  4. Paspy 3+ ioBroker und Node.js
iobroker nodejs paspberry
32 Beiträge 3 Kommentatoren 3.5k Aufrufe 2 Beobachtet
    Snupy
    Hallo
    auf meinem Raspi 3+ laufen mittlerweile folgende server ...
    Blynk, Apache, Plex und TVHeadend ... nun wollte ich ioBroker installieren um einige sonoff Pow zu steuern ... leider gelingt mir das nicht ... scheint wohl wegen der falschen/veralteten node version ? kann jemand helfen ?
    (node:6643) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    npm ERR! not a package /tmp/npm-6643-nIs2KVeW/1585177227319-0.347199047812637/tmp.tgz
    (node:6729) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    ioBroker needs at least Node.JS 8.12. You have installed 8.11.1
    Please update your Node.JS version!
    npm ERR! iobroker@1.3.1 install: `node lib/checkVersions.js`
    npm ERR! Exit status 2
    npm ERR!
    npm ERR! Failed at the iobroker@1.3.1 install script.
    npm ERR! This is most likely a problem with the iobroker package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node lib/checkVersions.js
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls iobroker
    npm ERR! There is likely additional logging output above.
    npm ERR! System Linux 4.19.42-v7+
    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "i" "iobroker" "--loglevel" "error"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v8.11.1
    npm ERR! npm -v 1.4.21
    npm ERR! code ELIFECYCLE
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! not ok code 0
    (node:6754) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    npm ERR! install Couldn't read dependencies
    npm ERR! package.json ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm ERR! package.json This is most likely not a problem with npm itself.
    npm ERR! package.json npm can't find a package.json file in your current directory.
    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "i" "--production" "--loglevel" "error" "--unsaf        e-perm"
    npm ERR! path /opt/iobroker/package.json
    npm ERR! syscall open
    npm ERR! code ENOPACKAGEJSON
    npm ERR! errno -2
    npm ERR!
    Mod-Edit: Code in Code-tags gesetzt!
    J 1 Antwort Letzte Antwort
    • S Snupy
      Hallo
      npm ERR!
      npm ERR!
      npm ERR! errno -2
      npm ERR!
      Jan1
      @Snupy
      Du hast ein Image für die IOBroker Installation verwendet, oder die Doku nicht gelesen, sonst wüsstest Du was zu tun ist ;-)
      Wenn Image, dann wohl sehr alt ansonsten mach einfach das was in der Doku bei der Installation zu Node steht.
      • J Jan1
        @Snupy
        @Jan1 sagte in Paspy 3+ ioBroker und Node.js:
        wohl eher nicht, sonst würde er ja nicht erst jetzt ioBroker installieren, nachdem da schon einiges läuft.
        eher eine veraltete externe Anleitung für die ioBroker-Installation genommen
          Jan1
          @Homoran
          Wir einigen uns auf Doku nicht gelesen ;-)
            Snupy
            schrieb am zuletzt editiert von Snupy
            mhhh ... was soll ich sagen ?
            das Image auf dem Raspy ist schon älter das stimmt und das hatte "damals" einen triftigen Grund genau das und kein anderes zu nehmen !
            die Installation Doku nicht gelesen .... ? sie ist (wie leider immer) in englisch ... sorry dessen bin ich nicht mächtig
            jetzt scheint er sich an der node Version 8.11 zu stören und will 8.12 haben ... aber auch wenn ich die 8.11 deinstalliere und node wieder neu drauf machen will ... kommt am ende wieder 8.11 dabei heraus
            pi@raspberrypi:/opt/iobroker $ node -v
            v8.11.1
            pi@raspberrypi:/opt/iobroker $ npm -v
            6.14.4
            pi@raspberrypi:/opt/iobroker $ nodejs -v
            v8.11.1
            pi@raspberry
            • S Snupy
              v8.11.1
              6.14.4
              v8.11.1
              pi@raspberry
              Jan1
              @Snupy
              Die Doku ist auf deutsch und ich meine die IOBroker Doku und die Installation dessen. Beim Image rede ich vom IOIBroker Image.
              Jetzt hast aber erst mal zwei Node Versionen installiert und das ist noch schlechter als ein alte.
              Verlesen, passt.
              • J Jan1
                @Snupy
                Verlesen, passt.
                Snupy
                @Jan1 said in Paspy 3+ ioBroker und Node.js:
                @Snupy
                ??? versteh ich nicht ....
                sorry ich gebe auf und lass das bleiben mit ioBroker
                • S Snupy
                  @Snupy
                  Jan1
                  @Snupy
                  Edit oben
                  Node ist Bestandteil des OS und wird auch über dieses ganz normal upgedatet, heißt für Dich jetzt:
                  sudo apt-get update && sudo apt-get upgrade
                  Steht aber auch in der Doku, bevor mal bastelt sollte erst mal das OS aktuell sein ;-)
                    Snupy
                    das hatte ich natürlich als erstes getan ... ändert aber am Resultat nüscht !
                    es bleibt bei version 8.11
                    • S Snupy
                      Jan1
                      @Snupy
                      Komisch, wobei es ist eh 10 empfohlen, deshalb wäre ein Update auf 10 sinnvoller.
                      Schau mal was die Doku dazu sagt und versuch es mal nach dieser.
                      • J Jan1
                        @Snupy
                        Edit oben
                        @Snupy sagte in Paspy 3+ ioBroker und Node.js:
                        apt update && apt upgrade ändert nur die Version innerhalb des major releases und auch das nur soweit es das eingestellte repository hergibt.
                        welche Doku meinst du?
                        zu jedem (ioBroker-)Image gibt es ein ReadMe in Deutsch.
                        sämtliche Dokus zu dem Thema nodejas und/oder ioBroker/node Installation sind auf Deusch - zu erreichen über den Link "Docu" in der Titelzeile des Forums.
                        zum Thema "node richtig updaten" gibt es sogar hier im Forum einen hervorragenden Thread von @Stabilostick
                        https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                          Snupy
                          hatte die hier benutzt
                          J HomoranH 2 Antworten Letzte Antwort
                          • S Snupy
                            Jan1
                            @Snupy
                            Schau mal was oben mittig steht "i Docu" und die ist aktuell :-)
                            • S Snupy
                              Danke für den Link.
                              Ich denke die Seite sollten wir mal stillegen. Die ist etwa 5 Jahre alt, wieso da noch was im Februar geändert wurde erschließt sich mir nicht
                                Snupy
                                @Jan1 ... das habe ich gelesen nachdem du so nett warst es zu verlinken ... wenn ich das abarbeite kommt folgendes dabei heraus ...
                                -ich deinstalliere node ...
                                da bekomme ich eine meldung das node nicht installiert sei und es deshalb auch nicht deinstalliert werden kann (bei der Abfrage die ich vorher machte, bekomme ich mit node -v die Version 8.11 angezeigt.
                                -ich deinstalliere nodejs
                                das wird ausgeführt
                                -danach reboote ich und führe folgendes aus
                                curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                                sudo apt install -y nodejs
                                sudo reboot
                                das Ergebnis sieht dann wie folgt aus -> installiert wird Version 8.11
                                im Code (Zeilen 11-18) steht dann etwas von "Problemen" mit dem strech Release
                                pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash        -
                                ## Installing the NodeSource Node.js 10.x repo...
                                ## Populating apt-get cache...
                                + apt-get update
                                OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                                OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                Ign:3 https://dev2day.de/pms stretch InRelease
                                Fehl:4 https://dev2day.de/pms stretch Release
                                 404  Not Found
                                E: The repository 'https://dev2day.de/pms stretch Release' does no longer have a        Release file.
                                N: Updating from such a repository can't be done securely, and is therefore disa        bled by default.
                                N: See apt-secure(8) manpage for repository creation and user configuration deta        ils.
                                Error executing command, exiting
                                pi@raspberrypi:~ $ sudo apt install -y nodejs
                                The following additional packages will be installed:
                                 libc-ares2 libhttp-parser2.8 libuv1 nodejs-doc
                                Die folgenden NEUEN Pakete werden installiert:
                                 libc-ares2 libhttp-parser2.8 libuv1 nodejs nodejs-doc
                                0 aktualisiert, 5 neu installiert, 0 zu entfernen und 159 nicht aktualisiert.
                                Es müssen noch 0 B von 5.087 kB an Archiven heruntergeladen werden.
                                Nach dieser Operation werden 22,2 MB Plattenplatz zusätzlich benutzt.
                                Vormals nicht ausgewähltes Paket libc-ares2:armhf wird gewählt.
                                (Lese Datenbank ... 135588 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../libc-ares2_1.14.0-1~bpo9+1_armhf.deb ...
                                Entpacken von libc-ares2:armhf (1.14.0-1~bpo9+1) ...
                                Vormals nicht ausgewähltes Paket libhttp-parser2.8:armhf wird gewählt.
                                Vorbereitung zum Entpacken von .../libhttp-parser2.8_2.8.1-1~bpo9+1_armhf.deb ..        .
                                Entpacken von libhttp-parser2.8:armhf (2.8.1-1~bpo9+1) ...
                                Vormals nicht ausgewähltes Paket libuv1:armhf wird gewählt.
                                Vorbereitung zum Entpacken von .../libuv1_1.18.0-3~bpo9+1_armhf.deb ...
                                Entpacken von libuv1:armhf (1.18.0-3~bpo9+1) ...
                                Vormals nicht ausgewähltes Paket nodejs wird gewählt.
                                Vorbereitung zum Entpacken von .../nodejs_8.11.1~dfsg-2~bpo9+1_armhf.deb ...
                                Entpacken von nodejs (8.11.1~dfsg-2~bpo9+1) ...
                                Vormals nicht ausgewähltes Paket nodejs-doc wird gewählt.
                                Vorbereitung zum Entpacken von .../nodejs-doc_8.11.1~dfsg-2~bpo9+1_all.deb ...
                                Entpacken von nodejs-doc (8.11.1~dfsg-2~bpo9+1) ...
                                nodejs-doc (8.11.1~dfsg-2~bpo9+1) wird eingerichtet ...
                                libuv1:armhf (1.18.0-3~bpo9+1) wird eingerichtet ...
                                Trigger für libc-bin (2.24-11+deb9u4) werden verarbeitet ...
                                Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                                libc-ares2:armhf (1.14.0-1~bpo9+1) wird eingerichtet ...
                                libhttp-parser2.8:armhf (2.8.1-1~bpo9+1) wird eingerichtet ...
                                nodejs (8.11.1~dfsg-2~bpo9+1) wird eingerichtet ...
                                update-alternatives: /usr/bin/nodejs wird verwendet, um /usr/bin/js (js) im auto        matischen Modus bereitzustellen
                                pi@raspberrypi:~ $ node -v
                                v8.11.1
                                • S Snupy
                                  das wird ausgeführt
                                  sudo reboot
                                  + apt-get update
                                   404  Not Found
                                  v8.11.1
                                  das wird ausgeführt
                                  bitte genau an die Anleitung halten. Am besten Schritt für Schritt:
                                  apt purge node
                                  apt purge nodejs
                                  node -v
                                  nodejs -v
                                  npm -v
                                  nicht mehr! und das Ergebnis hier posten.
                                  nicht unbedingt.
                                  Der Fehler ist abgeschnitten, ich vermute, dass du noch mit Stretch arbeitest und in dem Repo (was ist das eigentlich für eins?) kein node10 existiert.
                                  Du solltest auf Buster updaten
                                    Snupy
                                    apt purge node
                                    root@raspberrypi:/home/pi# apt purge node
                                    Paket »node« ist nicht installiert, wird also auch nicht entfernt.
                                    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 159 nicht aktualisiert.
                                    apt purge nodejs
                                    root@raspberrypi:/home/pi# apt purge nodejs
                                    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benöti        gt:
                                    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                    Die folgenden Pakete werden ENTFERNT:
                                      nodejs*
                                    0 aktualisiert, 0 neu installiert, 1 zu entfernen und 159 nicht aktualisiert.
                                    Nach dieser Operation werden 15,8 MB Plattenplatz freigegeben.
                                    Möchten Sie fortfahren? [J/n] j
                                    (Lese Datenbank ... 135736 Dateien und Verzeichnisse sind derzeit installiert.)
                                    Entfernen von nodejs (8.11.1~dfsg-2~bpo9+1) ...
                                    node -v
                                    nodejs -v
                                    npm -v
                                    -bash: node: Kommando nicht gefunden.
                                    pi@raspberrypi:~ $ nodejs -v
                                    -bash: nodejs: Kommando nicht gefunden.
                                    pi@raspberrypi:~ $ npm -v
                                    /usr/bin/env: „node“: Datei oder Verzeichnis nicht gefunden
                                    • S Snupy
                                      apt purge node
                                      apt purge nodejs
                                        nodejs*
                                      node -v
                                      nodejs -v
                                      npm -v
                                      @Snupy Das sieht gut aus!
                                      jetzt:
                                        Snupy
                                        root@raspberrypi:/home/pi# curl -sL https://deb.nodesource.com/setup_10.x | sudo        -E bash -
                                        + apt-get update
                                        Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
                                          404  Not Found
                                        Holen:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11        ,7 MB]
                                        • S Snupy
                                          + apt-get update
                                            404  Not Found
                                          und damit hat er die 10.x NICHT in den apt-Quellen eingetragen und kann sie NIE installieren.
                                          Was um alles in der Welt ist
                                          das existiert nicht mehr und wird als unsicher deklariert.
                                          Der Rest ist leider abgeschnitten
