  4. [Hilfe] Fehler beim Update von Adaptern
adapterfehlerupdate
3 Beiträge 3 Kommentatoren 501 Aufrufe 2 Beobachtet
  • W Offline
    W Offline
    webseb79
    ich habe ein Intel Nuc mit Proxmox und einer VM für ioBroker.
    Jetzt habe ich ein paar Adapter aktualisiert und jedesmal kommt folgende Meldung.
    $ ./iobroker upgrade web
    Update web from @3.0.8 to @3.0.9
    host.ioBroker Adapter "system.adapter.web.0" is stopped.
    NPM version: 6.14.4
    npm install iobroker.web@3.0.9 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/linux/BluetoothSerialPort.cc: At global scope:../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void void InitAll(Handle<Object> exports) {              ^~~~~~../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
    ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’ void InitAll(Handle<Object> exports) {              ^~~~~~              rand_r../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token void InitAll(Handle<Object> exports) {                           ^../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope void InitAll(Handle<Object> exports) {                             ^~~~~~~
    In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope NODE_MODULE(BluetoothSerialPort, InitAll)                                  ^~~~~~~/home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
    make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Fehler 1
    gyp
     ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.0-9-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    Kann jemand etwas dazu sagen?
    Danke im voraus
    Sebastian
    • W Offline
      W Offline
      w00dy
      Die Meldung "gyp ERR!" kommt bei mir, und ich ich denke bei vielen anderen, auch regelmäßig. Solange das Update am Ende mit "Code 0" durchläuft ist alles i. O.
      Viele Grüße
      w00dy
      • W w00dy
        arteckA Offline
        arteckA Offline
        arteck
        @w00dy genau so ist es
