  4. Script Engine Update nach 4.6.4
script engine
60 Beiträge 12 Kommentatoren 5.8k Aufrufe 13 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    schrieb am zuletzt editiert von Chaot
    Mir wurde gestern und heute das Update der Script Engine angeboten.
    Wenn ich das Update mache kommt dieser Fehler:
    javascript.0	2020-05-16 09:15:53.432	error	(2593) Cannot install xml2js: 254
    javascript.0	2020-05-16 09:15:53.386	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-16T07_15_53_365Z-debug.log
    javascript.0	2020-05-16 09:15:53.386	error	(2593) npm ERR! A complete log of this run can be found in:
    javascript.0	2020-05-16 09:15:53.383	error	(2593)
    javascript.0	2020-05-16 09:15:53.364	error	npm ERR! enoent
    javascript.0	2020-05-16 09:15:53.364	error	npm ERR! enoent This is related to npm not being able to find a file.
    javascript.0	2020-05-16 09:15:53.364	error	(2593) ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match'
    javascript.0	2020-05-16 09:15:53.361	error	(2593) npm
    javascript.0	2020-05-16 09:15:53.359	error	npm ERR! errno -2
    javascript.0	2020-05-16 09:15:53.359	error	npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    javascript.0	2020-05-16 09:15:53.359	error	(2593) npm ERR! syscall access
    javascript.0	2020-05-16 09:15:53.357	error	(2593) npm ERR! code ENOENT
    javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/open-fin-ts-js-client
    javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bunyan
    javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mv
    javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
    javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
    javascript.0	2020-05-16 09:15:53.184	error	(2593) npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-json-stringify
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ncp
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/dtrace-provider
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
    javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mkdirp
    javascript.0	2020-05-16 09:15:53.182	error	(2593) Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/encoding
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
    javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
    javascript.0	2020-05-16 09:15:53.181	error	(2593) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    javascript.0	2020-05-16 09:15:53.179	error	(2593) npm
    javascript.0	2020-05-16 09:15:42.908	error	(2593) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.0	2020-05-16 09:15:42.905	error	(2593) npm
    Irgendwie seltsam, weil ich ansonsten keinerlei Berechtigungsprobleme habe. Der Fixer bringt auch nichts.
    Jemand eine Idee?
    Edit:
    Der Fehler get weiter:
    In den Adaptern wird die 4.5.1. als installiert angezeigt und der Reiter "Scripte" zeigt nichts mehr an.
    Wenn ich manuell wieder den 4.5.1 installiere geht alles wieder.
    J 1 Antwort Letzte Antwort
    • ChaotC Chaot
      Jemand eine Idee?
      Edit:
      Jan1
      @Chaot
      Deinstalliere mal den JS Adapter und versuch ne Neuinstallation nach dem der Fixer noch mal lief.
      Ein reboot des ganzen System wirkt auch oft Wunder.
      • J Jan1
        @Chaot
        ChaotC Offline
        ChaotC Offline
        Chaot
        @Jan1
        Ich habe das auch schon versucht.
        Der letzte Versuch war jetzt mit der Brechstange.
        Das ganze Verzeichnis auf 777 gesetzt, Adapter installiert und danach den Fixer wieder drüber.
        Jetzt ist (seltsamerweise) 4.6.4 installiert und der Script Reiter zeigt auch wieder die Scripte.
        Fehlermeldung ist noch:
        javascript.0	2020-05-16 09:35:06.364	error	(27210) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        javascript.0	2020-05-16 09:35:06.361	error	(27210) npm
        javascript.0	2020-05-16 09:34:59.751	error	(27210) Cannot install request: 254
        javascript.0	2020-05-16 09:34:59.734	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-16T07_34_59_687Z-debug.log
        javascript.0	2020-05-16 09:34:59.734	error	(27210) A complete log of this run can be found in:
        javascript.0	2020-05-16 09:34:59.731	error	(27210) ERR!
        javascript.0	2020-05-16 09:34:59.728	error	(27210)
        javascript.0	2020-05-16 09:34:59.726	error	(27210) npm
        javascript.0	2020-05-16 09:34:59.724	error	(27210)
        javascript.0	2020-05-16 09:34:59.691	error	npm ERR! enoent
        javascript.0	2020-05-16 09:34:59.691	error	npm ERR! enoent This is related to npm not being able to find a file.
        javascript.0	2020-05-16 09:34:59.691	error	npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser'
        javascript.0	2020-05-16 09:34:59.691	error	npm ERR! errno -2
        javascript.0	2020-05-16 09:34:59.691	error	npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser
        javascript.0	2020-05-16 09:34:59.691	error	npm ERR! syscall access
        javascript.0	2020-05-16 09:34:59.691	error	(27210) npm ERR! code ENOENT
        javascript.0	2020-05-16 09:34:59.539	error	(27210) npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser
        host.ioBroker	2020-05-16 09:34:57.521	info	iobroker exit 0
        host.ioBroker	2020-05-16 09:34:56.504	info	iobroker Adapter "javascript" updated
        host.ioBroker	2020-05-16 09:34:56.447	info	iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
        host.ioBroker	2020-05-16 09:34:56.382	info	iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
        host.ioBroker	2020-05-16 09:34:56.317	info	iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        host.ioBroker	2020-05-16 09:34:56.256	info	iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
        host.ioBroker	2020-05-16 09:34:56.183	info	iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
        javascript.0	2020-05-16 09:34:56.142	error	(27210) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        javascript.0	2020-05-16 09:34:56.139	error	(27210) npm
        An dem Request Fehler scheint Bluefox zu arbeiten wenn ich das Changelog richtig lese. Aber warum er bei Rechten 777 immer noch die Rechte beim xml2js-parser bemängelt ist mit schleierhaft.
        • ChaotC Chaot
          @Jan1
          @Chaot Plötzliche unerklärliche Probleme mit den Rechten können auf ein sterbendes Dateisystem hindeuten.
            ChaotC Offline
            ChaotC Offline
            Chaot
            @Thomas-Braun Auf der SSD am NUC? Am Raspi könnte ich mir das erklären.
            • ChaotC Chaot
              @Chaot Auch die können sterben. Ich habe ja auch nicht gesagt, dass es 100% so ist, sondern das weggebröselte Dateirechte ein Hinweis auf Probleme dort sein kann.
                ChaotC Offline
                ChaotC Offline
                Chaot
                @Thomas-Braun Stimmt schon, aber komischerweise sind ja mit dem 4.1.5 die Dateirechte in Ordnung. Also liegt es vermutlich am Update.
                • ChaotC Chaot
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  @Chaot
                  versuche mal ein update auf v4.6.7
                  ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                  • ? Offline
                    Fragt sich der problem geplagte User, woher die 4.6.7 ?
                    in den "Verwahrungs Orten" ist die nicht b.z.w. wird über diese nicht angezeigt.
                      @Blechsoldat
                      Geht im Moment nur über git (die 'Katze')
                      • E Offline
                        Einstein67
                        Mittels das Katzensysmbol von Git-Hub installieren!
                        ? 1 Antwort Letzte Antwort
                        • E Einstein67
                          @Einstein67
                          Danke Sehr
                          • J Offline
                            Jan1
                            st über den timeout und dem zugehörigen stop timeout schon was bekannt?
                            Bei mir hat eben ein Script Fehler geworfen und beim Überprüfen ist mir das aufgefallen:
                            Das lässt sich zwar ändern, wird aber nicht gespeichert. Das Problem wird auch erst aktiv, wenn man am Script was ändert, ansonsten läuft das so und bringt auch keine Fehler. Seit wann das so ist und ob es mit dem Update des Adapter zusammenhängt weiß ich nicht.
                            Edit:
                            da ist definitiv was faul, da sich der Adapter nicht downgraden lässt, läuf zwar durch, aber an der Version ändert sich nichts und seit wann heißt das eigentlich "Wartezeit"?
                            Hier mal das Lag beim Deinstallieren, sind einige seltsame Meldungen drin:
                            $ ./iobroker del javascript
                            Delete adapter "javascript"
                            host.Beelink Counted 1 instances of javascript
                            host.Beelink Counted 1 meta of javascript
                            host.Beelink Counted 1 adapter for javascript
                            host.Beelink Counted 107 states of javascript
                            host.Beelink Counted 15 states of system.adapter.javascript
                            host.Beelink Counted 1 objects of javascript
                            host.Beelink file javascript.admin deleted
                            host.Beelink object javascript.admin deletedhost.Beelink Deleting 126 object(s).
                            npm uninstall iobroker.javascript --error --prefix "/opt/iobroker" (System call)
                            npm
                             WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                            npm
                             WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):npm WARN
                            notsup
                             SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            npm WARN
                             optional
                             SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm
                             WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):npm WARN
                             notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN
                            optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            process exited with code 0
                            • BBTownB BBTown
                              @Chaot
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              @BBTown 4..6.7 ist jetzt drauf. Bisher keine Fehlermeldung erschienen und alles scheint zu laufen.
                              • ChaotC Chaot
                                Jan1
                                @Chaot
                                Schau Dir mal Deine Blockly Scripte an die timeouts drin haben, selbst mit der Github Version war das buggy
                                • E Offline
                                  Einstein67
                                  Hab bei meiner Heizungssteuerung einen "Pulsbetrieb" mit dem ich 1,2, oder 3 Stunden die Heizung aktivieren kann. Das ist alles über Timeouts gesteuert ... und hat gerade (Schei*** Eisheilige ;) ) mit 4.6.7 problemlos funktioniert.
                                  • E Einstein67
                                    Jan1
                                    @Einstein67
                                    Das läuft schon, nur ändere mal was im Blockly, dann wars das😁
                                    • J Jan1
                                      @Einstein67
                                      @Jan1 !
                                      Läuft .... 😁
                                        @Jan1 !
                                        Läuft .... 😁
                                        Jan1
                                        @Blechsoldat
                                        Der Screenshot sagt aber was anderes😆
                                        Mir ist es erst aufgefallen, als ich an einem Script was ergänzt hatte und plötzlich auch so schöne Meldungen im Log hatte. Wenn man nichts ändert, läuft das Script ohne Fehler.
                                        • crunchipC Offline
                                          crunchipC Offline
                                          Habe ich heute auch festgestellt mit dem timeout, bei Script Änderung.
                                          Und generell, habe ich Probleme mit dem Speichern/ Ändern/Bearbeiten der Scripte. Alles sehr träge. Wird nicht übernommen, muss mehrmals speichern bzw Änderungen wiederholen.
                                          Probleme macht überwiegend FireFox.
