  4. [gelöst] BUG: sayit funktioniert bei win nicht zuverlässig.
    6.8k
bugsayit
95 Beiträge 6 Kommentatoren 9.3k Aufrufe 5 Beobachtet
  • bahnuhrB bahnuhr
    Instanz gestoppt und neu versucht.
    Weiterhin Fehler 25:
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.sayit/tarball/master" sayit
    install https://github.com/ioBroker/ioBroker.sayit/tarball/master
    NPM version: 6.14.4
    npm install https://github.com/ioBroker/ioBroker.sayit/tarball/master --loglevel error (System call)
    npm
     ERR! code EPERMnpm ERR! syscall renamenpm ERR! path C:\iobroker\node_modules\iobroker.sayitnpm ERR! dest C:\iobroker\node_modules\.iobroker.sayit.DELETEnpm ERR! errno -4048
    npm
    ERR! Error: EPERM: operation not permitted, rename 'C:\iobroker\node_modules\iobroker.sayit' -> 'C:\iobroker\node_modules\.iobroker.sayit.DELETE'npm ERR!  [OperationalError: EPERM: operation not permitted, rename 'C:\iobroker\node_modules\iobroker.sayit' -> 'C:\iobroker\node_modules\.iobroker.sayit.DELETE'] {npm ERR!   cause: [Error: EPERM: operation not permitted, rename 'C:\iobroker\node_modules\iobroker.sayit' -> 'C:\iobroker\node_modules\.iobroker.sayit.DELETE'] {npm ERR!     errno: -4048,npm ERR!     code: 'EPERM',npm ERR!     syscall: 'rename',npm ERR!     path: 'C:\\iobroker\\node_modules\\iobroker.sayit',npm ERR!     dest: 'C:\\iobroker\\node_modules\\.iobroker.sayit.DELETE'npm ERR!   },npm ERR!   errno: -4048,npm ERR!   code: 'EPERM',npm ERR!   syscall: 'rename',npm ERR!   path: 'C:\\iobroker\\node_modules\\iobroker.sayit',npm ERR!   dest: 'C:\\iobroker\\node_modules\\.iobroker.sayit.DELETE',npm ERR!   parent: 'iobroker'npm
     ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It's possible that the file was already in use (by a text editor or antivirus),npm ERR! or that you lack permissions to access it.npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR!
     the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR!     C:\Users\iobroker\AppData\Roaming\npm-cache\_logs\2020-07-27T09_30_00_889Z-debug.log
    ERROR: host.NUC-Buero Cannot install https://github.com/ioBroker/ioBroker.sayit/tarball/master: 4294963248
    @bahnuhr sagte in BUG: sayit funktioniert unter win nicht zuverlässig.:
    Irgendetwas sagt das npm das nichtdarf ... lösch das verzeichnis doch mal "per hand"
    • apollon77A apollon77
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @apollon77 sagte in BUG: sayit funktioniert unter win nicht zuverlässig.:
      Instanzen gelöscht.
      Dienst beendet.
      versucht ..node_modules.iobroker.sayit.sayit.2.say.mp3 zulöschen; hat aber nicht geklappt. mp3 Datei wurde ständig wieder neu erstellt.
      rechner komplett runter gefahren und neu gestartet.
      jetzt verzeichnis ...node_modules.iobroker.sayit gelöscht.
      auch auch verzeichnisse ...iobroker-data.files.sayit ... gelöscht
      dienst gestartet.
      warten bis alle Instanzen wieder da waren.
      Und dann: über git sayit neu installiert.
      mit code 0 (also alles ok).
      Verzeichnis unter ...node_modules und ...iobroker-data sind wieder da.
      Dann Instanzen 2,3,4 neu installiert.
      hat alles geklappt.
      Dann Script:
      setState('sayit.2.tts.text', "a b c ");
      und gleich Fehler im log:
      host.NUC-Buero	2020-07-27 11:57:53.449	error	instance system.adapter.sayit.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.NUC-Buero	2020-07-27 11:57:53.449	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:84:21)
      host.NUC-Buero	2020-07-27 11:57:53.449	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1221:12)
      host.NUC-Buero	2020-07-27 11:57:53.449	error	Caught by controller[0]: at IncomingMessage.EventEmitter.emit (domain.js:482:12)
      host.NUC-Buero	2020-07-27 11:57:53.448	error	Caught by controller[0]: at IncomingMessage.emit (events.js:327:22)
      host.NUC-Buero	2020-07-27 11:57:53.448	error	Caught by controller[0]: at IncomingMessage.<anonymous> (C:\iobroker\node_modules\iobroker.sayit\lib\text2speech.js:165:40)
      host.NUC-Buero	2020-07-27 11:57:53.447	error	Caught by controller[0]: ReferenceError: error is not defined
      sayit.2	2020-07-27 11:57:53.275	info	(8896) stopping...
      sayit.2	2020-07-27 11:57:53.274	error	(8896) ReferenceError: error is not defined at IncomingMessage.<anonymous> (C:\iobroker\node_modules\iobroker.sayit\lib\text2speech.js:165:40) at IncomingMessage.emit (events.js:327:22) at
      sayit.2	2020-07-27 11:57:53.274	error	(8896) uncaught exception: error is not defined
      sayit.2	2020-07-27 11:57:53.144	info	(8896) saying: a b c```
      mfg
      Dieter
      Danke.
      • bahnuhrB bahnuhr
        Instanzen gelöscht.
        Dienst beendet.
        dienst gestartet.
        hat alles geklappt.
        Dann Script:
        mfg
        Dieter
        @bahnuhr Hab ich im Sentry gesehn:-)
        Update nochmal
          Update nochmal
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          Update nochmal
          Weiterhin:
          sayit.2 2020-07-27 12:29:23.946 error (6080) File error: Error: EBUSY: resource busy or locked, open 'C:\iobroker\node_modules\iobroker.sayit\lib/../sayit.2.say.mp3'
          Danke.
          • bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            so, nochmal alles gelöscht und neu installiert.
            Wird das file mp3 nun gar nicht mehr gespeichert ???
            Wenn doch, wo ?
            Danke.
            • bahnuhrB bahnuhr
              Wenn doch, wo ?
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              Wenn doch, wo ?
              Nachtrag: das brauch ich ja (will ich ja kopieren)
              Danke.
              • apollon77A Offline
                Es sollte sich an der Speicherstelle nichts geändert haben - also ich habe nichts daran geändert ... vllt ist die Speicherstelle ja das Problem das es "Im npm verzeicghnis" ist ... vllt ists im iobroker-data besser aufgehoben?
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Ich weiß auch nicht.
                  In ...node_modules.iobroker.sayit
                  ist die Datei nicht mehr.
                  Danke.
                    aber er sagt das er sie erfolgreich geschrieben hat?
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      Dachte schon, aber eben nicht mehr.
                      host.NUC-Buero	2020-07-27 13:56:42.223	info	Restart adapter system.adapter.sayit.2 because enabled
                      host.NUC-Buero	2020-07-27 13:56:42.223	error	instance system.adapter.sayit.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.NUC-Buero	2020-07-27 13:56:42.223	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:84:21)
                      host.NUC-Buero	2020-07-27 13:56:42.222	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1221:12)
                      host.NUC-Buero	2020-07-27 13:56:42.222	error	Caught by controller[0]: at IncomingMessage.EventEmitter.emit (domain.js:482:12)
                      host.NUC-Buero	2020-07-27 13:56:42.222	error	Caught by controller[0]: at IncomingMessage.emit (events.js:327:22)
                      host.NUC-Buero	2020-07-27 13:56:42.222	error	Caught by controller[0]: at IncomingMessage.<anonymous> (C:\iobroker\node_modules\iobroker.sayit\lib\text2speech.js:165:70)
                      host.NUC-Buero	2020-07-27 13:56:42.220	error	Caught by controller[0]: ReferenceError: seconds is not defined
                      sayit.2	2020-07-27 13:56:42.051	info	(15988) stopping...
                      sayit.2	2020-07-27 13:56:42.050	error	(15988) ReferenceError: seconds is not defined at IncomingMessage.<anonymous> (C:\iobroker\node_modules\iobroker.sayit\lib\text2speech.js:165:70) at IncomingMessage.emit (events.js:327:22)
                      sayit.2	2020-07-27 13:56:42.050	error	(15988) uncaught exception: seconds is not defined
                      sayit.2	2020-07-27 13:56:41.928	info	(15988) saying: a b c
                      Ich glaub, wir geben auf.
                      Ist ja schon lange so; aber es ist zum Verzweifeln.
                      Danke.
                      • bahnuhrB bahnuhr
                        @bahnuhr Ja, hab ich grad gesehn. Update nochmal bitte. Mein Fehler ... Kopieren will gelernt haben
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          hat nichts geholfen:
                          weiterhin:
                          sayit.2 2020-07-27 15:26:31.354 error (1452) File error: Error: EBUSY: resource busy or locked, open 'C:\iobroker\node_modules\iobroker.sayit\lib/../sayit.2.say.mp3'
                          sayit.2 2020-07-27 15:26:29.071 info (1452) saying: Test
                          Danke.
                            Ok, jetzt zeig mal was Du mit dem File machst ... und wie. Nur um auszuschliessen das es gar nichts mit dem Adater zu tun hat!
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              Ich mach ja momentan nichts mit dem file:
                              zum Testen nur:
                              setState('sayit.2.tts.text', "Test");
                              Danke.
                              • bahnuhrB bahnuhr
                                zum Testen nur:
                                @bahnuhr Ahh ok ... schade :-)
                                Wie war es "Virenscanner"? Der ist aus? bzw File excluded?
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  Habe antivir.
                                  kann ich gern einmal ausmachen.
                                  Danke.
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    so, Antivir aus.
                                    gleiche Ergebnis:
                                    sayit.2	2020-07-27 16:06:18.912	error	(6640) File error: Error: EBUSY: resource busy or locked, open 'C:\iobroker\node_modules\iobroker.sayit\lib/../sayit.2.say.mp3'
                                    sayit.2	2020-07-27 16:06:14.853	info	(6640) saying: Test
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      so, Antivir aus.
                                      gleiche Ergebnis:
                                      @bahnuhr Dann bin ich jetzt (auch weil Du mit npm dies egrossen Probleme hatest): Checke mal die Rechte des Files und des Verzeichnisses ... bezogenm auf den User unter dem ioBroker läuft und stelle sicher das der da lesen und schreiben darf
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        Habe "jeder"; der darf alles
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          @bahnuhr Dann sind wir wieder am Anfang ... Mist
