  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 651.1k Aufrufe 118 Beobachtet
    DarkDevil
    #721
    Die Installation (bzw. das Update) haben schonmal geklappt. Danke dafür.
    Jetzt habe ich aber anscheinend den gleichen Fehler wie BamBam89
    mihome-vacuum.0	2020-04-11 07:47:03.668	info	(28242) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-04-11 07:47:03.668	warn	(28242) Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.0	2020-04-11 07:47:03.667	debug	(28242) Receive <<< Helo <<< 21310020000000000706b6555e9159d8ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-04-11 07:46:58.788	debug	(28242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-04-11 07:46:58.787	debug	(28242) no answer for undefined(id:1) received, giving up
    mihome-vacuum.0	2020-04-11 07:46:55.373	debug	(28242) system.adapter.admin.0: logging true
    mihome-vacuum.0	2020-04-11 07:46:53.786	debug	(28242) sendMsg[3] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-04-11 07:46:48.785	debug	(28242) sendMsg[2] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-04-11 07:46:46.064	debug	(28242) Xiaomi Cloud: Login successful
    mihome-vacuum.0	2020-04-11 07:46:45.241	debug	(28242) system.adapter.admin.0: logging false
    mihome-vacuum.0	2020-04-11 07:46:44.177	info	(28242) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-04-11 07:46:43.784	debug	(28242) sendMsg[1] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-04-11 07:46:43.755	debug	(28242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    • D DarkDevil
      haselchenH Offline
      haselchenH Offline
      haselchen
      #722
      @DarkDevil
      Hast du, wie vorher schonmal geraten, die MiHome App geöffnet ?
        BamBam89
        #723
        Morgen zusammen,
        also ich hab das schon gemacht, allerdings ohne besondere Verbesserung:
        mihome-vacuum.0	2020-04-11 09:33:39.352	debug	(5753) sendMsg[1] >>> {"id":478,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:33:39.349	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:33:39.348	info	(5753) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-04-11 09:33:39.348	debug	(5753) Receive <<< Helo <<< 21310020000000000f9b48a15e9172d3ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-04-11 09:33:34.353	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:33:34.353	debug	(5753) no answer for undefined(id:477) received, giving up
        mihome-vacuum.0	2020-04-11 09:33:29.353	debug	(5753) sendMsg[3] >>> {"id":477,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:33:24.352	debug	(5753) sendMsg[2] >>> {"id":477,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:33:19.351	debug	(5753) sendMsg[1] >>> {"id":477,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:33:19.346	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:33:19.346	info	(5753) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-04-11 09:33:19.346	debug	(5753) Receive <<< Helo <<< 21310020000000000f9b48a15e9172bfffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-04-11 09:33:14.351	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:33:14.350	debug	(5753) no answer for undefined(id:476) received, giving up
        mihome-vacuum.0	2020-04-11 09:33:09.349	debug	(5753) sendMsg[3] >>> {"id":476,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:33:04.349	debug	(5753) sendMsg[2] >>> {"id":476,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:32:59.347	debug	(5753) sendMsg[1] >>> {"id":476,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:32:59.346	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:32:59.346	info	(5753) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-04-11 09:32:59.346	debug	(5753) Receive <<< Helo <<< 21310020000000000f9b48a15e9172abffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-04-11 09:32:54.354	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:32:54.354	debug	(5753) no answer for undefined(id:475) received, giving up
        mihome-vacuum.0	2020-04-11 09:32:49.353	debug	(5753) sendMsg[3] >>> {"id":475,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:32:44.352	debug	(5753) sendMsg[2] >>> {"id":475,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:32:39.351	debug	(5753) sendMsg[1] >>> {"id":475,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 09:32:39.348	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 09:32:39.347	info	(5753) connecting, this can take up to 10 minutes ...~~~~
        • B BamBam89
          Morgen zusammen,
          haselchenH Offline
          haselchenH Offline
          haselchen
          #724
          @BamBam89
          Welcher Sauger welche Firmware Version?
          B 1 Antwort Letzte Antwort
          • haselchenH haselchen
            @BamBam89
            BamBam89
            #725
            @haselchen
            Es handelt sich um einen S502-00
            Firmware 3.5.7_002008
            • B BamBam89
              @haselchen
              haselchenH Offline
              haselchenH Offline
              haselchen
              #726
              @BamBam89
              Habe ich auch beides.
              Welche Adapter Version hast du drauf?
              Mit RC Nummer wenn du hast.
                @BamBam89
                BamBam89
                #727
                @haselchen
                Version 2.0.9. Mit RC Nummer kann ich aber nichts anfangen :-)
                • B BamBam89
                  @haselchen
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #728
                  @BamBam89
                  Auf debug stellen über den Experten Modus und dann den Adapter neu starten. Im Log steht dann die RC Nummer hinter 2.0.9
                    @BamBam89
                    BamBam89
                    #729
                    @haselchen
                    Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                    • B BamBam89
                      @haselchen
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #730
                      @BamBam89
                      Ist aktuell.
                      Und das Problem ist, dass er sich nicht verbindet?
                      Oder habe ich da was überlesen?
                      • DiginixD Diginix
                        @iphone333 Dann passt was nicht. Sollte eigentlich so im RAW von fan_power aussehen:
                        Welche Adapter Version nutzt du?
                        ltsalvatore
                        #731
                        @Diginix sagte in Test Adapter mihome-vacuum v2.0.x:
                        Hi Dginix,
                        ich wollte mal fragen, ob es mittlerweile ein lösung zu dem problem gibt.
                        ich habe auch das problem wie @iphone333, dass trotz aktuellen adapter v2.0.7 über den wert von fan_power* keine änderungen vorgenommen werden können.
                        auch bei mir sind die alten werte noch drin gewesen, habe diese um die von dir genannten ergänzt.. hilft aber leider nichts..
                        kuriose ist dabei, wenn ich einen wert über vis eintrage, dann funktioniert es einwandfrei..
                        nur über blockly script (sowohl text als auch zahl) nicht.
                        haselchenH L 2 Antworten Letzte Antwort
                          @BamBam89
                          Ist aktuell.
                          BamBam89
                          #732
                          @haselchen
                          also wenn ich das richtig verstehe, müsste ich ja über die Buttons die entsprechenden Befehle ausgeben können:
                          Da tut sich aber nichts. Er wird auch in den Instanzen nicht grün
                          • B BamBam89
                            @haselchen
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #733
                            @BamBam89
                            Zeig mal bitte deine Adpatereinstellungen
                            • L ltsalvatore
                              Hi Dginix,
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #734
                              @ltsalvatore
                              Aktuell wäre 2.0.9 RC7
                              Habe das Blockly aus dem Forum.
                              Es wird anscheinend von 100% ausgegangen für die einzelnen Stufen.
                              L 1 Antwort Letzte Antwort
                                @DarkDevil
                                DarkDevil
                                #735
                                @haselchen jo, das habe ich. Allerdings ohne Veränderung. Der Adapter bleibt gelb
                                  @BamBam89
                                  BamBam89
                                  #736
                                  @haselchen
                                  • B BamBam89
                                    @haselchen
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #737
                                    @BamBam89
                                    Hast du Valetudo drauf?
                                    Ob ja oder nein, deaktiviere den Punkt und starte den Adapter mal neu.
                                    Meinetwegen öffne nach ein paar Sekunden nach Adapterstart auch die App nochmal.
                                    Edit:
                                    Hast du 2 verschiedene Token?
                                    Dann passt es ja auch nicht.
                                    Der Token von oben, muss unten in manuelle Einstellungen
                                    B 2 Antworten Letzte Antwort
                                      @BamBam89
                                      Edit:
                                      BamBam89
                                      #738
                                      @haselchen
                                      Nein habe ich eigentlich nicht. Die beiden Token schreibt er da ja automatisch rein....
                                      Ich versuche das mal.
                                      • B BamBam89
                                        @haselchen
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #739
                                        @BamBam89
                                        Also Valetudo weg und beide Token gleich (den von oben >GetDevices)
                                          @BamBam89
                                          Edit:
                                          BamBam89
                                          #740
                                          @haselchen said in Test Adapter mihome-vacuum v2.0.x:
                                          @BamBam89
                                          Edit:
                                          Die Daten sind da.... !!! Es läuft!!
                                          Vielen, vielen Dank.
                                          Warum auch immer ob der kurze Token und unten den lange Token drin stand....
                                          Dann werde ich mich jetzt mal an den restlichen Einstellungen versuchen....
                                          und mich dann gegebenenfalls wieder melden :-)
