  4. Badradio
    5.4k
Badradio
blockly
75 Beiträge 10 Kommentatoren 7.1k Aufrufe 7 Beobachtet
  • J Jan1
    @lustig29
    kann das nicht importieren, kommt ein Fehler. Poste das noch mal.
    lustig29
    #41
    @Jan1
    code_text
    ```<xml xmlns="https://developers.google.com/blockly/xml">
      <block type="on" id="{!Ow5W{xI=1u8E[NnSUK" x="-462" y="-837">
        <field name="OID">deconz.0.Sensors.14.presence</field>
        <statement name="STATEMENT">
          <block type="controls_if" id="Kx3vNe=R:}qK8)0gWt@">
            <value name="IF0">
              <block type="logic_operation" id="mQ/dx2,-_w5IG$iE;)@J" inline="false">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="time_compare_ex" id="Tt0_xmUcA.@q=R^6c?K">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                    <field name="USE_ACTUAL_TIME">TRUE</field>
                    <field name="OPTION">not between</field>
                    <value name="START_TIME">
                      <shadow type="text" id="Ds2^t-6oqCLq{#P9fh(/">
                        <field name="TEXT">23:00</field>
                      </shadow>
                    </value>
                    <value name="END_TIME">
                      <shadow type="text" id="gu#LKi_N|YJrLy[.i6XR">
                        <field name="TEXT">04:30</field>
                      </shadow>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="on_source" id="9crFy+ImY/x|/4%_|Iuh">
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="0caXwgeFdZ2+*-%4$]n7" disabled="true">
                <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Commands.speak-volume</field>
                <field name="DELAY_MS">1</field>
                <value name="VALUE">
                  <block type="math_number" id="qgnMFdS`CHLm~05gl|0$">
                    <field name="NUM">30</field>
                  </block>
                </value>
                <next>
                  <block type="control" id="beIy{b}b`o+JDO}s--G*" disabled="true">
                    <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Commands.ssml</field>
                      <block type="text" id="@8xQbOq8H?PQJA?Obn$x">
                        <field name="TEXT">&lt;speak&gt;&lt;voice name="Hans"&gt;Hallo, ich wünsche dir viel Erfolg bei deinem Geschäft. Hände waschen bitte nicht vergessen!&lt;/voice&gt;.&lt;/speak&gt;</field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id="k!y+]`TjgB*YNCulFP(b" disabled="true">
                        <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Player.volume</field>
                          <block type="math_number" id="|,.2zG8A2}c;nn9~X%3Z">
                            <field name="NUM">20</field>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="!l0yy;jVq!YL4RH3xD/8" disabled="true">
                            <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Music-Provider.TuneIn</field>
                            <field name="DELAY_MS">4</field>
                              <block type="text" id="V4T*~XZ),3.JVa}:sLV,">
                                <field name="TEXT">HR 3</field>
                              </block>
                            </value>
                            <next>
                              <block type="control" id="DENupJe1)#Ft`L$5)c^,">
                                <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Player.controlPlay</field>
                                  <block type="logic_boolean" id="I%X3.ec/A@FYni-5!MvP">
                                  </block>
                                </value>
                                <next>
                                  <block type="control" id="-K*]=!?T(x=t3aH]yXB">
                                    <field name="OID">javascript.0.scriptEnabled.Alexa.Musik_an</field>
                                      <block type="logic_boolean" id="R4Lwk@QMSU7wLUUR_{)">
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
        <next>
          <block type="on" id="sM:.Y~^%@f(]1=[;xCd]">
            <field name="OID">deconz.0.Sensors.9.open</field>
            <field name="CONDITION">true</field>
              <block type="controls_if" id="5cj)P381Yi%K(%Q6B4l">
                <value name="IF0">
                  <block type="logic_operation" id="xRm)qTm9{hP%Om6X$S" inline="false">
                    <value name="A">
                      <block type="on_source" id="FQBb^YFSsXxvNU,7?;g7">
                      </block>
                    </value>
                    <value name="B">
                      <block type="get_value" id="I,5DN_vB(m]L_X%%l0C">
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="control" id="-YhxQx;-Ohq38S3jpH,F">
                    <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Player.controlPause</field>
                      <block type="logic_boolean" id=".=Zr.OXX+3jD[5g4N84O">
                      </block>
                    </value>
                    <next>
                      <block type="control" id="z.h$,n|N2GUp46ne8_SS">
                          <block type="logic_boolean" id="#Lz~5_ooORwjdqU#Xd|]">
                          </block>
                        </value>
                        <next>
                          <block type="control" id="oQu-RS?b?*%VTU/wm#PF" disabled="true">
                            <field name="OID">deconz.0.Sensors.6.presence</field>
                              <block type="logic_boolean" id="J5VYYL98Ib}qaE`GTXmi">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    J 1 Antwort Letzte Antwort
    • L lustig29
      @Jan1
      code_text
              <value name="IF0">
                  <value name="A">
                        </shadow>
                      </value>
                        </shadow>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                    </block>
                                  </value>
                                  <next>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </statement>
          <next>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </next>
        </block>
      </xml>
      Jan1
      #42
      @lustig29
      sollte so laufen:
        <block type="on" id="{!Ow5W{xI=1u8E[NnSUK" x="-713" y="-962">
          <field name="CONDITION">gt</field>
              <value name="IF0">
                <block type="logic_operation" id="4?*WfIKqZiI!c(5PfJ@j" inline="false">
                  <value name="A">
                    <block type="logic_operation" id="x`2E4DnQ.BgSd,iRP*c8" inline="false">
                      <value name="A">
                        <block type="logic_compare" id="Ohd:_Bw/iju]Awl-^=z-">
                          <field name="OP">NEQ</field>
                          <value name="A">
                            <block type="time_get" id="O^x[v[!?catkP4RCpOz]">
                              <field name="OPTION">wd</field>
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="Ja2f??qvp!GX*YKtcJ]6">
                              <field name="NUM">5</field>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_compare" id=")oLQU@bu6a5/?n_Dhv1h">
                          <value name="A">
                            <block type="time_get" id="NN4DT)!uI~)C([1SECM*">
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="My8hqgd2/OACXUvdMGC{">
                              <field name="NUM">6</field>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                          <field name="TEXT">21:00</field>
                        </shadow>
                      </value>
                        </shadow>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
                <block type="procedures_callnoreturn" id="HYDQ4AV{{wC}d6ksPT*]">
                  <mutation name="mach Musik"></mutation>
                </block>
              </statement>
              <value name="IF1">
                <block type="logic_operation" id="H:r0a@jlkAc9sL$O(O#V" inline="false">
                  <value name="A">
                    <block type="logic_operation" id="P$fbDr7:773XkVU2=BJp" inline="false">
                      <field name="OP">OR</field>
                      <value name="A">
                        <block type="logic_compare" id="i3/O:|ti/LY/uHR/fEU+">
                          <field name="OP">EQ</field>
                          <value name="A">
                            <block type="time_get" id="^G;Psf~+o2]}Uob(]b2a">
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="_.Mul65$$G*j*sZ^bQ.r">
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_compare" id="iK:{R?msG0E(6C}XAUog">
                          <value name="A">
                            <block type="time_get" id="H{FxEk#$^~Rwn5uv]37Y">
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="_P;Wn7P;KOm7#aLJNC)}">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                    <block type="time_compare_ex" id="^lfh?S(toOnFPFKDFi+g">
                        <shadow type="text" id="8dK5/$+^{fKNNFd^zvf/">
                        </shadow>
                      </value>
                        <shadow type="text" id="z=Vk@M/,CRI+E`n8`bUU">
                        </shadow>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <statement name="DO1">
                <block type="procedures_callnoreturn" id="dz?2/:3,Q*Br%A9/HRYS">
                </block>
              </statement>
            </block>
          </statement>
          <next>
                  <value name="IF0">
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </next>
        </block>
        <block type="procedures_defnoreturn" id="zDn%EJ=R{.L40rH7~+|Q" x="62" y="-962">
          <field name="NAME">mach Musik</field>
          <statement name="STACK">
                </block>
              </value>
              <next>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </xml>
      L 1 Antwort Letzte Antwort
      • J Jan1
        @lustig29
        sollte so laufen:
                <value name="IF0">
                    <value name="A">
                        <value name="A">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                          </shadow>
                        </value>
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  </block>
                </statement>
                <value name="IF1">
                    <value name="A">
                        <value name="A">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                          </shadow>
                        </value>
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
                    <value name="IF0">
                      </block>
                    </value>
                          </block>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
                  </block>
                </value>
                <next>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </xml>
        lustig29
        #43
        @Jan1 Hallo, das Skript läuft soweit ganz gut. Ich muss es nur beim ersten betreten selbst starten...?
        Beim ersten Betreten passiert nichts. Wenn ich Alexa sage: "Spiele... auf Tunein", geht es los.
        Beim nächsten Betreten des Bades funktioniert dann das Skript wie gewollt. Bewegung wird erkannt, Wiedergabe startet.
        Ich vermute das es mit dem Control Play / Control Pause zusammen hängt. Sind ja Buttons.
        Ich habe leider noch keine Lösung gefunden.
        Den BMW, schließe ich als Fehler aus. Ich habe noch einen LED Streifen im Bad, der über diesen und den Türkontakt gestört wird. Das geht ohne Probleme
        • L lustig29
          Jan1
          #44
          @lustig29
          Schau doch einfach mal die Trigger DPs an, wie die zuerst stehen und ob die sich wie angegeben ändern.
          • J Jan1
            @lustig29
            lustig29
            #45
            @Jan1 Control Play steht schon auf true. Das dürfte doch nicht sein, oder?
            J dslraserD 2 Antworten Letzte Antwort
            • L lustig29
              Jan1
              #46
              @lustig29
              Du startest ja ein weiteres Script und kein Plan was das macht. Wenn irgendwas auf true steht, hast einfach vergessen das per Script auch wieder auf false zu schalten. Schau einfach wo was nicht passt und ergänzt es. Das Grundgerüst läuft ja und der Rest ist Kindergeburtstag.
              • L lustig29
                dslraserD Offline
                dslraserD Offline
                dslraser
                #47
                @lustig29
                das geht schon so wie Du das machen möchtest, aber warum so kompliziert ?
                Ich habe mir mal eine Routine in der Alexa App gemacht (spiele ndr zwei). Diese Routine ist im Alexa Adapter (nach dem Routine erstellen den Adapter neu starten) verfügbar. Bei mir ist der Trigger eine HUE Lampe (weil die sowieso über einen Bewegungsmelder eingeschaltet wird) Diese Routine läuft immer zuverlässig und das Blockly wird sehr einfach (bis auf Deine Zusatzeinschränkungen)
                Geht das Licht an, startet der Radiosender, geht das Licht aus, dann auch der Radiosender...
                Routine
                Mein kurzes Blockly
                Edit: und hier schaltest Du ganze Scripte an und aus, das ist ohnehin nicht empfohlen...
                und hier...
                • dslraserD dslraser
                  @lustig29
                  Routine
                  Mein kurzes Blockly
                  und hier...
                  lustig29
                  #48
                  @dslraser Ja, aber warum funktioniert das mit ControlPlay nicht? Ich möchte ja nicht irgendeinen Radiosender abspielen. Ich will nur, dass die Musikwiedergabe fortgesetzt wird. Egal ob Tunein, Spotify, usw.
                  • L Offline
                    lustig29
                    #49
                    So sieht mein Skript im Moment aus
                    • J Jan1
                      @lustig29
                      lustig29
                      #50
                      @Jan1 Kannst du mir bitte nochmal helfen mit dem Control Play Problem?
                      • L lustig29
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #51
                        @lustig29
                        ich bin zwar nicht Jan1 und kenne Deinen Bewegungsmelder nicht (meine BWM bleiben auf true, solange Bewegung erkannt wird und lassen sich konfigurieren wann sie wieder auf false gehen wenn keine Bewegung mehr erkannt wird)
                        Ich weiß auch nicht wie lange der letzte Sender (oder Provider) in den Datenpunkten vom Alexa2 Adapter nach dem letzten abspielen drinn stehen bleibt. Wenn die immer drinn bleiben, dann sollte doch ein erneutes drücken auf play reichen.
                        Vorschlag, so in etwa (nicht getestet)
                         <block type="on" id="{!Ow5W{xI=1u8E[NnSUK" x="13" y="13">
                               <value name="IF0">
                                 <block type="logic_operation" id="6s#Qd!cP$$-Co+A*2M#}" inline="false">
                                   <value name="A">
                                     <block type="on_source" id="|fS~q#BQ?Z:3qR6Zc(t{">
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                           <value name="A">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <value name="B">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                             </shadow>
                                           </value>
                                             </shadow>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                   <mutation name="mach_Musik"></mutation>
                                 </block>
                               </statement>
                               <next>
                                 <block type="controls_if" id="BdojF*!sp8M9vMCtjhhe">
                                   <value name="IF0">
                                     <block type="logic_operation" id="HH=SzmL*B5~Qo?2*i/t-" inline="false">
                                       <value name="A">
                                         <block type="logic_negate" id=".Ii7VNQCQsLhy:JWjyq~">
                                           <value name="BOOL">
                                             <block type="on_source" id="xOrq{-st8fu1OD=sDVF~">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_operation" id="_H[;_U.9)+;(?xVw=nx-" inline="false">
                                           <value name="A">
                                             <block type="logic_operation" id="Zu%jHx}rM-}?isWGj^G6" inline="false">
                                               <value name="A">
                                                 <block type="logic_compare" id="tP9wbzWsjr/!2(5hbuy*">
                                                   <value name="A">
                                                     <block type="time_get" id="pc3r8jNP}93dl@z(qJU7">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="math_number" id="D+1,L!+7k,RhNF#!Zi_s">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="logic_compare" id="d[7+_W*E!hdU3~fg^nC+">
                                                   <value name="A">
                                                     <block type="time_get" id="ke?S?XPv4RV0w!+w0rmd">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="math_number" id="kDTTvvo+6I0+{Fmd.Z_j">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="time_compare_ex" id="eEmi%*(aJ?yF2q,(FGU=">
                                                 <shadow type="text" id="N=vutHo//d5eOiMv{4jw">
                                                 </shadow>
                                               </value>
                                                 <shadow type="text" id="(O5Z%*uN_hKPwR6R-rTu">
                                                 </shadow>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="procedures_callnoreturn" id="c8*jaAYriZRr$$yogeVO">
                                       <mutation name="mach_Musik_aus"></mutation>
                                     </block>
                                   </statement>
                                   <next>
                                     <block type="controls_if" id="u|H)(@*hqhJ@_:f36Pl,">
                                       <value name="IF0">
                                         <block type="logic_operation" id="hb=JsVjTrVc}ht6:@;Tz" inline="false">
                                           <value name="A">
                                             <block type="on_source" id="ul{^e1q@a6+kFZ{E^KH(">
                                             </block>
                                           </value>
                                           <value name="B">
                                               <value name="A">
                                                   <value name="A">
                                                       <value name="A">
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                       <value name="A">
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                     </shadow>
                                                   </value>
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                         </block>
                                       </statement>
                                       <next>
                                         <block type="controls_if" id="e9e,o`~.v1YnG3P|Y@~$">
                                           <value name="IF0">
                                             <block type="logic_operation" id="PD,K.Ln(G.#|5#c*CHrY" inline="false">
                                               <value name="A">
                                                 <block type="logic_negate" id="YwVAR5NSVG9}hk!?-b2!">
                                                   <value name="BOOL">
                                                     <block type="on_source" id="4+P3R)9yR)oa,Vg;0%a-">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="logic_operation" id="n66o?1ZAhp_}|=%g3vkK" inline="false">
                                                   <value name="A">
                                                     <block type="logic_operation" id="lp6kVF~vx~lsRByxwjWB" inline="false">
                                                       <value name="A">
                                                         <block type="logic_compare" id="/-l~FA*kjnc*1FO2Ug=5">
                                                           <value name="A">
                                                             <block type="time_get" id="4#mCT:Y6blSu7CU^ga)*">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="math_number" id="$cQcmW$vr^30oEb_1sDj">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         <block type="logic_compare" id="z;5t]?7`S4NLXJFY`iye">
                                                           <value name="A">
                                                             <block type="time_get" id="C.wBKjznQ19|x0NC5l3O">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="math_number" id="t09J}5nX!LxCp!v]IrER">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="time_compare_ex" id="E]FvF}F8HMMHT.]Xdr@^">
                                                         <shadow type="text" id="r-/xauF2lG}n}Yki--`Q">
                                                         </shadow>
                                                       </value>
                                                         <shadow type="text" id="dP;EQE3#GpXVo9RdmxX/">
                                                         </shadow>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                             <block type="procedures_callnoreturn" id="+p?%Yk^+)^3N_o2[yX6R">
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                                   <value name="IF0">
                                     <block type="on_source" id="h_B9RvL-9Tlsy*IDEMmH">
                                     </block>
                                   </value>
                                     <block type="procedures_callnoreturn" id="NT+:Zdud):f7dtw~|Y@]">
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                         <block type="procedures_defnoreturn" id="O(3*+|mgt]9chiP7/98V" x="337" y="13">
                           <field name="NAME">mach_Musik_aus</field>
                             <block type="comment" id="5W/()7s]5%k.hDzAvw]c">
                               <field name="COMMENT">hier den stopp Befehl Button</field>
                               <next>
                                 <block type="control" id="aw-U.VFFII+FtU]U/o`r">
                                     <block type="logic_boolean" id="I1WfR-nF,!Zs+:68P!?:">
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                         <block type="procedures_defnoreturn" id="zDn%EJ=R{.L40rH7~+|Q" x="288" y="837">
                           <field name="NAME">mach_Musik</field>
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                        </xml>
                        EDIT: Export eben noch mal etwas verändert (22.07.2020 19:06 Uhr)
                          @lustig29
                                 <value name="IF0">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                             <value name="A">
                                                 <value name="A">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="B">
                                                 <value name="A">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="B">
                                               </shadow>
                                             </value>
                                               </shadow>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                   </block>
                                 </statement>
                                 <next>
                                     <value name="IF0">
                                         <value name="A">
                                             <value name="BOOL">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="B">
                                             <value name="A">
                                                 <value name="A">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="B">
                                                   </shadow>
                                                 </value>
                                                   </shadow>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                       </block>
                                     </statement>
                                     <next>
                                         <value name="IF0">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                                 <value name="A">
                                                     <value name="A">
                                                         <value name="A">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                         <value name="A">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                       </shadow>
                                                     </value>
                                                       </shadow>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                           </block>
                                         </statement>
                                         <next>
                                             <value name="IF0">
                                                 <value name="A">
                                                     <value name="BOOL">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                     <value name="A">
                                                         <value name="A">
                                                             <value name="A">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                             <value name="A">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                           </shadow>
                                                         </value>
                                                           </shadow>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                               </block>
                                             </statement>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                             <next>
                                     <value name="IF0">
                                       </block>
                                     </value>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                                 <next>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                                   </block>
                                 </value>
                               </block>
                             </statement>
                           </block>
                          </xml>
                          lustig29
                          #52
                          @dslraser Dankeschön, werde ich mal testen.
                          • L lustig29
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #53
                            @lustig29 sagte in Badradio:
                            Ich habe das mal bei mir getestet.
                            Der Sender steht zwar noch in den Datenpunkten vom Alexa2 Adapter drinn, aber nach einer Weile (wie lange weiß ich nicht) reicht ein einfaches play drücken dann nicht mehr. Da muss dann erst einmal wieder bei den Povider Daten im Adapter (der Sender, oder auch eine Play Liste usw.) neu angestoßen werden.
                            Ich höre bei mir immer den gleichen Sender und lade quasi den dann neu.
                            Immer das was zu letzt gehört wurde irgendwann wieder einfach per play zu starten, geht also so nicht.
                            Man müsste wahrscheinlich dafür das zu letzt gehörte in eine Variable im Blockly weg schreiben (oder auch in einen eigenen Datenpunkt) und das dann wieder starten.
                              lustig29
                              #54
                              @dslraser Gute Idee.Wie würde das dann in etwa aussehen?
                              • L lustig29
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #55
                                bissl habe ich mir schon gebaut, ist aber nicht fertig. Jetzt bin ich erstmal bis morgen Abend unterwegs...., dann geht es weiter.
                                  lustig29
                                  #56
                                  @dslraser Super, vielen Dank schon mal
                                  • L lustig29
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #57
                                    immer das zu letzt gehörte nach irgendeiner Pause wieder ab zu spielen ist komplizierter als gedacht. Wenn es sich nur auf z.B. Radiosender von TuneIn begrenzen würde, dann ginge es ja noch.
                                    Aber, sobald andere Skills oder auch Playlisten, egal ob von Amazon Music oder auch andere Playlisten zwischendurch was abspielen, dann erscheinen die gar nicht in den Datenpunkten vom Alexa2 Adapter, somit kann man die nicht abgreifen.
                                    Da ich immer den gleichen TuneIn Sender einschalten lasse, habe ich da bisher auch nicht weiter drauf geachtet.
                                    Ich habe auch nicht wirklich eine Idee bzw. eine Logik wie man alle diese Datenpunkte beobachten soll (geht zwar) und dann eine Logik für das zu letzt gehörte aufbauen kann, da sich selbst innerhalb von TuneIn "Provider" oder auch Service verändern.
                                    Das alles ändert sich (das meiste davon)
                                    damit hatte ich so angefangen, werde es aber nicht weiter verfolgen
                                    Vielleicht hilft Dir Jemand anderes bei diesem Projekt...
                                    Ich bin da dann raus.
                                      lustig29
                                      #58
                                      Hätte noch einmal eine Frage. Kann man das Skript eventuell so gestalten, dass die Musik gleich beim Betreten startet und beim Verlassen sofort endet? Ich habe einen Türkontakt von Xiaomi und einen Bewegungsmelder von Ikea im Bad im Einsatz. Vielleicht kann man ja was mit den 2 Objekten basteln. Was mich aktuell auch noch stört, dass die Musikwiedergabe erst nach 5 Sekunden startet. Hänge mein aktuelles Skript nochmal als Bild dran.
                                      • L lustig29
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #59
                                        @lustig29
                                        Einen gewissen zeitlichen Versatz wirst Du immer haben, wenn Du mit Streams arbeitest. Skript wird ausgelöst, abgearbeitet, dann wird der Stream für Dein Gerät aufbereitet....da können schonmal 5sek ins Land ziehen.
                                        • haselchenH haselchen
                                          @lustig29
                                          lustig29
                                          #60
                                          Ich bins mal wieder.😊
                                          Dieses Mal mit diesem Bad Skript. Meine Frage, warum startet die Musik Wiedergabe nach ca. 2 Minuten neu und wie kann ich das ändern?
                                          A 1 Antwort Letzte Antwort
