  4. Hilfe! IoBroker stürzt wiederholt ab.
iobroker absturz
41 Beiträge 4 Kommentatoren 3.7k Aufrufe 3 Beobachtet
    Stoni
    schrieb am zuletzt editiert von Stoni
    @Einstein67
    @Homoran
    Der Log von 10:06 Uhr war der Letzte, danach kam der Neustart um 11:43 Uhr.
    Hat das was mit dem history-Adapter zu tun? Der schreibt Werte meiner PV-Anlage in ein Diagramm. Das mache ich aber schon lange so. Und in dem Pi sitzt ne neue 32GB SD.
    • S Stoni
      Jan 31 10:05:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
      Jan 31 10:06:06 raspberrypi bash[625]: ENOSPC: no space left on device, write
      Jan 31 10:06:06 raspberrypi bash[625]: Error: ENOSPC: no space left on device, write
      Jan 31 10:06:06 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=6/NOTCONFIGURED
      Jan 31 10:06:06 raspberrypi bash[625]: { [Error: ENOSPC: no space left on device, write] errno: -28, code: 'ENOSPC', syscall: 'write' }
      Jan 31 10:06:07 raspberrypi bash[625]: /opt/iobroker/node_modules/winston/lib/winston/logger.js:307
      Jan 31 10:06:07 raspberrypi bash[625]:       throw ex;
      Jan 31 10:06:07 raspberrypi bash[625]:       ^
      Jan 31 10:06:07 raspberrypi bash[625]: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      Jan 31 10:06:07 raspberrypi bash[625]:     at doWrite (_stream_writable.js:411:19)
      Jan 31 10:06:07 raspberrypi bash[625]:     at writeOrBuffer (_stream_writable.js:399:5)
      Jan 31 10:06:07 raspberrypi bash[625]:     at WriteStream.Writable.write (_stream_writable.js:299:11)
      Jan 31 10:06:07 raspberrypi bash[625]:     at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:602:26)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile.log (/opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js:138:20)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile._write (/opt/iobroker/node_modules/winston-transport/index.js:102:17)
      Jan 31 10:06:07 raspberrypi bash[625]:     at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:428:64)
      Jan 31 10:06:07 raspberrypi bash[625]:     at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:417:5)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:334:11)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:$
      Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
      Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
      Jan 31 10:06:07 raspberrypi systemd[1]: Stopped ioBroker Server.
      Jan 31 10:06:07 raspberrypi systemd[1]: Started ioBroker Server.
      Jan 31 10:06:09 raspberrypi bash[20201]: /opt/iobroker/node_modules/winston/lib/winston/logger.js:307
      Jan 31 10:06:09 raspberrypi bash[20201]:       throw ex;
      Jan 31 10:06:09 raspberrypi bash[20201]:       ^
      @Stoni sagte in Hilfe! IoBroker stürzt wiederholt ab.:
      Aber du liest was du postest?
        Stoni
        @Homoran Ja das habe ich gelesen, aber ich kann damit nichts anfangen. Wo soll ich keinen Speicherplatz haben? Wie gesagt, ist ne 32GB SD drin.
        • S Stoni
          und wie hast du Raspbian vor dem ioBroker installiert?
            Stoni
            @Homoran Mit dem fertigen Image inkl. ioBroker etc.
            Habe gerade was gelesen, dass irgendwas mit resize noch durchgeführt werden muss(te). sudo raspi-config. Was muss man da machen? Weiß nicht, ob ich das getan habe.
            • S Stoni
              dann wohl nicht das readme gelesen ;-)
              ja!
              wohl eher nicht.
              Was sagt denn df -h
                ja!
                wohl eher nicht.
                Was sagt denn df -h
                Stoni
                @Homoran
                Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                /dev/root       3,4G    3,2G  8,4M  100% /
                devtmpfs        1,8G       0  1,8G    0% /dev
                tmpfs           2,0G       0  2,0G    0% /dev/shm
                tmpfs           2,0G    8,5M  1,9G    1% /run
                tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                tmpfs           2,0G       0  2,0G    0% /sys/fs/cgroup
                /dev/mmcblk0p1  253M     52M  201M   21% /boot
                tmpfs           391M       0  391M    0% /run/user/1000
                • S Stoni
                  @Homoran
                  /dev/root 3,4G 3,2G
                  also kein resize gemacht.
                  Steht im Readme wie du richtig sagst über raspi-config resize filesystem
                  S 2 Antworten Letzte Antwort
                    /dev/root 3,4G 3,2G
                    Stoni
                    @Homoran
                    also sudo raspi-config
                    dann advanced Options und dann
                    Expand filesystem?
                    geht das jetzt noch nachträglich?
                      /dev/root 3,4G 3,2G
                      Stoni
                      @Homoran
                      /dev/root        29G    3,2G   25G   12% /
                      Und jetzt alles gut?
                      • S Stoni
                        @Homoran
                        Expand filesystem?
                        Expand filesystem?
                        so müsste es im ReadMe stehen - die Menüs ändern sich immer mal wieder - in jedem zugehörigen ReadMe sollte die richtige Vorgehensweise stehen,
                        Das resize benötigt auch etwas Speicherplatz. Wenn der nicht mehr da ist geht es nicht.
                        Ob die gescheiterten Versuche etwas zu schreiben unvollständige Daten erzeugt haben, die später zu Problemen führen kann man auch nicht ausschließen
                          Expand filesystem?
                          Stoni
                          @Homoran Habs gemacht. Siehe oben. Dann sollte das Problem jetzt nicht mehr auftreten oder? Kann ich den History dann wieder laufen lassen?
                            Expand filesystem?
                            Stoni
                            @Homoran Kann es sein, dass bei ioB ein täglicher Neustart um 05:00 Uhr eingestellt ist? Ist das gut oder kann man das löschen? Wenn ja wo?
                            Vielen Dank schon mal soweit...
                            • S Stoni
                              @Homoran
                              Zu 'alles' siehe den Kommentar eben
                              Immerhin wieder 25GByte freier Platz
                              ich denke schon
                              • S Stoni
                                Wo sollte das sein?
                                Der Ganze ioB oder nur ein Adapter/Instanz?
                                  Wo sollte das sein?
                                  Stoni
                                  @Homoran Kriege jeden morgen um 05:00 Uhr eine Telegram Nachricht, dass der Bot gestartet wurde...
                                  Ups, aktuell sind alle Instanzen rot...
                                  • S Stoni
                                    welcher Bot?
                                      welcher Bot?
                                      Stoni
                                      @Homoran Update: alle Instanzen wieder grün... Puuh... :-)
                                      In der Telegram App kommt unter dem "Bot", den ich für ioB angelegt habe, täglich um 05:04 Uhr eine Nachricht "Restarting" und dann im direkten Anschluss "Started".
                                      Den Bot habe ich angelegt, um darin die ioB Nachrichten zu bekommen, Ertrag PV Anlage z.B.
                                      • S Stoni
                                        @Stoni und das liegt daran dass der gesamte ioBroker neu startet?
                                          Stoni
                                          @Homoran sagte in Hilfe! IoBroker stürzt wiederholt ab.:
                                          das hatte ich daraus geschlossen. Aber vielleicht ist es auch nur der Telegram Adapter. Werde ich mal in einer ruhigen Minute recherchieren.
                                          Danke Homoran für Deine Hilfe! Bin echt erleichtert und hoffe, dass jetzt alles läuft. Dann kann ich ja getrost auf Dienstreise fahren und muss nicht Angst haben, dass meine Frau ihre Koffer gepackt hat, bis ich wieder zuhause bin :-)
                                          Muss ich jetzt noch irgendwas beachten oder kann ich noch irgendwas tun?
