  4. Javaskript Adapter
Javaskript Adapter
javascriptadminiobroker
48 Beiträge 7 Kommentatoren 3.7k Aufrufe 3 Beobachtet
  • O Oli
    @e-s, @paul53
    das ist bei mir seit heute auch so, obwohl ich keine Scripte erstellt habe
    host.ioBroker	2020-03-25 23:47:00.035	error	Caught by controller[0]: 18: 0x321b38b5bf7d
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 17: 0xbd5051 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 16: 0xfce729 v8::internal::JsonStringifier::Stringify(v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 15: 0xfcd9cd v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<false>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 14: 0xfc88bb v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::i
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 13: 0xfc80a1 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 12: 0xfc846e v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 11: 0x1204280 v8::internal::IncrementalStringBuilder::Extend() [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 10: 0xed403b v8::internal::Factory::NewRawTwoByteString(int, v8::internal::PretenureFlag) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 9: 0xf043f1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 8: 0xf01784 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 7: 0xf00e52 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 6: 0xef4d78 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 5: 0xef4c72 [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.032	error	Caught by controller[0]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.032	error	Caught by controller[0]: 2: 0x8fa0dc [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.032	error	Caught by controller[0]: 1: 0x8fa090 node::Abort() [io.javascript.0]
    host.ioBroker	2020-03-25 23:47:00.031	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    #41
    @Oli sagte:
    Das ist etwas Anderes.
      @Oli sagte:
      sigi234S Online
      sigi234S Online
      sigi234
      #42
      @paul53 sagte in Javaskript Adapter:
      @Oli sagte:
      Jupp, hast @Oli ev. einen Adapter installiert/aktualisiert?
      Immer Daten sichern!
      O 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @Oli sagte:
        O Offline
        O Offline
        Oli
        #43
        @sigi234
        eigentlich nur die offiziellen, außer den RSS-Feed Adapter und den Corona Adapter.
        Oliver
        • O Oli
          @sigi234
          sigi234S Online
          sigi234S Online
          sigi234
          #44
          @Oli sagte in Javaskript Adapter:
          Corona Adapter.
          Auf diesen Tippe ich wegen der Meldung:
          Dieser blockiert auch mein System wenn ich damit in den Einstellungen was mache, da er sehr Speicherintensiv ist am Anfang.
          • sigi234S sigi234
            Corona Adapter.
            O Offline
            O Offline
            Oli
            #45
            @sigi234
            die Meldung kam aber nach der Deinstallation des Adapters
            Oliver
            • O Oli
              @sigi234
              sigi234S Online
              sigi234S Online
              sigi234
              #46
              @sigi234
              Schon mal neu gestartet?
              • Uli977U Uli977
                Ich habe das gleich Phänomen erneut.
                Javascript Adapter geht an/aus/an/aus
                2020-03-25 20:46:11.353 - info: javascript.0 (28289) Stop script script.js.Benachrichtigungen.Pushover_benachrichtigungen
                2020-03-25 20:46:11.353 - warn: javascript.0 (28289) Got terminate signal. Checking desired PID: 28843 vs own PID 28289
                2020-03-25 20:46:11.353 - info: javascript.0 (28289) terminating
                2020-03-25 20:46:11.354 - info: javascript.0 (28289) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2020-03-25 20:46:11.881 - error: host.debian instance system.adapter.javascript.0 terminated with code 156 (156)
                2020-03-25 20:46:11.881 - info: host.debian Restart adapter system.adapter.javascript.0 because enabled
                2020-03-25 20:46:12.287 - debug: javascript.0 (28843) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2020-03-25 20:46:12.306 - debug: javascript.0 (28843) Objects client ready ... initialize now
                2020-03-25 20:46:12.308 - debug: javascript.0 (28843) Objects create System PubSub Client
                2020-03-25 20:46:12.308 - debug: javascript.0 (28843) Objects create User PubSub Client
                2020-03-25 20:46:12.309 - debug: javascript.0 (28843) Objects client initialize lua scripts
                2020-03-25 20:46:12.320 - debug: javascript.0 (28843) Objects connected to redis: 127.0.0.1:9001
                2020-03-25 20:46:12.325 - debug: javascript.0 (28843) objectDB connected
                2020-03-25 20:46:12.326 - debug: javascript.0 (28843) Redis States: Use Redis connection: 127.0.0.1:9000
                2020-03-25 20:46:12.331 - debug: javascript.0 (28843) States create User PubSub Client
                2020-03-25 20:46:12.332 - debug: javascript.0 (28843) States create System PubSub Client
                2020-03-25 20:46:12.342 - debug: javascript.0 (28843) States connected to redis: 127.0.0.1:9000
                2020-03-25 20:46:12.342 - debug: javascript.0 (28843) statesDB connected
                2020-03-25 20:46:12.979 - info: javascript.0 (28843) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.17.0
                2020-03-25 20:46:13.025 - debug: javascript.0 (28843) Loaded TypeScript definitions for node: ["@types/node/index.d.ts","@types/node/base.d.ts","@types/node/globals.d.ts","@types/node/assert.d.ts","@types/node/async_hooks.d.ts","@types/node/buffer.d.ts","@types/node/child_process.d.ts","@types/node/cluster.d.ts","@types/node/console.d.ts","@types/node/constants.d.ts","@types/node/crypto.d.ts","@types/node/dgram.d.ts","@types/node/dns.d.ts","@types/node/domain.d.ts","@types/node/events.d.ts","@types/node/fs.d.ts","@types/node/http.d.ts","@types/node/http2.d.ts","@types/node/https.d.ts","@types/node/inspector.d.ts","@types/node/module.d.ts","@types/node/net.d.ts","@types/node/os.d.ts","@types/node/path.d.ts","@types/node/perf_hooks.d.ts","@types/node/process.d.ts","@types/node/punycode.d.ts","@types/node/querystring.d.ts","@types/node/readline.d.ts","@types/node/repl.d.ts","@types/node/stream.d.ts","@types/node/string_decoder.d.ts","@types/node/timers.d.ts","@types/node/tls.d.ts","@types/node/trace_events.d.ts","@types/node/tty.d.ts","@types/node/url.d.ts","@types/node/util.d.ts","@types/node/v8.d.ts","@types/node/vm.d.ts","@types/node/worker_threads.d.ts","@types/node/zlib.d.ts"]
                2020-03-25 20:46:13.036 - debug: javascript.0 (28843) Loaded TypeScript definitions for request: []
                2020-03-25 20:46:13.037 - info: javascript.0 (28843) requesting all states
                2020-03-25 20:46:13.037 - info: javascript.0 (28843) requesting all objects
                2020-03-25 20:46:14.140 - info: javascript.0 (28843) received all states
                2020-03-25 20:46:14.501 - info: javascript.0 (28843) received all objects
                2020-03-25 20:46:14.930 - debug: javascript.0 (28843) system.adapter.admin.0: logging true
                2020-03-25 20:46:14.935 - info: javascript.0 (28843) Start javascript script.js.Abfall.abfall_tage
                2020-03-25 20:46:14.971 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.restmuell angelegt
                2020-03-25 20:46:14.972 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.blauetonne angelegt
                2020-03-25 20:46:14.972 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.biomuell angelegt
                2020-03-25 20:46:14.972 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.gelbersack angelegt
                2020-03-25 20:45:19.525 - info: javascript.0 (27740) script.js.Abfall.abfall_tage: Der nächste Müll ist in 0 Tagen
                2020-03-25 20:45:30.354 - info: tankerkoenig.0 (2107) Reading data from tankerkoenig ...
                2020-03-25 20:45:33.516 - debug: javascript.0 (27740) system.adapter.admin.0: logging false
                2020-03-25 20:45:40.750 - info: host.debian instance system.adapter.javascript.0 started with pid 28289
                2020-03-25 20:45:40.752 - warn: javascript.0 (27740) Got terminate signal. Checking desired PID: 0 vs own PID 27740
                2020-03-25 20:45:40.753 - info: javascript.0 (27740) Stop script script.js.Abfall.abfall_tage
                2020-03-25 20:45:40.754 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Aktivität_bei_Alarm
                2020-03-25 20:45:40.754 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Erkennung_Erdgeschoss
                2020-03-25 20:45:40.754 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Erkennung_Haustüre
                2020-03-25 20:45:40.755 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Erkennung_Obergeschoss
                Er scheint dann auch anzufangen die Skripte zu stoppen
                Kann man aus dem Log was erkennen?
                #47
                @Uli977 sagte in Javaskript Adapter:
                Ja!
                Swap ist aufgebraucht - also RAM auch
                Bitte keine Screenshot von Codes, sondern diesen als Text in Code-Tags posten, ggf. noch mit Spoiler
                • sigi234S sigi234
                  @sigi234
                  O Offline
                  O Offline
                  Oli
                  #48
                  @sigi234
                  ja, jedoch ohne Erfolg
                  Oliver
