  4. Fritzbox-Adapter Widget formatieren
    5.7k
24 Beiträge 5 Kommentatoren 8.0k Aufrufe
    Semenchkare
    ich verwende den Fritzbox-Adapter und lasse mittels Vis einige gefilterte Ergebnisse auf meinem Tablet anzeigen.
    Das Widget habe ich mit Hilfe von ruhr70 importiert:
    [{"tpl":"tplTableBody","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":true,"g_signals":true,"static_value":"[{\"Title\": \"first\", \"Value\": 1, \"_Description\": \"Value1\"}, {\"Title\": \"second\", \"Value\": 2, \"_Description\": \"Value2\"}]","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"colCount":"4","table_oid":"fritzbox.0.history.allTableJSON","g_header_§0":true,"colWidth2":"21%","colAttr2":"","colName3":" ","colWidth3":"5%","colName4":"  ","colWidth4":"6%","colName7":"Dauer","colAttr6":"","colWidth6":"8%","colName6":"Ltg.","colWidth7":"15%","colName2":" ","colName1":" ","hide_header":true,"colWidth1":"14%","views":null,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","max_rows":"8","colAttr3":"","colAttr4":"durationForm"},"style":{"left":"278px","top":"651px","width":"269px","height":"160px","color":"#ffffff","background-color":"","font-family":"Arial, Helvetica, sans-serif","z-index":"1","font-size":"small","font-style":"","text-align":"left","text-shadow":""},"widgetSet":"basic"}]
    Interessanterweise konnte ich das Widget bei den Eigenschaften bearbeiten. So habe ich es von 7 auf 4 Spalten gebracht, die Spalten anders angeordnet, die Schriftgröße geändert.
    Da Ergebnis sieht so aus:
    ~~![](</s><URL url=)http://www.joe-lion.de/old/fritzboxwidget.JPG" />
    Einzig und alleine, was mir nicht funktioniert:
    Ich kann der Schrift keine andere Farbe geben, die Zellenhintergründe sind farbig (dunkelgrau und hellgrau hinterlegt), die hätte ich gerne transparent.
    Hat jemand eine Ahnung wo ich das ändern kann?~~
    Viele Grüße
    Semenchkare
    raspberry 5 8GB mit iobroker,
    raspberry 5 8GB mit Raspberrymatic
    • ruhr70R Offline
      ruhr70R Offline
      ruhr70
      @Semenchkare:
      Hat jemand eine Ahnung wo ich das ändern kann? `
      Ohne Ahnung zu haben…
      Was ich probiert habe.
      Im VIS Editor, rechts unter Eigenschaften den Tab "CSS" ausgewählt und dort von "Global" auf "project" umgestellt und folgenden CSS Code reinkopiert:
      .tclass-tr-even {
          background-color: transparent;
      .tclass-tr-odd {
      Damit wurden bei mir die Tabellenzeilen transparent.
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        Kleiner Nachtrag…
        das wird dann wohl für alle Tabellen gelten?!
        Die gesamte CSS Klasse sieht wie folgt aus (falls Du noch was anpassen willst):
        (per Quelltextanzeige im Browser herausgesucht)
        /* ---------------------- Sample for table widget ------------------------- /
        .tclass-overflow {
        overflow-y: auto;
        .tclass {
        border: 0px solid black;
        width: 100%;
        table-layout: fixed;
        font-family: Arial;
        .tclass-inner {
        width: 100%;
        height: 100%;
        .tclass-inner-overflow {
        overflow-y: auto;
        height: calc(100% - 30px);
        .tclass-th {
        background-color: black;
        color: white;
        font-weight: bold;
        .tclass-th1 {
        width: 20px;
        text-align: center;
        .tclass-th2 {
        width: 20px;
        text-align: center;
        .tclass-th3 {
        width: 150px;
        .tclass-th4 {
        width: 200px;
        .tclass-tr {
        color: black;
        .tclass-tr-even {
        background-color: darkgray;
        .tclass-tr-odd {
        background-color: lightgray;
        .tclass-tr:hover {
        color:blue;
        cursor: pointer;
        .tclass-tr-selected {
        background-color: lightblue;
        color: white;*/
        .tclass-detail {
        width: 100%
        .tclass-detail-tr {
        width: 100%
        .tclass-detail-tr-even {
        .tclass-detail-tr-odd {
        .tclass-detail-td-name {
        width:200px;
        font-weight: bold;
        ! .tclass-detail-td-value {
        .tclass-print-button {
        position: absolute;
        bottom: 5%;
        right: 5%;
        .tclass-tr-error {
        color:red;
        .tclass-tr-warning {
        color:yellow;
        .tclass-img-type {
        width:16px;
        height:16px
        .tclass-img-person {
        width:16px;
        height:16px
        Wenn Du unterschiedliche JSON-Tabellen-Widgets anpassen möchtest, suche mal am Besten im Forum.
        Ich könnte mir vorstellen, dass man seine eigene Klasse definiert und dann unter ****Eigenschaften/Widget/Generell/CSS-Klasse**** diese dem Widget gezielt zuweist. Habe ich selbst noch nicht gemacht und das ist auch nur Spekulation.
          Semenchkare
          Du bist der absolute Held!
          Nun ist das Widget so, wie es sein sollte!
          Vielen Dank nochmals!
          Viele Grüße
          Semenchkare
          • W Offline
            W Offline
            womber
            Hallo :)
            Kannst du mir sagen wie ich ein neues FritzBox Widget installieren bzw in vis hinzufügen kann? Habe mir die Datei "iobroker_fritzbox_widget_gross.json" herunter geladen aber finde nirgendwo einen button o.ä. zum hinzufügen eines neues widgets :(
            Danke und Grüße,
            Alex
            • ruhr70R Offline
              ruhr70R Offline
              ruhr70
              @womber:
              Kannst du mir sagen wie ich ein neues FritzBox Widget installieren bzw in vis hinzufügen kann? Habe mir die Datei "iobroker_fritzbox_widget_gross.json" herunter geladen aber finde nirgendwo einen button o.ä. zum hinzufügen eines neues widgets :( `
              Das Fritzbox Widgets gross ist ein Beispiel und besteht aus mehreren kleinen Widgets.
              Im Prinzip kannst Du in Vis Dir auch alles selbst so zusammenbauen, wie Du es Dir vorstellst.
              Ein Widget importiert man in VIS über den Tab "Widgets" und dann über "Widgets importieren":
              • W Offline
                W Offline
                womber
                Danke für die schnelle Antwort… Und wie bekomme ich da jetzt die json Datei rein? Verstehe das irgendwie nicht... Oder muss ich die Datei mit dem Editor aufmachen und den Inhalt dort rein kopieren???
                Grüße,
                Alex
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  @womber:
                  Danke für die schnelle Antwort… Und wie bekomme ich da jetzt die json Datei rein? Verstehe das irgendwie nicht... Oder muss ich die Datei mit dem Editor aufmachen und den Inhalt dort rein kopieren??? `
                  genau.
                  Die Datei korrekt markieren, kopieren und und das Fenster einfügen, welches sich öffnet, wenn man auf "Widgets importieren" drückt.
                  Du musst nichts speichern und wieder einlesen, sondern einfach nur copy & paste durchführen.
                  • ruhr70R Offline
                    ruhr70R Offline
                    ruhr70
                    P.S.: willkommen im Forum! :-)
                    • W Offline
                      W Offline
                      womber
                      Super. Klappt!!!
                      1000 Dank!!!
                      Ja, bin jetzt endlich nach 2,5 Jahren ccu.io zu IO Broker gewechselt.. Muss sagen, bin SEHR begeistert :)
                      Grüße und schönen Abend,
                      Alex
                      • W Offline
                        W Offline
                        womber
                        ok.. ein Problem hab ich da doch noch…. bei der Anzeige ganz oben wird in rot angezeigt wenn jemand anruft mit der Rufnummer... Ist kein Anruf da ist das Feld lightgrey
                        (STIL in vis: background-color:lightgrey; color:black; font-size: 30px; padding: 0 20px 0 0;)
                        änder ich das lightgrey in z.B. "blue" wird das dann Blau.
                        Soweit ok...
                        Gibt es eine Möglichkeit das ganze transparent zu machen? Rauslöschen geht leider nicht. transparent schreiben geht leider auch nicht.... Ich finde leider nichts :(
                        Grüße,
                        Alex
                        • ruhr70R Offline
                          ruhr70R Offline
                          ruhr70
                          @womber:
                          Soweit ok...
                          Grüße,
                          Alex `
                          Wenn Du den Stil 0 wie folgt einstellst: background-color:transparent;
                          Und zusätzlich tiefer unter CSS Hintergrund/background transparent einträgst, (oder leer läßt)
                          ist es bei mir transparent.
                          Sieht so aus, als ob erst der STil 0 genommen wird und dann die voreingestellte Farbe unter Background.
                          • ruhr70R Offline
                            ruhr70R Offline
                            ruhr70
                            @womber:
                            Gibt es eine Möglichkeit das ganze transparent zu machen? Rauslöschen geht leider nicht. transparent schreiben geht leider auch nicht…. Ich finde leider nichts :( `
                            Ist das erledigt?
                            • W Offline
                              W Offline
                              womber
                              Ich probiere das morgen aus.. Arbeit lässt das momentan leider nicht zu. Ich gebe dann Rückmeldung :)
                              Danke und Grüße,
                              Alex
                              Gesendet von iPad mit Tapatalk
                                baeckerman83
                                Funktioniert bei euch die Missed Called JSON Formatierung? Bei mir ist die irgendwie leer. :( Die anderen Sachen sind aber gefüllt und in der HTML Formatierung ist auch alles enthalten.
                                • W Offline
                                  W Offline
                                  womber
                                  Nein, meine json ist auch leer, html ist alles da :)
                                  Grüße,
                                  Alex
                                  • ruhr70R Offline
                                    ruhr70R Offline
                                    ruhr70
                                    @baeckerman83:
                                    Funktioniert bei euch die Missed Called JSON Formatierung? Bei mir ist die irgendwie leer. :( Die anderen Sachen sind aber gefüllt und in der HTML Formatierung ist auch alles enthalten. `
                                    bei mir ist der Datenpunkt gefüllt.
                                      baeckerman83
                                      Könnte das mit der Version zusammen hängen? Ich hab die Version 0.2.1 installiert. Laut Github gibt es ja auch schon die 0.3.1 ich habe mich aber noch nicht so tief eingearbeitet und erst mal über die iobroker Oberfläche installiert.
                                      • ruhr70R Offline
                                        ruhr70R Offline
                                        ruhr70
                                        @baeckerman83:
                                        Könnte das mit der Version zusammen hängen? Ich hab die Version 0.2.1 installiert. Laut Github gibt es ja auch schon die 0.3.1 ich habe mich aber noch nicht so tief eingearbeitet und erst mal über die iobroker Oberfläche installiert. `
                                        Dürfte nicht. Die 0.2.1 war die Version, in der das JSON schon funktionstüchtig drin war.
                                        Keine Ahnung, warum es bei Dir/Euch nicht ausgegeben wird.
                                        Die 0.3.0 und 0.3.1 sind nicht von mir. Die habe ich ungeprüft übernommen (Konfigurationsseite ist damit sauberer und upnp).
                                        Ich gehe davon aus, dass in der Fritzbox-Konfigurationsseite die Haken alle gesetzt sind:
                                          baeckerman83
                                          Hiho!
                                          Mhm ich glaube das es einfach im Code fehlt:
                                              if (!showHistoryAllTableTxt) {
                                                  adapter.setState('history.allTableTxt',    "deactivated",          true);
                                              } else {
                                                  adapter.setState('history.allTableTxt',    headlineTableAllTxt,    true);
                                              if (!showHistoryAllTableJSON) {
                                                  adapter.setState('history.allTableJSON',   "deactivated",          true);
                                              if (!showHistoryAllTableHTML) {
                                                  adapter.setState('history.allTableHTML',   "deactivated",          true);
                                              } else {
                                                  adapter.setState('history.allTableHTML',   headlineTableAllHTML,   true);
                                              if (!showMissedTableHTML) {
                                                  adapter.setState('history.missedTableHTML', "deactivated",         true);
                                              } else {
                                                  adapter.setState('history.missedTableHTML', headlineTableMissedHTML,   true);
                                              if (!showMissedTableJSON)     adapter.setState('history.missedTableJSON',   "deactivated", true);
                                              if (!showCallmonitor) {
                                                  adapter.setState('callmonitor.connect', "deactivated", true);
                                                  adapter.setState('callmonitor.ring', "deactivated", true);
                                                  adapter.setState('callmonitor.call', "deactivated", true);
                                                  adapter.setState('callmonitor.all', "deactivated", true);
                                              } else {
                                                  adapter.setState('callmonitor.connect', "", true);
                                                  adapter.setState('callmonitor.ring', "", true);
                                                  adapter.setState('callmonitor.call', "", true);
                                                  adapter.setState('callmonitor.all', "", true);
                                          Mir scheint als fehlt da: if (!showMissedTableJSON) adapter.setState('history.missedTableJSON', "deactivated", true);
                                          etwas.
