  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 633.5k Aufrufe 118 Beobachtet
  • S smarti2015
    Hi, wollte update Installieren von 1.1.5 auf Version 2.x aber es kommt immer eine Fehlermeldung:
    host.All-In-One-Tinker	2020-02-20 12:50:29.060	info	iobroker exit 25
    host.All-In-One-Tinker	2020-02-20 12:50:28.043	error	iobroker host.All-In-One-Tinker Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
    host.All-In-One-Tinker	2020-02-20 12:50:28.006	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-02-20T11_50_27_975Z-debug.log
    host.All-In-One-Tinker	2020-02-20 12:50:27.955	info	iobroker This is probably not a problem with npm. There is likely additional logging output above.
    host.All-In-One-Tinker	2020-02-20 12:50:27.954	info	iobroker npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR!
    host.All-In-One-Tinker	2020-02-20 12:50:27.953	info	iobroker errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    host.All-In-One-Tinker	2020-02-20 12:50:27.951	info	iobroker code ELIFECYCLEnpm ERR!
    host.All-In-One-Tinker	2020-02-20 12:50:27.950	info	iobroker ERR!
    host.All-In-One-Tinker	2020-02-20 12:50:27.949	info	iobroker npm
    host.All-In-One-Tinker	2020-02-20 12:50:25.594	info	iobroker /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.18.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    host.All-In-One-Tinker	2020-02-20 12:50:25.593	info	iobroker ERR! System Linux 4.19.69-rockchipnode-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ER
    host.All-In-One-Tinker	2020-02-20 12:50:25.591	info	iobroker node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modu
    host.All-In-One-Tinker	2020-02-20 12:50:25.587	info	iobroker node-pre-gyp ERR! build error
    host.All-In-One-Tinker	2020-02-20 12:50:25.571	info	iobroker /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
    host.All-In-One-Tinker	2020-02-20 12:50:25.569	info	iobroker ERR! System Linux 4.19.69-rockchipgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroke
    host.All-In-One-Tinker	2020-02-20 12:50:25.568	info	iobroker stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Pr
    host.All-In-One-Tinker	2020-02-20 12:50:25.567	info	iobroker gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR!
    host.All-In-One-Tinker	2020-02-20 12:50:25.565	info	iobroker ERR! configure error
    host.All-In-One-Tinker	2020-02-20 12:50:25.564	info	iobroker gyp
    host.All-In-One-Tinker	2020-02-20 12:50:25.529	info	iobroker gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    host.All-In-One-Tinker	2020-02-20 12:50:25.528	info	iobroker Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' fou
    host.All-In-One-Tinker	2020-02-20 12:50:22.082	info	iobroker node-aead-crypto not needed on this system, since all ciphers are natively supported
    Bild Text
    Patchwork 3001P Offline
    Patchwork 3001
    schrieb am zuletzt editiert von Patchwork 3001
    #281
    @smarti2015 Wenn der Adapter nicht installiert werden kann, kann Canvas nicht installiert werden
    npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
    Dann müssen folgende Packete und Bibliotheken selber installiert werden:
    " sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev "
    " sudo npm install canvas --unsafe-perm=true "
    über putty ohne "
    K S 2 Antworten Letzte Antwort
    • B blackeagle998
      @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
      @Patchwork-3001 sagte in Test Adapter mihome-vacuum v2.0.x:
      property
      kannst du bitte mal das debug schicken?
      Habe das gleiche Thema, hier der DEBUG Auszug:
      mihome-vacuum.0	2020-02-20 11:54:12.943	error	(17390) TypeError: Cannot read property '0' of undefined
      mihome-vacuum.0	2020-02-20 11:54:12.430	debug	(17390) update_Map use old mapurl
      mihome-vacuum.0	2020-02-20 11:54:12.430	debug	(17390) update_Map Mimap enabled
      mihome-vacuum.0	2020-02-20 11:54:10.428	error	(17390) TypeError: Cannot read property '0' of undefined
      mihome-vacuum.0	2020-02-20 11:54:09.973	debug	(17390) update_Map got new time:1582196049
      mihome-vacuum.0	2020-02-20 11:54:09.973	debug	(17390) update_Map got new expires:1582197849
      mihome-vacuum.0	2020-02-20 11:54:09.972	debug	(17390) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/7?Expires=xxxxxxxxx&GalaxyAccessKeyId=xxxxxxxxx&Signature=xxxxxxxxxx=
      mihome-vacuum.0	2020-02-20 11:54:09.906	debug	(17390) update_Map need new mapurl
      mihome-vacuum.0	2020-02-20 11:54:09.905	debug	(17390) update_Map Mimap enabled
      mihome-vacuum.0	2020-02-20 11:54:07.903	error	(17390) TypeError: Cannot read property '0' of undefined
      mihome-vacuum.0	2020-02-20 11:54:07.388	debug	(17390) update_Map got new time:1582196047
      mihome-vacuum.0	2020-02-20 11:54:07.388	debug	(17390) update_Map got new expires:1582197847
      MeistertrM Offline
      MeistertrM Offline
      Meistertr
      #282
      @blackeagle998 dann bräuchte uch einen etwas größeren logauszug
      B 1 Antwort Letzte Antwort
      • Patchwork 3001P Patchwork 3001
        über putty ohne "
        K Online
        K Online
        K_o_bold
        #283
        @Patchwork-3001, @Meistertr ,
        bei mir läuft Iobroker in einem Docker-Container.
        Wenn Canvas z.T. manuell installiert werden muss, bedeutet das, dass ich es bei jedem Container Neustart wieder manuell installieren muss. ( Oder ich ändere das Docker-Container Image ).
        Wird das bis zur Stable Version so bleiben, dass man ggf. manuell etwas nachinstallieren muss?
        --> Ich bin am überlegen, ob ich jetzt schon umsteige auf die neue Version.
        Bisher was ich so gelesen habe ist sehr vielversprechend, tolle Arbeit an alle Beteiligten.. 👍
        • S smarti2015
          Bild Text
          dirkhe
          schrieb am zuletzt editiert von dirkhe
          #284
          @K_o_bold Das Problem ist, dass dies eine Abhängigkeit beim Installieren ist, hat mit dem Adapter selber nichts zu tun. Ich weiss nicht, ob man das optional machen kann, ich vermute mal eher nicht.
          K 1 Antwort Letzte Antwort
          • D dirkhe
            K Online
            K Online
            K_o_bold
            #285
            @Meistertr ,
            noch eine andere Frage:
            Mit IOS war die Tokenauslesung ein echter Krampf.
            Außerdem habe ich bei mir die Besonderheit, dass der Roboter in der App nur halblebig integriert ist, da ich das EU Modell gekauft habe aber alle anderen Geräte aus China kommen, habe ich Mainland China im Gateway eingestellt. Dadurch lässt sich der Roboter nicht sauber integrieren, funktioniert aber trotzdem einwandfrei mit dem Iobroker Adapter. Nur die Karte und Zonenreinigung konnte ich nie machen.
            Es wäre also ein echter Mehrwert die neue Version des Adapters. 😀
            Nun zur Frage:
            Die Token Gewinnung geht jetzt wirklich so einfach wie im ersten Post beschrieben?
            Gibt es für das Update aus der Adapterversion 1.1.5 noch Dinge worauf man achten muss?
            • K K_o_bold
              @Meistertr ,
              Nun zur Frage:
              dirkhe
              #286
              @K_o_bold Einfach machen, soviel kannst du ja nicht einstellen, was du verlieren könntest.
                über putty ohne "
                smarti2015
                #287
                @Patchwork-3001 Danke jetzt hat es geklapt. Wo kann ich jetzt eigentlich die Karte im ioBorker abrufen?
                GEEKOM AS 6
                C 1 Antwort Letzte Antwort
                • S smarti2015
                  Coffeelover
                  #288
                  @smarti2015 Die HTML-Karte in einem HTML-Widget (vgl. Anleitung auf Github) oder die GIF in einem IMG Widget.
                  • C Coffeelover
                    smarti2015
                    #289
                    @Coffeelover Ah vielen Dank!
                    GEEKOM AS 6
                    • MeistertrM Meistertr
                      blackeagle998
                      #290
                      @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                      Sorry für die späte Rückmeldung, ich habe aktuell drei Punkte:
                      1. Mir fehlt der Datenpunkt ResumeRoomClean --> ResumeZoneClean existiert, der funktioniert aber nicht, wenn man RoomClean gestartet hat (momentan nutze ich beides parallel)
                      2. Kann man irgendwo die Queue sehen und löschen?
                        Ich möchte nicht immer, dass er noch anstehende Jobs weiterführt, ggf. möchte ich per Schalter sagen, dass er zurück zur Ladestation soll und alle anstehenden Aufträge "vergisst".
                      3. Anbei ein größerer DEBUG LOG Auszug zu dem Error "TypeError: Cannot read property '0' of undefined":
                      mihome-vacuum.0	2020-02-21 08:58:39.044	debug	(6784) 24694
                      mihome-vacuum.0	2020-02-21 08:58:38.278	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:38.278	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:37.543	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:36.727	debug	(6784) requesting params every: 60 Sec
                      mihome-vacuum.0	2020-02-21 08:58:36.277	error	(6784) TypeError: Cannot read property '0' of undefined
                      mihome-vacuum.0	2020-02-21 08:58:35.534	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:35.533	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:34.992	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271914988,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                      mihome-vacuum.0	2020-02-21 08:58:34.222	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271914214,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                      mihome-vacuum.0	2020-02-21 08:58:33.531	error	(6784) TypeError: Cannot read property '0' of undefined
                      mihome-vacuum.0	2020-02-21 08:58:32.834	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:32.833	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:31.224	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271911221,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                      mihome-vacuum.0	2020-02-21 08:58:30.845	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271910430,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                      mihome-vacuum.0	2020-02-21 08:58:30.832	error	(6784) TypeError: Cannot read property '0' of undefined
                      mihome-vacuum.0	2020-02-21 08:58:30.047	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:30.046	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:28.046	error	(6784) TypeError: Cannot read property '0' of undefined
                      mihome-vacuum.0	2020-02-21 08:58:27.325	debug	(6784) update_Map got new time:1582271907
                      mihome-vacuum.0	2020-02-21 08:58:27.325	debug	(6784) update_Map got new expires:1582273707
                      mihome-vacuum.0	2020-02-21 08:58:27.324	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:58:27.237	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:58:27.236	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:25.234	error	(6784) TypeError: Cannot read property '0' of undefined
                      mihome-vacuum.0	2020-02-21 08:58:24.455	debug	(6784) update_Map got new time:1582271904
                      mihome-vacuum.0	2020-02-21 08:58:24.454	debug	(6784) update_Map got new expires:1582273704
                      mihome-vacuum.0	2020-02-21 08:58:24.453	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:58:24.370	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:24.349	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:58:24.348	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:21.010	debug	(6784) 24674
                      mihome-vacuum.0	2020-02-21 08:58:20.278	debug	(6784) update_Map got new time:1582271900
                      mihome-vacuum.0	2020-02-21 08:58:20.278	debug	(6784) update_Map got new expires:1582273700
                      mihome-vacuum.0	2020-02-21 08:58:20.277	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:58:20.197	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:20.187	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:58:20.187	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:17.425	debug	(6784) 24656
                      mihome-vacuum.0	2020-02-21 08:58:16.674	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:16.665	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:16.665	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:15.102	info	(6784) trigger cleaning zone [19720,32832,24549,35282,1]
                      mihome-vacuum.0	2020-02-21 08:58:15.074	debug	(6784) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [19720,32832,24549,35282,1]
                      mihome-vacuum.0	2020-02-21 08:58:15.074	debug	(6784) stateChange mihome-vacuum.0.control.zoneClean {"val":"[19720,32832,24549,35282,1]","ack":false,"ts":1582271895062,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582
                      mihome-vacuum.0	2020-02-21 08:58:15.071	debug	(6784) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1582271895062,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182398690}
                      mihome-vacuum.0	2020-02-21 08:58:15.067	debug	(6784) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582271895062,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142142021}
                      mihome-vacuum.0	2020-02-21 08:58:14.665	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:13.308	debug	(6784) 24656
                      mihome-vacuum.0	2020-02-21 08:58:12.530	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:12.529	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:09.812	debug	(6784) 24656
                      mihome-vacuum.0	2020-02-21 08:58:09.098	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:09.089	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:09.088	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:05.707	debug	(6784) 24661
                      mihome-vacuum.0	2020-02-21 08:58:04.985	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:04.975	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:04.975	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:58:02.250	debug	(6784) 24669
                      mihome-vacuum.0	2020-02-21 08:58:01.515	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:58:01.503	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:58:01.503	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:58.149	debug	(6784) 24548
                      mihome-vacuum.0	2020-02-21 08:57:57.423	debug	(6784) update_Map got new time:1582271877
                      mihome-vacuum.0	2020-02-21 08:57:57.423	debug	(6784) update_Map got new expires:1582273677
                      mihome-vacuum.0	2020-02-21 08:57:57.422	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:57.342	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:57.330	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:57.329	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:54.610	debug	(6784) 24570
                      mihome-vacuum.0	2020-02-21 08:57:53.898	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:53.888	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:53.888	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:50.514	debug	(6784) 24570
                      mihome-vacuum.0	2020-02-21 08:57:49.815	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:49.806	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:49.806	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:47.088	debug	(6784) 24570
                      mihome-vacuum.0	2020-02-21 08:57:46.321	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:46.305	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:46.304	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:42.967	debug	(6784) 24663
                      mihome-vacuum.0	2020-02-21 08:57:42.272	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:42.262	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:42.262	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:39.525	debug	(6784) 24790
                      mihome-vacuum.0	2020-02-21 08:57:38.795	debug	(6784) update_Map got new time:1582271858
                      mihome-vacuum.0	2020-02-21 08:57:38.795	debug	(6784) update_Map got new expires:1582273658
                      mihome-vacuum.0	2020-02-21 08:57:38.794	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:38.739	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:38.727	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:38.727	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:37.540	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:36.727	debug	(6784) requesting params every: 60 Sec
                      mihome-vacuum.0	2020-02-21 08:57:35.314	debug	(6784) 25095
                      mihome-vacuum.0	2020-02-21 08:57:34.604	debug	(6784) update_Map got new time:1582271854
                      mihome-vacuum.0	2020-02-21 08:57:34.603	debug	(6784) update_Map got new expires:1582273654
                      mihome-vacuum.0	2020-02-21 08:57:34.603	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:34.543	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:34.533	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:34.532	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:31.806	debug	(6784) 25095
                      mihome-vacuum.0	2020-02-21 08:57:31.095	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:31.075	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:31.075	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:27.734	debug	(6784) 25095
                      mihome-vacuum.0	2020-02-21 08:57:27.009	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:27.008	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:27.006	info	(6784) trigger cleaning zone [19720,32832,24549,35282,1]
                      mihome-vacuum.0	2020-02-21 08:57:27.006	debug	(6784) use clean trigger from Queue
                      mihome-vacuum.0	2020-02-21 08:57:25.090	debug	(6784) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1582271845086,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182857281}
                      mihome-vacuum.0	2020-02-21 08:57:18.680	debug	(6784) 25095
                      mihome-vacuum.0	2020-02-21 08:57:17.892	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:17.883	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:57:17.883	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:15.908	info	(6784) should trigger cleaning zone [19720,32832,24549,35282,1], but is currently active. Add to queue
                      mihome-vacuum.0	2020-02-21 08:57:15.892	debug	(6784) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [19720,32832,24549,35282,1]
                      mihome-vacuum.0	2020-02-21 08:57:15.891	debug	(6784) stateChange mihome-vacuum.0.control.zoneClean {"val":"[19720,32832,24549,35282,1]","ack":false,"ts":1582271834293,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582
                      mihome-vacuum.0	2020-02-21 08:57:15.889	debug	(6784) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1582271834293,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182398690}
                      mihome-vacuum.0	2020-02-21 08:57:15.887	debug	(6784) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582271834293,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142142021}
                      mihome-vacuum.0	2020-02-21 08:57:14.513	debug	(6784) 25095
                      mihome-vacuum.0	2020-02-21 08:57:13.636	debug	(6784) update_Map got new time:1582271833
                      mihome-vacuum.0	2020-02-21 08:57:13.635	debug	(6784) update_Map got new expires:1582273633
                      mihome-vacuum.0	2020-02-21 08:57:13.635	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:13.554	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:13.538	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:13.538	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:10.790	debug	(6784) 25246
                      mihome-vacuum.0	2020-02-21 08:57:10.068	debug	(6784) update_Map got new time:1582271829
                      mihome-vacuum.0	2020-02-21 08:57:10.068	debug	(6784) update_Map got new expires:1582273630
                      mihome-vacuum.0	2020-02-21 08:57:10.067	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:10.010	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:09.999	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:09.999	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:06.649	debug	(6784) 25261
                      mihome-vacuum.0	2020-02-21 08:57:06.178	debug	(6784) update_Map got new time:1582271826
                      mihome-vacuum.0	2020-02-21 08:57:06.178	debug	(6784) update_Map got new expires:1582273626
                      mihome-vacuum.0	2020-02-21 08:57:06.177	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:06.124	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:06.114	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:06.113	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:03.391	debug	(6784) 25258
                      mihome-vacuum.0	2020-02-21 08:57:02.917	debug	(6784) update_Map got new time:1582271822
                      mihome-vacuum.0	2020-02-21 08:57:02.916	debug	(6784) update_Map got new expires:1582273622
                      mihome-vacuum.0	2020-02-21 08:57:02.916	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:57:02.859	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:57:02.848	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:57:02.847	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:57:02.073	info	(6784) trigger cleaning zone [19720,32832,24549,35282,1]
                      mihome-vacuum.0	2020-02-21 08:57:02.032	debug	(6784) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [19720,32832,24549,35282,1]
                      mihome-vacuum.0	2020-02-21 08:57:02.030	debug	(6784) stateChange mihome-vacuum.0.control.zoneClean {"val":"[19720,32832,24549,35282,1]","ack":false,"ts":1582271822011,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582
                      mihome-vacuum.0	2020-02-21 08:57:02.027	debug	(6784) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1582271822011,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182398690}
                      mihome-vacuum.0	2020-02-21 08:57:02.019	debug	(6784) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582271822011,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142142021}
                      mihome-vacuum.0	2020-02-21 08:56:59.520	debug	(6784) 25258
                      mihome-vacuum.0	2020-02-21 08:56:59.079	debug	(6784) update_Map got new time:1582271818
                      mihome-vacuum.0	2020-02-21 08:56:59.079	debug	(6784) update_Map got new expires:1582273619
                      mihome-vacuum.0	2020-02-21 08:56:59.078	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:56:59.005	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:58.995	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:56:58.995	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:56.297	debug	(6784) 25258
                      mihome-vacuum.0	2020-02-21 08:56:55.807	debug	(6784) update_Map got new time:1582271815
                      mihome-vacuum.0	2020-02-21 08:56:55.807	debug	(6784) update_Map got new expires:1582273615
                      mihome-vacuum.0	2020-02-21 08:56:55.806	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:56:55.753	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:55.731	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:56:55.730	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:52.417	debug	(6784) 25258
                      mihome-vacuum.0	2020-02-21 08:56:51.925	debug	(6784) update_Map got new time:1582271811
                      mihome-vacuum.0	2020-02-21 08:56:51.924	debug	(6784) update_Map got new expires:1582273611
                      mihome-vacuum.0	2020-02-21 08:56:51.924	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:56:51.844	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:51.834	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:56:51.833	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:49.081	debug	(6784) 25258
                      mihome-vacuum.0	2020-02-21 08:56:48.632	debug	(6784) update_Map got new time:1582271808
                      mihome-vacuum.0	2020-02-21 08:56:48.631	debug	(6784) update_Map got new expires:1582273608
                      mihome-vacuum.0	2020-02-21 08:56:48.631	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:56:48.598	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:48.539	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:56:48.538	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:45.232	debug	(6784) 25253
                      mihome-vacuum.0	2020-02-21 08:56:44.791	debug	(6784) update_Map got new time:1582271804
                      mihome-vacuum.0	2020-02-21 08:56:44.791	debug	(6784) update_Map got new expires:1582273604
                      mihome-vacuum.0	2020-02-21 08:56:44.790	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:56:44.705	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:44.688	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:56:44.688	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:41.961	debug	(6784) 25234
                      mihome-vacuum.0	2020-02-21 08:56:41.523	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:41.511	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:56:41.511	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:40.350	debug	(6784) get rooms from map data: [19,2,3,22,18,21,16,20,17,7,8]
                      mihome-vacuum.0	2020-02-21 08:56:40.262	debug	(6784) 25234
                      mihome-vacuum.0	2020-02-21 08:56:39.666	debug	(6784) update_Map use old mapurl
                      mihome-vacuum.0	2020-02-21 08:56:39.653	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:39.653	debug	(6784) get rooms from map
                      mihome-vacuum.0	2020-02-21 08:56:39.652	debug	(6784) Empty array try to get from Map
                      mihome-vacuum.0	2020-02-21 08:56:38.138	debug	(6784) 25234
                      mihome-vacuum.0	2020-02-21 08:56:37.534	debug	(6784) update_Map got new time:1582271797
                      mihome-vacuum.0	2020-02-21 08:56:37.533	debug	(6784) update_Map got new expires:1582273597
                      mihome-vacuum.0	2020-02-21 08:56:37.533	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                      mihome-vacuum.0	2020-02-21 08:56:37.431	debug	(6784) update_Map need new mapurl
                      mihome-vacuum.0	2020-02-21 08:56:37.431	debug	(6784) update_Map Mimap enabled
                      mihome-vacuum.0	2020-02-21 08:56:37.430	debug	(6784) Mappointer_updated
                      mihome-vacuum.0	2020-02-21 08:56:36.616	debug	(6784) requesting params every: 60 Sec
                      mihome-vacuum.0	2020-02-21 08:56:19.644	debug	(6784) get rooms from map pending...
                      mihome-vacuum.0	2020-02-21 08:56:19.643	debug	(6784) get rooms from map
                      mihome-vacuum.0	2020-02-21 08:56:19.643	debug	(6784) Empty array try to get from Map
                      mihome-vacuum.0	2020-02-21 08:55:59.636	debug	(6784) get rooms from map pending...
                      mihome-vacuum.0	2020-02-21 08:55:59.636	debug	(6784) Empty array try to get from Map
                      mihome-vacuum.0	2020-02-21 08:55:39.629	debug	(6784) get rooms from map pending...
                      mihome-vacuum.0	2020-02-21 08:55:39.628	debug	(6784) Empty array try to get from Map
                      mihome-vacuum.0	2020-02-21 08:55:39.626	info	(6784) create state for carpet_mode
                      mihome-vacuum.0	2020-02-21 08:55:38.961	debug	(6784) Xiaomi Cloud: Login successful
                      mihome-vacuum.0	2020-02-21 08:55:37.154	info	(6784) set nächster Timer: Nicht verfügbar
                      mihome-vacuum.0	2020-02-21 08:55:36.729	info	(6784) create states for water box filter
                      mihome-vacuum.0	2020-02-21 08:55:36.728	info	(6784) create states for water box
                      mihome-vacuum.0	2020-02-21 08:55:36.701	debug	(6784) requesting params every: 60 Sec
                      mihome-vacuum.0	2020-02-21 08:55:36.696	debug	(6784) Connected
                      mihome-vacuum.0	2020-02-21 08:55:36.675	info	(6784) New generation or new fw detected, create new states goto and zoneclean
                      mihome-vacuum.0	2020-02-21 08:55:36.673	info	(6784) extend state mop for State control.fan_power
                      mihome-vacuum.0	2020-02-21 08:55:36.672	info	(6784) change states from State control.fan_power
                      mihome-vacuum.0	2020-02-21 08:55:36.622	debug	(6784) server started on 0.0.0.0:53421
                      mihome-vacuum.0	2020-02-21 08:55:36.599	info	(6784) Cloud control disabled
                      mihome-vacuum.0	2020-02-21 08:55:36.597	info	(6784) Expert mode disabled, states deleted
                      mihome-vacuum.0	2020-02-21 08:55:36.586	debug	(6784) Xiaomi Cloud: Logging in
                      mihome-vacuum.0	2020-02-21 08:55:36.584	debug	(6784) load Map creator... true
                      mihome-vacuum.0	2020-02-21 08:55:36.489	info	(6784) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                      mihome-vacuum.0	2020-02-21 08:55:33.823	debug	(6784) statesDB connected
                      mihome-vacuum.0	2020-02-21 08:55:33.823	debug	(6784) States connected to redis: 127.0.0.1:9000
                      mihome-vacuum.0	2020-02-21 08:55:33.805	debug	(6784) States create System PubSub Client
                      mihome-vacuum.0	2020-02-21 08:55:33.802	debug	(6784) States create User PubSub Client
                      mihome-vacuum.0	2020-02-21 08:55:33.791	debug	(6784) Redis States: Use Redis connection: 127.0.0.1:9000
                      mihome-vacuum.0	2020-02-21 08:55:33.788	debug	(6784) objectDB connected
                      mihome-vacuum.0	2020-02-21 08:55:33.782	debug	(6784) Objects connected to redis: 127.0.0.1:9001
                      mihome-vacuum.0	2020-02-21 08:55:33.763	debug	(6784) Objects client initialize lua scripts
                      mihome-vacuum.0	2020-02-21 08:55:33.763	debug	(6784) Objects create User PubSub Client
                      mihome-vacuum.0	2020-02-21 08:55:33.761	debug	(6784) Objects create System PubSub Client
                      mihome-vacuum.0	2020-02-21 08:55:33.757	debug	(6784) Objects client ready ... initialize now
                      mihome-vacuum.0	2020-02-21 08:55:33.364	debug	(6784) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      DiginixD D 2 Antworten Letzte Antwort
                      • B blackeagle998
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #291
                        @blackeagle998 sagte in Test Adapter mihome-vacuum v2.0.x:
                        Bei wem hast du diesen Datenpunkt denn gesehen? Den gibt es doch noch gar nicht.
                        1. Kann man irgendwo die Queue sehen und löschen?
                        Das ist sicher eine sinnvolle Erweiterung. Entweder die Warteschlange wird gelöscht wenn man nach "Pause" auch noch "Go Home" auslöst oder es gäbe noch ein neuen Button mit zB "Cancel all jobs".
                        ..:: So long! Tom ::..
                        • B blackeagle998
                          dirkhe
                          #292
                          @blackeagle998
                          1. Das ist ein spezieller Befehl, ob es so Was für segment(raum) such gibt, weiß ich nicht. Aber wofür braucht man den eigentlich? Man kann doch Pause und Start machen. Ich hatte immer gedacht, dass es eine Eigenheit der alten Firmware wäre und habe mich damit noch nicht näher beschäftigt
                          2. Wie viel in der queue noch anstehen, siehst du in info.queue. Den beschreibbar zu machen ist nicht so sinnvoll, da könnte man sich eher einen Knopf machen. Oder wir machen es so, wenn man den home Button in ioBroker drückt (bzw. Triggert durch Alexa oder vis), dass dann auch die queue gewettet wird
                            blackeagle998
                            #293
                            @Diginix
                            @dirkhe
                            zu Thema 1:
                            Den Knopf "ResumeRoomClean" habe ich noch nirgends gesehen, dachte mir aber, dass es Pendant zum ResumeZoneClean geben muss. Wenn ich nämlich in der MiHome APP einen Raum auswähle, dann die Reinigung starte, dann Pause drücke und dann wieder auf reinigen, sagt der Roboter "Resume Room clean".
                            Mache ich das gleiche mit einer Zone sagt der Roboter "Resume Zone clean".
                            --> Es muss also einen Unterschied in der Steuerung geben
                            Die Variante Pause und dann Start war auch mein erster Gedanke, der führt aber nicht dazu, dass der spezielle Raum weiter gereinigt wird, sondern alles (oder irre ich mich? --> teste ich gleich nochmal).
                            zu Thema 2:
                            Die Variante wenn 'mihome-vacuum.0.control.home' gedrückt wird, die Queue zu löschen halte ich für die beste Lösung.
                            Danke für eure schnellen Rückmeldungen.
                            • D dirkhe
                              @blackeagle998
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #294
                              @dirkhe Ich fände ein "Cancel all queued jobs" besser. Das müsste dann zusätzlich auch Pause auslösen.
                              Mal angenommen er ist im zweiten von 4 geplanten Räumen und mir fällt ein dass er aber nun doch ein SportClean oder noch anderen Raum saugen soll. Dann würde er bei "Home" anfangen in Richtung Station zu fahren. Mit Cancel bliebe er aber genau da stehen wo er ist und kann von dort aus den abweichenden Auftrag anfahren.
                              In 99% sollte man ja vorher wissen was er machen soll oder man ist gar nicht vor Ort.
                              Ich habe bisher auch noch nie probiert welche Kombinationen funktionieren und welche nicht.
                              Mal angenommen ich pausiere eine Raumreinigung bei der noch Räume in der Warteschlange stehen und starte ein SpotClean. Dann würde er wahrscheinlich danach den nächsten Raum aus der Warteschlange anfahren, aber nicht den abgebrochenen fertig saugen.
                              @blackeagle998 Ich starte meine Raumreinigungen auch immer über multiRoomClean und da müsste Pause > Start dazu führen dass er weiter macht.
                              D B 3 Antworten Letzte Antwort
                              • DiginixD Diginix
                                dirkhe
                                #295
                                Wenn er Pause macht, bleibt er stehen. Wenn du dann einen Spot anfahren wolltest, ob das dann geht?
                                • DiginixD Diginix
                                  blackeagle998
                                  #296
                                  @Diginix
                                  Guter Einwand, die Variante "Cancel all Jobs und bleib wo du bist bis du weitere Befehle bekommst" finde ich sehr gut!
                                  Wie startest du denn über multiRoomClean, mir ist noch nicht klar, wie dieser Button funktioniert.
                                  Momentan wähle ich noch bei jedem Raum einzeln den "roomClean" Button.
                                  Man muss doch aber die Raum-Indexe dem multiRoomClean irgendwie per Javascript zuweisen können oder wie machst du das?
                                  • B blackeagle998
                                    @Diginix
                                    dirkhe
                                    #297
                                    @blackeagle998 vergiss den multiclean, den have ich eingebaut, als es noch keine queue gab. Einfach alle räume antriggern oder einen Timer erstellen, denen ggf. Auf inaktiv setzt und den dann per "jetzt starten" antriggern
                                    B DiginixD 2 Antworten Letzte Antwort
                                    • DiginixD Diginix
                                      blackeagle998
                                      schrieb am zuletzt editiert von blackeagle998
                                      #298
                                      @Diginix
                                      @dirkhe
                                      Wenn ich vorher nur einen oder einige Räume gewählt hatte, dann Pause mache und dann Start drücke, führt das nicht dazu, dass er die vorherige Raumreinigung fortsetzt, sondern dazu, dass er alles reinigen will, er wählt dann nämlich die gesamte Karte aus.
                                      • D dirkhe
                                        blackeagle998
                                        #299
                                        Alles klar, Danke 👍
                                        • D dirkhe
                                          DiginixD Offline
                                          DiginixD Offline
                                          Diginix
                                          #300
                                          Den finde ich aber immer noch schöner weil ich eine Karte am Stück erhalte und auch nicht nach jedem Raum erst die Station angefahren wird um nach 10 Sek. zu merken dass er ja noch woanders hin soll.
                                          multiRoomClean entspricht der nativem Implementierung in der App.
                                          Wäre also unschön wenn es wieder aus dem Adapter fliegen sollte. Dann müsste ich mit das clean Array wieder selbst bauen.
