  4. Adapter "iobroker.nut" - UPS Daten im iobroker
83 Beiträge 14 Kommentatoren 21.4k Aufrufe 1 Beobachtet
    rascal
    #41
    hey,
    ich dachte, man muss das Intervall nun in den Adaptereinstellungen angeben, aber er fragt nach wie vor nach dem schedule:
    system-adapter-nut-0	2016-10-03 15:02:35.012	error	schedule attribute missing
    host-Mastermind	2016-10-03 15:02:32.510	warn	stopInstance system.adapter.nut.0 not scheduled
    host-Mastermind	2016-10-03 15:02:32.509	info	stopInstance system.adapter.nut.0
    der Adapter funktioniert nur, wenn man im Schedule die Werte eingibt, mit dem Wert im Adapter setup fängter er nichts an.
    Ebenfalls schreibt er nun einiges mehr in das Log:
    nut.0	2016-10-03 15:06:51.561	debug	host. redis publish io.nut.0.status.bypass {"val":false,"ack":true,"ts":1475500011533,"q":0,"from":"system.adapter.nut.0","lc":1472998201460}
    nut.0	2016-10-03 15:06:51.561	debug	host. redis publish io.nut.0.status.discharging {"val":false,"ack":true,"ts":1475500011533,"q":0,"from":"system.adapter.nut.0","lc":1475167426054}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.charging {"val":false,"ack":true,"ts":1475500011533,"q":0,"from":"system.adapter.nut.0","lc":1475169226032}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.replacebattery {"val":false,"ack":true,"ts":1475500011532,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.highbattery {"val":false,"ack":true,"ts":1475500011532,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.lowbattery {"val":false,"ack":true,"ts":1475500011532,"q":0,"from":"system.adapter.nut.0","lc":1474118700977}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.onbattery {"val":false,"ack":true,"ts":1475500011531,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.online {"val":true,"ack":true,"ts":1475500011531,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.vendorid {"val":"051d","ack":true,"ts":1475500011530,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.timer-shutdown {"val":"-1","ack":true,"ts":1475500011530,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.timer-reboot {"val":"0","ack":true,"ts":1475500011530,"q":0,"from":"system.adapter.nut.0","lc":1472998201457}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.status {"val":"OL","ack":true,"ts":1475500011529,"q":0,"from":"system.adapter.nut.0","lc":1475169226029}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500011529,"q":0,"from":"system.adapter.nut.0","lc":1472998201456}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.productid {"val":"0002","ack":true,"ts":1475500011529,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500011528,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500011528,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
    nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.mfr {"val":"APC","ack":true,"ts":1475500011527,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.load {"val":"28","ack":true,"ts":1475500011527,"q":0,"from":"system.adapter.nut.0","lc":1475167411043}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.firmware-aux {"val":"O3 ","ack":true,"ts":1475500011527,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.firmware {"val":"871.O3 .I","ack":true,"ts":1475500011526,"q":0,"from":"system.adapter.nut.0","lc":1472998201453}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.delay-shutdown {"val":"20","ack":true,"ts":1475500011526,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.beeper-status {"val":"enabled","ack":true,"ts":1475500011525,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.voltage-nominal {"val":"230","ack":true,"ts":1475500011525,"q":0,"from":"system.adapter.nut.0","lc":1472998201448}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.voltage {"val":"232.0","ack":true,"ts":1475500011525,"q":0,"from":"system.adapter.nut.0","lc":1475499511669}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.transfer-low {"val":"180","ack":true,"ts":1475500011524,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.transfer-high {"val":"266","ack":true,"ts":1475500011524,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.sensitivity {"val":"medium","ack":true,"ts":1475500011523,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.version-internal {"val":"0.38","ack":true,"ts":1475500011523,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.version-data {"val":"APC HID 0.95","ack":true,"ts":1475500011523,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.version {"val":"2.7.2","ack":true,"ts":1475500011522,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
    nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.parameter-port {"val":"auto","ack":true,"ts":1475500011522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.driver.parameter-pollinterval {"val":"2","ack":true,"ts":1475500011522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.driver.parameter-pollfreq {"val":"30","ack":true,"ts":1475500011521,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.driver.name {"val":"usbhid-ups","ack":true,"ts":1475500011521,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.type {"val":"ups","ack":true,"ts":1475500011520,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500011520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500011520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.mfr {"val":"APC","ack":true,"ts":1475500011519,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.voltage-nominal {"val":"12.0","ack":true,"ts":1475500011519,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.voltage {"val":"13.7","ack":true,"ts":1475500011518,"q":0,"from":"system.adapter.nut.0","lc":1475499511664}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.type {"val":"PbAc","ack":true,"ts":1475500011518,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.runtime-low {"val":"120","ack":true,"ts":1475500011518,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.runtime {"val":"1672","ack":true,"ts":1475500011517,"q":0,"from":"system.adapter.nut.0","lc":1475169241007}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500011517,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.date {"val":"not set","ack":true,"ts":1475500011516,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.charge-warning {"val":"50","ack":true,"ts":1475500011516,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:51.557	debug	host. redis publish io.nut.0.battery.charge-low {"val":"10","ack":true,"ts":1475500011516,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:51.557	debug	host. redis publish io.nut.0.battery.charge {"val":"100","ack":true,"ts":1475500011515,"q":0,"from":"system.adapter.nut.0","lc":1475169241004}
    nut.0	2016-10-03 15:06:51.557	info	nut.0 All Nut values set
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.severity = 0
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.shutdown = false
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.shutdown
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.boosting = false
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.boosting
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.trimming = false
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.trimming
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.overload = false
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.overload
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.offline = false
    nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.offline
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.calibration = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.calibration
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.bypass = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.bypass
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.discharging = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.discharging
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.charging = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.charging
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.replacebattery = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.replacebattery
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.highbattery = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.highbattery
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.lowbattery = false
    nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.lowbattery
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State status.onbattery = false
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State status.onbattery
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Severity Flag idle=true
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State status.online = true
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State status.online
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create Channel status
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.vendorid = 051d
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.vendorid
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.timer-shutdown = -1
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.timer-shutdown
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.timer-reboot = 0
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.timer-reboot
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.status = OL
    nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.status
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.serial = 5B1349T03604
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.serial
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.productid = 0002
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.productid
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.model = Back-UPS ES 700G
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.model
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.mfr-date = 2013/12/04
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.mfr-date
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.mfr = APC
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.load = 28
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.load
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.firmware-aux = O3
    nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.firmware-aux
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State ups.firmware = 871.O3 .I
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State ups.firmware
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State ups.delay-shutdown = 20
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State ups.delay-shutdown
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State ups.beeper-status = enabled
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State ups.beeper-status
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create Channel ups
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.voltage-nominal = 230
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State input.voltage-nominal
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.voltage = 232.0
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.transfer-low = 180
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State input.transfer-low
    nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.transfer-high = 266
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State input.transfer-high
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State input.sensitivity = medium
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State input.sensitivity
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create Channel input
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.version-internal = 0.38
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State driver.version-internal
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.version-data = APC HID 0.95
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State driver.version-data
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.version = 2.7.2
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.parameter-port = auto
    nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State driver.parameter-port
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State driver.parameter-pollinterval = 2
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State driver.parameter-pollinterval
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State driver.parameter-pollfreq = 30
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State driver.parameter-pollfreq
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State driver.name = usbhid-ups
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State driver.name
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create Channel driver
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State device.type = ups
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State device.type
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State device.serial = 5B1349T03604
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State device.serial
    nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State device.model = Back-UPS ES 700G
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State device.model
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State device.mfr = APC
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State device.mfr
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create Channel device
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.voltage-nominal = 12.0
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State battery.voltage-nominal
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.voltage = 13.7
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.type = PbAc
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State battery.type
    nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.runtime-low = 120
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.runtime-low
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.runtime = 1672
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.mfr-date = 2013/12/04
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.mfr-date
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.date = not set
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.date
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.charge-warning = 50
    nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.charge-warning
    nut.0	2016-10-03 15:06:51.547	debug	nut.0 Set State battery.charge-low = 10
    nut.0	2016-10-03 15:06:51.547	debug	nut.0 Create State battery.charge-low
    nut.0	2016-10-03 15:06:51.547	debug	nut.0 Set State battery.charge = 100
    nut.0	2016-10-03 15:06:51.547	debug	nut.0 Create Channel battery
    nut.0	2016-10-03 15:06:51.547	debug	nut.0 Got values, start setting them
    nut.0	2016-10-03 15:06:51.542	debug	nut.0 NUT Connection ready
    nut.0	2016-10-03 15:06:51.541	info	nut.0 Start NUT update
    nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.uptime {"val":196,"ack":true,"ts":1475500011384,"q":0,"from":"system.adapter.nut.0","lc":1475500011384}
    nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.memHeapUsed {"val":17.8,"ack":true,"ts":1475500011384,"q":0,"from":"system.adapter.nut.0","lc":1475500011384}
    nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.memHeapTotal {"val":20.82,"ack":true,"ts":1475500011384,"q":0,"from":"system.adapter.nut.0","lc":1475500011384}
    nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.memRss {"val":41.21,"ack":true,"ts":1475500011383,"q":0,"from":"system.adapter.nut.0","lc":1475500011383}
    nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.connected {"val":true,"ack":true,"ts":1475500011383,"q":0,"from":"system.adapter.nut.0","lc":1475499816328}
    nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.alive {"val":true,"ack":true,"ts":1475500011383,"q":0,"from":"system.adapter.nut.0","lc":1475499816327}
    Mastermind	2016-10-03 15:06:50.533	warn	host.Mastermind instance system.adapter.nut.0 already running with pid 14081
    nut.0	2016-10-03 15:06:46.578	debug	nut.0 NUT Connection closed. Done.
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.severity {"val":0,"ack":true,"ts":1475500006547,"q":0,"from":"system.adapter.nut.0","lc":1475498551530}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.shutdown {"val":false,"ack":true,"ts":1475500006547,"q":0,"from":"system.adapter.nut.0","lc":1472998201462}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.boosting {"val":false,"ack":true,"ts":1475500006546,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.trimming {"val":false,"ack":true,"ts":1475500006546,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.overload {"val":false,"ack":true,"ts":1475500006546,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.offline {"val":false,"ack":true,"ts":1475500006545,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.calibration {"val":false,"ack":true,"ts":1475500006545,"q":0,"from":"system.adapter.nut.0","lc":1472998201460}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.bypass {"val":false,"ack":true,"ts":1475500006545,"q":0,"from":"system.adapter.nut.0","lc":1472998201460}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.discharging {"val":false,"ack":true,"ts":1475500006544,"q":0,"from":"system.adapter.nut.0","lc":1475167426054}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.charging {"val":false,"ack":true,"ts":1475500006544,"q":0,"from":"system.adapter.nut.0","lc":1475169226032}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.replacebattery {"val":false,"ack":true,"ts":1475500006543,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.highbattery {"val":false,"ack":true,"ts":1475500006543,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.lowbattery {"val":false,"ack":true,"ts":1475500006542,"q":0,"from":"system.adapter.nut.0","lc":1474118700977}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.onbattery {"val":false,"ack":true,"ts":1475500006542,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
    nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.online {"val":true,"ack":true,"ts":1475500006541,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.vendorid {"val":"051d","ack":true,"ts":1475500006540,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.timer-shutdown {"val":"-1","ack":true,"ts":1475500006538,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.timer-reboot {"val":"0","ack":true,"ts":1475500006537,"q":0,"from":"system.adapter.nut.0","lc":1472998201457}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.status {"val":"OL","ack":true,"ts":1475500006536,"q":0,"from":"system.adapter.nut.0","lc":1475169226029}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500006535,"q":0,"from":"system.adapter.nut.0","lc":1472998201456}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.productid {"val":"0002","ack":true,"ts":1475500006535,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500006534,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500006533,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.mfr {"val":"APC","ack":true,"ts":1475500006532,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.load {"val":"28","ack":true,"ts":1475500006531,"q":0,"from":"system.adapter.nut.0","lc":1475167411043}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.firmware-aux {"val":"O3 ","ack":true,"ts":1475500006531,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.firmware {"val":"871.O3 .I","ack":true,"ts":1475500006530,"q":0,"from":"system.adapter.nut.0","lc":1472998201453}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.delay-shutdown {"val":"20","ack":true,"ts":1475500006529,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
    nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.beeper-status {"val":"enabled","ack":true,"ts":1475500006528,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.voltage-nominal {"val":"230","ack":true,"ts":1475500006528,"q":0,"from":"system.adapter.nut.0","lc":1472998201448}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.voltage {"val":"232.0","ack":true,"ts":1475500006527,"q":0,"from":"system.adapter.nut.0","lc":1475499511669}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.transfer-low {"val":"180","ack":true,"ts":1475500006526,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.transfer-high {"val":"266","ack":true,"ts":1475500006525,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.sensitivity {"val":"medium","ack":true,"ts":1475500006525,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.version-internal {"val":"0.38","ack":true,"ts":1475500006523,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.version-data {"val":"APC HID 0.95","ack":true,"ts":1475500006523,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.version {"val":"2.7.2","ack":true,"ts":1475500006523,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.parameter-port {"val":"auto","ack":true,"ts":1475500006522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.parameter-pollinterval {"val":"2","ack":true,"ts":1475500006522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.parameter-pollfreq {"val":"30","ack":true,"ts":1475500006522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.name {"val":"usbhid-ups","ack":true,"ts":1475500006521,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.device.type {"val":"ups","ack":true,"ts":1475500006521,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
    nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.device.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500006520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.device.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500006520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.device.mfr {"val":"APC","ack":true,"ts":1475500006520,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.voltage-nominal {"val":"12.0","ack":true,"ts":1475500006519,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.voltage {"val":"13.7","ack":true,"ts":1475500006518,"q":0,"from":"system.adapter.nut.0","lc":1475499511664}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.type {"val":"PbAc","ack":true,"ts":1475500006517,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.runtime-low {"val":"120","ack":true,"ts":1475500006517,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.runtime {"val":"1672","ack":true,"ts":1475500006516,"q":0,"from":"system.adapter.nut.0","lc":1475169241007}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500006515,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.date {"val":"not set","ack":true,"ts":1475500006515,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.charge-warning {"val":"50","ack":true,"ts":1475500006514,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.charge-low {"val":"10","ack":true,"ts":1475500006514,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
    nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.charge {"val":"100","ack":true,"ts":1475500006513,"q":0,"from":"system.adapter.nut.0","lc":1475169241004}
    nut.0	2016-10-03 15:06:46.573	info	nut.0 All Nut values set
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.severity = 0
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.shutdown = false
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.shutdown
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.boosting = false
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.boosting
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.trimming = false
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.trimming
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.overload = false
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.overload
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.offline = false
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.offline
    nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.calibration = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.calibration
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.bypass = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.bypass
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.discharging = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.discharging
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.charging = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.charging
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.replacebattery = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.replacebattery
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.highbattery = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.highbattery
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.lowbattery = false
    nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.lowbattery
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State status.onbattery = false
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State status.onbattery
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Severity Flag idle=true
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State status.online = true
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State status.online
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create Channel status
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.vendorid = 051d
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.vendorid
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.timer-shutdown = -1
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.timer-shutdown
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.timer-reboot = 0
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.timer-reboot
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.status = OL
    nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.status
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.serial = 5B1349T03604
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.serial
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.productid = 0002
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.productid
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.model = Back-UPS ES 700G
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.model
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.mfr-date = 2013/12/04
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.mfr-date
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.mfr = APC
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.load = 28
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.load
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.firmware-aux = O3
    nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.firmware-aux
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State ups.firmware = 871.O3 .I
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State ups.firmware
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State ups.delay-shutdown = 20
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State ups.delay-shutdown
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State ups.beeper-status = enabled
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State ups.beeper-status
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create Channel ups
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State input.voltage-nominal = 230
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State input.voltage-nominal
    nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State input.voltage = 232.0
    nut.0	2016-10-03 15:06:46.568	debug	nut.0 Set State input.transfer-low = 180
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State input.transfer-low
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State input.transfer-high = 266
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State input.transfer-high
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State input.sensitivity = medium
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State input.sensitivity
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create Channel input
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.version-internal = 0.38
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State driver.version-internal
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.version-data = APC HID 0.95
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State driver.version-data
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.version = 2.7.2
    nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.parameter-port = auto
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.parameter-port
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State driver.parameter-pollinterval = 2
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.parameter-pollinterval
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State driver.parameter-pollfreq = 30
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.parameter-pollfreq
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State driver.name = usbhid-ups
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.name
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create Channel driver
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State device.type = ups
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State device.type
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State device.serial = 5B1349T03604
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State device.serial
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State device.model = Back-UPS ES 700G
    nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State device.model
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State device.mfr = APC
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State device.mfr
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create Channel device
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.voltage-nominal = 12.0
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.voltage-nominal
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.voltage = 13.7
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.type = PbAc
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.type
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.runtime-low = 120
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.runtime-low
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.runtime = 1672
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.mfr-date = 2013/12/04
    nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.mfr-date
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.date = not set
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create State battery.date
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.charge-warning = 50
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create State battery.charge-warning
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.charge-low = 10
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create State battery.charge-low
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.charge = 100
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create Channel battery
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 Got values, start setting them
    nut.0	2016-10-03 15:06:46.564	debug	nut.0 NUT Connection ready
    nut.0	2016-10-03 15:06:46.564	info	nut.0 Start NUT update
    Mastermind	2016-10-03 15:06:45.531	warn	host.Mastermind instance system.adapter.nut.0 already running with pid 14081
    obwohl der Adapter auf log Level "info" steht
    • apollon77A Offline
      #42
      Korrekt Homoran … sorry hab den Pfad vergessen anzugeben.
      • HomoranH Offline
        HomoranH Offline
        #43
        hast du nach dem download ein
        iobroker upload nut
        gemacht?
        sonst ist ggf. noch die alte Version aktiv, obwohl im admin schon die neue angezeigt wird.
        Rainer
          rascal
          #44
          Ja, habe ich
          Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
            rascal
            #45
            Habe iobroker auch neu gestartet
              #46
              @rascal:
              hey,
              ich dachte, man muss das Intervall nun in den Adaptereinstellungen angeben, aber er fragt nach wie vor nach dem schedule: `
              Bitte versuche mal wie von Homoran gesagt das upload.
              AN sich ist im Adapter ein Stück Code drin der den "Tausch" machen sollte …
              Wenn es dann immer noch nicht tut dann geh mal zu "Objekte".
              Dort dann bei Type auf "instance" und auf den "Nut.0" (o.ä.) hinten auf edit klicken. Dann bekommst Du das Konfigobjekt angezeigt. poste das mal bitte.
              Falls dort bei "mode" noch "schedule" steht dann schreib einfach "daemon" rein ... aber eigentlich sollte das der Adapter selbst machen ...den Tip dazu hatte mit Bluefox gegeben. Wenn nicht muss ich da nochmal ran :-(
              Zum Logging: Häää ... komisch. Er gibt bei Dir "debug" Meldungen aus. ALs ob der Adapter auf Debug stehen würde. AUch das Loglevel findest Du in diesem Konfigobjekt von oben.
                rascal
                #47
                das "raw" Feld des system.adapter.nut.0
                  "common": {
                    "name": "nut",
                    "version": "1.0.0",
                    "title": "Network UPS Adapter",
                    "desc": "Read all data from your UPS/USV via nut protocol",
                    "platform": "Javascript/Node.js",
                    "mode": "schedule",
                    "schedule": "*/5 * * * * *",
                    "icon": "nut.png",
                    "extIcon": "https://raw.githubusercontent.com/Apollon77/ioBroker.nut/master/admin/nut.png",
                    "readme": "https://github.com/Apollon77/ioBroker.nut",
                    "license": "MIT",
                    "type": "hardware",
                    "loglevel": "info",
                    "installedVersion": "1.0.0",
                    "host": "Mastermind",
                    "subscribe": "messagebox",
                    "enabled": true,
                    "messagebox": true,
                    "news": {
                      "0.3.0": {
                        "en": "add better usable status states under 'status channel",
                        "de": "Besser nutzbare Stati States unter 'status' eingefügt",
                        "ru": "add better usable status states under 'status channel"
                      "1.0.0": {
                        "en": "change mode from schedule to deamon, implement message support to receive messages from upsmon, add status.severity",
                        "de": "Adapter arbeitet nun als Deamon, Notify-Support per upsmon hinzugefügt, status.severity hinzugefügt",
                        "ru": "change mode from schedule to deamon, implement message support to receive messages from upsmon, add status.severity"
                    "npmLibs": [],
                    "keywords": [
                      "iobroker",
                      "nut",
                      "ups",
                      "usv"
                  "native": {
                    "host_ip": "127.0.0.1",
                    "host_port": "3493",
                    "ups_name": "Powerplant",
                    "update_interval": "5"
                  "acl": {
                    "object": 1638,
                    "owner": "system.user.admin",
                  "_id": "system.adapter.nut.0",
                  "type": "instance"
                allgemein:
                  #48
                  Schreib bei mode mal "daemon" rein und starte neu. was passiert dann?
                  … und du willst wirklich alle 5 Sekunden neu lesen?
                    rascal
                    #49
                    hey,
                    ja, es läuft.
                    einziger Schönheitsfehler ist wieder das Log:
                    host-Mastermind	2016-10-03 17:37:10.012	warn	instance system.adapter.nut.0 already running with pid 21959
                    nut-0	2016-10-03 17:37:08.906	info	All Nut values set
                    nut-0	2016-10-03 17:37:08.886	info	Start NUT update
                    nachdem ich iobroker neu gestartet habe, scheint es auch mit dem Log zu funktionieren
                    Danke für die Hilfe, falls mir was auffällt, melde ich mich wieder.
                      #50
                      Mit Loglevel "warn" sollte fast nichts im Log stehen.
                        #51
                        Soooo … jetzt ist die Version im Github auch wirklich mit der Logik die von Schedule- auf Daemon-Modus automagisch umbaut :-)
                        Also wenn noch jemand testen will :-)
                        Update am besten per Kommandozeile und danach "upload" manuell machen - nötig wegen dem Direktinstall vom Github.
                        Theoretisch sollte er nach dem Update dann die DInger erstmal noch als "Schedule" haben und beim ersten Start wird dann umgeschrieben.
                        Ggf ist danach ein iobroker restart nötig bis dann alles echt rund läuft. Bei meinen Tests lief er als Daemon, wurde aber trotzdem einmal pro Stunde zusätzlich gestartet was nur eine Fehlerzeile im Log gab. Rest lief rund.
                        Nach neustart war alles super.
                        Kann das noch jemand testen?
                        Ingo F
                        • wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          #52
                          versuche gerade den Adapter zum laufen zu bekommen.
                          Wenn ich meine UPS Abfrage welche direkt am iobroker Server hängt sieht das so aus:
                          > upsc ups@127.0.0.1
                          battery.charge: 100
                          battery.charge.low: 10
                          battery.charge.warning: 50
                          battery.date: 2001/09/25
                          battery.mfr.date: 2013/11/18
                          battery.runtime: 11440
                          battery.runtime.low: 120
                          battery.type: PbAc
                          battery.voltage: 27.1
                          battery.voltage.nominal: 24.0
                          device.mfr: American Power Conversion
                          device.model: Back-UPS RS 900G
                          device.serial: 3B1329X15638
                          device.type: ups
                          driver.name: usbhid-ups
                          driver.parameter.pollfreq: 30
                          driver.parameter.pollinterval: 2
                          driver.parameter.port: auto
                          driver.parameter.vendorid: 051d
                          driver.version: 2.6.4
                          driver.version.data: APC HID 0.95
                          driver.version.internal: 0.37
                          input.sensitivity: medium
                          input.transfer.high: 294
                          input.transfer.low: 176
                          input.voltage: 231.0
                          input.voltage.nominal: 230
                          ups.beeper.status: enabled
                          ups.delay.shutdown: 20
                          ups.firmware: 879.L4 .I
                          ups.firmware.aux: L4
                          ups.load: 5
                          ups.mfr: American Power Conversion
                          ups.mfr.date: 2013/07/19
                          ups.model: Back-UPS RS 900G
                          ups.productid: 0002
                          ups.realpower.nominal: 540
                          ups.serial: 3B1329X15638
                          ups.status: OL
                          ups.test.result: No test initiated
                          ups.timer.reboot: 0
                          ups.timer.shutdown: -1
                          ups.vendorid: 051d
                          Wenn ich den Adapter mit den default Werten starte erscheint das im log:
                          nut.0	2017-01-10 21:41:30.887	error	Error happend: Error: connect ECONNREFUSED 127.0.0.1:3493
                          Das ganze ist Debian Wheezy mit folgenden Node und NPM Versionen:
                           npm -v
                          2.15.11
                          root@openmediavault /opt/iobroker/node_modules/iobroker.nut/test > node -v
                          v4.7.0
                          Fehlt mir etwas auf meinem System oder liegt das an meiner USV?
                          Danke und Gruß
                          Mirko
                            #53
                            In welchem Modus läuft denn der nut? (/etc/nut/nut.conf). Es sollte nicht auf "none" stehen … must vllt mal die modi durchprobieren ... netserver geht in jedem Fall denke ich.
                              wendy2702W Offline
                              wendy2702
                              #54
                              Läuft auf:
                               cat /etc/nut/nut.conf
                              MODE=standalone
                              Mal auf netserver und netclient gestellt.
                              Geht mit beiden nicht oder muss ich nach ändern der nut.conf noch mehr machen als nur den Adapter neu starten?
                              Ist es richtig das in der nut.conf nur diese eine Zeile steht?
                                #55
                                Wenn Du auf netserver stellst und neu startest … was sagt das log? Ich glaube aber da muss dann noch mehr rein in ein anderes File.
                                Schau mal z.B. hier: https://wiki.openwrt.org/inbox/software.nut
                                http://zackreed.me/installing-nut-on-ubuntu/
                                  wendy2702W Offline
                                  wendy2702
                                  #56
                                  so sieht es mit netserver aus:
                                  nut.0	2017-01-10 23:22:53.415	error	Error happend: Error: connect ECONNREFUSED 127.0.0.1:3493
                                  nut.0	2017-01-10 23:22:53.410	info	Start NUT update
                                  nut.0	2017-01-10 23:22:53.397	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.nut, node: v4.7.0
                                    wendy2702W Offline
                                    wendy2702
                                    #57
                                    Mal von dem einen link die Befehle abgefragt:
                                    MODE=netserver
                                     cat /etc/nut/ups.conf
                                    [ups]
                                    driver = usbhid-ups
                                    port = auto
                                    vendorid = 051d
                                    upsdrvctl start
                                    Network UPS Tools - UPS driver controller 2.6.4
                                    Network UPS Tools - Generic HID driver 0.37 (2.6.4)
                                    USB communication driver 0.32
                                    Using subdriver: APC HID 0.95
                                     cat /etc/nut/upsd.conf
                                    MAXAGE 15
                                    MAXCONN 1024
                                    LISTEN 127.0.0.1 3493
                                    Hier bei ist der einzige fehler:
                                    upsd
                                    Network UPS Tools upsd 2.6.4
                                    fopen /var/run/nut/upsd.pid: No such file or directory
                                    listening on 127.0.0.1 port 3493
                                    Connected to UPS [ups]: usbhid-ups-ups
                                     upsc ups@localhost ups.status
                                    OL
                                    root@openmediavault /opt/iobroker/node_modules/iobroker.nut/test > upsc ups@localhost
                                    battery.charge: 100
                                    battery.runtime: 12810
                                    battery.type: PbAc
                                    device.type: ups
                                    input.voltage: 230.0
                                    ups.load: 5
                                    ups.productid: 0002
                                    ups.status: OL
                                    ups.timer.reboot: 0
                                    ups.vendorid: 051d
                                    gerade einen letzten Versuch gestartet.
                                    Mir war nicht bewusst das ich scheinbar:
                                     upsdrvctl start
                                    root@openmediavault /var/run/nut > upsd
                                    /var/run/nut is world readable
                                    selber starten muss.
                                    Ist das so richtig oder sollte das nicht eigentlich der Adapter erledigen?
                                    Wenn ich nach manuellem start den Adapter starte sieht es so im log aus:
                                    nut.0	2017-01-10 23:46:57.134	info	All Nut values set
                                    nut.0	2017-01-10 23:46:57.122	info	Start NUT update
                                    nut.0	2017-01-10 23:46:57.108	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.nut, node: v4.7.0
                                      #58
                                      Hey, den UPS/NUT Prozess musst Du starten. Der Adapter verbindet sich nur da hin und liesst die Daten. Der Adapter kann ja auch den UPS/NUT-Prozess gar nicht starten weil er ja auch nicht lokal laufen kann …
                                      Aber jetzt scheint es ja zu tun, oder ?!
                                        wendy2702W Offline
                                        wendy2702
                                        #59
                                        Ja. So funktioniert es.
                                        Muss das jetzt später noch restart resistent machen.
                                        Jetzt aber schlafen.
                                        Gute Nacht und danke für deine Hilfe.
                                          wendy2702W Offline
                                          wendy2702
                                          #60
                                          Muss nochmal kurz fragen.
                                          Habe irgendwie auf den beiden Seiten nichts gefunden was ich machen kann/muss um dafür zu sorgen das die Prozesse nach einem restart von alleine starten.
                                          Ist das noch etwas notwendig oder starten die von alleine?
                                          Thx
