  5. Licht schalten nach Lichtmessung [GELÖST]
25 Beiträge 5 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • YodameisterY Yodameister
    @Jan1 sagte in Licht schalten nach Lichtmessung:
    @Yodameister
    Poste mal Dein Blockly Export.
    Ich bau das später mal ein.
    Super , Danke schon mal
    <block type="on" id=":1Dgj/b)/QtLMQ3Hc6JG" x="-787" y="-112">
    <field name="OID">hm-rpc.1.NEQ0322642.1.LUX</field>
    <statement name="STATEMENT">
    <block type="controls_if" id="lZhxYOrWGolw}mXAERA"> <value name="IF0"> <block type="logic_operation" id="H?Pzd~xv4w?P})0Y?vO[" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="g5D:V9UW@u)l;IZaYN.$"> <field name="OP">LTE</field> <value name="A"> <block type="get_value" id="_7PChaevVy(bAmLyenI2"> <field name="ATTR">val</field> <field name="OID">hm-rpc.1.NEQ0322642.1.LUX</field> </block> </value> <value name="B"> <block type="math_number" id="_@~SN1zp.hsc/~A/@Dp)"> <field name="NUM">8</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="AH?$9~_}?(c1%@}^Hw,">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="get_value" id="@bFIF%ETLeLbF}tS!ac*">
    <field name="OID">hm-rega.0.1263</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="x9GUX~GLN1/rMw|eeOZ{">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="control" id="k^inN@vy,]$9Qu(Eo86~">
    <field name="OID">hm-rpc.1.MEQ1425913.1.LEVEL</field>
    <value name="VALUE">
    <block type="math_number" id="cx|Qe{,EMf2eCB.J9nC|">
    <field name="NUM">0</field>
    </block>
    </value>
    <next>
    <block type="control" id="Jt9DOTSo~Y{(h|j=yNPf">
    <mutation delay_input="true"></mutation>
    <field name="OID">hm-rpc.1.MEQ1731405.1.LEVEL</field>
    <field name="DELAY_MS">1</field>
    <block type="math_number" id=",E?2QhU;F?y2RfgXlT1"> <field name="NUM">0</field> </block> </value> <next> <block type="control" id="786YKl6NX8{pCLl?o{IQ"> <mutation delay_input="true"></mutation> <field name="OID">hm-rpc.1.OEQ0365754.1.LEVEL</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">2</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_number" id="Yr7ez,fJAF1l?ZrQ(COe"> <field name="NUM">0</field> </block> </value> <next> <block type="control" id="p=6?;l^@eTbd-6.dhtaV"> <mutation delay_input="true"></mutation> <field name="OID">hm-rpc.1.MEQ1106339.1.LEVEL</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">3</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_number" id="v#;)moUko3XZ5PHR4Uc)"> <field name="NUM">0</field> </block> </value> <next> <block type="control" id="xfGn}+!E4~5q:xTnnmS-"> <mutation delay_input="true"></mutation> <field name="OID">hm-rpc.1.LEQ1021949.1.LEVEL</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">4</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_number" id="|0Db$aA#xz+i9z3VUF]K"> <field name="NUM">0</field> </block> </value> <next> <block type="control" id="5qAB(GP%F:cp!qd^(L=2"> <mutation delay_input="true"></mutation> <field name="OID">hm-rpc.1.MEQ1731510.1.LEVEL</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">5</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_number" id="=_}DT|sg%Y[deB6jw=;9"> <field name="NUM">0</field> </block> </value> <next> <block type="control" id="+6Yc6b.X;)}scaXEjF=1"> <mutation delay_input="true"></mutation> <field name="OID">hm-rpc.1.LEQ1028657.1.LEVEL</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">6</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_number" id="+UY$hylO[l$]3$ms?LC5"> <field name="NUM">0</field> </block> </value> <next> <block type="control" id="2G4+V*{y=rfVsd5tTwrk"> <mutation delay_input="true"></mutation> <field name="OID">hm-rpc.1.MEQ0392887.1.LEVEL</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">7</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_number" id="2RL2+QGvNXXAE?tGUW0">
    </block>
    </value>
    <next>
    <block type="control" id="IFj!qs~OrF83q~o6CHMb">
    <field name="OID">hm-rpc.1.NEQ1687762.1.LEVEL</field>
    <field name="DELAY_MS">8</field>
    <block type="math_number" id="Kp+JxADo#Kffr]z##jQX">
    </block>
    </value>
    <next>
    <block type="control" id="bqz,=R7VY:,n!:bv8aU9">
    <field name="OID">hm-rpc.1.NEQ0682277.1.STATE</field>
    <field name="DELAY_MS">30</field>
    <block type="logic_boolean" id="rYo?yC.)#atd[-F~Zep%">
    </block>
    </value>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </xml>
    dslraserD Offline
    dslraserD Offline
    dslraser
    @Yodameister Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    YodameisterY 1 Antwort Letzte Antwort
      @Yodameister
      <value name="A">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </xml>
      Jan1
      @Yodameister
      Hier mal auf die schnelle:
      <block xmlns="http://www.w3.org/1999/xhtml" type="on" id=":1Dgj/b)/QtLMQ3Hc6JG" x="-837" y="-162">
       <field name="CONDITION">lt</field>
         <block type="timeouts_cleartimeout" id="WEfkA7H|3Sd(t+=M{LSJ">
           <next>
             <block type="timeouts_settimeout" id="f{h{HFR+qyM,iU?=@`8/">
               <field name="DELAY">30</field>
                   <value name="IF0">
                       <value name="A">
                           <value name="A">
                             <block type="on_source" id="8ZgnEpT8)@@wR?sN++:1">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                       <next>
                             </block>
                           </value>
                           <next>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                     </block>
                                                   </value>
                                                   <next>
                                                         </block>
                                                       </value>
                                                       <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </statement>
      </block>
      Den Trigger mal umgestellt auf kleiner als letzer. So tiggert schon mal nichts, wenn es heller wird. Dann den Timeout rein der dafür sorgt, dass nicht sofort was passiert nur weil es mal kurz dunkler war (30s ist nur ein Beispiel). Die Falls wird so nur ausgeführt, wenn der Wert kleiner als letzter war und nach 30 Sekunden immer noch keiner = 8 Lux ist.
      Den UND Teil Deiner FALLS kenne ich nicht. Was sagt dieser DP aus?
      • dslraserD dslraser
        YodameisterY Offline
        Yodameister
        @dslraser
        Sorry , kommt nicht wieder vor
        Grüße
        Maik
        • J Jan1
          @Yodameister
               <next>
                       <value name="IF0">
                           <value name="A">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                           <next>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                     </block>
                                                   </value>
                                                   <next>
                                                         </block>
                                                       </value>
                                                       <next>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
          </block>
          Yodameister
          @Jan1
          Sieht erstmal top aus , auch wenn ich nicht verstehe , baue das gleich mal ein und berichte morgen
          Den UND Teil Deiner FALLS kenne ich nicht. >>> Das ist eine Variable die unterscheidet ob wir daheim sind oder im Urlaub
          Grüße
          Maik
          J 1 Antwort Letzte Antwort
            @Jan1
            Jan1
            @Yodameister
            Im Spoiler ist der Export, dann brauchst nichts nachbauen.
            Warum nennst die Variable nicht einfach Anwesenheit, dann ist das deutlicher was das macht😉
