  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.4k Aufrufe 35 Beobachtet
  • Jey CeeJ Jey Cee
    @Sepp ist doch schon drin.
    Sepp
    #341
    @Jey-Cee hab den mit B net gefunden
    • S Sepp
      Jey CeeJ Offline
      Jey CeeJ Offline
      Jey Cee
      #342
      @Sepp ach Sch... Namensgebung bei Eltako.
      EDIT: Jetzt ist er drin.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • Jey CeeJ Jey Cee
        Sepp
        #343
        @Jey-Cee ok, adapter noch ma löschen und neu installieren?
        • S Sepp
          Jey CeeJ Offline
          Jey CeeJ Offline
          Jey Cee
          #344
          @Sepp ja
          S 2 Antworten Letzte Antwort
          • Jey CeeJ Jey Cee
            @Sepp ja
            Sepp
            #345
            @Jey-Cee perfekt danke funktioniert :)
            • Jey CeeJ Jey Cee
              @Sepp ja
              Sepp
              #346
              @Jey-Cee
              enocean.0	2020-12-18 16:06:55.563	debug	(6487) system.adapter.admin.0: logging true
              enocean.0	2020-12-18 16:06:53.689	debug	(6487) Packet type 2 received: 02
              enocean.0	2020-12-18 16:06:53.688	debug	(6487) 55000100026503
              enocean.0	2020-12-18 16:06:53.675	debug	(6487) Sent data: 55000a0701eba501000008ffdc54010000ffb17b2fff007b
              enocean.0	2020-12-18 16:06:53.667	info	(6487) state ffb17b2f.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1608304013662,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608304013662}
              enocean.0	2020-12-18 16:06:51.146	debug	(6487) Packet type 2 received: 02
              enocean.0	2020-12-18 16:06:51.145	debug	(6487) 55000100026503
              enocean.0	2020-12-18 16:06:51.121	debug	(6487) Sent data: 55000a0701eba501000009ffdc54010000ffb17b2fff00ef
              enocean.0	2020-12-18 16:06:51.112	info	(6487) state ffb17b2f.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1608304011106,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608304011106}
              enocean.0	2020-12-18 16:06:48.967	debug	(6487) system.adapter.admin.0: logging false
              enocean.0	2020-12-18 16:06:48.477	debug	(6487) Message for ID 0410bbbe has been received.
              enocean.0	2020-12-18 16:06:48.473	debug	(6487) 55000707017af6500410bbbe3000ffffffff4000
              enocean.0	2020-12-18 16:06:47.819	debug	(6487) Packet type 2 received: 02
              enocean.0	2020-12-18 16:06:47.818	debug	(6487) 55000100026500
              enocean.0	2020-12-18 16:06:47.798	debug	(6487) Sent data: 55000a0701eba501000008ffdc548000000410bbbeff00c4
              enocean.0	2020-12-18 16:06:47.788	info	(6487) state 0410bbbe.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1608304007783,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608304007783}
              enocean.0	2020-12-18 16:06:44.924	debug	(6487) Message for ID 0410bbbe has been received.
              enocean.0	2020-12-18 16:06:44.922	debug	(6487) 55000707017af6700410bbbe3000ffffffff3d00
              enocean.0	2020-12-18 16:06:44.315	debug	(6487) Packet type 2 received: 02
              enocean.0	2020-12-18 16:06:44.314	debug	(6487) 55000100026500
              enocean.0	2020-12-18 16:06:44.302	debug	(6487) Sent data: 55000a0701eba501000009ffdc548000000410bbbeff0050
              enocean.0	2020-12-18 16:06:44.285	info	(6487) state 0410bbbe.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1608304004280,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608304004280}
              enocean.0	2020-12-18 16:06:33.588	debug	(6487) system.adapter.admin.0: logging true
              enocean.0	2020-12-18 16:06:10.515	debug	(6487) system.adapter.admin.0: logging false
              zu erst hab ich den FR62 geschaltet dann den FSR14
                Sepp
                #347
                gerade noch gesehn bekomme jetzt immer nen Fehler
                enocean.0	2020-12-18 16:19:06.675	info	(6913) Terminated (NO_ERROR): Without reason
                enocean.0	2020-12-18 16:19:06.674	info	(6913) terminating
                enocean.0	2020-12-18 16:19:06.343	info	(6913) The serial port was closed.
                enocean.0	2020-12-18 16:19:06.333	info	(6913) cleaned everything up...
                enocean.0	2020-12-18 16:19:06.330	error	(6913) Error: The "enocean.0.0590f9cb." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:518:23) at Enocean.setStat
                enocean.0	2020-12-18 16:19:06.324	error	(6913) unhandled promise rejection: The "enocean.0.0590f9cb." is invalid. Ids are not allowed to end in "."
                enocean.0	2020-12-18 16:19:06.323	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                enocean.0	2020-12-18 16:19:06.301	debug	(6913) Message for ID 0590f9cb has been received.
                enocean.0	2020-12-18 16:19:06.292	debug	(6913) 55000a0701eba5cb1e000f0590f9cb0000ffffffff5b00
                enocean.0	2020-12-18 16:20:46.384	info	(6970) Terminated (NO_ERROR): Without reason
                enocean.0	2020-12-18 16:20:46.383	info	(6970) terminating
                enocean.0	2020-12-18 16:20:46.375	info	(6970) The serial port was closed.
                enocean.0	2020-12-18 16:20:46.367	info	(6970) cleaned everything up...
                enocean.0	2020-12-18 16:20:46.363	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                enocean.0	2020-12-18 16:20:46.363	error	at handleType1.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:157:16)
                enocean.0	2020-12-18 16:20:46.363	error	at handleType1.setState (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:174:22)
                enocean.0	2020-12-18 16:20:46.363	error	at Enocean.setStateAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1584:16)
                enocean.0	2020-12-18 16:20:46.363	error	at new Promise (<anonymous>)
                enocean.0	2020-12-18 16:20:46.363	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1585:16
                enocean.0	2020-12-18 16:20:46.363	error	at Enocean.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5713:17)
                enocean.0	2020-12-18 16:20:46.363	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:518:23)
                enocean.0	2020-12-18 16:20:46.363	error	(6970) Error: The "enocean.0.0590f9cb." is invalid. Ids are not allowed to end in "."
                enocean.0	2020-12-18 16:20:46.356	error	(6970) unhandled promise rejection: The "enocean.0.0590f9cb." is invalid. Ids are not allowed to end in "."
                P 1 Antwort Letzte Antwort
                • S Sepp
                  pgBroker
                  schrieb am zuletzt editiert von pgBroker
                  #348
                  Habe heute nochmals die 0.3 installiert und mit meinem FAH60B getestet.
                  Im Log werden Rohdaten empfangen:
                  enocean.0	2020-12-21 19:46:43.488	debug	(5751) Message for ID 05871db2 has been received.
                  enocean.0	2020-12-21 19:46:43.485	debug	(5751) 55000a0701eba50000000905871db20000ffffffff3400
                  enocean.0	2020-12-21 19:46:03.584	debug	(5751) Message for ID 05871f12 has been received.
                  enocean.0	2020-12-21 19:46:03.582	debug	(5751) 55000a0701eba55d00000905871f120000ffffffff4300
                  enocean.0	2020-12-21 19:45:02.069	debug	(5751) Message for ID 05871db2 has been received.
                  enocean.0	2020-12-21 19:45:02.066	debug	(5751) 55000a0701eba50000000905871db20000ffffffff3300
                  enocean.0	2020-12-21 19:44:41.702	debug	(5751) Message for ID 05871db2 has been received.
                  enocean.0	2020-12-21 19:44:41.699	debug	(5751) 55000a0701eba5640d000905871db20000ffffffff3d00
                  enocean.0	2020-12-21 19:44:22.183	debug	(5751) Message for ID 05871f12 has been received.
                  enocean.0	2020-12-21 19:44:22.179	debug	(5751) 55000a0701eba55f00000905871f120000ffffffff4900
                  enocean.0	2020-12-21 19:44:21.334	debug	(5751) Message for ID 05871db2 has been received.
                  enocean.0	2020-12-21 19:44:21.333	debug	(5751) 55000a0701eba5640f000905871db20000ffffffff3d00
                  Aber im Interface kommt nichts an:
                  Hast du eine Idee woran es liegt?
                  • P pgBroker
                    Jey CeeJ Offline
                    Jey CeeJ Offline
                    Jey Cee
                    #349
                    @pgBroker hatte der FAH60B bei dir schon funktioniert?
                      batteliere
                      schrieb am zuletzt editiert von batteliere
                      #350
                      @Jey-Cee said in [Frage] Enocean in IoBroker implementieren:
                      @batteliere bitte Antworte in diesem Thema: https://forum.iobroker.net/topic/37331/test-adapter-enocean-2-v0-3-x/347
                      Folgende fragen:
                      • Wie hast du den Adapter installiert?
                      • Wie hast du versucht den FTKE an zu lernen?
                      Hi Jey-Cee,
                      inzwischen konnte ich den Adapter in Betrieb nehmen (als ich den USB-Stick angesteckt habe, wurde /dev/ttyAMA0 als Schnittstelle voreingestellt, habe ich geändert auf USB). Ich konnte schließlich zwei ELTAKO FTKE anlernen (automatisch erkannt, top!). Das hat nicht gleich auf Anhieb geklappt, ich habe den Adapter mehrfach händisch neu gestartet und irgendwann ging es dann.
                      Jetzt kämpfe ich damit, den Zustand der Sensoren auszulesen. Bei jedem Tastendruck ändert sich der Wert der Signalstärke - damit ist klar, dass eine Verbindung besteht. Die Übrigen Werte (A0, AI, B0, BI) bleiben aber immer auf "false" stehen, egal wie viel ich auf den Dingern rumklicke. Muss ich da was einstellen?
                      Viele Grüße,
                      Thomas
                      • B batteliere
                        Folgende fragen:
                        Hi Jey-Cee,
                        Viele Grüße,
                        Thomas
                        Jey CeeJ Offline
                        Jey CeeJ Offline
                        Jey Cee
                        #351
                        @batteliere sagte in Test Adapter EnOcean (2) v0.3.x:
                        Klingt als hast du den Falschen enOcean Adapter. Deswegen die Frage wie hast du ihn installiert?
                        B 1 Antwort Letzte Antwort
                        • Jey CeeJ Jey Cee
                          batteliere
                          #352
                          @Jey-Cee von Github. Gibt sich als Version 0.3.0 erkennen.
                          • B batteliere
                            Jey CeeJ Offline
                            Jey CeeJ Offline
                            Jey Cee
                            #353
                            @batteliere lösch den Adapter und installier ihn nochmal von hier: https://github.com/Jey-Cee/ioBroker.enocean
                            So muss da aussehen.
                            • Jey CeeJ Jey Cee
                              batteliere
                              #354
                              @Jey-Cee said in Test Adapter EnOcean (2) v0.3.x:
                              ok, hab ich installiert. Verbindung zum USB-Stick ist da. Nun gibt es aber kein Auto-Detect mehr? Hätte ich mir mal die Geräte-ID merken sollen...
                              • B batteliere
                                batteliere
                                #355
                                So, nochmal von vorn:
                                Adapter wieder runter, wieder diesen hier installiert:
                                https://github.com/iobroker-community-adapters/ioBroker.enocean
                                Mit der "Auto-Detect"- Funktion, die da drin ist, die beiden FTKE wieder gefunden und die IDs notiert.
                                Adapter wieder runter und diesen hier drauf:
                                Dabei ist mir ein kleiner aber wichtiger Bug in der Maske für die Konfiguration aufgefallen: Der Drop-Down für die Schnittstelle ist halb verdeckt, siehe Scrollbalken rechts... das ganze Fenster könnte viel länger sein. Hab ich erst nicht bemerkt und deshalb nicht geschnallt, dass ich auf "USB" umstellen muss.
                                Die beiden ELTAKOs von Hand eingetragen. Nun läufts!!
                                Danke, dass Du das alles machst, Jey-Cee. Großes Kino!
                                • B batteliere
                                  Jey CeeJ Offline
                                  Jey CeeJ Offline
                                  Jey Cee
                                  #356
                                  Hm das ist bei mir nicht. Was hast du für einen Browser?
                                  • Jey CeeJ Jey Cee
                                    batteliere
                                    #357
                                    @Jey-Cee firefox 78.5.0
                                    Hab's mal mit Edge geöffnet, da sieht alles gut aus.
                                    Thomas
                                      TheAriba
                                      #358
                                      Hat jemand einen FSR61 schon erfolgreich eingelernt? Habe meinen nicht eingelernt bekommen. Irgendwie wollte sich gerade ein TF61L auch nicht einlernen lassen.
                                      Muss ich heute Abend oder morgen früh nochmal mit aktivem Loging versuchen.
                                      • Jey CeeJ Jey Cee
                                        pgBroker
                                        #359
                                        Wirklich funktioniert in der Form, dass der Datenpunkt ILL einen Wert zeigte, hat er mit deinem Adapter noch nie.
                                        Er funktioniert in Node Red. Dort aber mit der EEP a5-06-01 während er bei deinem Adapter automatisch die EEP TF-13-10 bekommt.
                                        Vielleicht liegt es daran, dass der Payload nicht geparst wird?
                                        • P pgBroker
                                          Jey CeeJ Offline
                                          Jey CeeJ Offline
                                          Jey Cee
                                          #360
                                          @pgBroker TF-13-10 ist wie A5-06-01 nur das der Werte Bereich angepasst ist. Ich schau mir das aber nochmal an.
                                          P 2 Antworten Letzte Antwort
