  4. Material Design Widgets: Calendar Widget
vis
201 Beiträge 46 Kommentatoren 54.4k Aufrufe 53 Beobachtet
  • Damrak2022D Damrak2022
    @tt-tom Danke, aber mach Dir keinen Stress. Heute Abend, oder morgen ist völlig ausreichend
    TT-Tom
    #141
    @damrak2022
    Ich schau heute Abend rein.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      @damrak2022
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #142
      @tt-tom Danke Dir
      Mit besten Grüßen
      Andy
        @tt-tom Danke Dir
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #143
        @damrak2022 So sieht jetzt mein komplettes Script aus:
        // momentjs is required as dependecies in javascript adapter
        const moment = require("moment");
        var instances = $(`[id=ical.*.data.table]`);
        instances.on(ical2CalendarWidget);
        // remove this, if you know to use your own datapoint
        let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
        createState(datapointId, "[]", {
          read: true,
          write: false,
          desc: "JSON String for Calendar Widget",
          type: "string",
          def: "[]"
        function ical2CalendarWidget() {
            try {
                let calList = [];
                for (var inst = 0; inst <= instances.length - 1; inst++) {
                    let icalObj = getState(instances[inst]).val;
                    if (icalObj) {
                        for (var i = 0; i <= icalObj.length - 1; i++) {
                            let item = icalObj[i];
                            // extract calendar color
                            let calendarName = item._class.split(' ')[0].replace('ical_', '');
        console.log(calendarName);
                            let startTime = moment(item._date);
                            let endTime = moment(item._end);
                            let start = startTime.format("YYYY-MM-DD HH:mm");
                            let end = endTime.format("YYYY-MM-DD HH:mm");
                            if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                                // is full-day event
                                if (endTime.diff(startTime, 'hours') === 24) {
                                    // full-day event, one day
                                    start = startTime.format("YYYY-MM-DD");
                                    end = startTime.format("YYYY-MM-DD");
                                } else {
                                    // full-day event, multiple days
                                    end = endTime.format("YYYY-MM-DD");
                            // create object for calendar widget
                            calList.push({
                                color: getMyCalendarColor(calendarName),
                                colorText: getMyCalendarTextColor(calendarName),
                                start: start,
                                end: end
                        function getMyCalendarColor(calendarName) {
                            // assign colors via the calendar names, use calendar name as set in ical
                             if (calendarName === 'ioBroker') {
                                return '#F16BBFB';
                            } else if (calendarName === 'Finanzen') {
                                return '#DA0B05'
                            } else if (calendarName === 'Gesundheit') {
                                return '#DA0B05'
                            }else if (calendarName === 'Urlaub')  {
                                return '#FC5307'
                            }else if (calendarName === 'Marktforschung Andy') {
                                return '#043DCC'
                            }else if (calendarName === 'Kfz')   {
                                return '#B3B3B3'
                            }else if (calendarName === 'Office')    {
                                return '#A3D87A'
                            }else if (calendarName === 'Haushalt')   {
                                return '#FDA49F'
                            }else if (calendarName === 'Freizeit')   {
                                return '#66028D'
                            }else if (calendarName === 'Arbeit') {
                                return '#FCC131'}}
                        function getMyCalendarTextColor(calendarName) {
                                return '#8bf46c';
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'}}
                    // Enter the destination data point that is to be used as object ID in the widget
                    setState(datapointId, JSON.stringify(calList), true);
            } catch (e) {
                console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
        ical2CalendarWidget();
        Im Log gibt es diesen Fehler:
        javascript.0
        2022-06-12 11:42:20.854	error	script.js.common.Kalender.Kalender_ical compile failed:
        at script.js.common.Kalender.Kalender_ical:108
        Und danach noch diese:
        javascript.0
        2022-06-12 11:42:20.857	error	at processImmediate (internal/timers.js:466:21)
        javascript.0
        2022-06-12 11:42:20.857	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1472:17)
        javascript.0
        2022-06-12 11:42:20.857	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2001:17
        javascript.0
        2022-06-12 11:42:20.856	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1900:37)
        javascript.0
        2022-06-12 11:42:20.856	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1647:28)
        javascript.0
        2022-06-12 11:42:20.856	error	at Object.createScript (vm.js:262:10)
        javascript.0
        2022-06-12 11:42:20.856	error	at new Script (vm.js:102:7)
        javascript.0
        2022-06-12 11:42:20.855	error	SyntaxError: Missing catch or finally after try
        Mit besten Grüßen
        Andy
            read: true,
            write: false,
            type: "string",
            def: "[]"
              try {
                  let calList = [];
                      if (icalObj) {
                                  } else {
                              calList.push({
                                  start: start,
                                  end: end
                                  return '#F16BBFB';
                                  return '#DA0B05'
                                  return '#DA0B05'
                                  return '#FC5307'
                                  return '#043DCC'
                                  return '#B3B3B3'
                                  return '#A3D87A'
                                  return '#FDA49F'
                                  return '#66028D'
                                  return '#FCC131'}}
                                  return '#8bf46c';
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'}}
              } catch (e) {
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          TT-Tom
          #144
          @damrak2022
          Hi du hast in der Zeile 105 zwei Klammern zu viel. Jede Klammer die du öffnest, musst du auch wieder schliessen. Bei Verschachtelungen musst du von innen nach aussen prüfen. Im Script-Editor bei IoBroker siehst du immer den Gegenspieler, wenn du den Cursor an eine Klammer setzt. Ich habe das Script jetzt angepasst sollte so laufen.
          Ps was noch ein Problem machen kann ist das Leerzeichen im Kalender Marktforschung, hier ggf. mit einem Unterstrich arbeiten.
            read: true,
            write: false,
            type: "string",
            def: "[]"
              try {
                  let calList = [];
                      if (icalObj) {
                              //console.log(calendarName);
                                  } else {
                              calList.push({
                                  start: start,
                                  end: end
                                  return '#F16BBFB';
                                  return '#DA0B05'
                                  return '#DA0B05'
                                  return '#FC5307'
                                  return '#043DCC'
                                  return '#B3B3B3'
                                  return '#A3D87A'
                                  return '#FDA49F'
                                  return '#66028D'
                                  return '#FCC131'
                                  return '#8bf46c';
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
              } catch (e) {
          Gruß Tom
          Public Transport
          Damrak2022D 2 Antworten Letzte Antwort
          • T TT-Tom
            @damrak2022
              read: true,
              write: false,
              type: "string",
              def: "[]"
                try {
                    let calList = [];
                        if (icalObj) {
                                    } else {
                                calList.push({
                                    start: start,
                                    end: end
                                    return '#F16BBFB';
                                    return '#DA0B05'
                                    return '#DA0B05'
                                    return '#FC5307'
                                    return '#043DCC'
                                    return '#B3B3B3'
                                    return '#A3D87A'
                                    return '#FDA49F'
                                    return '#66028D'
                                    return '#FCC131'
                                    return '#8bf46c';
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                                    return '#8bf46c'
                } catch (e) {
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            schrieb am zuletzt editiert von Damrak2022
            #145
            @tt-tom Danke, jetzt klappt alles. Den Kalender Marktforschung habe ich vorher angepasst.
            Jetzt versuche ich mich an den restlichen Anpassungen.
            Mit besten Grüßen
            Andy
            • T TT-Tom
              @damrak2022
                read: true,
                write: false,
                type: "string",
                def: "[]"
                  try {
                      let calList = [];
                          if (icalObj) {
                                      } else {
                                  calList.push({
                                      start: start,
                                      end: end
                                      return '#F16BBFB';
                                      return '#DA0B05'
                                      return '#DA0B05'
                                      return '#FC5307'
                                      return '#043DCC'
                                      return '#B3B3B3'
                                      return '#A3D87A'
                                      return '#FDA49F'
                                      return '#66028D'
                                      return '#FCC131'
                                      return '#8bf46c';
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                                      return '#8bf46c'
                  } catch (e) {
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #146
              @tt-tom Eine Frage habe ich noch: Wo passe ich die Farben für die umrandeten Bereiche an?
              Ich vermute per css von dem ich keine Ahnung habe.
              Mit besten Grüßen
              Andy
                TT-Tom
                #147
                @damrak2022
                Da bin ich raus. Das muss ich auch immer nachlesen und kopieren.
                Gruß Tom
                Public Transport
                • T TT-Tom
                  @damrak2022
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #148
                  @tt-tom Okay, vielleicht kann mir ja jemand anders erklären wie ich die gewünschten Bereiche auswähle. Wie ich die Farbe ändere habe ich mittlerweile gelesen.
                  Mit besten Grüßen
                  Andy
                  O 1 Antwort Letzte Antwort
                    O Online
                    O Online
                    Oli
                    #149
                    @damrak2022
                    Die Farben kannst du im Adapter einstellen
                    Oliver
                    Damrak2022D 3 Antworten Letzte Antwort
                    • O Oli
                      @damrak2022
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #150
                      @oli Danke, ich habe es heute dann entdeckt
                      Mit besten Grüßen
                      Andy
                      • O Oli
                        @damrak2022
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #151
                        @oli Wie bekomme ich es hin, das mir Kalendereinträge nicht abgeschnitten werden, wenn es z.B. 2 oder mehr Termine im selben Zeitfenster sind. Es wäre gut, wenn da ein Zeilenumbruch erfolgen würde:
                        Mit besten Grüßen
                        Andy
                          O Online
                          O Online
                          Oli
                          #152
                          @damrak2022
                          Das kann ich dir nicht sagen, ich trage meine Termine immer so ein, dass sie sich nicht überschneiden. Der erste Termin würde bei mir enden, wenn der zweite beginnt. Da kann dir aber bestimmt @Scrounger helfen.
                          Oliver
                          • O Oli
                            @damrak2022
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #153
                            @oli Das würde ich auch so machen, aber da die Kalender mit mehreren Personen genutzt werden, lassen sich Überschneidungen nicht vermeiden.
                            Mit besten Grüßen
                            Andy
                            • O Oli
                              @damrak2022
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #154
                              @oli Hallo, ich habe vor mehr als einer Stunde einen Termin im Kalender eingetragen, welcher aber nicht im Calendar Widget erscheint.
                              Das Script läuft ohne Fehlermeldung
                              Die Abfrage Zeit des ical Adapters steht auf 10 Minuten
                              Kalender ist dort eingetragen und auch aktiv.
                              Ich habe auch mehrfach einen Browserrefresh gemacht und auch eine anderen Browser ausprobiert.
                              Hast Du eine Idee, warum der Termin nicht angezeigt wird.
                              Mit besten Grüßen
                              Andy
                                O Online
                                O Online
                                Oli
                                #155
                                @damrak2022
                                Da kann ich dir im Moment nicht helfen, da ich im Urlaub bin.
                                Oliver
                                • O Oli
                                  @damrak2022
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #156
                                  @oli Genieße erstmal Deinen Urlaub.
                                  Mit besten Grüßen
                                  Andy
                                    TT-Tom
                                    #157
                                    @damrak2022
                                    Prüf bitte mal den Zeitstempel vom iCal Datenpunkt ical.0.data.table, wann wurde der letztes mal aktualisiert?
                                    Hast du mehrere Instanzen?
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @damrak2022
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #158
                                      @tt-tom Das funktioniert jetzt. Der Eintrag ist nun vorhanden.Da steht als Zeitstempel das drin:
                                      Was ich aber nicht verstehe, ist das meine gestrigen Termine nicht mehr sichtbar sind. Im Ical Adapter habe ich 14 Tage Vorschau und 10 Tage bei vergangenen Terminen eingestellt. Muss ich da noch was gesondert einstellen?
                                      Und eventuell kannst Du mir erklären, wie ich einen Zeilenumbruch hinbekomme, wenn mehrere Termin die gleiche Uhrzeit haben, was bei uns öfters passiert
                                      Mit besten Grüßen
                                      Andy
                                      T M 2 Antworten Letzte Antwort
                                        TT-Tom
                                        #159
                                        @damrak2022
                                        wie du den Zeilenumbruch erstellen kannst, keine Ahnung.
                                        Schau mal ins Log, ob auch alle Kalender abgerufen werden. Hast du dir die Json mal im Editor angesehen, ob die Termine wirklich fehlen? Nicht das es ein Darstellungsproblem in der Vis ist.
                                        Die Tage gelten für alle Kalender.
                                        Gruß Tom
                                        Public Transport
                                        • T TT-Tom
                                          @damrak2022
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #160
                                          @tt-tom Das habe ich mir gerade angeschaut. Da stimmt alles. Jetzt ist auch alles vorhanden.
                                          Mit besten Grüßen
                                          Andy
