  4. [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe
javascripttemplatemonitoring
581 Beiträge 81 Kommentatoren 169.5k Aufrufe 84 Beobachtet
  • hananH hanan
    Hallo zusammen
    Habe das Skript installiert und erhalte auch eine Ausgabe.
    Leider habe ich im Log auch Fehlermeldungen:
    avascript.0	2020-05-02 13:51:11.958	error	(17025) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2020-05-02 13:51:11.957	error	(17025) at runMicrotasks (<anonymous>:null:null)
    javascript.0	2020-05-02 13:51:11.957	error	(17025) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2020-05-02 13:51:11.957	error	(17025) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-05-02 13:51:11.957	error	(17025) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17
    javascript.0	2020-05-02 13:51:11.956	error	(17025) at /opt/iobroker/node_modules/iobroker.javascript/main.js:855:17
    javascript.0	2020-05-02 13:51:11.956	error	(17025) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17
    javascript.0	2020-05-02 13:51:11.956	error	(17025) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
    javascript.0	2020-05-02 13:51:11.956	error	(17025) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
    javascript.0	2020-05-02 13:51:11.956	error	(17025) at Object.createScript (vm.js:263:10)
    javascript.0	2020-05-02 13:51:11.955	error	(17025) at new Script (vm.js:88:7)
    javascript.0	2020-05-02 13:51:11.955	error	(17025) SyntaxError: Invalid regular expression: missing /
    javascript.0	2020-05-02 13:51:11.955	error	(17025) ^
    javascript.0	2020-05-02 13:51:11.955	error	(17025) / Batterieüberwachungsskript Version 1.5.5 Stand 28.04.2020
    javascript.0	2020-05-02 13:51:11.954	error	at script.js.common.BatterieUeberwachung:1
    javascript.0	2020-05-02 13:51:11.954	error	(17025) script.js.common.BatterieUeberwachung compile failed:
    Arbeite mit:
    Node.js v12.16.3
    NPM 6.14.4
    Hat jemand bitte einen Tipp für mich.
    Grüsse aus der Schweiz
    #61
    @hanan Hast Du das Skript wirklich die oben kopiert? zeig mal nen Screenshot vom Skript editor und dem Anfang vom Skript.
    Und: welche javascript adapter version?
    • hananH Offline
      hananH Offline
      hanan
      #62
      Hallo apollo77
      Habe alles so kopiert..
      // Batterieüberwachungsskript Version 1.5.5 Stand 28.04.2020
      //Überwacht Batteriespannungen beliebig vieler Geräte
      //WICHTIG!!!
      //Vorraussetzungen: Den Gerätechannels müssen Räume, sowie die Funktion "BatterieSpannung_xx" für jeden entsprechenden Batteriespannungs Datenpunkt zugewiesen sein.
      //Grund Einstellungen
      const praefix = "javascript.0.BatterieUeberwachung."; //Grundpfad für Script DPs
      const logging = true; //Logging aktivieren?
      const FunktionBaseName = "BatterieSpannung_"; //Name der Funktion welche für die Batterieüberwachung genutzt wird
      const UseTelegram = false; // Sollen Nachrichten via Telegram gesendet werden?
      const UseMail = false; // Sollen Nachrichten via Mail gesendet werden?
      const UseAlexa = false; // Sollen Nachrichten via Alexa ausgegeben werden?
      const AlexaId = ""; // Die Alexa Seriennummer
      const UseSay = false; // Sollen Nachrichten via Say ausgegeben werden? Funktion des Authors, sollte bei Anwendern auf false gesetzt werden.
      const UseEventLog = false; // Sollen Nachrichten ins Eventlog geschreiben werden? Funktion des Authors, sollte bei Anwendern auf false gesetzt werden.
      const UsePopUp = false // Soll PopUp angezeigt werden? Funktion des Authors, sollte bei Anwendern auf false gesetzt werden.
      const ProzMeansLive = true; //Zeigen Prozentwerte des Gerätedatenpunktes Batteriekapazität oder restliche Lebensdauer?
      //Tabellen Einstellungen
      const TblOkBgColor = "#4caf50"; //Hintergrundfarbe für Batteriestatus Ok
      const TblInfoBgColor = "#ffc107"; //Hintergrundfarbe für Batteriestatus Info, also die leerste Batterie welche noch nicht das Limit unterschreitet
      const TblWarnBgColor = "#f44336"; //Hintergrundfarbe für Batteriestatus Warnung, also jene Batterie welche unter das Limit kam.
      const HeadBgColor = "dimgrey"; //Hintergrundfarbe des Tabellenkopfes
      const FontColor = "black"; //Textfarbe für Tabelleninhalt
      const HeadFontColor = "white"; //Textfarbe für Tabellenkopf
      const TblShowLfdCol = true; //Tabellenspalte mit laufender Nummer anzeigen?
      const TblShowDeviceIDCol = true; //Tabellenspalte mit Geräte ID anzeigen?
      const TblShowDeviceNameCol = true; //Tabellenspalte mit Gerätenamen anzeigen?
      const TblShowRoomCol = true; //Tabellenspalte mit Raum anzeigen?
      const TblShowUmaxCol = true; //Tabellenspalte mit Batterie Nennspannung anzeigen?
      const TblShowUistCol = true; //Tabellenspalte mit aktueller Batteriespannung anzeigen?
      const TblShowUlimitCol = true; //Tabellenspalte mit unterer Batterielimit Spannung anzeigen?
      const TblShowProzbatCol = true; //Tabellenspalte mit Batteriestand in Prozent anzeigen?
      const TblShowProzliveCol = true; //Tabellenspalte mit Restlebensdauer unter Berücksichtigung der Limitspannung in Prozent anzeigen? Beispiel: Batterie hat 3V Nennspannung, Limit ist bei 2V, aktueller Batteriestand ist 2.5V, dann wäre die Restlebensdauer 50%
      const TblShowStatusCol = false; //Tabellenspalte mit Status ausgeben?
      //Ab hier nix mehr ändern
      Liebe Grüsse aus der Schweiz
      Andy
      ioBroker auf NUC unter Proxmox, Raspberrymatic-CCU auf NUC unter Proxmox mit RPI-RF-MOD Funkmodul und Omnidiraktional Antenne
      P 1 Antwort Letzte Antwort
      • hananH hanan
        Hallo apollo77
        //WICHTIG!!!
        Pittini
        schrieb am zuletzt editiert von Pittini
        #63
        @hanan sagte in [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe:
        Hallo apollo77
        So kriegt @apollon77 das nicht mit.
        Mach mal testweise in der Zeile 298 an den Anfang zwei Schrägstriche. Also so: // . Die Zeile sollte dann so aussehen:
        //    room = room.replace(/_/g, " "); //Unterstriche durch Leerzeichen ersetzen
        .Dann speichern und guggen ob der Fehler immer noch gemeldet wird und hier Feedback geben.
        • hananH Offline
          hananH Offline
          hanan
          #64
          Hallo Pittini
          Habe ich jetzt gemacht und erhalte folgenden Fehler:
          2.5.2020, 16:28:53.493	[info ]: javascript.0 (1272) Stop script script.js.common.BatterieUeberwachung
          2.5.2020, 16:28:55.765	[info ]: javascript.0 (1272) Start javascript script.js.common.BatterieUeberwachung
          2.5.2020, 16:28:55.768	[error]: javascript.0 (1272) script.js.common.BatterieUeberwachung compile failed:
          at script.js.common.BatterieUeberwachung:497
          Andy
          • hananH Offline
            hananH Offline
            hanan
            #65
            Habe die Adapter neu installiert und jetzt geht es...
            Coole Sache, danke für die Hilfe.
            Schönes Wochenende.
            Andy
            • hananH Offline
              hananH Offline
              hanan
              #66
              Ups, zu früh gefreut...
              Habe Zeile 291 auskommandiert und keine Fehlermeldung mehr.
              Andy
              • hananH hanan
                Schönes Wochenende.
                Pittini
                #67
                Welche Adapter?
                • hananH Offline
                  hananH Offline
                  hanan
                  #68
                  Den Script Engine
                  Andy
                  • hananH hanan
                    Den Script Engine
                    Pittini
                    #69
                    Den Script Engine
                    Wow, 6 Instanzen. Wofür brauchste die denn alle (reine Neugier).?
                    • hananH Offline
                      hananH Offline
                      hanan
                      schrieb am zuletzt editiert von hanan
                      #70
                      Habe Licht, Sound etc. aufgeteilt in je eine Instanz.
                      Also, wenn ich Zeile 291 auskommandiere habe ich keine Fehlermeldungen mehr, doch bei den Ikea "tradfri"-Teilen gibt es mir kein Raum an.
                      Andy
                      • hananH hanan
                        Pittini
                        #71
                        Sehr seltsam, Zeile 291 is an sich absolut unkritisch, in dem verarbeiteten String sollte aber der Raum sein, evtl is da der Zusammenhang. Mach mir mal den Screenshot aus der ausgeklappten Objektliste von sonem tradfri Teil, inkl der übergeordneten Channels. Glaub das hatte noch keiner, evtl. is da was anderes als bei den anderen und unberücksichtigt.
                        • hananH Offline
                          hananH Offline
                          hanan
                          #72
                          OK, hier die Objektliste von einem "tratfri":
                          Habe die Fernbedienungen vom "tradfri" rausgenommen und das Skript läuft ohne Fehlermeldung durch.
                          Mit dem "tradfri" habe ich folgende Fehlermeldungen:
                          avascript.0	2020-05-02 19:31:23.992	error	(12508) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                          javascript.0	2020-05-02 19:31:23.992	error	(12508) at runMicrotasks (<anonymous>:null:null)
                          javascript.0	2020-05-02 19:31:23.992	error	(12508) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                          javascript.0	2020-05-02 19:31:23.991	error	(12508) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                          javascript.0	2020-05-02 19:31:23.991	error	(12508) at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697
                          javascript.0	2020-05-02 19:31:23.991	error	(12508) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
                          javascript.0	2020-05-02 19:31:23.991	error	(12508) at Object.<anonymous> (script.js.common.Überwachung.Batteriestatus:84:13)
                          javascript.0	2020-05-02 19:31:23.990	error	(12508) at main (script.js.common.Überwachung.Batteriestatus:197:5)
                          javascript.0	2020-05-02 19:31:23.990	error	(12508) at MakeTable (script.js.common.Überwachung.Batteriestatus:388:68)
                          javascript.0	2020-05-02 19:31:23.989	error	(12508) at GetRoom (script.js.common.Überwachung.Batteriestatus:291:17)
                          javascript.0	2020-05-02 19:31:23.989	error	(12508) Error in callback: TypeError: Cannot read property 'replace' of undefined
                          Hmm... bei Shelly stimmt auch etwas nicht.
                          Hier erhalte ich die Meldung:
                          javascript.0	2020-05-02 19:37:19.349	info	(12508) script.js.common.Überwachung.Batteriestatus: Aktuell niedrigster Batteriestand (2.47V): Küche bei Gerät Channel bat
                          Sollte aber das Gerät
                          sein.
                          Andy
                          • hananH hanan
                            sein.
                            Pittini
                            #73
                            Was Du da zeigst is auf jeden Fall ein Konfigurationsfehler. Schau mal welchem Datenpunkt Du die Batteriespannung verpasst hast, setz das eine Zeile tiefer, starte den js Adapter neu und berichte erneut.
                            Und shellys haben doch gar keine Batterie? Und wenn doch zeigst Du mir nicht den richtigen Datenpunkt.
                            • hananH Offline
                              hananH Offline
                              hanan
                              #74
                              Oh mann, knapp daneben ist auch daneben...
                              JS Adapter neu gestartet und es kommen von den "tradfri" keine Fehlermeldung mehr.
                              Und hier ein Shelly H&T (Temperatur und Feuchte)
                              Andy
                              • hananH Offline
                                hananH Offline
                                hanan
                                #75
                                Sorry, habe den JS Adapter neu gestartet und es kommt von den "tradfri" keine Fehlermeldung mehr.
                                Andy
                                • hananH hanan
                                  Pittini
                                  #76
                                  Wollt grad sagen, die Fwehlermeldung kommt mir bekannt vor und Du hast den Adapter nicht neu gestartet. Also bleibt jetzt nur noch das Shelly Problem?
                                  • hananH Offline
                                    hananH Offline
                                    hanan
                                    #77
                                    Jep...
                                    aber als Problem würde ich dieses nicht bezeichnen, sondern "Feinschliff".
                                    Andy
                                    P 2 Antworten Letzte Antwort
                                    • hananH hanan
                                      Jep...
                                      Pittini
                                      #78
                                      Jep...
                                      Feinschliff oder nicht, meine Skripte haben gefälligst zu funktionieren. Hab da auch ne Vermutung, beim shelly is noch der bat channel dazwischen, sowas hat sonst nur HM. Ich schau mir das später oder morgen mal an, jetzt gibts Abendessen.
                                      • hananH Offline
                                        hananH Offline
                                        hanan
                                        #79
                                        OK, passt.
                                        Besten Dank erstmal und einen schönen Abend.
                                        E guete...
                                        Andy
                                        • W Wildbill
                                          @Pittini @dos1973
                                          Eben getestet, jetzt schaut alles perfekt aus. 👍 😬
                                          Gruss, Jürgen
                                          dos1973
                                          #80
                                          @Wildbill sagte in [Vorlage] Generische Batteriestandsüberwachung + Vis-ausgabe:
                                          @Pittini @dos1973
                                          Gruss, Jürgen
                                          ich habe eben die Version 1.5.5 Stand 28.04.2020 installiert.
                                          bei mir sind weiterhin die :0
