  4. TR-064 Problem
TR-064 Problem
234
24 Beiträge 6 Kommentatoren 3.8k Aufrufe 5 Beobachtet
  • K Offline
    kg36304
    Ich weiß, der ein oder Andere kann es nicht mehr hören.
    Ich habe alle möglichkeiten und Lösungen durchprobiert, trotzdem bleibt der Adapter rot.
    Neuen Benutzer angelegt.
    über die Konsole die Befehle eingegeben
    die Community Version aufgespielt
    trotzdem rot.
    hier ein Log-Auszug
    host.raspberrypi4-iob	2020-02-21 07:48:16.695	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.raspberrypi4-iob	2020-02-21 07:48:16.695	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi4-iob	2020-02-21 07:48:16.695	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    host.raspberrypi4-iob	2020-02-21 07:48:16.695	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.raspberrypi4-iob	2020-02-21 07:48:16.695	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.raspberrypi4-iob	2020-02-21 07:48:16.695	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
    host.raspberrypi4-iob	2020-02-21 07:48:16.694	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2491:65)
    host.raspberrypi4-iob	2020-02-21 07:48:16.694	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
    host.raspberrypi4-iob	2020-02-21 07:48:16.694	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
    host.raspberrypi4-iob	2020-02-21 07:48:16.694	error	Caught by controller[0]: ReferenceError: secret is not defined
    tr-064.0	2020-02-21 07:48:16.171	info	(30151) Terminated (NO_ERROR): Without reason
    tr-064.0	2020-02-21 07:48:16.170	info	(30151) terminating
    tr-064.0	2020-02-21 07:48:16.144	error	(30151) ReferenceError: secret is not defined at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49) at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.
    tr-064.0	2020-02-21 07:48:16.143	error	(30151) uncaught exception: secret is not defined
    tr-064.0	2020-02-21 07:48:16.054	info	(30151) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
    host.raspberrypi4-iob	2020-02-21 07:48:13.991	info	instance system.adapter.tr-064.0 started with pid 30151
    host.raspberrypi4-iob	2020-02-21 07:48:13.969	info	"system.adapter.tr-064.0" enabled
    vllt. hat jemand noch nen guten Rat. Ich möchte die Anwesenheitskontrolle damit steuern oder geht das auch noch anders ohne diesen Adapter?
    • K kg36304
      trotzdem rot.
      hier ein Log-Auszug
      crunchipC Offline
      crunchipC Offline
      @kg36304 sagte in TR-064 Problem:
      Community Version
      du hast den normalen tr-64, was auch richtig ist, jedoch steht bei dir v 3.2.0? Aktuell verfügbar im latest v 3.1.4
      edit, gerade gesehen 3.2.0 auf git
      bin mir nicht sicher was damit gemeint ist, Zugangsdaten...benutzer passwort vllt?
      EDIT: hab gerade die version 3.2.0 getestet, selber Fehler, also eine version zurück gehen, dann sollte es gehen
      • K Offline
        kg36304
        OK, wie gehe ich eine Version zurück?
        chris12205C 1 Antwort Letzte Antwort
        • K Offline
          kg36304
          Ok, hab es gefunden und teste mal. Danke
          • K Offline
            kg36304
            So, bin eine Version zurück, jetzt ist er Grün, Danke für deine Hilfe.
            • K Offline
              kg36304
              Moin,
              jetzt habe ich den Adapter am laufen aber das nächste Problemchen.
              Ich habe folgendes Blocky am laufen:
              Es fuktioniert auch fas richtig, wenn Kai das Haus verlässt bekomme ich folgende Nachrichten per Telegram:
              Kai ist weg gegangen.
              1 Min später
              Kai ist nach Hause gekommen.
              1 Min später
              1 Min später
              1 Min später
              Dann ist ruhe!
              Wenn kai dann nach Hause kommt, kommte einmal die Meldung:
              An was liegt es, dass oben die Meldungen so oft kommen? Einmal "Kai ist weg gegangen" würde reichen.
              Liegt es am Blockly oder an was?
              Danke.
              • K kg36304
                Moin,
                1 Min später
                1 Min später
                1 Min später
                1 Min später
                Dann ist ruhe!
                Danke.
                crunchipC Offline
                crunchipC Offline
                @kg36304 welchen Router, Fritzbox, Unifi?
                • K Offline
                  kg36304
                  Moin, ist ne FritzBox 7490
                  • K kg36304
                    crunchipC Offline
                    crunchipC Offline
                    @kg36304
                    ok, und welche Software ist drauf, original oder beta?
                    gibt/gab Probleme mit der zeitlichen Erkennung der Netzwerkgeräte.
                    Ist denk ich das ähnliche Problem wie auch bei Unifi, das die Geräte im System "zurückgehalten" werden.
                    Heisst, die Software wartet bis das Gerät wirklich weg ist, daher auch der Zeitversatz.
                    ist das Gerät xy nur kurzfristig weg, Verbindung verloren,reconnect, Bandwechsel, etc...oder wirklich nicht mehr da....und dadurch kommt das Problem, das sich das Gerät aus/ein/aus loggt....
                    so ist meine Vermutung
                    Problem könntest damit abfangen, einen timeout in deinem blockly einzubauen, folglich verzögert sich dann halt die Meldung abwesend
                    • K Offline
                      kg36304
                      Ist die FritzOS 7.12 original.
                      • K kg36304
                        crunchipC Offline
                        crunchipC Offline
                        @kg36304 ok, ich verwende die aktuelle beta, jedoch habe ich bei mir ein USG dahinterhängen, somit läuft das bei mir nicht mehr über die Fritzbox.
                        Du hast die möglichkeit deiner Fritzbox ein update zu verpassen(aber dann bitte genau die Hinweise beachten, was sich alles ändert) oder eben dein blockly umbauen
                        • K Offline
                          kg36304
                          Also ich würde gerne mein Blocky umbauen.
                          Wo kommt den der Timeout genau hin?
                          Muss ja genau genommen nur in den Teil wo man geht.
                          Der Teil kommen funktioniert ja.
                            SSW-mcor
                            schrieb am zuletzt editiert von SSW-mcor
                            Ich hab es so gemacht:
                            Sind beide Geräte in Ping und tr-064 false, soll die Meldung nach den Minuten kommen...
                            Um so mehr Zeit, desto sicher die Aussage - soll ja net bei WLAN-Verlust melden 🤔
                            Funktioniert und reicht mir 😀
                            • K Offline
                              kg36304
                              Ok, hab es soweit hin bekommen. Allerdings mit 10 Min. Timeout.
                              Ich dachte bei TR-064 kann man auch die Anwesenheit von Android Handys sehen wenn Sie im Standby sind.
                              Bei dem Handy meiner Frau (Galaxy S9) verschwindet die Anwesenheit sobald das Display aus geht 8-).
                              Gibt es da möglichkeiten?
                              • K kg36304
                                SSW-mcor
                                @kg36304: Liegt wohl eher an der Handyeinstellung...
                                • K kg36304
                                  chris12205C Offline
                                  chris12205C Offline
                                  chris12205
                                  @kg36304 said in TR-064 Problem:
                                  leider habe ich es nicht verstanden. Wie geht es?
                                  • K Offline
                                    kg36304
                                    Bei mir war es so, wenn Du auf die 3 Punkte beim Adapter drückst, bekommst Du die Möglichkeit geboten eine Version niedriger zu nehmen.
                                    • chris12205C Offline
                                      chris12205C Offline
                                      chris12205
                                      danke, jetzt läuft die Version 3.0.1 . Jedenfalls wird der Adapter grün.
                                      Was ich nur nicht verstehe woher ich jetzt für meine Anwesendheitserkennung für Blockly jetzt die Objekte der angemeldeten Wlan Devices bekomme?
                                      Da taucht in den Objekten nichts auf.
                                      • K Offline
                                        kg36304
                                        Du musst unter dem Schraubenschlüssel (Instanzen) die Geräte welche Du überwachen möchtest auswählen. Unter dem Reiter Geräte und dann Gerät suchen, werden alle aktuell im Lan und Wlan angemeldeten Geräte aufgelistet.
                                        Diese erscheinen dann in den Objekten unter dem Adapter TR-064 und dort unter devices.
                                        Sorry, bin gerade nicht zu Hause, daher kann ich kein Bild mit senden.
                                        • S SSW-mcor
                                          TorstenU
                                          @SSW-mcor
                                          Hallo SSW-mcor,
                                          ich würde gerne dein Blockly-Programm zur Anwesenheitserkennung verwenden.
                                          Könntest du es mir zur Verfügung stellen?
                                          MfG
                                          Torsten
                                          Viele Grüße!
                                          Torsten
                                          K 1 Antwort Letzte Antwort
