  4. Ständig prebuild Fehler beim Adapter installieren / updaten
prebuildinstallationupdateadapterfehlermeldung
34 Beiträge 4 Kommentatoren 4.3k Aufrufe 5 Beobachtet
    peterfido
    wie im Titel bereits beschrieben, tauchen bei mir bei jeder Kompilierung Fehler auf:
    $ ./iobroker upgrade mobile
    Update mobile from @0.5.0 to @1.0.1
    NPM version: 6.14.4npm install iobroker.mobile@1.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
    prebuild-install
    info begin Prebuild-install version 5.3.3
    prebuild-install info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/405966-usb-v1.6.3-node-v64-linux-x64.tar.gz
    prebuild-install info found cached prebuild prebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/405966-usb-v1.6.3-node-v64-linux-x64.tar.gz
    prebuild-install info unpack resolved to /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node
    prebuild-install info unpack required /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
    In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);        ^In file included from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node.h:63,                 from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:3993:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:3996:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:26,                 from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node.h:63,                 from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:2476:46: note: declared here   V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);                                              ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:26,                 from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node.h:63,                 from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:2476:46: note: declared here   V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);                                              ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.cache/node-gyp/10.21.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.21.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~In file included from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node.h:63,                 from /home/iobroker/.cache/node-gyp/10.21.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.21.0/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../../nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.21.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    make: *** [binding.target.mk:103: Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
    gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.0-8-amd64gyp ERR! command
    "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v10.21.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    Entferne ich das Prebuild, lädt er es sich einfach wieder herunter:
    $ ./iobroker upgrade daswetter
    Update daswetter from @3.0.1 to @3.0.3
    host.proxbroker Adapter "system.adapter.daswetter.0" is stopped.
    NPM version: 6.14.4npm install iobroker.daswetter@3.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
    prebuild-install
    info
    begin
    prebuild-install
    info
    prebuild-install
    http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-linux-x64.tar.gz
    prebuild-install http 200 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-linux-x64.tar.gz
    prebuild-install info downloading to @ /home/iobroker/.npm/_prebuilds/405966-usb-v1.6.3-node-v64-linux-x64.tar.gz.4629-3631c1fd5b1c8.tmp
    prebuild-install info renaming to @ /home/iobroker/.npm/_prebuilds/405966-usb-v1.6.3-node-v64-linux-x64.tar.gzprebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/405966-usb-v1.6.3-node-v64-linux-x64.tar.gz
    make: *** [binding.target.mk:103: Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v10.21.0
    Danach gibt es dann einen weiteren Anlauf und der Adapter wird installiert / aktualisiert.
    Trotzdem ist es nervíg. Gerade beim Testen. Wenn ich einen Adapter anpasse, mache ich das neuerdings über GitHub. Durch den Fehler dauert das aktualisieren aber unnötig lange.
    Wie kommt npm darauf, dass jeder, wirklich jeder Adapter das USB-node benötigt?
    Peterfido
    • P peterfido
      prebuild-install
      prebuild-install
      info
      begin
      prebuild-install
      info
      prebuild-install
      @peterfido sagte in Ständig prebuild Fehler beim Adapter installieren / updaten:
      Tut nicht jeder. Aber npm unternimmt immer einen neuen Versuch die Arbeit zu Ende zu bringen, wenn es aufgerufen wird.
      Mach den cache mal leer:
      npm cache clean --force
      node 10.21.0? Da würde ich ja auf die aktuelle LTS node12 gehen.
      P apollon77A 2 Antworten Letzte Antwort
        peterfido
        @Thomas-Braun
        Ja, die 10er Version.
        klappt im Home Verzeichnis.
        Im iobroker-Verzeichnis darf ich das nicht.
        peter@proxbroker:~$ cd /opt/iobroker
        peter@proxbroker:/opt/iobroker$ npm cache clean --force
        [sudo] Passwort für peter:
        Das hat nicht funktioniert, bitte nochmal probieren.
        Leider darf der Benutzer peter »/usr/bin/npm cache clean --force« als iobroker auf proxbroker nicht ausführen.
        Peterfido
        • P peterfido
          @Thomas-Braun
          @peterfido
          Eigentlich sollte bei einem 'richtig' aufgesetzen ioBroker das möglich sein. Hier geht es jedenfalls:
          pi@raspberrypi:~ $ cd /opt/iobroker/
          pi@raspberrypi:/opt/iobroker $ npm cache clean --force
          npm WARN using --force I sure hope you know what you are doing.
          sudoers richtig? peter in den richtigen Gruppen?
          P 1 Antwort Letzte Antwort
            @peterfido
            peterfido
            @Thomas-Braun
            Folgende sudoers habe ich:
            # This file MUST be edited with the 'visudo' command as root.
            # Please consider adding local content in /etc/sudoers.d/ instead of
            # directly modifying this file.
            # See the man page for details on how to write a sudoers file.
            Defaults        env_reset
            Defaults        mail_badpass
            Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
            # Host alias specification
            # User alias specification
            # Cmnd alias specification
            # User privilege specification
            root    ALL=(ALL:ALL) ALL
            Peter   ALL = NOPASSWD: ALL
            # Allow members of group sudo to execute any command
            %sudo   ALL=(ALL:ALL) ALL
            # See sudoers(5) for more information on "#include" directives:
            #includedir /etc/sudoers.d
            iobroker ALL = NOPASSWD: /var/scripte/*
            Peterfido
            • P peterfido
              @Thomas-Braun
              Defaults        env_reset
              @peterfido
              Das ist imho auch nicht richtig.
              Peter ist nicht peter und in meiner sudoers steht der 'pi' gar nicht drin:
              Was steht in
              ls -ls /etc/sudoers.d/
              drin?
                @peterfido
                Was steht in
                drin?
                peterfido
                @Thomas-Braun
                Peter habe ich gerade in klein geändert, war mir eben auch aufgefallen.
                Im suders.d:
                root@proxbroker:/opt/iobroker# ls -ls /etc/sudoers.d/
                insgesamt 8
                4 -r--r----- 1 root root 1206 Jun 28 07:43 iobroker
                4 -r--r----- 1 root root  958 Feb  2  2020 README
                root@proxbroker:/opt/iobroker# cat /etc/sudoers.d/iobroker
                iobroker ALL=(ALL) ALL
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/shutdown
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/halt
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/poweroff
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/reboot
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemctl start
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemctl stop
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/mount
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/umount
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemd-run
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/apt-get
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/dpkg
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/make
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/ping
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/fping
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/arp-scan
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/setcap
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/cat
                iobroker ALL=(ALL) NOPASSWD: /usr/bin/df
                iobroker ALL=(ALL) NOPASSWD: /usr/sbin/ldconfig
                ALL ALL=NOPASSWD: /usr/bin/systemctl start iobroker
                ALL ALL=NOPASSWD: /usr/bin/systemctl stop iobroker
                ALL ALL=NOPASSWD: /usr/bin/systemctl restart iobroker
                ALL ALL=(iobroker) NOPASSWD: /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js *
                Peterfido
                • P peterfido
                  @Thomas-Braun
                  Im suders.d:
                  insgesamt 8
                  @peterfido
                  groups
                  für den 'peter'
                    @peterfido
                    groups
                    für den 'peter'
                    peterfido
                    @Thomas-Braun
                    peter@proxbroker:/opt/iobroker$ groups
                    peter cdrom floppy audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
                    dabei habe ich vorhin nochmal
                    sudo usermod -aG sudo peter
                    durchgeführt.
                    Peterfido
                    • P peterfido
                      @Thomas-Braun
                      durchgeführt.
                      @peterfido
                      Hmmmm.
                      Also der peter sollte in die sudo-Gruppe rein...
                      Da musst du dich wohl mal ausnahmsweiste als root anmelden und den peter da reinhieven:
                      sudo su
                      usermod -a -G sudo peter
                      exit
                      Vielleicht funktioniert das unter Proxmox aber auch anders...
                        @peterfido
                        Hmmmm.
                        sudo su
                        exit
                        peterfido
                        @Thomas-Braun
                        lüppt jetzt:
                        Allerdings wird die sudo - Gruppe immer noch nicht aufgelistet.
                        Peterfido
                        • P peterfido
                          @Thomas-Braun
                          lüppt jetzt:
                          @peterfido Hast du den peter mal ausgeloggt?
                          Die Gruppen werden nur bei der Anmeldung eingelesen.
                          P 2 Antworten Letzte Antwort
                            peterfido
                            schrieb am zuletzt editiert von peterfido
                            @Thomas-Braun
                            Okay, das wars :)
                            Leider hat es nicht viel gebracht:
                            prebuild-install
                            info
                            prebuild-install
                            prebuild-install
                            prebuild-install
                            gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                            gyp
                             ERR!
                             ERR! node -v
                             v10.21.0gyp
                            npm
                            Mache jetzt Feierabend für Heute.
                            Vielen Dank.
                            Peterfido
                              peterfido
                              @Thomas-Braun
                              habe nun auf nodejs12.19.0 aktualisiert.
                              Der Fehler ist geblieben. Dafür fehlt Node-Red jetzt der Serialport und der S7 - Adapter startet ständig neu, weil er auf nen Fehler stößt. Daher spiele ich gerade das Backup wieder ein und lebe mit dem Fehler.
                              $ ./iobroker upgrade s7@1.1.8
                              Update s7 from @1.1.8 to @1.1.8
                              NPM version: 6.14.8npm install iobroker.s7@1.1.8 --loglevel error --prefix "/opt/iobroker" (System call)
                              prebuild-install
                              prebuild-install info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gzprebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-x64.tar.gz
                              prebuild-install http 200 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-x64.tar.gzprebuild-install info downloading to @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gz.16422-a9ce1741c8a2e.tmp
                              prebuild-install info renaming to @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gzprebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gz
                              prebuild-install info unpack resolved to /opt/iobroker/node_modules/usb/build/Release/usb_bindings.nodeprebuild-install info unpack required /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
                              ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:128:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());        ^
                              In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
                              ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:269:109: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));        ^
                              In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                              In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4281:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4281:44: note:   candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4284:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~
                              /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4284:44: note:   candidate expects 1 argument, 2 provided
                              ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: error: no matching function for call to ‘v8::Value::IntegerValue()’       devId = arg0->IntegerValue();                                  ^
                              In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(                                        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note:   candidate expects 1 argument, 0 provided../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: error: no matching function for call to ‘v8::Value::IntegerValue()’       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(                                        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note:   candidate expects 1 argument, 0 provided
                              In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:761:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
                              make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.0-8-amd64gyp
                              ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                              upload [11] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/words.js words.js application/javascript
                              upload [10] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript
                              upload [9] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
                              upload [8] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
                              upload [7] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
                              upload [6] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
                              upload [5] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
                              upload [4] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
                              upload [3] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
                              upload [2] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/index.html index.html text/html
                              upload [1] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/img/plc_back.png img/plc_back.png image/png
                              upload [0] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/S7.png S7.png image/png
                              Adapter "s7" updated
                              process exited with code 0
                              peter@proxbroker:/var/scripte$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                              /usr/bin/nodejs
                              v12.19.0
                              /usr/bin/node
                              v12.19.0
                              /usr/bin/npm
                              6.14.8
                              nodejs:
                               Installiert:           12.19.0-1nodesource1
                               Installationskandidat: 12.19.0-1nodesource1
                               Versionstabelle:
                              *** 12.19.0-1nodesource1 500
                                     500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                                     100 /var/lib/dpkg/status
                                  10.21.0~dfsg-1~deb10u1 500
                                     500 http://deb.debian.org/debian buster/main amd64 Packages
                                     500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                              peter@proxbroker:/var/scripte$ iobroker fix
                              library: loaded
                              Library version=2020-06-12
                              Peterfido
                              • P peterfido
                                @Thomas-Braun
                                prebuild-install
                                /usr/bin/nodejs
                                v12.19.0
                                /usr/bin/node
                                v12.19.0
                                /usr/bin/npm
                                6.14.8
                                nodejs:
                                 Versionstabelle:
                                library: loaded
                                @peterfido Da muss noch ein rebuild erfolgen.
                                Cache zuvor löschen.
                                  peterfido
                                  @Thomas-Braun
                                  Auch nach einem Rebuild läuft der Serialport nicht. Habe jetzt nen Update des Serialports innerhalb Node-Red durchgeführt. Auch der läuft nicht.
                                  node-red.0	2020-10-17 18:31:46.146	info	(5987) node-red exited with 1
                                  node-red.0	2020-10-17 18:31:46.136	debug	(5987) 17 Oct 18:31:46 - Error: Module did not self-register: '/opt/iobroker/iobroker-data/node-red/node_modules/modbus-serial/node_modules/@serialport/bindings/build/Release/bindings.node'. at Ob
                                  node-red.0	2020-10-17 18:31:46.134	debug	(5987) 17 Oct 18:31:46 - [red] Uncaught Exception:
                                  Peterfido
                                    peterfido
                                    @Thomas-Braun
                                    Cache gelöscht, Node-Red aktualisiert, alles neu gebuildet. Ergebnis ernüchternd:
                                    $ ./iobroker add linkeddevices  --host proxbroker
                                    NPM version: 6.14.8npm install iobroker.linkeddevices@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
                                    prebuild-install
                                    info begin
                                    prebuild-install info found cached prebuild prebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gz
                                    prebuild-install
                                    ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:128:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
                                    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:269:109: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4281:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4281:44: note:   candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4284:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4284:44: note:   candidate expects 1 argument, 2 provided../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
                                    ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: error: no matching function for call to ‘v8::Value::IntegerValue()’       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(                                        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note:   candidate expects 1 argument, 0 provided../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: error: no matching function for call to ‘v8::Value::IntegerValue()’       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(                                        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note:   candidate expects 1 argument, 0 provided
                                    gyp
                                    ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.0-11-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                    host.proxbroker install adapter linkeddevices
                                    upload [11] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/words.js words.js application/javascript
                                    upload [10] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/style.css style.css text/css
                                    upload [9] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_small.png linkeddevices_small.png image/png
                                    upload [8] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_missing.png linkeddevices_missing.png image/png
                                    upload [7] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_info.png linkeddevices_info.png image/png
                                    upload [6] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices.png linkeddevices.png image/png
                                    upload [5] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.js index_m.js application/javascript
                                    upload [4] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.html index_m.html text/html
                                    upload [3] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/img/info-big.png img/info-big.png image/png
                                    upload [2] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom_m.html custom_m.html text/html
                                    upload [1] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom.js custom.js application/javascript
                                    upload [0] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/admin.d.ts admin.d.ts video/mp2t
                                    host.proxbroker object system.adapter.linkeddevices created/updated
                                    host.proxbroker create instance linkeddevices
                                    host.proxbroker object linkeddevices.0.info.notlinkedObjects created
                                    host.proxbroker object linkeddevices.0.info.linkedObjects created
                                    host.proxbroker object linkeddevices.0.info created
                                    host.proxbroker object system.adapter.linkeddevices.0.sigKill created
                                    host.proxbroker object system.adapter.linkeddevices.0.eventLoopLag created
                                    host.proxbroker object system.adapter.linkeddevices.0.outputCount created
                                    host.proxbroker object system.adapter.linkeddevices.0.inputCount created
                                    host.proxbroker object system.adapter.linkeddevices.0.uptime created
                                    host.proxbroker object system.adapter.linkeddevices.0.memRss created
                                    host.proxbroker object system.adapter.linkeddevices.0.memHeapTotal created
                                    host.proxbroker object system.adapter.linkeddevices.0.memHeapUsed created
                                    host.proxbroker object system.adapter.linkeddevices.0.cputime created
                                    host.proxbroker object system.adapter.linkeddevices.0.cpu created
                                    host.proxbroker object system.adapter.linkeddevices.0.compactMode created
                                    host.proxbroker object system.adapter.linkeddevices.0.connected created
                                    host.proxbroker object system.adapter.linkeddevices.0.alive created
                                    host.proxbroker Set default value of linkeddevices.0.info.notlinkedObjects: 0
                                    host.proxbroker Set default value of linkeddevices.0.info.linkedObjects: 0
                                    host.proxbroker object system.adapter.linkeddevices.0 created
                                    Und das hier:
                                    v12.19.0 (Es gibt eine neuere Version: v12.16.2 Die Version v12.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v10.20.1)
                                    Und der HUE Bewegungsmelder hat sich auch verabschiedet. Der lief jetzt seit Tagen mit der minütlichen Abfrage durch.
                                    Peterfido
                                    • P peterfido
                                      @Thomas-Braun
                                      prebuild-install
                                      info begin
                                      prebuild-install
                                      gyp
                                      Und das hier:
                                      Hast die libudev-dev installiert?
                                        peterfido
                                        @Thomas-Braun
                                        Ja.
                                        peter@proxbroker:/opt/iobroker$ sudo apt install libudev-dev
                                        libudev-dev ist schon die neueste Version (241-7~deb10u4).
                                        Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                                         libjsoncpp1
                                        Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        Peterfido
                                        • P peterfido
                                          @Thomas-Braun
                                          Ja.
                                           libjsoncpp1
                                          @peterfido
                                          Das Build-Environment auch?
                                          On Unix
                                          Python v2.7, v3.5, v3.6, v3.7, or v3.8
                                          make
                                          A proper C/C++ compiler toolchain, like GCC
