 13:34:59.171	info	createFbDeviceObjects finished successfully
    fb-checkpresence.0
    2022-12-17 13:34:55.900	info	createMemberObjects finished successfully
    fb-checkpresence.0
    2022-12-17 13:34:55.619	info	createGlobalObjects finished successfully
    fb-checkpresence.0
    2022-12-17 13:34:55.396	info	Layer3Forwarding1-GetDefaultConnectionService is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.396	info	LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.396	info	WANPPPConnection1-ForceTermination is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.396	info	DeviceConfig1-Reboot is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.396	info	X_AVM-DE_HostFilter-GetWANAccessByIP is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.395	info	X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.395	info	DeviceInfo1-GetInfo is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.395	info	WLANConfiguration3-GetSecurityKeys is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.395	info	WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.395	info	WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.394	info	WANIPConnection1-GetInfo is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.394	info	WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.394	info	WANCommonInterfaceConfig1-GetCommonLinkProperties is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.394	info	DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.394	info	Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.393	info	Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.393	info	Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.393	info	Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0
    2022-12-17 13:34:55.393	info	configuration default connection: 1.WANPPPConnection.1
    fb-checkpresence.0
    2022-12-17 13:34:55.391	info	start fb-checkpresence.0: FRITZ!Box 7590 version: 154.07.39-101676 ip-address: "fritz.box" - interval devices: 60 s - interval members: 30 s
    fb-checkpresence.0
    2022-12-17 13:34:53.590	info	starting. Version 1.1.22 (non-npm: afuerhoff/ioBroker.fb-checkpresence) in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v16.18.1, js-controller: 4.0.24
    host.IoBroker
    2022-12-17 13:34:52.444	info	instance system.adapter.fb-checkpresence.0 started with pid 127181
    host.IoBroker
    2022-12-17 13:34:49.860	info	iobroker exit 0
    host.IoBroker
    2022-12-17 13:34:49.423	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.IoBroker
    2022-12-17 13:34:48.892	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
    fb-checkpresence.0
    2022-12-17 13:34:48.849	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0
    2022-12-17 13:34:48.849	info	terminating
    fb-checkpresence.0
    2022-12-17 13:34:48.849	info	cleaned everything up ...
    fb-checkpresence.0
    2022-12-17 13:34:48.847	info	Got terminate signal TERMINATE_YOURSELF
    host.IoBroker
    2022-12-17 13:34:48.845	info	stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
    host.IoBroker
    2022-12-17 13:34:48.819	info	iobroker Update "system.adapter.fb-checkpresence.0"
    host.IoBroker
    2022-12-17 13:34:48.789	info	iobroker upload [0] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
    host.IoBroker
    2022-12-17 13:34:48.781	info	iobroker upload [1] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/style.css style.css text/css
    host.IoBroker
    2022-12-17 13:34:48.776	info	iobroker upload [2] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
    host.IoBroker
    2022-12-17 13:34:48.772	info	iobroker upload [3] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
    host.IoBroker
    2022-12-17 13:34:48.768	info	iobroker upload [4] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/fb-checkpresence.png fb-checkpresence.png image/png
    host.IoBroker
    2022-12-17 13:34:48.757	info	iobroker upload [5] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/dateformat.png dateformat.png image/png
    host.IoBroker
    2022-12-17 13:34:48.708	info	iobroker upload [6] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/access_settings_network.png access_settings_network.png image/png
    host.IoBroker
    2022-12-17 13:34:48.665	info	iobroker removed 94 packages, and changed 2 packages in 5s58 packages are looking for funding run `npm fund` for details
    host.IoBroker
    2022-12-17 13:34:43.618	info	iobroker Installing afuerhoff/ioBroker.fb-checkpresence... (System call)
    host.IoBroker
    2022-12-17 13:34:43.618	info	iobroker NPM version: 8.19.2
    host.IoBroker
    2022-12-17 13:34:43.246	info	iobroker install afuerhoff/ioBroker.fb-checkpresence
    host.IoBroker
    2022-12-17 13:34:42.398	info	iobroker url afuerhoff/ioBroker.fb-checkpresence --host IoBroker --debug
      @dominik-f
      • devicelist: ....
      Dominik F.D Offline
      Dominik F.D Offline
      Dominik F.
      #822
      @afuerhoff
      Durch deine neuen Warnmeldungen konnte ich tatsächlich die IP Adresse identifizieren.
      Es hat in der Fritzbox den Namen: PC-192-168-178-34
      Ich hab mich seit Tagen übrigens immer wieder gefragt, was das genau für ein Gerät ist^^
      afuerhoffA 1 Antwort Letzte Antwort
      • Dominik F.D Dominik F.
        @afuerhoff
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        schrieb am zuletzt editiert von afuerhoff
        #823
        @dominik-f
        War denn für dieses Gerät in der Devicelist der Hostname leer? Hätte ja eigentlich dann nicht sein dürfen. Kannst du mir mal den einen Eintrag posten. Nicht die ganze Liste. Vielleicht hab ich ja auch noch einen Fehler drin.
        Dominik F.D 2 Antworten Letzte Antwort
          @dominik-f
          Dominik F.D Offline
          Dominik F.D Offline
          Dominik F.
          #824
          @afuerhoff
          Nein, das Gerät wurde auch erstellt unter dem Namen.
          Ich hatte das Log leider gelöscht und warte gerade darauf, dass die Warnungen nochmals kommen, bisher aber nicht.
            @dominik-f
            Dominik F.D Offline
            Dominik F.D Offline
            Dominik F.
            #825
            @afuerhoff
            So, nun kam endlich die Warnung:
            fb-checkpresence.0
            2022-12-20 14:00:41.482	warn	getAllFbObjects: Hostname is empty: AC:6F:BB:DB:1B:CE
              @afuerhoff
              fb-checkpresence.0
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #826
              @dominik-f
              Da müsste ja auch noch eine zweite Meldung gekommen sein. Wird dort ein Hostname in der Devicelist zum Gerät angezeigt?
                @dominik-f
                Dominik F.D Offline
                Dominik F.D Offline
                Dominik F.
                #827
                @afuerhoff
                Nein, da wird nix angezeigt:
                {"Index":"1","IPAddress":"192.168.178.34","MACAddress":"AC:6F:BB:DB:1B:CE","Active":"0","HostName":"","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE_UpdateAvailable":"0","X_AVM-DE_UpdateSuccessful":"unknown","X_AVM-DE_InfoURL":"","X_AVM-DE_MACAddressList":"","X_AVM-DE_Model":"","X_AVM-DE_URL":"","X_AVM-DE_Guest":"0","X_AVM-DE_RequestClient":"0","X_AVM-DE_VPN":"0","X_AVM-DE_WANAccess":"granted","X_AVM-DE_Disallow":"0","X_AVM-DE_IsMeshable":"0","X_AVM-DE_Priority":"0","X_AVM-DE_FriendlyName":"","X_AVM-DE_FriendlyNameIsWriteable":"1"}
                  @afuerhoff
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #828
                  @dominik-f
                  Ok. Danke. Dann ist es ein Fehler in der Fritzbox, der allerdings nicht ständig zuschlägt. Sonst hätte der Adapter das Objekt ja nicht anlegen können. In der nächsten Version fange ich das dann noch ab.
                    @dominik-f
                    Dominik F.D Offline
                    Dominik F.D Offline
                    Dominik F.
                    #829
                    @afuerhoff
                    Ich danke dir.
                    Ich bin aber trotzdem sehr verwundert über das Gerät. Ich hab keine Ahnung was das sein soll^^
                      @afuerhoff
                      Ich danke dir.
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #830
                      @dominik-f
                      Hier steht noch etwas bei AVM. Vielleicht hilft es.
                      -> Incorrect or unknown entries in the list of "Devices and Users"
                      https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7340-int/763_Incorrect-or-unknown-entries-in-the-list-of-Devices-and-Users/
                      • afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #831
                        Hallo, ich habe gerade eine neue Version ins Latest Repository hochgeladen. Die leeren Hostnames werden jetzt ignoriert und eine Warnmeldung ausgegeben.
                        • JB_SullivanJ Offline
                          JB_Sullivan
                          schrieb am zuletzt editiert von JB_Sullivan
                          #832
                          Juhu - ich glaube ich gehöre auch zu denen wo der Adapter nicht mehr mitspielen mag. Habe heute das Update hochgeladen, aber der Adapter läßt sich nun nicht mehr starten.
                          Er lief sonst Monatelang ohne Probleme.
                          PS: und dein Rollback auf eine frühere Version geht auch nicht, weil da wohl noch der Uralte ETRAGET Fehler für Windows User drin steckt - siehe unten.
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:16.190	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:16.189	info	terminating
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:16.188	info	cleaned everything up ...
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:16.184	info	Got terminate signal TERMINATE_YOURSELF
                          host.GLTGLT)
                          2022-12-21 17:56:16.149	info	host.GLT(GLT) stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
                          host.GLTGLT)
                          2022-12-21 17:56:16.149	info	host.GLT(GLT) "system.adapter.fb-checkpresence.0" disabled
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:16.069	warn	onReady: Fb init: ReferenceError: AbortController is not defined
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:16.048	info	starting. Version 1.1.23 in C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence, node: v14.16.0, js-controller: 4.0.24
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.607	debug	States connected to redis: 127.0.0.1:9000
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.552	debug	States create User PubSub Client
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.551	debug	States create System PubSub Client
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.519	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.473	debug	Objects connected to redis: 127.0.0.1:9001
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.465	debug	Objects client initialize lua scripts
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.318	debug	Objects create User PubSub Client
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.317	debug	Objects create System PubSub Client
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.316	debug	Objects client ready ... initialize now
                          fb-checkpresence.0
                          10364	2022-12-21 17:56:15.270	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                          $ iobroker upgrade fb-checkpresence@1.1.21 --debug
                          Update fb-checkpresence from @1.1.23 to @1.1.21
                          NPM version: 6.14.11
                          Installing iobroker.fb-checkpresence@1.1.21... (System call)
                          npm ERR! code ETARGET
                          npm ERR! A complete log of this run can be found in: npm ERR! C:\iobroker\GLT\env\npm-cache\_logs\2022-12-21T17_06_59_598Z-debug.log
                          upload [6] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/access_settings_network.png access_settings_network.png image/png
                          upload [5] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/dateformat.png dateformat.png image/png
                          upload [3] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
                          upload [2] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
                          upload [0] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
                          Process exited with code 0
                          afuerhoffA 3 Antworten Letzte Antwort
                          • JB_SullivanJ JB_Sullivan
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            host.GLTGLT)
                            host.GLTGLT)
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            fb-checkpresence.0
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #833
                            @jb_sullivan
                            Mach mal auf Version 1.1.20 oder 1.1.22. Die 21 gab es gar nicht offiziell.
                            JB_SullivanJ 1 Antwort Letzte Antwort
                              @jb_sullivan
                              JB_Sullivan
                              #834
                              @afuerhoff OK - Danke, die 1.1.20 funktioniert wieder - bzgl. der "nicht offiziellen" Version - dann sollte so etwas idealer Weise nicht über den Admin in der Adapter History auftauchen.
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                host.GLTGLT)
                                host.GLTGLT)
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                fb-checkpresence.0
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #835
                                @jb_sullivan
                                Hallo, die Funktion AbortController, die ich nutze, ist leider erst ab Node 15 implementiert.
                                Du nutzt noch die Node 14 Version. Sorry. Die alte Funktionalität, die ich bisher genutzt habe ist in axios abgekündigt. Node 14 ist übrigens im Maintenance Status. Du solltest auf Node 16 updaten.
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  host.GLTGLT)
                                  host.GLTGLT)
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  fb-checkpresence.0
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #836
                                  @jb_sullivan
                                  Hallo, ich hab mal eine Testversion auf Github hochgeladen. Die kannst Du testen. Die alte Funktionalität habe ich optional noch mit eingebaut. Ich hoffe es funktioniert so.
                                    @jb_sullivan
                                    JB_Sullivan
                                    #837
                                    @afuerhoff Guten Morgen - ich habe die GIT Version installiert und diese funktioniert einwandfrei - Vielen Dank für deinen Einsatz.
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #838
                                      @jb_sullivan
                                      Ok. Danke für die Rückmeldung. Die kommt dann ins Latest.
                                        afuerhoffA Offline
                                        afuerhoff
                                        #839
                                        Hallo, neue Version ist jetzt im Latest.
                                        Sie benutzt CancelToken, wenn AbortController nicht zur Verfügung steht, was bei Node 14 der Fall ist. Mit diesen Funktionen kann ein laufender Axios Request abgebrochen werden.
                                          Thias
                                          #840
                                          getAllFbObjects: Hostname of fritzbox device XX: XX: XX: XX: XX: XX is empty!
                                          die Fehlermeldung kommt seit einigen Tagen. Ich habe schon die Version 1.1.24 installiert und die Fritz!Box mehrfach neu gestartet.
                                          Nach dem Neustart ist erst einmal Ruhe, dann kommt der Fehler nach einigen Zeit wieder.
                                          Betroffen sind mehrere MAC-Adressen, die teilweise in der Fritz!Box als ungenutzte Verbindung stehen.
                                          In der Fritz!Box habe ich dann einen generischen Rechnernamen (PC+IP-Adresse)
                                          Weitere Fehlermeldungen kommen nicht.
                                          Hat noch jemand Ideen?
