  4. sql startet nach update nicht mehr
sql adapter crash error
32 Beiträge 14 Kommentatoren 4.5k Aufrufe 13 Beobachtet
    madison
    Systemdata vmware
    Hardwaresystem: vmware
    Arbeitsspeicher: 4GB
    Festplattenart: HDD
    Betriebssystem: Ubuntu
    Node-Version: 12.16.1
    Nodejs-Version: 12.16.1
    NPM-Version: 6.13.4
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    nach dem update auf 1.13.0 startet der sql adapter nicht mehr.
    folgendes ist im log zu finden.
    sql.0	2020-05-18 18:34:29.779	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    sql.0	2020-05-18 18:34:29.779	error	at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115328)
    sql.0	2020-05-18 18:34:29.779	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1482:21
    sql.0	2020-05-18 18:34:29.779	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:26
    sql.0	2020-05-18 18:34:29.779	error	at Array.map (<anonymous>)
    sql.0	2020-05-18 18:34:29.779	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39
    sql.0	2020-05-18 18:34:29.779	error	(31880) TypeError: Cannot read property 'startsWith' of undefined
    sql.0	2020-05-18 18:34:29.776	error	(31880) unhandled promise rejection: Cannot read property 'startsWith' of undefined Unhandled	2020-05-18 18:34:29.776	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    sql.0	2020-05-18 18:28:32.141	error	(31422) TypeError: Cannot read property 'startsWith' of undefined at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39 at Array.map (<anonymous>) at /opt/iobroker/no
    sql.0	2020-05-18 18:28:32.138	error	(31422) unhandled promise rejection: Cannot read property 'startsWith' of undefined
    sql.0	2020-05-18 18:28:32.138	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
      madison
      nach downgrade auf 1.12.5 läuft der adapter wieder.
      sieht nach einem bug in der version 1.13.0 aus!
      C 1 Antwort Letzte Antwort
        rascal
        das Gleiche hier:
        host.Mastermind	2020-05-18 19:47:51.590	info	instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
        host.Mastermind	2020-05-18 19:47:51.590	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
        host.Mastermind	2020-05-18 19:47:51.590	error	Caught by controller[1]: at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115328)
        host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1482:21
        host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:26
        host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at Array.map (<anonymous>)
        host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39
        host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: TypeError: Cannot read property 'startsWith' of undefined
        host.Mastermind	2020-05-18 19:47:51.588	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
        sql.0	2020-05-18 19:47:51.469	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.468	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.467	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.466	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.465	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.464	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.463	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.462	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.461	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.460	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.454	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.453	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.452	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.451	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.450	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.449	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.448	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.447	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.446	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.445	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.444	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.443	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.442	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.441	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.440	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.369	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.368	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.364	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.363	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.357	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.356	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.353	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.352	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.349	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.348	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.345	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.339	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.337	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.336	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.333	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.331	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.330	warn	(453392) No Connection to database
        sql.0	2020-05-18 19:47:51.043	info	(453392) Terminated (NO_ERROR): Without reason
        sql.0	2020-05-18 19:47:51.041	info	(453392) terminating
        sql.0	2020-05-18 19:47:50.436	error	(453392) TypeError: Cannot read property 'startsWith' of undefined at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39 at Array.map (<anonymous>) at /opt/iobroker/n
        sql.0	2020-05-18 19:47:50.426	error	(453392) unhandled promise rejection: Cannot read property 'startsWith' of undefined
        sql.0	2020-05-18 19:47:50.425	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        • M madison
          C-3po
          @madison said in sql startet nach update nicht mehr:
          Jo,
          Hier das selbe Ergebnis. Nur seltsam das es in der History noch eine 1.12.6 gibt. Selbige aber nicht Installierbar ist.
          Mit 1.12.5 wieder io.
          cu C-3po
            rascal
            mit 1.12.6 hatte ich den Fehler auch
            • FeuersturmF Offline
              FeuersturmF Offline
              Feuersturm
              Es gibt hierzu auch ein Github Issue: https://github.com/ioBroker/ioBroker.sql/issues/120
              • L Offline
                Lstt
                  bommel_030
                  schrieb am zuletzt editiert von bommel_030
                  Habe auch auf die 1.13.0 aktualisiert (Vermute von der 1.12.5). Instanz ist permanent neu gestartet.
                  Habe dann den Downgrade auf 1.12.5 und bekomme seitdem folgende Fehlermeldung.
                  sql.0	2020-05-19 07:34:49.602	info	(4756) No Data
                  sql.0	2020-05-19 07:34:24.964	error	(4756) Error: Packets out of order. Got: 1 Expected: 0
                  Egal welche Version ich auch installiere, die Meldung kommt jetzt immer. Hat jemand ne Idee was das sein könnte?
                  Edit:
                  Downgrade auf 1.9.4 und danach upgrade auf 1.12.5 hat geholfen, warum auch immer...
                  • opossumO Offline
                    opossumO Offline
                    opossum
                    bei mir gleiches Problem, aber Downgrade auf 1.12.5 hat fehlerfrei geklappt. Downgrade von 1.13.0 auf 1.12.6 hat bei mir gar nicht funktioniert.
                    https://www.schlepper-petersdorf.de
                    • Dr. BakteriusD Offline
                      Dr. Bakterius
                      Kann ich auch bestätigen! Das mit der nicht existenten 1.12.6 ist auch fies. Wird ohne Fehler installiert, doch danach ist immer noch 1.13.0 installiert. Wollte schon über die Console installieren als ich diesen Hinweis hier bekam.
                        Berchemer
                        schrieb am zuletzt editiert von Berchemer
                        Schließe mich an.
                        Habe jetzt die 1.12.6 gar nicht erst versucht sondern direkt auf 1.12.5 downgegraded und alles ist wieder gut.
                        Danke für die Warnung mit der 1.12.6 :-)
                        oberfraggerO 1 Antwort Letzte Antwort
                        • B Berchemer
                          Schließe mich an.
                          oberfraggerO Offline
                          oberfragger
                          schrieb am zuletzt editiert von oberfragger
                          Vielen Dank für das Posting. Dachte nur bei mir wäre was im Eimer. 1.12.5 funktiniert auf Anhieb!
                            bombastikde
                            Nach dem Downgrade auf 1.12.5 funktionert jetzt wieder alles - Das hat aber einigen Scheiss gekostet
                              madison
                              hat die Version 1.13.1 schon jemand getestet?
                              C FeuersturmF 2 Antworten Letzte Antwort
                              • M madison
                                C-3po
                                @madison
                                Jupp
                                eben gerade
                                Rennt wieder.
                                cu C-3po
                                • C C-3po
                                  @madison
                                  Jupp
                                  eben gerade
                                  Rennt wieder.
                                  madison
                                  @C-3po super, danke!
                                  • M madison
                                    C-3po
                                    @madison
                                    dafür schiest aber das neue Script Engine quer
                                    cu C-3po
                                    • C C-3po
                                      @madison
                                      madison
                                      @C-3po welche version?
                                      • M madison
                                        C-3po
                                        schrieb am zuletzt editiert von C-3po
                                        @madison
                                        4.6.13
                                        macht stress mit Blockly und Datumsabfragen.
                                        bin erst mal wieder auf 4.6.4
                                        cu C-3po
                                        M B 2 Antworten Letzte Antwort
                                        • C C-3po
                                          @madison
                                          4.6.13
                                          madison
                                          @C-3po Datumsabfragen verwende ich nicht, sonst wäre mir noch nichts aufgefallen!
