  4. Hue Adapter 3.0.1 -Update nur mit NodeJS 10.x
hue adapter update
11 Beiträge 5 Kommentatoren 1.3k Aufrufe 5 Beobachtet
  • MaufloM Offline
    MaufloM Offline
    Mauflo
    ACHTUNG: Wenn man den Hue Adapter auf 3.0.1 updaten möchte, braucht man unbedingt NodeJS 10.x. Ich habe mir beim Update mein System gecrasht, da der Adapter ständig (im Millisekundentakt) in das Logfile folgende Medung schrieb:
    2020-01-10 17:05:36.765  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: instance disabled because of node.js version mismatch
    2020-01-10 17:05:36.794  - ^[[33mwarn^[[39m: host.ioBroker.compactgroup1 startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.822  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.819  - ^[[33mwarn^[[39m: host.ioBroker.compactgroup1 startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.841  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: instance disabled because of node.js version mismatch
    2020-01-10 17:05:36.892  - ^[[33mwarn^[[39m: host.ioBroker.compactgroup1 startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.904  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.919  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: instance disabled because of node.js version mismatch
    2020-01-10 17:05:36.952  - ^[[33mwarn^[[39m: host.ioBroker.compactgroup1 startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.955  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:36.971  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: instance disabled because of node.js version mismatch
    2020-01-10 17:05:37.006  - ^[[33mwarn^[[39m: host.ioBroker.compactgroup1 startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:37.016  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:37.067  - ^[[33mwarn^[[39m: host.ioBroker.compactgroup1 startInstance hue.0: required node.js version >=10, actual version v8.15.0
    2020-01-10 17:05:37.068  - ^[[33mwarn^[[39m: host.ioBroker startInstance hue.0: instance disabled because of node.js version mismatch
    Damit war der Iobroker so beschäftigt, dass er mir den Admin praktisch lahmgelegt hat. Erst als ich über die Konsole den hue Adapter gestoppt hatte und ihn wieder auf version 2.5.0 gesetzt habe lief IoBroker wieder! Das hat aber ungefähr 15 Minuten gedauert, da er offenbar im Prozess weiter im Hintergrund mit dem schreiben des Logfiles beschäftigt war. ALSO NUR UPDATE AUF 3.0.1 WENN NODEJS 10.x am Server installiert ist!
    Meine Konfig ist:
    Betriebssystem linux
    os linux
    Architektur arm
    CPUs 4
    Geschwindigkeit 1400 MHz
    Modell ARMv7 Processor rev 4 (v7l)
    RAM 976.74 MB
    Node.js v8.15.0 (Es gibt eine neuere Version: v8.17.0 - Empfohlene Version v10.18.1)
    NPM 6.4.1
    Festplatte Größe 14.53 GB
    Festplatte frei 11.72 GB
    Aktive Instanzen 16
    RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
    • NegaleinN Negalein
      da kann sicher @foxriver76 was dazu sagen.
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      @Negalein Ja man benötigt Nodejs 10, daher auch der Major Increase von 2.x.x auf 3.x.x. Zudem ist Nodejs 8 End of Life seit Beginn 2020. Auch habe ich es mal https://forum.iobroker.net/topic/27994/test-adapter-hue-2-5-0/9 erwähnt sowie in der package json in den engines hinterlegt, leider arbeiten wir aktuell noch daran, dass Upgrades vom Controller verhindert werden wenn diese Voraussetzung fehlt. Ich werde mal einen 3.X Test Thread öffnen und da nochmal explizit darauf hinweisen.
      Videotutorials & mehr
      NegaleinN MaufloM 2 Antworten Letzte Antwort
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        ° Fixer ---> iob fix
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          • foxriver76F foxriver76
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            @foxriver76 sagte in Hue Adapter 3.0.1 -Update nur mit NodeJS 10.x:
            War mir nicht mehr ganz sicher.
            Dann weiß @Mauflo jetzt die Ursache seines Fehlers.
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              schrieb am zuletzt editiert von foxriver76
              @Negalein Ne die Ursache steht ja auch da.. das extreme Logging (im ms Takt) ist allerdings ein Problem und geloggt wird ja auch, dass die Instanz gestoppt wird, wird sie allerdings nicht - bzw. ständig neugestartet. Schaut nach nem Fehler im Controller aus, evtl im Zusammenspiel mit Compact Modus.
              cashC 1 Antwort Letzte Antwort
                cashC Offline
                cashC Offline
                cash
                @foxriver76 ich fände es Sinnvoll wenn das auch deutlich in den Release-Infos steht.
                • MaufloM Mauflo
                  Meine Konfig ist:
                  os linux
                  Architektur arm
                  CPUs 4
                  RAM 976.74 MB
                  NPM 6.4.1
                  Aktive Instanzen 16
                  apollon77A Online
                  apollon77A Online
                  @Mauflo bitte leg mal ein issue beim js-Controller an das wir diese komische Schleife fixen. Das ist falsch.
                  MaufloM 1 Antwort Letzte Antwort
                    MaufloM Offline
                    MaufloM Offline
                    Mauflo
                    @foxriver76 Danke!
                    • apollon77A apollon77
                      MaufloM Offline
                      MaufloM Offline
                      Mauflo
                      @apollon77 werd ich machen!
                      • MaufloM Mauflo
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        @Mauflo brauchst nicht. Fix schon da https://github.com/ioBroker/ioBroker.js-controller/pull/603
                        • apollon77A Online
                          apollon77A Online
                          Wir fixen das im bald kommenden js-controller 2.2.8 (kommt demnächst ins Latest)
