  4. Material Design Widgets: Buttons Widget
    1.0k
    6.1k
vis
157 Beiträge 38 Kommentatoren 38.4k Aufrufe 40 Beobachtet
  • S Schnutexxl
    @scrounger
    Runtime neu starten hat nichts gebracht. Springt von rot sofort wieder in blau. Hier der Export:
    [{"tpl":"tplVis-materialdesign-Icon-Button-Toggle","data":{"oid":"hm-rpc.0.REQ0777633.1.STATE","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","toggleType":"boolean","stateIfNotTrueValue":"off","vibrateOnMobilDevices":"50","autoLockAfter":"10","lockIconTop":"45","lockIconLeft":"55","lockIconSize":"20","lockIconColor":"red","lockBackgroundSizeFactor":"1","lockFilterGrayscale":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"image":"water-pump-off","valueOff":"false","valueOn":"true","imageTrue":"water-pump","iconHeight":"30","imageTrueColor":"red","imageColor":"#0277bd","lockIconBackground":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.icon.lock_icon_background;dark:vis-materialdesign.0.colors.dark.button.icon.lock_icon_background; mode === \"true\" ? dark : light}","g_color":true,"colorBgFalse":"#mdwTheme:vis-materialdesign.0.colors.button.icon.background_off","colorBgTrue":"#mdwTheme:vis-materialdesign.0.colors.button.icon.background_on","colorPress":"#mdwTheme:vis-materialdesign.0.colors.button.icon.pressed"},"style":{"left":"306px","top":"534px","width":"40px","height":"40px","z-index":"2"},"widgetSet":"materialdesign"}]
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    #141
    @schnutexxl sagte in Material Design Widgets: Buttons Widget:
    @scrounger
    Habs getestet, funktioniert wie es soll. Was steht in der Konsole zur Runtime (F12) wenn sich die Farbe ändert?
    @micklafisch sagte in Material Design Widgets: Buttons Widget:
    @scrounger
    ok verstehe. Ich ändere meine händischen Pfade wieder zurück auf ohne das "light".
    Daüfr kannst du den Button "use theme" verwenden, dann brauchst das nich händisch machen.
    Nur da scheinbar wegen dem Theme Editor das Binding nicht mehr funktioniert, wie kann ich dann elegant das bisherige Layout abbilden? Buttons sind weiß mit blauer Schrift und wenn aktiv dann blau mit weißer Schrift.
    Welcher Button - Button Toggle?
    Dann so z.B.:
    [{"tpl":"tplVis-materialdesign-Button-Toggle-vertical","data":{"oid":"0_userdata.0.bool","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","toggleType":"boolean","stateIfNotTrueValue":"on","vibrateOnMobilDevices":"50","buttontext":"Toggle","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.vertical.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.vertical.text","alignment":"center","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.vertical.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.vertical.secondary","image":"checkbox-marked","iconPosition":"top","iconHeight":"26","autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockIconColor":"#mdwTheme:vis-materialdesign.0.colors.button.lock_icon","lockFilterGrayscale":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"labelColorTrue":"white","labelColorFalse":"blue","colorBgTrue":"blue"},"style":{"left":"608px","top":"187px"},"widgetSet":"materialdesign"}]
    S M 2 Antworten Letzte Antwort
    • ScroungerS Scrounger
      @scrounger
      @scrounger
      Dann so z.B.:
      Schnutexxl
      #142
      @scrounger
      also, die Konsole sagt mir nichts:
      [oidNeedSubscribe] Icon Button (w00208): oid 'vis-materialdesign.0.colors.light.button.icon.background_off' need subscribe (view)
      widgets.min.js:1 [oidNeedSubscribe] Icon Button (w00208): oid 'vis-materialdesign.0.colors.dark.button.icon.background_off' need subscribe (view)
      widgets.min.js:1 [oidNeedSubscribe] Icon Button (w00208): oid 'vis-materialdesign.0.colors.light.button.icon.background_on' need subscribe (view)
      widgets.min.js:1 [oidNeedSubscribe] Icon Button (w00208): oid 'vis-materialdesign.0.colors.dark.button.icon.background_on' need subscribe (view)
      widgets.min.js:1 [oidNeedSubscribe] Icon Button (w00208): oid 'vis-materialdesign.0.colors.light.button.icon.pressed' need subscribe (view)
      widgets.min.js:1 [oidNeedSubscribe] Icon Button (w00208): oid 'vis-materialdesign.0.colors.dark.button.icon.pressed' need subscribe (view)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208) subscribe states at runtime
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): 'vis-materialdesign.0.colors.light.button.icon.background_off' subscribed (View)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): 'vis-materialdesign.0.colors.dark.button.icon.background_off' subscribed (View)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): 'vis-materialdesign.0.colors.light.button.icon.background_on' subscribed (View)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): 'vis-materialdesign.0.colors.dark.button.icon.background_on' subscribed (View)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): 'vis-materialdesign.0.colors.light.button.icon.pressed' subscribed (View)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): 'vis-materialdesign.0.colors.dark.button.icon.pressed' subscribed (View)
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): Request 6 states.
      widgets.min.js:1 [isLayoutRefreshNeeded] Icon Button (w00208): subscribed oids: ["vis-materialdesign.0.lastchange"]
      widgets.min.js:1 [subscribeStatesAtRuntime] Icon Button (w00208): inform widgets 6 states subscribed
      widgets.min.js:1 [isLayoutRefreshNeeded] Icon Button (w00208): subscribed oids: []
      Komisch ist, wenn ich den Button im einen anderen View kopiere geht es einmalig, mache ich eine Aktualisierung des Browsers, springt er von rot direkt auf blau. Hast du auch mal eine Aktualisierung gemacht?
      Kann das was mit den Themes zu tuen haben? Themes in den Views?
      Ich will ja nicht gleich die Flinte ins Korn werfen, aber am liebsten würde ich ein rollback auf die ältere Version machen.
      ScroungerS 1 Antwort Letzte Antwort
      • S Schnutexxl
        @scrounger
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #143
        @schnutexxl
        Konnte es jetzt reproduzieren. Teste bitte die aktuelle Version von github. Wichtig Vis upload nach installation machen!
          @schnutexxl
          Schnutexxl
          #144
          @scrounger
          Moin!
          Habe ich gemacht, sieht nun erstmal fein aus. Wenn es so bleibt, super und DANKE!
            @scrounger
            @scrounger
            Dann so z.B.:
            M Online
            M Online
            micklafisch
            schrieb am zuletzt editiert von micklafisch
            #145
            @scrounger
            Danke für den Toggle Button. Ich benötige es aber für einen State Button (Export des Widgets oben). Wenn ich die Farbe für "aktiv" ändere, dann passt die Textfarbe nicht mehr und es ist wie im Post vom 20.04. 10:40 Uhr beschrieben dann blau auf blau.
            • M Online
              M Online
              michihorn
              #146
              Hallo, bei mir ist die zweite Zeile seit dem letzten Update heute zu weit nach rechts gerutscht. Kann man das fixen?
              Michael
              • BostilB Offline
                BostilB Offline
                Bostil
                schrieb am zuletzt editiert von Bostil
                #147
                Hat sich erledigt - mein Learning: Wert war nicht korrekt, sondern Boolean. Musste mir den Datenpunkt mal genau ansehen! Danke trotzdem.
                Hallo zusammen, möchte eigentlich bloß mit dem Button WIdget (Toggle) den Status eines Gerätes in Form eines Standby-Symbols wiedergeben. Rotes Symbol = Gerät ausgeschaltet ("online" = false) und eben grün für den anderen Status. Leider scheitere ich an dieser simplen Aufgabenstellung :-( Das Symbol ändert sich einfach nicht.
                Habt ihr eine Idee ?
                Widget-Einstellungen:
                Datenpunkt:
                • D3ltoroxpD Offline
                  D3ltoroxpD Offline
                  D3ltoroxp
                  schrieb am zuletzt editiert von D3ltoroxp
                  #148
                  Frage,
                  ich möchte mit dem Button zwischen on und off steuern. Im ioB sieht das so aus.
                  Wie kann ich nun zwischen on und off wechseln ? Ich kann den Wert nicht rein schreiben, sondern muss dazwischen wechseln mit DropDown. Wie kann ich das über die VIS realisieren ? Oder ist hier Button das falsche Widget.
                  Im Button hab ich on und off geschrieben und auch zwischen Wert oder Boolean gewechselt, es steht dort dann immer true und false.
                  • BostilB Bostil
                    Datenpunkt:
                    dos1973
                    schrieb am zuletzt editiert von dos1973
                    #149
                    @bostil
                    Du hast „nur lesend“ aktiviert.
                    Und wenn es ein True/ false Dp ist, dann stelle den Wert auch auf Boolean
                    Edit, ignorieren: habs überlesen
                    • H Offline
                      HSK
                      #150
                      Vielen Dank für die sehr guten Visu- Elemente. Für die "Lustelektronik" klappt alles wunderbar. Leider bin ich bei meiner umfangreichen KNX- Visu noch immer am basteln. Dort habe ich praktisch immer zwei Datenpunkte: den eigentlichen Command- Befehl und dann die Rückmeldung über den Status-Datenpunkt. Wenn der Button mit Farbe und Icon auf den Status-Datenpunkt reagieren könnte würde die Bastelung mit sichbar/unsichtbar Überlagerungen entfallen. Gäbe es da eine Möglichkeit - oder habe ich eine übersehen? Danke!
                      • C Offline
                        c.radi
                        #151
                        Hallo, ich setzte meine Visu auch mit diesen Widgets um.
                        Gibt es bei dem "Button Navigation" die Möglichkeit darzustellen, wenn die aufgerufene Seite angezeigt wird.
                        Also kann man einen solchen Button als "dauerhaft gedrückt" anzeigen?
                        Oder kann ich mit einem anderen Button (Toggle Button) eine View aufrufen und das ganze dann über Hintergrundscripte und Datenpunkte lösen?
                        Christian
                        • L Offline
                          lugge86
                          schrieb am zuletzt editiert von lugge86
                          #152
                          Hallo Scrounger,
                          ich spiele aktuell viel mit deinen Buttons herum (z.B ButtonToggle, ButtonState).
                          Du bietest die Möglichkeit, für aktive Buttons eine eigene Farbe und ein eigenes Icon zu definieren.
                          Das ist prinzipiell gut, reicht mir aber nicht ganz.
                          Ich würde gerne mit css etwas mehr am Button ändern.
                          Dazu muss ich das widget aber erstmal mit einem css-Selektor erwischen.
                          Mit der F12-Konsole habe ich aber spontan nichts gefunden, wie ich per Selektor ein aktives Widget identifizieren kann.
                          Am einfachsten ginge es natürlich per Klassse. Also, wenn das aktive Widget zusätzlich eine Klasse "mdw-active" oder so erhalten würde.
                          Diese Klasse könnte man dann per css selektieren.
                          Wäre es aufwendig, so ein Feature einzubauen?
                          Oder weißt du spontan eine andere Möglichkeit, wie ich per css an aktive Widgets herankomme?
                          Hintergrund:
                          Man hätte mehr Flexibilität beim gestalten des aktiven Widgets, z.B. könne man sowas machen wie lesiflo hier macht (die dicke weiße Linie überhalb des Buttons, leider benutzt er kein Vis):
                          https://forum.iobroker.net/assets/uploads/files/1568013398283-fenster.jpg
                            Supermicha
                            #153
                            bei mir werden die Farben für Hintergrund und aktiver Hintergrund nicht aus dem Theme übernommen.
                            Verwendetes Widget "Button Toggle"
                            is das ein Bug oder kommt das noch?
                            es gibt ja schon den Punkt button.icon.background_off und button.icon.background_on
                            oder mache ich was falsch?
                            • C Offline
                              CyberMicha
                              #154
                              letzter Beitrag ewig her aber ich habe eine Frage.
                              Die Buttons ändern bei mir am Handy mit der App die Farbe nicht wenn aktiv. Im Browser geht es ohne Probleme.
                              Bug oder mache ich etwas falsch? Habe den Adapter durch Zufall gefunden da ich bisher keinen anderen Button gefunden habe, der den Hintergrund ändert wenn aktiv.
                                srkonus
                                schrieb am zuletzt editiert von srkonus
                                #155
                                ich beschäftige mich erst seit gestern mit den Material Design Widgets. Vom Style her gefallen sie mir gut, viel Auswahl um schöne Sachen zu realisieren. Nun wollte ich einen Button mit einem anderen Icon versehen, scheitere allerdings daran. Es wird immer der Stift angezeigt, egal ob ich in dem Textfeld eins aussuche oder per Dateibrowser eins wähle. Kann mir jemand einen Tipp geben was ich falsch mache?
                                Ich verwende derzeit die vis2, vielleicht geht es dort ja noch nicht.
                                VG
                                srkonus
                                • GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #156
                                  @srkonus sagte in Material Design Widgets: Buttons Widget:
                                  richtig ....
                                  https://github.com/ioBroker/ioBroker.vis-2/issues/68
                                  hier auch mal reinschauen , es wurde dort mal beandelt :
                                  https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-alpha
                                  aktuelles zu Vis2 BETA , dann in diesem Thread
                                  https://forum.iobroker.net/topic/67676/vis-2-0-neuer-adapter-als-beta
                                  oder im Issues
                                  • a200A Offline
                                    a200A Offline
                                    a200
                                    #157
                                    Probleme mit multi-views mit vis-2
                                    Hallo ich will "Icon Button Navigation" von "materialdesign" und multi-views nutzen. Leider wird die Position der Buttons in den Unterview verworfen und die Buttons werden einfach bei 0,0 (oben links) angezeigt. Dieses Verhalten habe ich bei einigen alten Widges und vis-2.
                                    Gibt es einen Möglichkeit die Buttons trotzdem zu verwenden?
