  4. [gelöst]Backitup plötzliche Errors
backitup backuperrorproblem
6 Beiträge 3 Kommentatoren 401 Aufrufe 3 Beobachtet
  • Dominik F.D Offline
    Dominik F.D Offline
    Dominik F.
    schrieb am zuletzt editiert von Dominik F.
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: 10.x.x
    Nodejs-Version: 10.19.0
    NPM-Version: 6.13.4
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    Backitup lief jetzt Monate ohne Probleme, seit ein paar Tagen bekomme ich folgende Errors:
    Hat jemand eine Idee?
    backitup.0	2020-02-07 01:30:59.536	error	Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    backitup.0	2020-02-07 01:30:59.536	error	mount error(112): Host is down
    backitup.0	2020-02-07 01:30:59.536	error	(21829) Error: Command failed: sudo mount -t cifs -o username=ioBroker_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/SanDisk-UltraUSB3-0-01/Backup_ioBroker /opt/iobro
    backitup.0	2020-02-07 01:30:59.237	info	(21829) [ccu] backup was activated at 01:30 every 1 day(s)
    backitup.0	2020-02-07 01:30:59.223	info	(21829) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2020-02-07 01:30:59.159	info	(21829) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
    host.raspberrypi4-io	2020-02-07 01:30:54.729	info	instance system.adapter.backitup.0 started with pid 21829
    host.raspberrypi4-io	2020-02-07 01:30:24.707	info	Restart adapter system.adapter.backitup.0 because enabled
    host.raspberrypi4-io	2020-02-07 01:30:24.707	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi4-io	2020-02-07 01:30:24.706	error	Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
    host.raspberrypi4-io	2020-02-07 01:30:24.706	error	Caught by controller[0]: at listOnTimeout (timers.js:263:5)
    host.raspberrypi4-io	2020-02-07 01:30:24.706	error	Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
    host.raspberrypi4-io	2020-02-07 01:30:24.706	error	Caught by controller[0]: at ontimeout (timers.js:436:11)
    host.raspberrypi4-io	2020-02-07 01:30:24.705	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/90-pushover.js:78:80)
    host.raspberrypi4-io	2020-02-07 01:30:24.704	error	Caught by controller[0]: TypeError: Cannot read property 'pass' of undefined
    Meister MopperM GlasfaserG 2 Antworten Letzte Antwort
    • Dominik F.D Dominik F.
      Hardwaresystem: Pi4
      NPM-Version: 6.13.4
      Meister MopperM Online
      Meister Mopper
      @Dominik-F Da funktioniert das mounten nicht. Ich monte mein NAS. Nach einem Rücklesen des Backitup-Adapters hat er manchmal fehlerhaft Benutzerkennung und Passwort geschrieben. Ich habe die Daten manuell im Backitup eingegeben und das backup lief wieder.
      Proxmox und HA ...
        Hardwaresystem: Pi4
        NPM-Version: 6.13.4
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        @Dominik-F sagte in Backitup plötzliche Errors:
          Dominik F.D Offline
          Dominik F.
          @Meister-Mopper
          ich habe jetzt alle Daten nochmal eingegeben, jedoch bekomme ich immer noch folgenden fehler:
           Error: Command failed: sudo mount -t cifs -o username=ioBroker_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //fritz.box/fritz.nas/SanDisk-UltraUSB3-0-01/Backup_ioBroker /opt/iobroker/b
          backitup.0	2020-02-07 11:44:23.926
          host.raspberrypi4-io	2020-02-07 11:47:58.490	error	instance system.adapter.backitup.0 terminated with code 156 (156)
          backitup.0	2020-02-07 11:47:57.951	info	(26548) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          backitup.0	2020-02-07 11:47:57.950	info	(26548) terminating
          backitup.0	2020-02-07 11:47:57.451	warn	(26548) Got terminate signal. Checking desired PID: 27259 vs own PID 26548
          backitup.0	2020-02-07 11:47:57.447	warn	(26548) Got terminate signal. Checking desired PID: 0 vs own PID 26548
          Habe in der Fritzbox und im Backitup Adapter das Passwort nochmal geändert um ein falsches Passwort auszuschließen
          Laut den Datenpunkten backitup.0.history. hier scheint das Backup von Iobroker zu funktionieren, das der CCU nicht.
          @Glasfaser
          Das habe ich auch gelesen, ich weiß nur nicht wie ich das Problem beheben kann
            @Meister-Mopper
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @Dominik-F
            Vielleicht kommst du mit diesem Thread weiter , dort war auch ein " Host is down "
            Link Text
            • GlasfaserG Glasfaser
              @Dominik-F
              Link Text
              Dominik F.D Offline
              Dominik F.D Offline
              Dominik F.
              @Glasfaser
              Danke für den Hinweis, der Thread bietet leider keine Lösung.
              Hab jetzt einfach eine frühere Version des Adapters installiert und jetzt funktioniert wieder alles.
