  4. ioBroker nicht mehr erreichbar
iobroker nicht erreichbar
86 Beiträge 6 Kommentatoren 12.0k Aufrufe 4 Beobachtet
  • Pedder007P Online
    Pedder007P Online
    Pedder007
    #41
    Hmhm, im Logfile wiederholt sich immer wieder der folgende Eintrag. Das heißt bestimmt nichts Gutes ..
    2020-04-23 22:07:57.071  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/ioredis/built/utils/index.js:1
    2020-04-23 22:07:57.072  - error: host.raspberrypi Caught by controller[0]: ���M
    2020-04-23 22:07:57.074  - error: host.raspberrypi Caught by controller[0]: ^
    2020-04-23 22:07:57.074  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2020-04-23 22:07:57.075  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
    2020-04-23 22:07:57.076  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    2020-04-23 22:07:57.077  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
    2020-04-23 22:07:57.078  - error: host.raspberrypi Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    2020-04-23 22:07:57.079  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    2020-04-23 22:07:57.080  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:692:17)
    2020-04-23 22:07:57.081  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:25:18)
    2020-04-23 22:07:57.082  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/ioredis/built/command.js:6:17)
    2020-04-23 22:07:57.083  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
    2020-04-23 22:07:57.083  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    2020-04-23 22:07:57.084  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-04-23 22:07:57.084  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    Pedder
    All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
    Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
    Under construction: Smart-WoMo auf Raspi4
    • Pedder007P Pedder007
      #42
      @Pedder007 redis ist installiert?
      • Pedder007P Online
        Pedder007P Online
        Pedder007
        #43
        öhh, was ist 'redis'? habe ich noch nie gehört...
        Pedder
          #44
          @Pedder007 Eine Datenbank.
          iobroker status
          • Pedder007P Online
            Pedder007P Online
            Pedder007
            #45
            'no objects found'
            Pedder
              'no objects found'
              #46
              @Pedder007
              apt policy redis
              • Pedder007P Online
                Pedder007P Online
                Pedder007
                schrieb am zuletzt editiert von Pedder007
                #47
                pi@raspberrypi:~ $ apt policy redis
                N: Paket redis kann nicht gefunden werden.
                ... das hatte ich aber meines Wissens vorher auch nicht installiert ...?
                Pedder
                  #48
                  @Pedder007 Hast du iobroker als image eingespielt oder per skript installiert?
                  Das image setzt soweit ich weiß auf redis, die skript-Installetion auf file-basierte Dateiablage.
                  Wobei redis eigentlich bei apt auftauchen sollte. Ist im main drin.
                  Pedder007P 1 Antwort Letzte Antwort
                    Pedder007P Online
                    Pedder007P Online
                    Pedder007
                    #49
                    @Thomas-Braun als Script.
                    Heute neu auf einem Raspbian Stretch Image aufgebaut.
                    Meine erste Installation war allerdings auf Basis eines Clones (auch Stretch) meiner Pimatic Prod-Umgebung.
                    Ich hatte da nur jetzt ein komplett neues Image genommen, da mir die vorherige Installation ja 'kaputt' gegangen war.
                    Evtl. kam da Pimatic-seitig etwas mit ...?
                    Edit: Da fällt mir noch ein, es gab im 3ten oder 4ten Installationsschritt von ioBroker eine ganze Reihe 'Warning'.
                    Mag da evtl. etwas schief gelaufen sein?
                    Pedder
                      #50
                      @Pedder007
                      grep -Erh ^deb /etc/apt/sources.list*
                      Die Installation hört sich etwas abenteuerlich an...
                      Ich hätte auch Buster und nicht Stretch genommen.
                      • Pedder007P Online
                        Pedder007P Online
                        Pedder007
                        #51
                        @Thomas-Braun said in ioBroker nicht mehr erreichbar:
                        pi@raspberrypi:~ $ grep -Erh ^deb /etc/apt/sources.list*
                        deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
                        deb http://archive.raspberrypi.org/debian/ stretch main ui
                        deb https://deb.nodesource.com/node_10.x stretch main
                        deb-src https://deb.nodesource.com/node_10.x stretch main
                        Bis auf die Warnings war alles super durchgelaufen.
                        Evtl. sollte ich
                        nochmal drüber laufen lassen?
                        Pedder
                          Evtl. sollte ich
                          #52
                          Das dürfte kein Problem sein, das mit dem Fixer zu beheben wäre.
                          Ich vermute, deine Images verwendeten schon redis, welches aber nicht in den Quellen von Stretch vorhanden ist. Bei Buster ist das jedenfalls drin.
                          Ich weiß auch bei pimatic nicht was da läuft und wie/ob man das in iobroker reinpflanzen kann.
                          Ich setze iobroker immer sauber von Hand bzw. per Skript auf.
                          • Pedder007P Online
                            Pedder007P Online
                            Pedder007
                            #53
                            @Thomas-Braun, wie meinst Du das von Hand?
                            Also ich hatte mir ein frisches Stretch Image aus dem Git Repository geholt.
                            Das installiert, alle Updates ausgeführt und dann ioBroker nach dieser Anleitung installiert:
                            https://www.iobroker.net/#de/documentation/install/linux.md
                            ... wobei das wäre dann von Hand, ja?
                            Auf dem Raspi war sonst überhaupt nichts drauf, da ich ja vorher mit meinem Clone-Image in Probleme gelaufen war ...
                            Edit: ... und in der Anleitung wird auch nicht Buster gefordert, was ich aktuell noch meide, da das mit Pimatic wohl noch nicht ganz rund läuft, ...
                            Wenn man ganz noch oben scrollt wird sogar explizit Stretch referenziert. Daran dürfte es also eigentlich nicht liegen!?
                            Pedder
                              #54
                              @Pedder007 Bei pimatic bin ich raus.
                              Für iobroker auf einem Raspberry würde ich auf ein raspbian Buster aufsetzen.
                              • Pedder007P Online
                                Pedder007P Online
                                Pedder007
                                #55
                                Hmhm, ich bin da noch nicht, weil wie gesagt es lief ja schon auf Stretch und in der Inst-Anleitung ist ja auch sogar Stretch angegeben.
                                Das Pimatic Interface läuft auch echt super und ich habe mittlerweile etliche Stunden in VIS investiert, was natürlich jetzt echt ärgerlich ist.
                                Aber ich danke Dir trotzdem für Deine Hilfe, Du kannst ja definitiv nichts dafür :-)
                                Pedder
                                  #56
                                  @Pedder007 Ich hab jetzt Mal kurz bei pimatic gelinst...
                                  Davon abgesehen, dass die da auf ganz hahnebüchene Weise node in ein Debian reinprügeln (von der Art und Weise rate ich dringendst ab) spricht soweit ich das sehen konnte nichts gegen die weitere Installation auf einem Buster.
                                  Ich würde glaube ich ganz bei Null anfangen. Per noobs erstmal ein raspbian lite installieren, dann node 12, dann iobroker und dann pimatic.
                                  • Pedder007P Online
                                    Pedder007P Online
                                    Pedder007
                                    #57
                                    Ja, das mit Node habe ich ja nun gelernt :-)
                                    Bzgl. Buster nehme ich die Community sehr zurückhaltend war und da ich auch nicht der Ober-Spezie bin, habe ich das bisher mal lieber gelassen ...
                                    Andererseits habe ich als parallele Neuinstallation ja nichts zu verlieren. Meine Prod-Pimatic Umgebung läuft ja nebenbei sicher auf Stretch weiter, Motioneye übrigens genauso; also so ein wenig Erfahrungen habe ich ja schon im letzten Jahr gesammelt ;-)
                                    Ich werde mal ne' Nacht drüber schlafen... ;-)
                                    ... wobei, es ärgert mich schon das das nicht funzt, weil ich habe mich ja original hier an die Anleitung gehalten ...
                                    Für heute ist erstmal Schluß, sonst komme ich morgen nicht raus ...
                                    Danke Dir nochmal 👍
                                    Pedder
                                      Danke Dir nochmal 👍
                                      #58
                                      @Pedder007 sagte in ioBroker nicht mehr erreichbar:
                                      hattest du ein Backup eingespielt, das mit redis arbeitete?
                                      • Pedder007P Online
                                        Pedder007P Online
                                        Pedder007
                                        #59
                                        Hallo @Homoran, nein nichts dergleichen.
                                        • Wirklich nur ein frisches Stretch Image aus dem Repository gezogen.
                                        • Dieses mit Win32DiskImager auf die SD Karte.
                                        • Damit dann den PI gestartet.
                                        • Installation mit Updates durchgeführt.
                                        • XRDP installiert
                                        • Bedienungstechnisch auf die XRDP Session gewechselt (Nutzer PI)
                                        • ioBroker wie in der Inst-Anleitung beschrieben installiert.
                                        • Alle node(js) und npm Versionen 100% korrekt
                                        • Rebootet
                                        • Statusabfrage zeigt das:
                                        pi@raspberrypi:~ $ sudo systemctl status iobroker
                                        ● iobroker.service - ioBroker Server
                                           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                                           Active: active (running) since Thu 2020-04-23 22:01:54 CEST; 10s ago
                                             Docs: http://iobroker.net
                                         Main PID: 1245 (iobroker.js-con)
                                            Tasks: 18 (limit: 4915)
                                           CGroup: /system.slice/iobroker.service
                                                   ├─1245 iobroker.js-controller
                                                   └─1289 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Module.load (internal/modules/cjs/loader.js:653:32)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Module.require (internal/modules/cjs/loader.js:692:17)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at require (internal/modules/cjs/helpers.js:25:18)
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Object.<anonymous> (/opt/iobroker/node_modules/ioredis/built/command.js:6:1
                                        Apr 23 22:02:01 raspberrypi bash[1245]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
                                        • Und im Logfile steht am Ende immer mehrfach das:
                                        Ich habe ioBroker dann noch mehrfach manuell neu gestartet, aber das Ergebnis ist immer das gleiche.
                                        Den 'Fixer' habe ich schon ausprobiert und ich habe auch nochmals eine neue Installation drüber gezogen.
                                        Alles ohne Erfolg.
                                        Pedder
                                          • XRDP installiert
                                          • Rebootet
                                          Alles ohne Erfolg.
                                          #60
                                          Was ist das?
                                          XRDP installiert
                                          Wofür hast du das gemacht?
