  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 424.1k Aufrufe 101 Beobachtet
  • M Online
    M Online
    michihorn
    #841
    Ich habe auch mal wieder einen gelben Adapter. Ging 10 Tage gut, heute ist wieder Schluß.
    Die selben Fehlermeldungen wie zuvor.
    smartgarden.0	2022-05-25 12:56:33.205	info	(23704) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0	2022-05-25 12:56:33.204	info	(23704) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0	2022-05-25 12:56:33.199	info	(23704) 3/ getConnection: trying to connect again in 500 seconds
    smartgarden.0	2022-05-25 12:56:33.199	info	(23704) 3/ getConnection: returned connection error: request returned 429
    smartgarden.0	2022-05-25 12:56:33.199	info	(23704) 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0	2022-05-25 12:56:33.199	error	(23704) Error: request returned 429
    smartgarden.0	2022-05-25 12:56:33.199	info	(23704) 3/ get_locations failure:..return with error
    smartgarden.0	2022-05-25 12:56:33.198	info	(23704) 3/ get_locations failure: response.statusCode/Message=429/
    smartgarden.0	2022-05-25 12:56:33.198	info	(23704) 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0	2022-05-25 12:56:33.051	info	(23704) 3/ ---> State change by device: state sg.0.info.RateLimitCounter changed, (ack = true)
    smartgarden.0	2022-05-25 12:56:33.038	info	(23704) 3/ incrementLimitCounter: new counters : y2022 / m2022-05: 5914 / d2022-05-25: 243 / hr10: 18 / last30days: 6895 / last31days: 6895
    smartgarden.0	2022-05-25 12:56:33.036	info	(23704) 3/ get_locations ...
    smartgarden.0	2022-05-25 12:56:33.035	info	(23704) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    smartgarden.0	2022-05-25 12:56:33.035	info	(23704) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
    smartgarden.0	2022-05-25 12:56:33.034	info	(23704) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    smartgarden.0	2022-05-25 12:56:32.742	info	(23704) 3/ ---> State change by device: state sg.0.info.RateLimitCounter changed, (ack = true)
    smartgarden.0	2022-05-25 12:56:32.728	info	(23704) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0	2022-05-25 12:56:32.721	info	(23704) 3/ incrementLimitCounter: new counters : y2022 / m2022-05: 5913 / d2022-05-25: 242 / hr10: 17 / last30days: 6894 / last31days: 6894
    smartgarden.0	2022-05-25 12:56:32.720	info	(23704) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0	2022-05-25 12:56:32.719	info	(23704) 3/ connecting to Gardena Smart System Service ...
    smartgarden.0	2022-05-25 12:56:32.719	info	(23704) 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0	2022-05-25 12:56:32.719	info	(23704) 3/ connectToGardena...
    smartgarden.0	2022-05-25 12:56:32.718	info	(23704) 3/ getConnection...
    smartgarden.0	2022-05-25 12:56:12.947	error	(23704) Error: sendCommand: command not send, because not connected to Gardena Webservice
    smartgarden.0	2022-05-25 12:56:12.943	info	(23704) 3/ ---> Command should be sent to device: state sg.0.L_ae1e.D_b9ff.S_MOWER_cbtg.activity_control_i changed, START_DONT_OVERRIDE (ack = false)
    • JohGreJ Offline
      JohGreJ Offline
      JohGre
      #842
      @michihorn
      das selbe wie in deinem letzten Problem-Post. Rate-Limit überschritten, siehe Auszug aus der API-Beschreibung
      Rate Limits
      Rate limits are in place to prevent malicious use of the API that would impact other users.
      Each application has the following limits:
      Throttling occurs if average call rate exceeds one call every fifteen minutes.
      Quota of 3'000 requests per month.
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      • JohGreJ JohGre
        @michihorn
        Rate Limits
        M Online
        M Online
        michihorn
        #843
        @johgre Kannst du mir sagen was ich in der Konfig des Adapters einzutragen habe?
        JohGreJ S 2 Antworten Letzte Antwort
        • M michihorn
          JohGreJ Offline
          JohGreJ Offline
          JohGre
          #844
          @michihorn Das sind meine Einstellungen und da hatte ich den 429 noch nie
          • JohGreJ JohGre
            M Online
            M Online
            michihorn
            #845
            @johgre OK Danke ich übernehme die mal
            oberfraggerO 1 Antwort Letzte Antwort
            • M michihorn
              oberfraggerO Offline
              oberfragger
              #846
              @michihorn Ich habe diese settings und auch kein Problem.
              • M michihorn
                stevie77
                #847
                @michihorn sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                Man korrigiere mich, aber die Einstellungen allein sind das ja nicht (unbedingt). Bei mir war ein von mir unbedacht geschriebenes Skript der Auslöser, ich hatte schlicht zu oft den Status eines Geräts abgefragt bzw. gesetzt. Erst als ich das geändert habe, war das Problem weg.
                jpgorganizerJ 1 Antwort Letzte Antwort
                • S stevie77
                  jpgorganizerJ Offline
                  jpgorganizer
                  #848
                  @stevie77
                  korrekt
                  @michihorn
                  durch Änderung der Einstellungen kann ich mir überhaupt nicht vorstellen, wie es da zu einem 403 kommen kann bzw. wie man ihn dann wieder umgehen könnte.
                  Wie @stevie77 schon schrieb, ich tippe darauf, dass du bewusst oder unbewusst eine Loop gebaut hast, die regelmäßig Befehle sendet. Da reicht es schon alle 5 Minuten etwas zu tun, dann bist du nach ~10 Tagen bei 3000 Befehlen und hast das Limit gerissen.
                  smartgarden Adapter für GARDENA smart system
                  Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
                  • jpgorganizerJ jpgorganizer
                    Hallo liebe ioBroker Gemeinde,
                    da Gardena in 2019 eine Websocket Schnittstelle für die Smart Geräte wie Mähroboter, Bewässerungsanlage (smart irrigation control) veröffentlicht hat und es m.W. noch keinen Adapter dafür gibt, habe ich in den vergangenen Wochen einen Adapter dafür entwickelt.
                    Ich bitte euch nun diesen zu testen. Für Fragen, Fehler etc. bitte diesen Thread nutzen. Ich werde versuchen die Fragen zu beantworten und auch Fehler zu beheben.
                    Der Adapter liegt in github unter https://github.com/jpgorganizer/ioBroker.smartgarden.
                    Viele Grüße
                    jpgorganizer
                    stevie77
                    #849
                    Ich habe mal ne Frage.
                    Ich habe für jeden Tag beispielsweise mähen von 10 bis 18 Uhr eingestellt. Ich schicke den Mäher um 15 Uhr mit PARK_UNTIL_NEXT_TASK zurück ins Häuschen, da der Regenmesser eine bestimmte Menge Regen meldet. Das funktioniert auch. Nur fängt er danach wieder an zu mähen. Ich hätte jetzt gedacht, dass er Pause bis zum nächsten Tag um 10 Uhr hat, wenn es wieder losgehen soll. Oder ist PARK_UNTIL_NEXT_TASK so zu verstehen, dass er nach ner Weile (wenn Batterie wieder voll?) wieder loslegt, da der aktuelle Task (bis 18 Uhr) noch nicht abgeschlossen ist?
                    • JohGreJ Offline
                      JohGreJ Offline
                      JohGre
                      #850
                      @stevie77 Ich machs mit PARK_UNTIL_FURTHER_NOTICE
                      • S stevie77
                        jpgorganizer
                        #851
                        @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                        was sagt die Gardena App, wenn du den Mäher heimgeschickt hast? Die zeigt doch, wann es wieder weitergeht.
                        @johgre sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                        ich auch. Hoffentlich frägt jetzt keiner warum. Ich kann es nicht mehr sagen. Ist bei mir in meiner eigenen App so eingestellt seid ewiger Zeit.
                        • JohGreJ JohGre
                          stevie77
                          #852
                          @johgre Aber dann startet der Mäher am nächsten Tag nicht wieder, ne? Also nicht nach dem App-Programm. Du hast dann dein Programm vollständig im ioBroker und startest ihn dann wohl auch wieder darüber, oder?
                          JohGreJ 1 Antwort Letzte Antwort
                          • S stevie77
                            JohGreJ Offline
                            JohGreJ Offline
                            JohGre
                            #853
                            @stevie77 Ich starte den Zeitplan wieder um 6:00 Uhr mit START_DONT_OVERRIDE
                            Ist aber alles gut beschrieben in der Adapter ReadMe
                              stevie77
                              #854
                              @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                              Das ist ja gerade das verwirrende: Die sagte Nächster Zeitplan: Morgen um 10:30 Uhr. Eine halbe Stunde später hab ich ihn aber auch schon wieder laufen sehen.
                              Inzwischen habe ich aber noch ganz andere Probleme gehabt: Ich hab einen Objekt-State geloggt und zum gleichen Zeitpunkt wurde im Skript was anderes geloggt als im Objektbaum. Hat sich dann herausgestellt, dass irgendwie die Device-Nummer anders war in meinem Skript als im Objektbaum. Ist sowas möglich, dass sich die irgendwie geändert hat über den Winter? Momentan verstehe ich das nicht, aber ich habe jetzt mal den Objektbaum komplett neu anlegen lassen, die Device-Nummer ins Skript übernommen und kontrolliere das morgen nochmals (falls es wieder regnet). Verstehe irgendwie nicht, wie das überhaupt (teilweise) funktionieren konnte. Ich muss mal abwarten und nochmals kontrollieren...
                              • JohGreJ JohGre
                                stevie77
                                #855
                                @johgre Ja, ich überlasse die Zeiten komplett der Gardena-App. Bei PARK_UNTIL_FURTHER_NOTICE würde der Mäher in meinem Fall nicht mehr starten, deswegen scheidet das aus (wenn ich die Hilfe sprachlich richtig deute).
                                - um den aktuellen Vorgang abzubrechen, zur Ladestation zurückkehren und ignorieren
                                Zeitplan verwenden Zeichenfolge PARK_UNTIL_FURTHER_NOTICE
                                Leider steht die Antwort zu meiner Frage zu PARK_UNTIL_NEXT_TASK nicht drin: Ist der aktuelle Vorgang erledigt, wenn einmal abgebrochen, obwohl der Vorgang noch ein paar Stunden dauern würde? Man sollte es annehmen...ich meine heute das Gegenteil beobachtet zu haben. Aber ich muss das nochmals gegenchecken.
                                - um den aktuellen Vorgang abzubrechen und zur Nutzung der Ladestation zurückzukehren
                                Zeichenkette PARK_UNTIL_NEXT_TASK
                                  berndpehome
                                  #856
                                  Bei mir das selbe, habe ihn heute per PARK_UNTIL_NEXT_TASK heimgeschickt und später fuhr er wieder obwohl als er in der Ladestation war nächster Start Morgen in der APP stand.
                                  Das hat letztes Jahr funktioniert aber jetzt nicht mehr, ich habe das heuer schon einige Male beobachtet aber dachte mir nur eventuell hat sich der IOBROKER verschluckt aber wenn ich hier lese das ich nicht der einzige damit bin wird es wohl am Adapter oder Gardena liegen.
                                  • B berndpehome
                                    jpgorganizer
                                    #857
                                    @berndpehome sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                    am Adapter liegt das nicht, der reicht den Befehl nur durch. Was Gardena draus macht liegt ausserhalb der Einflußsphäre des Adapters
                                    Aber btw., ich habe dieses Jahr schon mehrere Dinge beobachtet, bei denen ich mir zu 99,9% sicher bin, dass das vergangenes Jahr anders war.
                                    • JohGreJ Offline
                                      JohGreJ Offline
                                      JohGre
                                      #858
                                      Prinzipiell lasse ich ihn auch per APP-Zeitplan laufen, nur wenn es regnet schicke ich ihn nach Hause PARK_UNTIL_FURTHER_NOTICE , wenn's dann wieder aufgehört hat lass ich ihn weitermähen.
                                      Regenerkennung mache ich mit dem Netatmo Regenmesser, der hat einen Datenpunkt mit der Regensumme der letzten Stunde. Hat es wieder aufgehört starte ich ihn immer mit einer Duration bis 17:00 Uhr, das ist meine APP-Ende-Mähzeit.
                                      Und das wars dann auch schon und wie schon geschrieben um 6:00 Uhr setzte ich den Zeitplan quasi wieder in Betrieb START_DONT_OVERRIDE.
                                      • JohGreJ JohGre
                                        oberfragger
                                        #859
                                        @johgre Stell doch mal bitte dein Blockly bzw. Script ein.
                                        Danke.
                                          stevie77
                                          #860
                                          @jpgorganizer Ich kann meinerseits Entwarnung geben. Nachdem ich gestern die Device-ID angepasst hatte, fuhr der Kleine heute nach einem von Netatmo übermittelten Regenschauer um 12:53 Uhr mit PARK_UNTIL_NEXT_TASK ins Häuschen und regt sich seitdem nicht mehr.
                                          Funktioniert also nach wie vor (zumindest bei mir). Muss gestern wohl ein niedriger Akkustand und nicht der zeitgleiche Regenschauer gewesen sein, der den Mäher zurück schickte? Allerdings habe ich ganz sicher gesehen in der App, dass er geparkt war und erst am nächsten Tag wieder starten wollte.
                                          Hat vielleicht mit der falschen Device-ID zu tun, die komischerweise auch keinen Skriptfehler auslöste. Aber vielleicht ist das auch normal, dass es kein direktes Feedback gibt. Ich hatte nur im Skript-Log nachgesehen, nicht direkt unter dem Menüpunkt Protokolle für alle Adapter. Wie auch immer, heute hat jedenfalls alles funktioniert wie es soll.
