  4. js-controller 3.0/3.1 jetzt im Latest!
    1.0k
    6.1k
js-controller
1.3k Beiträge 127 Kommentatoren 593.2k Aufrufe 89 Beobachtet
    amsernat
    #621
    Frage von Noob:
    nach js-controller update funkt backitup nicht mehr.
    kann mir bitte jemand sagen was hier schief gelaufen ist?
    Danke im Voraus.
    host.raspberrypi	2020-05-01 12:56:19.026	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    host.raspberrypi	2020-05-01 12:56:07.650	info	Restart adapter system.adapter.backitup.0 because enabled
    host.raspberrypi	2020-05-01 12:56:07.649	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-05-01 12:56:07.649	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:840:9
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at detectLatestBackupFile (/opt/iobroker/node_modules/iobroker.backitup/main.js:699:33)
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at Array.map (<anonymous>)
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:699:48
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at new Promise (<anonymous>)
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:700:13
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at module.exports (/opt/iobroker/node_modules/iobroker.backitup/lib/list.js:72:36)
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at Object.list (/opt/iobroker/node_modules/iobroker.backitup/lib/list/googledrive.js:6:24)
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31)
    host.raspberrypi	2020-05-01 12:56:07.646	error	Caught by controller[1]: at JSON.parse (<anonymous>)
    host.raspberrypi	2020-05-01 12:56:07.646	error	Caught by controller[1]: SyntaxError: Unexpected token ' in JSON at position 1
    host.raspberrypi	2020-05-01 12:56:07.645	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    backitup.0	2020-05-01 12:56:07.108	info	(20766) Terminated (NO_ERROR): Without reason
    backitup.0	2020-05-01 12:56:07.106	info	(20766) terminating
    backitup.0	2020-05-01 12:56:07.057	info	(20766) cleaned everything up...
    backitup.0	2020-05-01 12:56:07.055	error	(20766) SyntaxError: Unexpected token ' in JSON at position 1 at JSON.parse (<anonymous>) at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31) at O
    backitup.0	2020-05-01 12:56:07.049	error	(20766) uncaught exception: Unexpected token ' in JSON at position 1
    backitup.0	2020-05-01 12:56:06.962	info	(20766) [iobroker] backup was activated at 02:00 every 3 day(s)
    backitup.0	2020-05-01 12:56:06.903	info	(20766) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.16.3, js-controller: 3.0.20
    host.raspberrypi	2020-05-01 12:56:02.989	info	instance system.adapter.backitup.0 started with pid 20766
    pi@raspberrypi:~ $ node -v
    v12.16.3
    pi@raspberrypi:~ $ iobroker status
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $ npm -v
    6.14.4
    RAM
    3.81 GB
    System Betriebszeit
    14 T. 01:25:12
    Festplatte Größe
    28.98 GB
    Festplatte frei
    22.98 GB
    Anzahl der Adapter
    346
    Betriebszeit
    13:25:16
    Aktive Instanzen
    21
    raspberrypi
    Typ: js-controller
    Titel: JS controller
    OS: linux
    Verfügbar: 3.0.20
    Installiert: 3.0.20
    Ereignisse: ⇥26 / ↦15
      Marty56
      #622
      Habe die Version 3.0.20 installiert. Soweit keine Probleme. Gut Arbeit.
      Im Log File habe jetzt ein paar Warnings, z. B.
      readFile 2020-05-01 14:05:43.635 warn will not read this file (devices/cpu.png) in future versions: icons-open-icon-library-png is not an object of type "meta"
      Es handelt sich da wohl um eigene Icons, die ich in VIS verwende.
      Bei dem Update vom VIS Module gab es auch mal eine Memory Warnung, aber nach Abschuss der Installation war wieder ausreichend Memory frei.
      Bei Zigbee Adapter gab es die Warnung
      zigbee.0 2020-05-01 14:05:07.228 warn (COMPACT) no connection to objects DB
      Er scheint aber zu laufen.
      Ich habe auch versucht auf die neueste Version (4.5.1) der Script Engine upzudaten, aber die Installation scheint nicht zu funktionieren und es wird immer noch 4.4.3 angezeigt.
      2020-05-01 14:18:19.059 - info: host.ioBroker-RasPi4 iobroker Update javascript from @4.4.3 to @4.5.1
      2020-05-01 14:18:21.640 - info: host.ioBroker-RasPi4 iobroker NPM version: 6.11.3
      2020-05-01 14:18:21.646 - info: host.ioBroker-RasPi4 iobroker npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
      2020-05-01 14:19:25.371 - info: host.ioBroker-RasPi4 iobroker npm
      2020-05-01 14:19:25.377 - info: host.ioBroker-RasPi4 iobroker ERR! code ENOTSUPnpm ERR! notsup
      2020-05-01 14:19:25.383 - info: host.ioBroker-RasPi4 iobroker Unsupported engine for puppeteer@3.0.2: wanted: {"node":">=10.18.1"} (current: {"node":"10.17.0","npm":"6.11.3"})npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Required: {"node":">=10.18.1"}npm ERR! notsup Actual: {"npm":"6.11.3","node":"10.17.0"}
      2020-05-01 14:19:25.473 - info: host.ioBroker-RasPi4 iobroker
      2020-05-01 14:19:25.478 - info: host.ioBroker-RasPi4 iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-01T12_19_25_434Z-debug.log
      2020-05-01 14:19:25.985 - info: host.ioBroker-RasPi4 iobroker Update "system.adapter.javascript.0"
      2020-05-01 14:19:26.178 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 (force=false, process=true)
      2020-05-01 14:19:26.197 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 send kill signal
      2020-05-01 14:19:26.197 - info: javascript.0 (3513) Got terminate signal TERMINATE_YOURSELF
      2020-05-01 14:19:26.208 - info: javascript.0 (3513) Stop script script.js.common.Heizung
      2020-05-01 14:19:26.215 - info: javascript.0 (3513) Stop script script.js.common.Jalousien
      2020-05-01 14:19:26.220 - info: javascript.0 (3513) Stop script script.js.common.Licht_und_Schalter
      2020-05-01 14:19:26.224 - info: javascript.0 (3513) Stop script script.js.common.Sicherheit
      2020-05-01 14:19:26.228 - info: javascript.0 (3513) Stop script script.js.common.Sound
      2020-05-01 14:19:26.231 - info: javascript.0 (3513) Stop script script.js.common.Systeminfo
      2020-05-01 14:19:26.235 - info: javascript.0 (3513) Stop script script.js.common.Waschen
      2020-05-01 14:19:26.237 - info: javascript.0 (3513) Stop script script.js.common.Tagescharakteristik
      2020-05-01 14:19:26.240 - info: javascript.0 (3513) Stop script script.js.common.Email_und_Telegram_über_IFTTT_senden
      2020-05-01 14:19:26.243 - info: javascript.0 (3513) Stop script script.js.common.Batteriezustände_und_Fensteröffnungen
      2020-05-01 14:19:26.248 - info: javascript.0 (3513) Stop script script.js.common.Feuchte_und_Belüftung
      2020-05-01 14:19:26.251 - info: javascript.0 (3513) Stop script script.js.common.Telefonanrufe_verarbeiten
      2020-05-01 14:19:26.253 - info: javascript.0 (3513) Stop script script.js.common.Presence
      2020-05-01 14:19:26.256 - info: javascript.0 (3513) Stop script script.js.common.Wetter_und_Bewässerung_mit_Promisses
      2020-05-01 14:19:26.260 - info: javascript.0 (3513) terminating
      2020-05-01 14:19:26.263 - info: javascript.0 (3513) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-05-01 14:19:26.875 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-05-01 14:19:29.332 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 started with pid 3893
      Edit: code tags
      HW:NUC (16 GB Ram)
      OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
      Thomas BraunT BBTownB apollon77A 4 Antworten Letzte Antwort
      • M Marty56
        Edit: code tags
        #623
        @Marty56 Dein node ist zu alt. Auf eine aktuelle 10er bringen, ich würde aber direkt auf node 12 springen.
        • M Marty56
          Edit: code tags
          BBTownB Offline
          BBTownB Offline
          BBTown
          #624
          @Marty56
          mal etwas OT ... Du hast bereits 700 post hier, und packst dennoch die LOGs nicht in code-Tags, das kann ich nicht nachvollziehen ... es gibt so viele User die von unterwegs mobil hier reinschauen und versuchen zu unterstützen, für die ist so eine Antwort einfach schei...
          J apollon77A 2 Antworten Letzte Antwort
          • BBTownB BBTown
            @Marty56
            Jan1
            #625
            @BBTown
            Und er schafft es auch nicht den ersten Post zu lesen, in dem sehr deutlich steht, dass mindestens Node 10 vorausgesetzt wird.
            • J Jan1
              @BBTown
              #626
              @Jan1 said in js-controller 3.0 jetzt im Latest!:
              @BBTown
              node10 hat er ja, allerdings ist die minor version auch zu alt:
              "node":"10.17.0
                @BBTown
                "node":"10.17.0
                Jan1
                #627
                @Thomas-Braun
                Die wird doch mit nem System Update hochgezogen und das sollte wohl auch ab und an gemacht werden.
                • O oFbEQnpoLKKl6mbY5e13
                  @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                  @oFbEQnpoLKKl6mbY5e13 Leg es bitte an bzw reopen wenn falsch geschlossen. Kriegen wir alles irgendwie hin
                  Der Fehler ist nicht mehr aufgetaucht, sodass ich jetzt erst mal abwarte.
                  Allerdings melden beim Start meines Containers verschiedene Adapter und nicht immer dieselben:
                  warn (329) no connection to objects DB
                  #628
                  @oFbEQnpoLKKl6mbY5e13 der fehler passiert wenn ein Adapter zu lange braucht um die Verbindung mit der iobroker dB zu bekommen. Kann es sein das in den Situationen recht viel Last auf der Liste herrschen? Wie geht es den Prozessen/cpu/RAM ...?
                  O 1 Antwort Letzte Antwort
                  • A amsernat
                    Frage von Noob:
                    Danke im Voraus.
                    v12.16.3
                    Objects type: file
                    States  type: file
                    6.14.4
                    RAM
                    3.81 GB
                    System Betriebszeit
                    14 T. 01:25:12
                    Festplatte Größe
                    28.98 GB
                    Festplatte frei
                    22.98 GB
                    Anzahl der Adapter
                    346
                    Betriebszeit
                    13:25:16
                    Aktive Instanzen
                    21
                    raspberrypi
                    Typ: js-controller
                    OS: linux
                    Verfügbar: 3.0.20
                    Installiert: 3.0.20
                    #629
                    @amsernat irgend ein json file ist kaputt. Speicher mal die konfig neu. Hat nix mit Controller zu tun. Bitte in einem der backitup threads fragen Oder-Neiße-Linie anlegen.
                    • apollon77A apollon77
                      O Abwesend
                      O Abwesend
                      #630
                      @apollon77
                      Heute macht mein NAS ein RAID-Scrubbing, da ist es ziemlich träge. Das dauert auch fast den ganzen Tag. Ich beobachte das.
                      • M Marty56
                        Edit: code tags
                        #631
                        @Marty56 zu dem Icon Thema. Eigene icons in eigenen Verzeichnissen sind schon seit controller 2.2 „böse“. Bitte sauber aufsetzen oder in einen Ordner bewegen wo sie erlaubt sind.
                          @BBTown
                          "node":"10.17.0
                          #632
                          @Thomas-Braun exakr. Formal muss der js Adapter das korrekt angeben. Legt bitte jemand ein issue dort an?
                            @apollon77
                            #633
                            @oFbEQnpoLKKl6mbY5e13 das wär eine Vermutung weil damit i/o Träger ist.
                            • BBTownB BBTown
                              @Marty56
                              #634
                              @BBTown ich hab’s mal gefixt.
                              • J Jan1
                                @Thomas-Braun
                                #635
                                Aber auch nur, wenn man ein Repo für node hat und halt auch das Gesamtsystem ab und an frisch hält. Ich würde das wenigstens so einmal im Monat machen.
                                J 1 Antwort Letzte Antwort
                                  Jan1
                                  #636
                                  @Thomas-Braun
                                  Auf dem Pi und jetzt mit Debian auf dem Beelink war das auf alle Fälle immer so :-)
                                  • padrinoP Online
                                    padrinoP Online
                                    padrino
                                    #637
                                    So, jetzt wage ich mich an den Kram und was ist?
                                    Ich krieg es ja nicht mal hin NodeJS auf V12 upzudaten. :( (wie man es macht, steht wohl nirgends, nur dass man muss?)
                                    Ich weiß schon, wieso ich die ganze Zeit bei V1 geblieben bin... das lief wenigstens. 😢
                                    • padrinoP padrino
                                      BBTownB Offline
                                      BBTownB Offline
                                      BBTown
                                      #638
                                      @padrino
                                      ernsthaft, jetzt???????????????
                                      • BBTownB BBTown
                                        @padrino
                                        Jan1
                                        #639
                                        @BBTown
                                        Das blinkt nicht, deshalb wir es gerne übersehen ;-)
                                        padrinoP M 2 Antworten Letzte Antwort
                                        • J Jan1
                                          @BBTown
                                          padrinoP Online
                                          padrinoP Online
                                          padrino
                                          #640
                                          @BBTown
                                          Geh Dir mal 'n Bier holen, das beruhigt. :)
                                          @Jan1
                                          Vermutlich. ;)
                                          Aber da ich fast nur mobil hier unterwegs bin, muss ich sagen, so weit runter scroll ich eigentlich nie. 😌
                                          J BBTownB 2 Antworten Letzte Antwort
