  4. JS CONTROLLER STOPPED
js controllerzigbee
37 Beiträge 3 Kommentatoren 4.4k Aufrufe 2 Beobachtet
    SmartKokoin
    schrieb am zuletzt editiert von SmartKokoin
    Servus zusammen,
    nachdem mein ioBroker 2 Monate offline war, habe ich alles geupdatet und nun habe ich die Fehlermeldung von meinem Zigbee im Log.
    host.MyPi	2020-03-20 18:14:32.944	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.MyPi	2020-03-20 18:14:32.944	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1002:32)
    host.MyPi	2020-03-20 18:14:32.944	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1178:10)
    host.MyPi	2020-03-20 18:14:32.944	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1158:30)
    host.MyPi	2020-03-20 18:14:32.943	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.MyPi	2020-03-20 18:14:32.943	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.MyPi	2020-03-20 18:14:32.943	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.MyPi	2020-03-20 18:14:32.942	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1044:19)
    host.MyPi	2020-03-20 18:14:32.942	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:901:14)
    host.MyPi	2020-03-20 18:14:32.942	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1002:32)
    host.MyPi	2020-03-20 18:14:32.942	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1208:18)
    host.MyPi	2020-03-20 18:14:32.941	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.MyPi	2020-03-20 18:14:32.941	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.MyPi	2020-03-20 18:14:32.941	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    host.MyPi	2020-03-20 18:14:32.940	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.MyPi	2020-03-20 18:14:32.940	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.MyPi	2020-03-20 18:14:32.939	error	Caught by controller[0]: ^
    host.MyPi	2020-03-20 18:14:32.939	error	Caught by controller[0]: throw e;
    host.MyPi	2020-03-20 18:14:32.937	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    Leider werde ich aus dem Log nicht wirklich schlau. Ich hoffe einer von euch schon :).
    npm -v -> 6.14.3
    node -v ->10.19.0
    JS-Controller -> 2.2.9
    Sollten ihr irgendwas wissen müssen, lässt es mich wissen :).
    Vielen Dank und beste Grüße
    Koko
    J 1 Antwort Letzte Antwort
    • S SmartKokoin
      Servus zusammen,
      npm -v -> 6.14.3
      node -v ->10.19.0
      Koko
      Jan1
      @SmartKokoin
      Node Update gemacht?
      • J Jan1
        @SmartKokoin
        SmartKokoin
        @Jan1 ja war auch nen Node Update dabei
        • S SmartKokoin
          Jan1
          @SmartKokoin
          Dann steht Dein Problem samt Lösung in Deinem Log ;-)
          Hast die Anleitung vom Node Update nicht wirklich gelesen?
          • J Jan1
            @SmartKokoin
            SmartKokoin
            @Jan1 eigentlich schon. Aber anscheinend was falsch gemacht. xD
            • S SmartKokoin
              Jan1
              @SmartKokoin
              nein, nur nicht alles, oder hast das NPM rebuild gemacht?
              • J Jan1
                @SmartKokoin
                SmartKokoin
                @Jan1 ja hab ich MEHRFACH -.-
                • S SmartKokoin
                  Jan1
                  @SmartKokoin
                  Dann installiere den JS Controller noch mal, wobei ich jetzt nicht mal genau wüsste, wie man den noch mal installiert :-)
                  • J Jan1
                    @SmartKokoin
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    @Jan1 sagte in JS CONTROLLER STOPPED:
                    https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
                    Immer Daten sichern!
                    J S 2 Antworten Letzte Antwort
                    • sigi234S sigi234
                      Jan1
                      @sigi234
                      Was nicht alles in der Doku steht :-)
                      Ich hatte den bisher immer nur upgedatet und damit noch nie ein Problem gehabt.
                      • sigi234S sigi234
                        SmartKokoin
                        @sigi234 Servus ich seh auch gerade das mein NPM und mein Node auf unterschiedlichen Versionen laufen.
                        Node 12.16.1
                        NPM 6.14.3
                        NodeJS ist auf Version 10.19.0
                        kA wie das alles passiert ist :D
                        Lösungsvorschläge?`
                        • S SmartKokoin
                          Node 12.16.1
                          NPM 6.14.3
                          Lösungsvorschläge?`
                          Jan1
                          @SmartKokoin
                          Steht auch in der Doku und Du hast wohl im falschen Verzeichnis installiert, deshalb hast jetzt 2 mal Node laufen und das noch in unterschiedlichen Versionen.
                          • J Jan1
                            @SmartKokoin
                            SmartKokoin
                            @Jan1 ja und wie behebe ich das Problem der 2 Versionen?
                            • S SmartKokoin
                              Jan1
                              @SmartKokoin
                              so lange deinstallieren bis keine mehr da ist
                              • J Jan1
                                @SmartKokoin
                                SmartKokoin
                                @Jan1 die Frage ist ja wie finde ich die? Laut dir sind sie ja auch in verschiedenen Verzeichnissen ^^
                                • S SmartKokoin
                                  Jan1
                                  @SmartKokoin
                                  Ich tippe mal Du hast im IOBroker Verzeichnis installiert und Node ist aber Bestandteil des OS. Dann hast schon Deine 2 in Frage kommende Verzeichnisse.
                                  • J Jan1
                                    @SmartKokoin
                                    SmartKokoin
                                    @Jan1 ok, alles runter -.-
                                    NPM node und nodejs einfach alles raus gehauen
                                    Kannst du mir nun sagen wo ich was installieren muss?
                                    • S SmartKokoin
                                      Jan1
                                      @SmartKokoin
                                      Node normal im root und NPM kommt mit Node mit.
                                      Bist sicher, dass alles weg ist?
                                      • J Jan1
                                        @SmartKokoin
                                        SmartKokoin
                                        @Jan1 node -v, npm -v und nodejs -v zeigen alle nichts an
                                        • S SmartKokoin
                                          Jan1
                                          @SmartKokoin
                                          Dann nach Doku Node installieren und da das vor IOBroker passiert, wird das auch im root gemacht.
