  4. Javaskript Adapter
Javaskript Adapter
javascriptadminiobroker
48 Beiträge 7 Kommentatoren 3.7k Aufrufe 3 Beobachtet
  • Uli977U Uli977
    Ich habe das gleich Phänomen erneut.
    Javascript Adapter geht an/aus/an/aus
    2020-03-25 20:46:11.353 - info: javascript.0 (28289) Stop script script.js.Benachrichtigungen.Pushover_benachrichtigungen
    2020-03-25 20:46:11.353 - warn: javascript.0 (28289) Got terminate signal. Checking desired PID: 28843 vs own PID 28289
    2020-03-25 20:46:11.353 - info: javascript.0 (28289) terminating
    2020-03-25 20:46:11.354 - info: javascript.0 (28289) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-03-25 20:46:11.881 - error: host.debian instance system.adapter.javascript.0 terminated with code 156 (156)
    2020-03-25 20:46:11.881 - info: host.debian Restart adapter system.adapter.javascript.0 because enabled
    2020-03-25 20:46:12.287 - debug: javascript.0 (28843) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-03-25 20:46:12.306 - debug: javascript.0 (28843) Objects client ready ... initialize now
    2020-03-25 20:46:12.308 - debug: javascript.0 (28843) Objects create System PubSub Client
    2020-03-25 20:46:12.308 - debug: javascript.0 (28843) Objects create User PubSub Client
    2020-03-25 20:46:12.309 - debug: javascript.0 (28843) Objects client initialize lua scripts
    2020-03-25 20:46:12.320 - debug: javascript.0 (28843) Objects connected to redis: 127.0.0.1:9001
    2020-03-25 20:46:12.325 - debug: javascript.0 (28843) objectDB connected
    2020-03-25 20:46:12.326 - debug: javascript.0 (28843) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-03-25 20:46:12.331 - debug: javascript.0 (28843) States create User PubSub Client
    2020-03-25 20:46:12.332 - debug: javascript.0 (28843) States create System PubSub Client
    2020-03-25 20:46:12.342 - debug: javascript.0 (28843) States connected to redis: 127.0.0.1:9000
    2020-03-25 20:46:12.342 - debug: javascript.0 (28843) statesDB connected
    2020-03-25 20:46:12.979 - info: javascript.0 (28843) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.17.0
    2020-03-25 20:46:13.025 - debug: javascript.0 (28843) Loaded TypeScript definitions for node: ["@types/node/index.d.ts","@types/node/base.d.ts","@types/node/globals.d.ts","@types/node/assert.d.ts","@types/node/async_hooks.d.ts","@types/node/buffer.d.ts","@types/node/child_process.d.ts","@types/node/cluster.d.ts","@types/node/console.d.ts","@types/node/constants.d.ts","@types/node/crypto.d.ts","@types/node/dgram.d.ts","@types/node/dns.d.ts","@types/node/domain.d.ts","@types/node/events.d.ts","@types/node/fs.d.ts","@types/node/http.d.ts","@types/node/http2.d.ts","@types/node/https.d.ts","@types/node/inspector.d.ts","@types/node/module.d.ts","@types/node/net.d.ts","@types/node/os.d.ts","@types/node/path.d.ts","@types/node/perf_hooks.d.ts","@types/node/process.d.ts","@types/node/punycode.d.ts","@types/node/querystring.d.ts","@types/node/readline.d.ts","@types/node/repl.d.ts","@types/node/stream.d.ts","@types/node/string_decoder.d.ts","@types/node/timers.d.ts","@types/node/tls.d.ts","@types/node/trace_events.d.ts","@types/node/tty.d.ts","@types/node/url.d.ts","@types/node/util.d.ts","@types/node/v8.d.ts","@types/node/vm.d.ts","@types/node/worker_threads.d.ts","@types/node/zlib.d.ts"]
    2020-03-25 20:46:13.036 - debug: javascript.0 (28843) Loaded TypeScript definitions for request: []
    2020-03-25 20:46:13.037 - info: javascript.0 (28843) requesting all states
    2020-03-25 20:46:13.037 - info: javascript.0 (28843) requesting all objects
    2020-03-25 20:46:14.140 - info: javascript.0 (28843) received all states
    2020-03-25 20:46:14.501 - info: javascript.0 (28843) received all objects
    2020-03-25 20:46:14.930 - debug: javascript.0 (28843) system.adapter.admin.0: logging true
    2020-03-25 20:46:14.935 - info: javascript.0 (28843) Start javascript script.js.Abfall.abfall_tage
    2020-03-25 20:46:14.971 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.restmuell angelegt
    2020-03-25 20:46:14.972 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.blauetonne angelegt
    2020-03-25 20:46:14.972 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.biomuell angelegt
    2020-03-25 20:46:14.972 - info: javascript.0 (28843) script.js.Abfall.abfall_tage: State muell.gelbersack angelegt
    2020-03-25 20:45:19.525 - info: javascript.0 (27740) script.js.Abfall.abfall_tage: Der nächste Müll ist in 0 Tagen
    2020-03-25 20:45:30.354 - info: tankerkoenig.0 (2107) Reading data from tankerkoenig ...
    2020-03-25 20:45:33.516 - debug: javascript.0 (27740) system.adapter.admin.0: logging false
    2020-03-25 20:45:40.750 - info: host.debian instance system.adapter.javascript.0 started with pid 28289
    2020-03-25 20:45:40.752 - warn: javascript.0 (27740) Got terminate signal. Checking desired PID: 0 vs own PID 27740
    2020-03-25 20:45:40.753 - info: javascript.0 (27740) Stop script script.js.Abfall.abfall_tage
    2020-03-25 20:45:40.754 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Aktivität_bei_Alarm
    2020-03-25 20:45:40.754 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Erkennung_Erdgeschoss
    2020-03-25 20:45:40.754 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Erkennung_Haustüre
    2020-03-25 20:45:40.755 - info: javascript.0 (27740) Stop script script.js.Alarmanlage_und_Anwesenheit.ALARM_Erkennung_Obergeschoss
    Er scheint dann auch anzufangen die Skripte zu stoppen
    Kann man aus dem Log was erkennen?
    sigi234S Online
    sigi234S Online
    @Uli977
    Trial & Error
    Alle JS stoppen und einzeln aktivieren.
    • E Offline
      e-s
      schrieb am zuletzt editiert von e-s
      hmmm, habe seit heute auch ständige neustarts.
      Hatte vorhin ein neues script gebastelt was den js komplett abgeschossen hat, was meines Erachtens auch nicht passieren dürfte. Dieses Testscript ist aber aus, trotzdem startet er immer wieder neu.
      Edit: alle scripte aus und trotzdem ständige neustarts mit dem fehlercode 156.
      Hatte ansonsten meinen ubuntu server heute seit langen wegen updates neu gestartet.
      Im debug Log ist nichts zu sehen, bei Silly kommt zwar enorm viel aber es fällt nichts auf.
      Vielleicht müsste hier @apollon77 was dazu sagen
      Edit2:
      iobroker per ssh beendet und neu gestartet, jetzt scheint Ruhe zu sein.
      O 1 Antwort Letzte Antwort
      • Uli977U Uli977
        @Uli977 sagte:
        Extrem hohe CPU-Belastung durch die Javascript-Instanz. Vermutlich hast Du eine Endlos-Schleife programmiert.
        • E e-s
          Edit2:
          O Offline
          O Offline
          Oli
          schrieb am zuletzt editiert von Oli
          @e-s, @paul53
          das ist bei mir seit heute auch so, obwohl ich keine Scripte erstellt habe
          host.ioBroker	2020-03-25 23:47:00.035	error	Caught by controller[0]: 18: 0x321b38b5bf7d
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 17: 0xbd5051 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 16: 0xfce729 v8::internal::JsonStringifier::Stringify(v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 15: 0xfcd9cd v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<false>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 14: 0xfc88bb v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::i
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 13: 0xfc80a1 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 12: 0xfc846e v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.034	error	Caught by controller[0]: 11: 0x1204280 v8::internal::IncrementalStringBuilder::Extend() [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 10: 0xed403b v8::internal::Factory::NewRawTwoByteString(int, v8::internal::PretenureFlag) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 9: 0xf043f1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 8: 0xf01784 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 7: 0xf00e52 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 6: 0xef4d78 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 5: 0xef4c72 [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.033	error	Caught by controller[0]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.032	error	Caught by controller[0]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.032	error	Caught by controller[0]: 2: 0x8fa0dc [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.032	error	Caught by controller[0]: 1: 0x8fa090 node::Abort() [io.javascript.0]
          host.ioBroker	2020-03-25 23:47:00.031	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          Oliver
          • O Oli
            @e-s, @paul53
            @Oli sagte:
            Das ist etwas Anderes.
              @Oli sagte:
              sigi234S Online
              sigi234S Online
              @paul53 sagte in Javaskript Adapter:
              @Oli sagte:
              Jupp, hast @Oli ev. einen Adapter installiert/aktualisiert?
              • sigi234S sigi234
                @Oli sagte:
                O Offline
                O Offline
                Oli
                @sigi234
                eigentlich nur die offiziellen, außer den RSS-Feed Adapter und den Corona Adapter.
                Oliver
                • O Oli
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @Oli sagte in Javaskript Adapter:
                  Corona Adapter.
                  Auf diesen Tippe ich wegen der Meldung:
                  Dieser blockiert auch mein System wenn ich damit in den Einstellungen was mache, da er sehr Speicherintensiv ist am Anfang.
                  • sigi234S sigi234
                    Corona Adapter.
                    O Offline
                    O Offline
                    Oli
                    @sigi234
                    die Meldung kam aber nach der Deinstallation des Adapters
                    Oliver
                    • O Oli
                      @sigi234
                      sigi234S Online
                      sigi234S Online
                      @sigi234
                      Schon mal neu gestartet?
                      • Uli977U Uli977
                        @Uli977 sagte in Javaskript Adapter:
                        Ja!
                        Swap ist aufgebraucht - also RAM auch
                        Bitte keine Screenshot von Codes, sondern diesen als Text in Code-Tags posten, ggf. noch mit Spoiler
                        • sigi234S sigi234
                          @sigi234
                          O Offline
                          O Offline
                          Oli
                          @sigi234
                          ja, jedoch ohne Erfolg
                          Oliver
