Test Adapter Midea Geräten v1.x.x
hallo, ich versuche den Midea-Adapter zu installieren. Bekomme dann die Meldung, das ich Python 3.8 installieren soll. Wie installiert mal Python, und vor allem wo. Ich ahbe schon ein paar Versuche hinter mit und bekomme es nicht hin.
$ iobroker url TA2k/ioBroker.midea --host raspberry --debug install TA2k/ioBroker.midea NPM version: 10.9.7 Installing TA2k/ioBroker.midea... (System call) npm error code 1 npm error git dep preparation failed npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > esbuild@0.11.23 postinstallnpm error > node install.jsnpm errornpm errornpm error > iobroker.midea@0.1.0 postinstallnpm error > node ./pythonPackages.jsnpm errornpm errornpm error Start Python package installationnpm errornpm error Python 3 not found. Please install minimum python 3.8npm error npm warn using --force Recommended protections disabled.npm error npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array insteadnpm error npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema insteadnpm error npm warn deprecated glob@10.5.0: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.menpm error npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.npm error /bin/sh: 1: python3: not foundnpm error npm error code 1npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-clonei3tMNdnpm error npm error command failednpm error npm error command sh -c node ./pythonPackages.jsnpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-18T18_18_38_166Z-debug-0.log host.raspberry Cannot install TA2k/ioBroker.midea: 1 ERROR: Process exited with code 25MOD-EDIT: Code in code-tags gesetzt!
@Holger-Etzel das mit dem python wird aber nicht richtig funktionieren.. ich werde es wohl nochmal umschreiben aber brauch jemand zum testen via email tombox2020@gmail.com
Ja, ändere es dahingehend, das es richtig in einem ENV läuft.
Die obige Installation musste ich etwas dreckig machen... -
lässt sich Debian leichter bedienen als Ubuntu, oder warum schwört jeder auf Debian. Sorry für meine blöde Frage, ich kenne es halt nicht
@Holger-Etzel ist jetzt alles wieder native nodejs.. bitte mal testen
@Holger-Etzel als Otto-Normal-Benutzer der Server-Version ohne GUI, also maximal in der Bash unterwegs wirst du Unterschiede mit der Lupe suchen müssen.
Debian besteht komplett aus freier Software, also ohne proprietäre Treiber oder Programme wie z.B. Grafikkartentreiber.
Ubuntu integriert bei Bedarf eben diese Treiber und Programme wenn diese benötigt werden.Bedienen lässt sich beides gleich. Wenn ich für etwas keine Anleitung für Ubuntu finde, nehme ich eben die von Debian.
Ubuntu basiert auf Debian, hat aber z.B. seine eigenen Kernel.
Die Wahrheit liegt wie immer in der Mitte - Proxmox basiert z.B. Debian, nutzt aber den Ubuntu-Kernel.Im Gewerblichen Umfeld interessant: Bei Ubuntu kann man direkt bei Canonical (der Firma dahinter) Support einkaufen, bei Debian gibt es so etwas nicht direkt. Weshalb es innerhalb von Appliances steckt, z.B. in Everpure-Storagesystemen (ehemals Pure Storage)
Ein Unterschied bei den Nutzern von Ubuntu ist, das diese sich nicht negativ über Debian äußern, Debianer aber gerne über Ubuntu herziehen weil es ja nur abgeleitet ist und nicht das Original ist.
Wie auch über die 51 anderen bekannten Linux-Distributionen die auf Debian basieren: https://de.wikipedia.org/wiki/Kategorie:Debian-basierte_Linux-DistributionAlso: Kein Problem, nimm was du meinst, du wirst zurecht kommen.
Nein, nicht weil es auf Debian basiert kritisiere ich Ubuntu, sondern wegen deren mehr als seltsamen Entscheidungen und ihrem komischen Sonderstrick (z. B. snap) in der Vergangnenheit, der dann meist auch nach relativ kurzer Zeit wieder eingestellt wurde.
Das stimmt so auch nicht. Frag mal die Leute von
https://libre.debian.net/ -
@BananaJoe Der Adapter wurde komplett neu geschrieben bitte testen ob er noch funktioniert
@tombox Anmeldung klappt nicht.
Ich nutze dieNetHome PlusApp, Passwort ist richtig! Gerade mit der App kontrolliert und im Adapter neu gesetzt:2026-05-19 11:53:41.900 - info: host.iobroker instance system.adapter.midea.0 in version "1.3.0" (non-npm: TA2k/ioBroker.midea) started with pid 29112 2026-05-19 11:53:42.930 - info: midea.0 (29112) starting. Version 1.3.0 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2 2026-05-19 11:53:47.981 - info: midea.0 (29112) LAN discovery found 2 appliance(s) 2026-05-19 11:53:48.468 - warn: midea.0 (29112) Could not fetch token/key for 145135534971917: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong. 2026-05-19 11:53:48.888 - warn: midea.0 (29112) Could not fetch token/key for 144036023343615: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong. 2026-05-19 11:53:49.195 - warn: midea.0 (29112) Cloud listAppliances failed: CloudClient: Account or password incorrect, please re-enter (code=3102)Hier als Debug:
2026-05-19 11:58:12.264 - info: host.iobroker "system.adapter.midea.0" enabled 2026-05-19 11:58:13.059 - info: host.iobroker instance system.adapter.midea.0 in version "1.3.0" (non-npm: TA2k/ioBroker.midea) started with pid 30124 2026-05-19 11:58:13.620 - debug: midea.0 (30124) Redis Objects: Use Redis connection: 0.0.0.0:9001 2026-05-19 11:58:14.645 - debug: midea.0 (30124) Objects client ready ... initialize now 2026-05-19 11:58:14.647 - debug: midea.0 (30124) Objects create System PubSub Client 2026-05-19 11:58:14.647 - debug: midea.0 (30124) Objects create User PubSub Client 2026-05-19 11:58:14.811 - debug: midea.0 (30124) Objects client initialize lua scripts 2026-05-19 11:58:14.820 - debug: midea.0 (30124) Objects connected to redis: 0.0.0.0:9001 2026-05-19 11:58:14.902 - debug: midea.0 (30124) Redis States: Use Redis connection: 127.0.0.1:6379 2026-05-19 11:58:14.910 - debug: midea.0 (30124) States create System PubSub Client 2026-05-19 11:58:14.911 - debug: midea.0 (30124) States create User PubSub Client 2026-05-19 11:58:14.915 - debug: midea.0 (30124) States connected to redis: 127.0.0.1:6379 2026-05-19 11:58:15.397 - info: midea.0 (30124) starting. Version 1.3.0 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2 2026-05-19 11:58:15.414 - debug: midea.0 (30124) Schedule restart: 1 4,13 * * * 2026-05-19 11:58:16.461 - debug: midea.0 (30124) Midea adapter starting up, poll interval=30 s 2026-05-19 11:58:16.462 - debug: midea.0 (30124) discover: starting UDP broadcast target=255.255.255.255 timeoutMs=5000 2026-05-19 11:58:16.543 - debug: midea.0 (30124) discover: 192.168.1.30 -> id=145135534971917 type=0xac (ac) v3=true 2026-05-19 11:58:16.551 - debug: midea.0 (30124) discover: 192.168.1.29 -> id=144036023343615 type=0xac (ac) v3=true 2026-05-19 11:58:21.463 - debug: midea.0 (30124) discover: finished, 2 appliance(s) 2026-05-19 11:58:21.464 - info: midea.0 (30124) LAN discovery found 2 appliance(s) 2026-05-19 11:58:21.564 - debug: midea.0 (30124) CloudClient: POST /v1/user/login/id/get bodyLen=205 hasToken=false 2026-05-19 11:58:22.260 - debug: midea.0 (30124) CloudClient: /v1/user/login/id/get reply code=3102 msg=Account or password incorrect, please re-enter 2026-05-19 11:58:22.260 - warn: midea.0 (30124) Could not fetch token/key for 145135534971917: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong. 2026-05-19 11:58:22.367 - debug: midea.0 (30124) CloudClient: POST /v1/user/login/id/get bodyLen=205 hasToken=false 2026-05-19 11:58:22.684 - debug: midea.0 (30124) CloudClient: /v1/user/login/id/get reply code=3102 msg=Account or password incorrect, please re-enter 2026-05-19 11:58:22.684 - warn: midea.0 (30124) Could not fetch token/key for 144036023343615: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong. 2026-05-19 11:58:22.684 - debug: midea.0 (30124) CloudClient: POST /v1/user/login/id/get bodyLen=205 hasToken=false 2026-05-19 11:58:22.993 - debug: midea.0 (30124) CloudClient: /v1/user/login/id/get reply code=3102 msg=Account or password incorrect, please re-enter 2026-05-19 11:58:22.993 - warn: midea.0 (30124) Cloud listAppliances failed: CloudClient: Account or password incorrect, please re-enter (code=3102)Die alte Version 0.0.7 konnte zwar nicht schalten, aber die Werte abfragen
Edit: Passende Tokens für die Geräte für den lokalen Zugriff hätte ich sogar, kann man die manuell setzen?
Und im Objekte-Baum habe ich die Anlagen jetzt 2x:
Die unteren unterhalb von
devicessind von der neuen Version? Das es Klimaanlagen sind, wurde ja scheinbar schon erkannt
