  4. Beta Test js-controller 3.0.x auf GitHub
    6.0k
js-controller
416 Beiträge 39 Kommentatoren 100.5k Aufrufe 38 Beobachtet
  • J Jan1
    @apollon77
    Sollte da nach dem Update nicht 3.1.0 stehen?
    jan@Beelink:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller
    [sudo] Passwort für jan:
    > iobroker.js-controller@3.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.4
    > iobroker.js-controller@3.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object system.certificates updated
    The following notifications happened during sync:
    - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@3.0.21
    updated 4 packages in 183.579s
    44 packages are looking for funding
      run `npm fund` for details
    #361
    @Jan1 Wir sind doch hier im Beta Test GitHub Thread ... da steht es erst wenn ich heute Abend das ins Latest gepusht habe
    • apollon77A apollon77
      Halli Hallo an alle Euch fleissigen und treuen Tester,
      das Wetter ist ja heute eh komisch, dann habt Ihr vllt spontan Zeit die 3.1. des js-controller mla kurz anzuschauen :-)
      Es kam noch ein Feature dazu und daher haben wir (auch weil wir schon bei 3.0.20 waren) für als Vorbereitung für den Stable Release das ganze 3.1 zu nennen :-)
      Wir haben nach dem Release der 3.0.20 jetzt gesammelt und alles für den finalen Release finalisiert und auch Sentry hat die letzten paar Tage keine weiteren Meldungen mehr geschickt :-)
      Changelog:
      3.1.0 (2020-05-09) Release Elena
      • (foxriver76) catch error on alias ids with empty objects
      • (Apollon77) make sure promise rejections without error are not crashing the controller
      • (bluefox) Add Controller messages to allow read and write controller base settings (iobroker.json); introduce adapter feature flag CONTROLLER_READWRITE_BASE_SETTINGS
      • (Apollon77) handle edge case where hostName is not a string when sending messages (Sentry IOBROKER-ADMIN-B)
      • (Apollon77) handle case where letsencrypt directory can not be created (Sentry IOBROKER-ADMIN-C/IOBROKER-WEB-B)
      • (bluefox) add IDs to some log messages
      • (foxriver76) fix some logging in objects lib
      • (Apollon77) make sure to catch error when reading log directory (Sentry IOBROKER-JS-CONTROLLER-1F)
      • (foxriver76) Make decrypt and encrypt methods available in adapter object for developers. System secret is read automatically soonly the value is passed to the function
      • (AlCalzone) Add adapter exit code 13 (ADAPTER_REQUESTED_REBUILD) to also allow to tell js-controller to rebuild this adapter.
      • (Apollon77) change logging for invalid readFile actions to debug because ca be triggered also by other cases then planned ones. Update objects lib
      • (Apollon77) make sure command on cmdExec is a string (Sentry IOBROKER-JS-CONTROLLER-1H)
      • (Apollon77) Check more cases for existence of variables before accessing them (Sentry IOBROKER-JS-CONTROLLER-E)
      • (Apollon77) Add a node.js version check and output special error message if node.js version is not satisfied
      • (AlCalzone) Add missing parameter digest to crypto calls
      • (AlCalzone) further code optimizatons
      • (AlCalzone) Allow reverse lookup of exit codes (exit code -> error name)
      • (Apollon77) make sure Objects/States backup files are deleted correctly according to backup settings
      • (foxriver76) Make sure default state value is only set if state is not existing also in setObject
      • (foxriver76) check that alias is of type state when adding subscribing pattern
      • (Apollon77) Make sure error are checked correctly (Sentry IOBROKER-JS-CONTROLLER-1N)
      • (Apollon77) Inform about sentry activation if not configured on "iobroker setup first"
      • (bluefox) implement maintenance mode for adapter methods
      • (bluefox) store for binary states the binary flag in objects
      • (Apollon77) update Plugin system
      • (Apollon77) update Sentry plugin to respect all options to disable reporting including new disableDataReporting flag ( will be integrated into Admin later)
      • (AlCalzone) Add Plugin CLI commands to enable/disable plugins
      Es gelten die ganz Normalen "Installation vom GitHub Anweisungen aus dem ersten Post. Wenn Ihr nichts findet dann geht das heute Abend offiziell ins Latest Repository und in ein paar Tagen ins Stable.
      Danke im Voraus für Eure Unterstützung.
      Ingo
      Jan1
      #362
      @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
      Hatte mich darauf bezogen und gedacht es wäre nun schon als npm verfügbar ;-)
      • E Offline
        Einstein67
        #363
        Aha OK! Die 3.0.21 läuft bisher ohne Probleme!
        • J Jan1
          @apollon77
          NPM version: 6.14.4
          #364
          @Jan1 Aahhh jetzt sehe ich was DU meinst ... warte mal ... mach nochmal das install ... die 3.0.21 war so "Intermediate". irgendwe at Du scheinbar nicht das allerneueste bekommen ... vllt warst Du zu schnell :-)
          J 1 Antwort Letzte Antwort
          • apollon77A Offline
            #365
            aahhhh mist ... my fault ... WARTEN BITTE!!
              Jan1
              #366
              @apollon77
              Ok, ich warte mal 5 Minuten und versuche es noch mal :-)
                #367
                Ja bitte alle die eine 3.0.21 bekommen haben, nochmal update ... die letzten Dinge waren in nem Branch gelandet :-) Jetzt ist GitHub aktuell!
                  Changelog:
                  Ingo
                  #368
                  @apollon77
                  pi@raspberrypi:~ $ iobroker version
                  3.0.21
                  pi@raspberrypi:~ $ nodejs -v
                  v14.2.0
                  Der amazon2-Adapter klemmt:
                  2020-05-09 13:47:46.526  - info: host.raspberrypi "system.adapter.alexa2.0" enabled
                  2020-05-09 13:47:46.599  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 10253
                  2020-05-09 13:47:49.033  - info: alexa2.0 (10253) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.2.0, js-controller: 3.0.21
                  2020-05-09 13:47:49.250  - info: alexa2.0 (10253) Proxy IP not set, use first network interface (192.168.178.50) instead
                  2020-05-09 13:47:50.092  - warn: alexa2.0 (10253) Exception: TypeError: Cannot read property 'end' of null
                  2020-05-09 13:47:50.095  - error: alexa2.0 (10253) uncaught exception: Cannot read property 'end' of null
                  2020-05-09 13:47:50.097  - error: alexa2.0 (10253) TypeError: Cannot read property 'end' of null
                      at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36)
                      at IncomingMessage.emit (events.js:327:22)
                      at IncomingMessage.EventEmitter.emit (domain.js:485:12)
                      at endReadableNT (_stream_readable.js:1225:12)
                      at processTicksAndRejections (internal/process/task_queues.js:84:21)
                  2020-05-09 13:47:50.142  - info: alexa2.0 (10253) terminating
                  2020-05-09 13:47:50.146  - info: alexa2.0 (10253) Terminated (NO_ERROR): Without reason
                  2020-05-09 13:47:50.648  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'end' of null
                  2020-05-09 13:47:50.649  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36)
                  2020-05-09 13:47:50.649  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.emit (events.js:327:22)
                  2020-05-09 13:47:50.649  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.EventEmitter.emit (domain.js:485:12)
                  2020-05-09 13:47:50.650  - error: host.raspberrypi Caught by controller[0]:     at endReadableNT (_stream_readable.js:1225:12)
                  2020-05-09 13:47:50.650  - error: host.raspberrypi Caught by controller[0]:     at processTicksAndRejections (internal/process/task_queues.js:84:21)
                  2020-05-09 13:47:50.651  - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    @apollon77
                    3.0.21
                    v14.2.0
                    #369
                    @Thomas-Braun Alexa 2 liegt an nodejs 14 ... Du bist sehr experimentell unterwegs :-) Da ist was inkompatibel, kommt mit als nächstes. Aber nix mit controller zu tun
                      #370
                      @apollon77 Das weiß ich. Deswegen hatte ich die node-Version extra bekannt gegeben. Ich schnall mal flugs node 12 drauf...
                      Im Admin wird
                      Verfügbar: 3.0.20
                      Installiert: 3.0.21
                      vermeldet.
                        Im Admin wird
                        Verfügbar: 3.0.20
                        Installiert: 3.0.21
                        vermeldet.
                        Jan1
                        #371
                        @Thomas-Braun
                        Machs noch mal, jetzt ist 3.1 online ;-)
                          #372
                          Wie gesagt wer eine 3.0.21 bekommen hat bitte nochmal installieren, dann sollte eine 3.1.0 kommen
                          J Thomas BraunT 3 Antworten Letzte Antwort
                            Jan1
                            #373
                            @apollon77
                            IOBroker Start ohne Fehler im Log mit 3.1.0 👍
                            • G Offline
                              guergen
                              #374
                              Der unifi-Adapter kommt mit folgendem Fehler im Log:
                              unifi.0	2020-05-09 14:11:56.948	error	(3567) Error: api.err.Invalid
                              unifi.0	2020-05-09 14:11:56.037	debug	(3567) Update started
                              unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted WLANs: []
                              unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted networks: []
                              unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted health: []
                              unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted devices: []
                              unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted clients: []
                              unifi.0	2020-05-09 14:11:56.035	debug	(3567) updateInterval = 60
                              unifi.0	2020-05-09 14:11:56.035	debug	(3567) controller = 192.168.1.208:8443
                              unifi.0	2020-05-09 14:11:56.032	info	(3567) Unifi adapter is ready
                              unifi.0	2020-05-09 14:11:56.018	info	(3567) starting. Version 0.5.0-beta.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.16.3, js-controller: 3.1.0
                              unifi.0	2020-05-09 14:11:55.956	debug	(3567) Plugin sentry Initialize Plugin (enabled=true)
                              apollon77A 3 Antworten Letzte Antwort
                                #375
                                @apollon77
                                3.1.0
                                v12.16.3
                                alexa2:
                                Alexa startet jetzt.
                                tado:
                                Klemmt im Moment, da werde ich aber immer von deren Servern abgewiesen. Hatte das aber schon mit vorherigen Softwareständen. Hat wohl nicht mit dem controller zu tun.
                                ble:
                                Bei 'ble' musste ich die capabilities wieder manuell setzen. Wie immer bei node-Wechseln.
                                Ansonsten so auf den ersten Blick alles i.O. , das logfile bleibt auch ruhig.
                                  #376
                                  @apollon77
                                  2020-05-09 14:03:58.851  - warn: iot.0 (12964) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                  was compiled against a different Node.js version using
                                  NODE_MODULE_VERSION 83. This version of Node.js requires
                                  NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                  the module (for instance, using `npm rebuild` or `npm install`).
                                  canvas hatte ich mal selber gebaut. Das versuche ich jetzt mit einem rebuild gerade zu zupfen.
                                  Sonst keine Auffälligkeiten im log.
                                  • G guergen
                                    #377
                                    @guergen Adapterproblem bitte beim Adapte rmelden. Keine Ahnung wie das am controller liegen könnte
                                    G 1 Antwort Letzte Antwort
                                      @apollon77
                                      3.1.0
                                      v12.16.3
                                      alexa2:
                                      tado:
                                      ble:
                                      #378
                                      @Thomas-Braun sagte in Beta Test js-controller 3.0.x auf GitHub:
                                      "iobroker fix" nach einem nodejs update is your friend
                                        @apollon77
                                        #379
                                        @Thomas-Braun Jupp liegt an deinem "Nodejs Downgrade". Sag mal ob die rebuild Kommandos getan haben
                                          guergen
                                          #380
                                          @apollon77 ICH habe doch keine Ahnung, an was das liegt... lief nur vorher. Die 0.4.3 startet auch nicht durch....
