  4. Script Engine Update nach 4.6.4
script engine
60 Beiträge 12 Kommentatoren 5.8k Aufrufe 13 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    #41
    Bei mir bleibt die Fehlermeldung:
    javascript.0	2020-05-18 08:33:23.122	error	(18887) Cannot install xml2js: 254
    javascript.0	2020-05-18 08:33:23.107	error	(18887) npm ERR! /home/iobroker/.npm/_logs/2020-05-18T06_33_23_092Z-debug.log
    javascript.0	2020-05-18 08:33:23.105	error	(18887) A complete log of this run can be found in:
    javascript.0	2020-05-18 08:33:23.104	error	(18887) ERR!
    javascript.0	2020-05-18 08:33:23.103	error	(18887)
    javascript.0	2020-05-18 08:33:23.101	error	(18887) npm
    javascript.0	2020-05-18 08:33:23.100	error	(18887)
    javascript.0	2020-05-18 08:33:23.089	error	npm ERR! enoent
    javascript.0	2020-05-18 08:33:23.089	error	npm ERR! enoent This is related to npm not being able to find a file.
    javascript.0	2020-05-18 08:33:23.089	error	(18887) enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match'
    javascript.0	2020-05-18 08:33:23.088	error	(18887) npm ERR!
    javascript.0	2020-05-18 08:33:23.086	error	npm ERR! errno -2
    javascript.0	2020-05-18 08:33:23.086	error	npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    javascript.0	2020-05-18 08:33:23.086	error	npm ERR! syscall access
    javascript.0	2020-05-18 08:33:23.086	error	(18887) ERR! code ENOENT
    javascript.0	2020-05-18 08:33:23.085	error	(18887) npm
    javascript.0	2020-05-18 08:33:22.965	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/open-fin-ts-js-client
    javascript.0	2020-05-18 08:33:22.965	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bunyan
    javascript.0	2020-05-18 08:33:22.965	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mv
    javascript.0	2020-05-18 08:33:22.965	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
    javascript.0	2020-05-18 08:33:22.965	error	(18887) Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
    javascript.0	2020-05-18 08:33:22.963	error	npm WARN checkPermissions
    javascript.0	2020-05-18 08:33:22.963	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
    javascript.0	2020-05-18 08:33:22.963	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
    javascript.0	2020-05-18 08:33:22.963	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
    javascript.0	2020-05-18 08:33:22.963	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-json-stringify
    javascript.0	2020-05-18 08:33:22.963	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
    javascript.0	2020-05-18 08:33:22.963	error	(18887) npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ncp
    javascript.0	2020-05-18 08:33:22.962	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/dtrace-provider
    javascript.0	2020-05-18 08:33:22.962	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
    javascript.0	2020-05-18 08:33:22.962	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mkdirp
    javascript.0	2020-05-18 08:33:22.962	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist
    javascript.0	2020-05-18 08:33:22.962	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
    javascript.0	2020-05-18 08:33:22.962	error	(18887) Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
    javascript.0	2020-05-18 08:33:22.961	error	npm WARN checkPermissions
    javascript.0	2020-05-18 08:33:22.961	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/encoding
    javascript.0	2020-05-18 08:33:22.961	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
    javascript.0	2020-05-18 08:33:22.961	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
    javascript.0	2020-05-18 08:33:22.961	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
    javascript.0	2020-05-18 08:33:22.961	error	(18887) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    javascript.0	2020-05-18 08:33:22.960	error	(18887) npm
    Bleibt auch bestehen wenn ich wieder auf die 4.5.1 zurück will.
    J 1 Antwort Letzte Antwort
    • ChaotC Chaot
      Jan1
      #42
      @Chaot sagte in Script Engine Update nach 4.6.4:
      Steht da sehr oft in Deinem Log. Den Fixer schon mal drüber laufen gelassen?
      • J Jan1
        ChaotC Offline
        ChaotC Offline
        Chaot
        schrieb am zuletzt editiert von Chaot
        #43
        @Jan1 Der fixer lief schon gefühlte 1000 mal.
        Ich habe jetzt das ganze Verzeichnis manuell auf 777 gesetzt und den Adapter nochmal versucht:
        avascript.1	2020-05-18 08:49:15.193	error	(7890) Cannot install open-fin-ts-js-client: 254
        javascript.1	2020-05-18 08:49:15.149	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-18T06_49_15_134Z-debug.log
        javascript.1	2020-05-18 08:49:15.149	error	(7890) ERR! A complete log of this run can be found in:
        javascript.1	2020-05-18 08:49:15.147	error	(7890) npm
        javascript.1	2020-05-18 08:49:15.146	error	(7890)
        javascript.1	2020-05-18 08:49:15.133	error	npm ERR! enoent
        javascript.1	2020-05-18 08:49:15.133	error	(7890) npm ERR! enoent This is related to npm not being able to find a file.
        javascript.1	2020-05-18 08:49:15.132	error	(7890) npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser'
        javascript.1	2020-05-18 08:49:15.130	error	npm ERR! errno -2
        javascript.1	2020-05-18 08:49:15.130	error	npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser
        javascript.1	2020-05-18 08:49:15.130	error	npm ERR! syscall access
        javascript.1	2020-05-18 08:49:15.130	error	(7890) code ENOENT
        javascript.1	2020-05-18 08:49:15.129	error	(7890) npm ERR!
        javascript.1	2020-05-18 08:49:15.001	error	(7890) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser
        javascript.1	2020-05-18 08:49:14.998	error	(7890) npm
        Wieviel Permissions weill er denn noch?
        Weitere Fehler:
        javascript.0	2020-05-18 08:49:34.655	error	npm WARN request-promise-core@1.1.3 requires a peer of request@^2.34 but none is installed. You must install peer dependencies yourself.
        javascript.0	2020-05-18 08:49:34.655	error	(7883) WARN request-promise-native@1.0.8 requires a peer of request@^2.34 but none is installed. You must install peer dependencies yourself.
        javascript.0	2020-05-18 08:49:34.653	error	(7883) npm
        und
        javascript.0	2020-05-18 08:49:18.854	error	(7883) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        javascript.0	2020-05-18 08:49:18.852	error	(7883) npm
        • ChaotC Chaot
          Weitere Fehler:
          und
          Jan1
          #44
          @Chaot
          Da hast Dir wohl irgend was anderes geschossen.
          Ich bin nicht der Linux Experte und bei so was immer schnell mit nem Backup zur Hand. Wenn nicht gerade am OS was verbogen ist, wird beim Rückspielen und vorheriger Neuinstallation des IObroker alles frisch installiert und der Fehler sollte auch weg sein.
          Funktioniert auf einen reinen IOBroker System immer perfekt.
          • J Jan1
            @Chaot
            ChaotC Offline
            ChaotC Offline
            Chaot
            #45
            @Jan1 Glaube ich nicht unbedingt.
            Mit den Permissions auf 777 kann ich ja auch ohne Fehlermeldung zurück auf 4.5.1. Erst wenn der Fixer drüber gelaufen ist kommen die Fehler.
            Mit Fixer kann ich mich unterhalb von der 4.5.1 frei bewegen. Also ich kann alles was unter 4.5.1 ist ohne Fehlermeldung installieren. Die Permissions Feher kommen erst wenn ich einmal irgendeine Version über 4.5.1 auf dem System hatte.
            • ChaotC Chaot
              Jan1
              #46
              @Chaot
              bei mir läuft die 4.6.11 ohne Fehler und klar, wenn der Fixer läuft, ist das 777 wieder weg, weil zu viel erlaubt ;-)
              • J Jan1
                @Chaot
                ChaotC Offline
                ChaotC Offline
                Chaot
                #47
                @Jan1 Stimmt schon. Aber bis zur 4.5.1 scheinen die Rechte ja zu passen. Erst ab da verlangt er plötzlich höhere Rechte die er nicht hat.
                • apollon77A Offline
                  #48
                  Für funktionale Themen und Feedback zur 4.6.11 bitte zu https://forum.iobroker.net/topic/33485/test-adapter-javascript-4-6-x wechseln :-)
                  • ChaotC Chaot
                    #49
                    @Chaot Wie sehen die Rechte denn aus, wenn der Fehler sich zeigt?
                    Bei mir so:
                    pi@raspberrypi:/opt/iobroker $ ls -la ./node_modules/iobroker.javascript/node_modules/
                    insgesamt 60
                    drwxr-xr-x+ 15 iobroker iobroker 4096 Mai 18 07:29 .
                    drwxr-xr-x+  6 iobroker iobroker 4096 Mai 18 07:29 ..
                    drwxrwxr-x+  2 iobroker iobroker 4096 Mai 17 18:51 .bin
                    drwxr-xr-x+  4 iobroker iobroker 4096 Mai 18 07:29 cron-parser
                    drwxr-xr-x+  3 iobroker iobroker 4096 Mai 18 07:29 define-properties
                    drwxrwxr-x+  3 iobroker iobroker 4096 Mai 16 02:16 @iobroker
                    drwxr-xr-x+  4 iobroker iobroker 4096 Mai 18 07:29 is-nan
                    drwxr-xr-x+  2 iobroker iobroker 4096 Mai 18 07:29 long-timeout
                    drwxr-xr-x+  7 iobroker iobroker 4096 Mai 18 07:29 moment
                    drwxr-xr-x+  4 iobroker iobroker 4096 Mai 18 07:29 moment-timezone
                    drwxrwxr-x+  4 iobroker iobroker 4096 Apr 12 13:04 node-schedule
                    drwxr-xr-x+  3 iobroker iobroker 4096 Mai 18 07:29 object-keys
                    drwxrwxr-x+  7 iobroker iobroker 4096 Apr 18 09:03 semver
                    drwxr-xr-x+  2 iobroker iobroker 4096 Mai 18 07:29 sorted-array-functions
                      Bei mir so:
                      insgesamt 60
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #50
                      @Thomas-Braun
                      Mir fällt nichts besonderes auf:
                      • ChaotC Chaot
                        @Thomas-Braun
                        #51
                        @Chaot
                        Mir fällt schon mal die root-shell auf.
                        Sicher, dass dein Dateisystem noch gesund ist?
                          @Chaot
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          #52
                          @Thomas-Braun root deshalb weil ich das in der Konsole im Proxmox Container habe. Das ist ganz normal. Da ist das mit Usern schwieriger zu handeln.
                          • ChaotC Chaot
                            #53
                            @Chaot Ich fahre zwar kein Proxmox, aber soweit ich weiß funktioniert das da auch nicht anders als in einer nativen Installation von Debian. Aber mach wie du meinst, wunder dich aber nicht über verschobene Rechte.
                            Docker ist wieder was anderes.
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              #54
                              @Thomas-Braun Muss ich jetzt nicht verstehen.
                              Die Problematik ist doch das bis zur Version 4.5.1 alles in Ordnung ist und sobald ich auf eine höhere Version gehen will die Rechteprobleme auftauchen. Der Fehler ist klar reproduzierbar und hat nach meiner Meinung mit root nichts zu tun.
                              Ich kann unterhalb von 4.1.5 jede beliebige Version installieren und es taucht eben kein Fehler auf.
                              Aktuell habe ich erneut das Update versucht und scheinbar das größtenteils erfolgreich absolviert.
                              Jetzt verbleibt nur noch eine Fehlermeldung:
                              javascript.0	2020-05-18 12:03:34.203	error	(28978) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              javascript.0	2020-05-18 12:03:34.199	error	(28978) npm
                              Die Rechteprobleme haben sich bisher nicht gezeigt.
                              • ChaotC Chaot
                                #55
                                @Chaot WARN != Error :-) It nur eine Info Meldung zu einem Paket was deprecated ist wir aber noch nutzen. Alles ok.
                                Am Ende ist es mega strange was da bei Dir passiert. Die 4.6.x ist genauso wie die 4.5.1 ein NPM Paket und npm behandelt alles an sich wie sonst auch ... also keine Idee von mir was da abgeht
                                  Steffl
                                  #56
                                  Etwas weiter oben in deinem Logfileauszug heißt es:
                                  Gibt es denn das xml2js-parser Verzeichnis überhaupt? Bei meiner Installation ist das nicht da.
                                  Kann es sein, dass da noch Reste eines alten Treibers rumspuken?
                                  • S Steffl
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #57
                                    @Steffl Das wäre noch eine Idee die eventuell zu meinem letzten Vorgehen passen könnte.
                                    Ich habe das jetzt ganz aufwändig geschafft:
                                    Rechte auf 777 und Version 4.5.1 installiert.
                                    Reboot
                                    iobroker gestoppt
                                    Fixer laufen lassen
                                    Reboot
                                    Update auf 4.6.11 laufen lassen
                                    und die Fehlemeldungen waren weg. Ich vermute/hoffe das es an den reboots gelegen hat.
                                    Was mir noch eingefallen ist, das ich nach dem ersten Updateversuch auf die 4.6.11 in den Adaptern die 4.6.4 als installiert angezeigt bekommen habe obwohl die Installation angeblich erfolgreich war.
                                    • NegaleinN Negalein
                                      habe auch bei Blockly ein Problem mit 4.6.7
                                      Das 18:00ist ein Phantom. Soll dort nicht sein, geht auch nicht zum löschen, hat aber zumindest keine Funktion.
                                      Blockly funktioniert trotz dem Phantom.
                                      Mit 4.6.9 aus Git besteht das Phänomen noch immer.
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #58
                                      @Negalein sagte in Script Engine Update nach 4.6.4:
                                      mit 4.6.17 besteht das Problem wieder.
                                      wird in einem bestehenden Blockly der Zeit-Block kopiert, ist im kopierten Block wieder das Phantom.
                                      ° Fixer ---> iob fix
                                        #59
                                        @Negalein sagte:
                                        Das ist aber nur temporär: Beim Wechsel in die Javascript-Ansicht und zurück verschwindet das Phantom.
                                          @Negalein sagte:
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #60
                                          @paul53 sagte in Script Engine Update nach 4.6.4:
                                          Danke, funktioniert 😊
