  4. Test Adapter rtspStream v0.0.x GitHub
    6.5k
rtsp stream
157 Beiträge 36 Kommentatoren 36.1k Aufrufe 53 Beobachtet
  • K Kanufreak
    nachdem ich heute den iobroker auf meinem raspbeery pi 4 auf den neusten Stand gebracht habe, zeigte sich schon nach kurzer Zeit wieder ein Problem mit dem rtsp-Adapter.
    Hier der gefilterte
    2020-01-25 00:26:31.602 - info: host.raspberrypi4 instance system.adapter.rtspStream.0 started with pid 13420
    2020-01-25 00:26:32.926 - debug: rtspStream.0 (13420) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-01-25 00:26:33.612 - debug: rtspStream.0 (13420) Objects client ready ... initialize now
    2020-01-25 00:26:33.619 - debug: rtspStream.0 (13420) Objects create System PubSub Client
    2020-01-25 00:26:33.621 - debug: rtspStream.0 (13420) Objects create User PubSub Client
    2020-01-25 00:26:33.622 - debug: rtspStream.0 (13420) Objects client initialize lua scripts
    2020-01-25 00:26:33.667 - debug: rtspStream.0 (13420) Objects connected to redis: 127.0.0.1:9001
    2020-01-25 00:26:33.674 - debug: rtspStream.0 (13420) objectDB connected
    2020-01-25 00:26:33.678 - debug: rtspStream.0 (13420) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-01-25 00:26:33.728 - debug: rtspStream.0 (13420) States create User PubSub Client
    2020-01-25 00:26:33.741 - debug: rtspStream.0 (13420) States create System PubSub Client
    2020-01-25 00:26:33.831 - debug: rtspStream.0 (13420) States connected to redis: 127.0.0.1:9000
    2020-01-25 00:26:33.833 - debug: rtspStream.0 (13420) statesDB connected
    2020-01-25 00:26:37.745 - info: rtspStream.0 (13420) starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.rtspStream, node: v10.18.1
    2020-01-25 00:26:37.797 - debug: rtspStream.0 (13420) Starting rtsp Stream
    2020-01-25 00:26:37.913 - debug: rtspStream.0 (13420) State Change: rtspStream.0.startStream to true ack false
    2020-01-25 00:26:37.913 - debug: rtspStream.0 (13420) Start stream on rtsp://xxxxx:xxxxx@192.168.20.29/profile3/media.smpwith port 554
    2020-01-25 00:47:09.772 - debug: rtspStream.0 (13420) system.adapter.admin.0: logging true
    2020-01-25 00:49:09.694 - debug: rtspStream.0 (13420) system.adapter.admin.0: logging false
    2020-01-25 00:55:14.185 - debug: rtspStream.0 (13420) system.adapter.admin.0: logging true
    2020-01-25 00:55:38.981 - debug: rtspStream.0 (13420) system.adapter.admin.0: logging false
    2020-01-25 00:56:16.372 - debug: rtspStream.0 (13420) system.adapter.admin.0: logging true
    2020-01-25 00:59:01.594 - debug: rtspStream.0 (13420) system.adapter.admin.0: logging false
    2020-01-25 01:00:40.825 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:40.825 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    at VideoStream.emit (events.js:198:13)
    at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    at Mpeg1Muxer.emit (events.js:198:13)
    at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    at Socket.emit (events.js:198:13)
    at addChunk (_stream_readable.js:288:12)
    at readableAddChunk (_stream_readable.js:269:11)
    at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:40.857 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:40.857 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:40.897 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:40.898 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:40.975 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:40.975 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.012 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.012 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.074 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.074 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.128 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.129 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.150 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.152 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.212 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.213 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.271 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.272 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.283 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.283 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.332 - info: rtspStream.0 (13420) terminating
    2020-01-25 01:00:41.335 - info: rtspStream.0 (13420) Terminated (NO_ERROR): Without reason
    2020-01-25 01:00:41.373 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.375 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.438 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:41.439 - error: rtspStream.0 (13420) ReferenceError: i is not defined
    2020-01-25 01:00:41.525 - error: rtspStream.0 (13420) uncaught exception: i is not defined
    2020-01-25 01:00:44.755 - error: host.raspberrypi4 Caught by controller[6]: frame=40286 fps= 20 q=3.5 size= 103517kB time=00:33:36.42 bitrate= 420.6kbits/s speed= 1x
    2020-01-25 01:00:44.756 - error: host.raspberrypi4 Caught by controller[7]: frame=40297 fps= 20 q=6.7 size= 103533kB time=00:33:36.85 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.756 - error: host.raspberrypi4 Caught by controller[8]: frame=40306 fps= 20 q=7.1 size= 103559kB time=00:33:37.35 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.757 - error: host.raspberrypi4 Caught by controller[9]: frame=40317 fps= 20 q=5.5 size= 103587kB time=00:33:37.86 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.757 - error: host.raspberrypi4 Caught by controller[10]: frame=40327 fps= 20 q=6.1 size= 103615kB time=00:33:38.36 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.757 - error: host.raspberrypi4 Caught by controller[11]: frame=40338 fps= 20 q=6.4 size= 103643kB time=00:33:38.86 bitrate= 420.6kbits/s speed= 1x
    2020-01-25 01:00:44.757 - error: host.raspberrypi4 Caught by controller[12]: frame=40348 fps= 20 q=6.7 size= 103669kB time=00:33:39.44 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.758 - error: host.raspberrypi4 Caught by controller[13]: frame=40358 fps= 20 q=6.1 size= 103696kB time=00:33:39.80 bitrate= 420.6kbits/s speed= 1x
    2020-01-25 01:00:44.758 - error: host.raspberrypi4 Caught by controller[14]: frame=40369 fps= 20 q=6.8 size= 103711kB time=00:33:40.45 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.758 - error: host.raspberrypi4 Caught by controller[15]: frame=40379 fps= 20 q=7.6 size= 103739kB time=00:33:40.95 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.758 - error: host.raspberrypi4 Caught by controller[16]: frame=40389 fps= 20 q=7.2 size= 103765kB time=00:33:41.45 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.759 - error: host.raspberrypi4 Caught by controller[17]: frame=40399 fps= 20 q=8.4 size= 103795kB time=00:33:41.95 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.759 - error: host.raspberrypi4 Caught by controller[18]: frame=40409 fps= 20 q=6.9 size= 103821kB time=00:33:42.53 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.759 - error: host.raspberrypi4 Caught by controller[19]: frame=40420 fps= 20 q=7.4 size= 103850kB time=00:33:43.03 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.760 - error: host.raspberrypi4 Caught by controller[20]: frame=40430 fps= 20 q=4.2 size= 103879kB time=00:33:43.39 bitrate= 420.6kbits/s speed= 1x
    2020-01-25 01:00:44.760 - error: host.raspberrypi4 Caught by controller[21]: frame=40440 fps= 20 q=6.8 size= 103893kB time=00:33:43.90 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.760 - error: host.raspberrypi4 Caught by controller[22]: frame=40450 fps= 20 q=6.0 size= 103921kB time=00:33:44.55 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.760 - error: host.raspberrypi4 Caught by controller[23]: frame=40460 fps= 20 q=6.2 size= 103946kB time=00:33:45.12 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.761 - error: host.raspberrypi4 Caught by controller[24]: frame=40471 fps= 20 q=5.5 size= 103976kB time=00:33:45.55 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.761 - error: host.raspberrypi4 Caught by controller[25]: frame=40481 fps= 20 q=7.2 size= 104001kB time=00:33:46.05 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.761 - error: host.raspberrypi4 Caught by controller[26]: frame=40490 fps= 20 q=6.3 size= 104028kB time=00:33:46.63 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.762 - error: host.raspberrypi4 Caught by controller[27]: frame=40501 fps= 20 q=5.8 size= 104048kB time=00:33:46.99 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.762 - error: host.raspberrypi4 Caught by controller[28]: frame=40512 fps= 20 q=6.3 size= 104073kB time=00:33:47.49 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.762 - error: host.raspberrypi4 Caught by controller[29]: frame=40521 fps= 20 q=5.0 size= 104098kB time=00:33:48.14 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.763 - error: host.raspberrypi4 Caught by controller[30]: frame=40532 fps= 20 q=6.9 size= 104128kB time=00:33:48.64 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.763 - error: host.raspberrypi4 Caught by controller[31]: frame=40542 fps= 20 q=7.7 size= 104156kB time=00:33:49.15 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.763 - error: host.raspberrypi4 Caught by controller[32]: frame=40552 fps= 20 q=5.9 size= 104182kB time=00:33:49.65 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.763 - error: host.raspberrypi4 Caught by controller[33]: frame=40562 fps= 20 q=5.4 size= 104211kB time=00:33:50.23 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.764 - error: host.raspberrypi4 Caught by controller[34]: frame=40573 fps= 20 q=5.6 size= 104229kB time=00:33:50.73 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.764 - error: host.raspberrypi4 Caught by controller[35]: frame=40584 fps= 20 q=5.5 size= 104256kB time=00:33:51.09 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.764 - error: host.raspberrypi4 Caught by controller[36]: frame=40593 fps= 20 q=7.2 size= 104281kB time=00:33:51.74 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.765 - error: host.raspberrypi4 Caught by controller[37]: frame=40603 fps= 20 q=6.1 size= 104310kB time=00:33:52.24 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.765 - error: host.raspberrypi4 Caught by controller[38]: frame=40613 fps= 20 q=7.2 size= 104334kB time=00:33:52.60 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.765 - error: host.raspberrypi4 Caught by controller[39]: frame=40623 fps= 20 q=8.2 size= 104363kB time=00:33:53.25 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.766 - error: host.raspberrypi4 Caught by controller[40]: frame=40634 fps= 20 q=3.5 size= 104393kB time=00:33:53.68 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.766 - error: host.raspberrypi4 Caught by controller[41]: frame=40645 fps= 20 q=4.4 size= 104411kB time=00:33:54.18 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.766 - error: host.raspberrypi4 Caught by controller[42]: frame=40655 fps= 20 q=5.0 size= 104440kB time=00:33:54.69 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.767 - error: host.raspberrypi4 Caught by controller[43]: frame=40665 fps= 20 q=7.1 size= 104464kB time=00:33:55.19 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.767 - error: host.raspberrypi4 Caught by controller[44]: frame=40675 fps= 20 q=5.8 size= 104491kB time=00:33:55.70 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.767 - error: host.raspberrypi4 Caught by controller[45]: frame=40686 fps= 20 q=6.1 size= 104522kB time=00:33:56.20 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.767 - error: host.raspberrypi4 Caught by controller[46]: frame=40696 fps= 20 q=5.7 size= 104550kB time=00:33:56.70 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.767 - error: host.raspberrypi4 Caught by controller[47]: frame=40707 fps= 20 q=4.0 size= 104582kB time=00:33:57.28 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[48]: frame=40717 fps= 20 q=4.3 size= 104597kB time=00:33:57.78 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[49]: frame=40726 fps= 20 q=4.5 size= 104624kB time=00:33:58.29 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[50]: frame=40737 fps= 20 q=4.4 size= 104654kB time=00:33:58.72 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[51]: frame=40746 fps= 20 q=6.6 size= 104679kB time=00:33:59.29 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[52]: frame=40756 fps= 20 q=7.5 size= 104708kB time=00:33:59.80 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[53]: frame=40768 fps= 20 q=7.7 size= 104737kB time=00:34:00.30 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.768 - error: host.raspberrypi4 Caught by controller[54]: frame=40778 fps= 20 q=3.7 size= 104767kB time=00:34:00.81 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[55]: frame=40788 fps= 20 q=5.6 size= 104782kB time=00:34:01.38 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[56]: frame=40798 fps= 20 q=7.3 size= 104810kB time=00:34:01.88 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[57]: ReferenceError: i is not defined
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[57]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[57]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[57]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.769 - error: host.raspberrypi4 Caught by controller[57]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.770 - error: host.raspberrypi4 Caught by controller[57]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.770 - error: host.raspberrypi4 Caught by controller[57]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.770 - error: host.raspberrypi4 Caught by controller[57]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.770 - error: host.raspberrypi4 Caught by controller[57]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.770 - error: host.raspberrypi4 Caught by controller[57]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[57]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: ReferenceError: i is not defined
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.771 - error: host.raspberrypi4 Caught by controller[58]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[58]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[58]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[58]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[58]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[59]: ReferenceError: i is not defined
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[59]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.772 - error: host.raspberrypi4 Caught by controller[59]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.773 - error: host.raspberrypi4 Caught by controller[59]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[59]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: ReferenceError: i is not defined
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.774 - error: host.raspberrypi4 Caught by controller[60]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[60]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[60]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[60]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[60]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[61]: ReferenceError: i is not defined
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[61]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[61]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.775 - error: host.raspberrypi4 Caught by controller[61]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[61]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.776 - error: host.raspberrypi4 Caught by controller[62]: ReferenceError: i is not defined
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.777 - error: host.raspberrypi4 Caught by controller[62]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[62]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[62]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[63]: frame=40808 fps= 20 q=6.0 size= 104840kB time=00:34:02.53 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[64]: ReferenceError: i is not defined
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[64]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[64]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.778 - error: host.raspberrypi4 Caught by controller[64]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[64]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.779 - error: host.raspberrypi4 Caught by controller[65]: ReferenceError: i is not defined
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.780 - error: host.raspberrypi4 Caught by controller[65]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[65]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[65]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[66]: ReferenceError: i is not defined
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[66]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[66]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[66]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.781 - error: host.raspberrypi4 Caught by controller[66]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[66]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[66]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[66]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[66]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[66]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[66]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[67]: ReferenceError: i is not defined
    2020-01-25 01:00:44.782 - error: host.raspberrypi4 Caught by controller[67]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.783 - error: host.raspberrypi4 Caught by controller[67]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.783 - error: host.raspberrypi4 Caught by controller[67]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.783 - error: host.raspberrypi4 Caught by controller[67]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.783 - error: host.raspberrypi4 Caught by controller[67]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.783 - error: host.raspberrypi4 Caught by controller[67]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[67]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[67]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[67]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[67]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[68]: ReferenceError: i is not defined
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[68]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[68]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.784 - error: host.raspberrypi4 Caught by controller[68]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[68]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.785 - error: host.raspberrypi4 Caught by controller[69]: ReferenceError: i is not defined
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.786 - error: host.raspberrypi4 Caught by controller[69]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[69]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[69]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[70]: ReferenceError: i is not defined
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[70]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[70]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[70]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[70]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.787 - error: host.raspberrypi4 Caught by controller[70]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[70]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[70]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[70]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[70]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[70]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[71]: ReferenceError: i is not defined
    2020-01-25 01:00:44.788 - error: host.raspberrypi4 Caught by controller[71]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.789 - error: host.raspberrypi4 Caught by controller[71]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[71]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[72]: ReferenceError: i is not defined
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[72]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[72]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[72]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[72]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.790 - error: host.raspberrypi4 Caught by controller[72]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[72]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[72]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[72]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[72]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[72]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[73]: ReferenceError: i is not defined
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[73]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.791 - error: host.raspberrypi4 Caught by controller[73]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.792 - error: host.raspberrypi4 Caught by controller[73]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[74]: frame=40818 fps= 20 q=10.6 size= 104864kB time=00:34:02.89 bitrate= 420.5kbits/s speed= 1x
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: ReferenceError: i is not defined
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.793 - error: host.raspberrypi4 Caught by controller[75]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[75]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[75]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[75]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[75]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[76]: ReferenceError: i is not defined
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[76]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[76]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.794 - error: host.raspberrypi4 Caught by controller[76]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[76]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.795 - error: host.raspberrypi4 Caught by controller[77]: ReferenceError: i is not defined
    2020-01-25 01:00:44.796 - error: host.raspberrypi4 Caught by controller[77]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.796 - error: host.raspberrypi4 Caught by controller[77]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.796 - error: host.raspberrypi4 Caught by controller[77]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.796 - error: host.raspberrypi4 Caught by controller[77]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.797 - error: host.raspberrypi4 Caught by controller[77]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.797 - error: host.raspberrypi4 Caught by controller[77]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.797 - error: host.raspberrypi4 Caught by controller[77]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[77]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[77]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[77]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[78]: ReferenceError: i is not defined
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[78]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[78]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.798 - error: host.raspberrypi4 Caught by controller[78]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.799 - error: host.raspberrypi4 Caught by controller[78]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.800 - error: host.raspberrypi4 Caught by controller[79]: ReferenceError: i is not defined
    2020-01-25 01:00:44.800 - error: host.raspberrypi4 Caught by controller[79]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
    2020-01-25 01:00:44.800 - error: host.raspberrypi4 Caught by controller[79]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
    2020-01-25 01:00:44.800 - error: host.raspberrypi4 Caught by controller[79]: at VideoStream.emit (events.js:198:13)
    2020-01-25 01:00:44.800 - error: host.raspberrypi4 Caught by controller[79]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
    2020-01-25 01:00:44.800 - error: host.raspberrypi4 Caught by controller[79]: at Mpeg1Muxer.emit (events.js:198:13)
    2020-01-25 01:00:44.801 - error: host.raspberrypi4 Caught by controller[79]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
    2020-01-25 01:00:44.801 - error: host.raspberrypi4 Caught by controller[79]: at Socket.emit (events.js:198:13)
    2020-01-25 01:00:44.801 - error: host.raspberrypi4 Caught by controller[79]: at addChunk (_stream_readable.js:288:12)
    2020-01-25 01:00:44.801 - error: host.raspberrypi4 Caught by controller[79]: at readableAddChunk (_stream_readable.js:269:11)
    2020-01-25 01:00:44.801 - error: host.raspberrypi4 Caught by controller[79]: at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-25 01:00:44.802 - info: host.raspberrypi4 instance system.adapter.rtspStream.0 terminated with code 0 (NO_ERROR)
    2020-01-25 01:00:44.802 - info: host.raspberrypi4 Restart adapter system.adapter.rtspStream.0 because enabled
    2020-01-25 01:01:14.841 - info: host.raspberrypi4 instance system.adapter.rtspStream.0 started with pid 1172
    2020-01-25 01:01:15.992 - debug: rtspStream.0 (1172) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-01-25 01:01:16.039 - debug: rtspStream.0 (1172) Objects client ready ... initialize now
    2020-01-25 01:01:16.043 - debug: rtspStream.0 (1172) Objects create System PubSub Client
    2020-01-25 01:01:16.044 - debug: rtspStream.0 (1172) Objects create User PubSub Client
    2020-01-25 01:01:16.045 - debug: rtspStream.0 (1172) Objects client initialize lua scripts
    2020-01-25 01:01:16.070 - debug: rtspStream.0 (1172) Objects connected to redis: 127.0.0.1:9001
    2020-01-25 01:01:16.076 - debug: rtspStream.0 (1172) objectDB connected
    2020-01-25 01:01:16.079 - debug: rtspStream.0 (1172) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-01-25 01:01:16.091 - debug: rtspStream.0 (1172) States create User PubSub Client
    2020-01-25 01:01:16.093 - debug: rtspStream.0 (1172) States create System PubSub Client
    2020-01-25 01:01:16.113 - debug: rtspStream.0 (1172) States connected to redis: 127.0.0.1:9000
    2020-01-25 01:01:16.114 - debug: rtspStream.0 (1172) statesDB connected
    2020-01-25 01:01:17.418 - info: rtspStream.0 (1172) starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.rtspStream, node: v10.18.1
    2020-01-25 01:01:17.454 - debug: rtspStream.0 (1172) Starting rtsp Stream
    2020-01-25 01:01:17.560 - debug: rtspStream.0 (1172) State Change: rtspStream.0.startStream to true ack false
    2020-01-25 01:01:17.560 - debug: rtspStream.0 (1172) Start stream on rtsp://xxxxx:xxxxx@192.168.20.29/profile3/media.smpwith port undefined
    2020-01-25 01:01:34.445 - debug: rtspStream.0 (1172) system.adapter.admin.0: logging true
    Nach dem Neustart des Adapters startet der Stream ohne definiertem Port, also auch ohne Bild.
    Ich hoffe das hilft weiter.
    dbwebD Offline
    dbwebD Offline
    dbweb
    @Kanufreak bin grad im Urlaub, schaus mir in 2 Wochen an.
    • wawyoW Offline
      wawyoW Offline
      wawyo
      schrieb am zuletzt editiert von wawyo
      Als erstes möchte ich mich bedanken für die Gelegenheit den Adapter weiterzuentwickeln (für den Privaten Gebrauch).
      Ich habe der Code angepasst und mehrere Funktionen hinzugefügt: 3 Kamera, Auflösung Anpassung und TCP Port ;-)
      Wer hat Interesse, kann ich die zwei angepassten Dateien (main.js und index.html) hochladen ;-)
      LatziL dbwebD 2 Antworten Letzte Antwort
      • wawyoW wawyo
        LatziL Online
        LatziL Online
        Latzi
        @wawyo sagte in Test Adapter rtspStream v0.0.x GitHub:
        Wer hat Interesse
        Ja, da hab ich wirklich Interesse, wäre cool wenn du die Weiterentwicklung teilen würdest (vielleicht mit Anleitung, wie die 2 Dateien einzubinden sind) 👍 👏
        • wawyoW wawyo
          dbwebD Offline
          dbwebD Offline
          dbweb
          @wawyo mach doch botte einen pull request im repo, dann kann ich das im Adapter einfügen.
          • K Offline
            Kanufreak
            Interesse habe ich auch!
            Seit den letzten Updates von IoBroker startet der Stream nur noch mit undefiniertem Port und somit ohne Funktion.
            wawyoW 2 Antworten Letzte Antwort
            • K Kanufreak
              wawyoW Offline
              wawyoW Offline
              wawyo
              es ist noch optimierbar 😊
              1- Zugriffsrechte ändern.
              sudo chmod 777 /opt/iobroker/node_modules/iobroker.rtspStream/main.js
              sudo chmod 777 /opt/iobroker/iobroker-data/files/rtspStream.admin/index_m.html
              2- Datein Sichern dann überschreiben.
              main.js
              index_m.html
              main.js und index_m.html mit FileZilla ersetzen
              3- System restart
              sudo reboot
              4- Fertig :-)
              @dbweb Danke ;-)
              LatziL 2 Antworten Letzte Antwort
              • wawyoW wawyo
                main.js
                index_m.html
                3- System restart
                sudo reboot
                4- Fertig :-)
                @dbweb Danke ;-)
                LatziL Online
                LatziL Online
                Latzi
                @wawyo Danke!
                @dbweb baust du so etwas in der Art in den Adapter ein?
                • K Offline
                  Kanufreak
                  Hallo wawyo, Hallo dbweb,
                  auch nach dem Austausch der zwei Dateien entsprechend der Anleitung und mit richtig eingestelltem Port auf 554, startet der Stream mit undefiniertem Port.
                  Ich hoffe ihr findet den Fehler noch.
                  Danke für eure Mühen, auf diesen Adapter habe ich lange gewartet.
                  • K Kanufreak
                    wawyoW Offline
                    wawyoW Offline
                    wawyo
                    @Kanufreak anscheinend du hast die :554 vergessen!
                    rtsp://Benutzer:Passwort@IPAdresse:Port/..
                    rtsp://Benutzer:Passwort@192.168.20.29:554/profile3/media.smpw
                    • wawyoW wawyo
                      main.js
                      index_m.html
                      3- System restart
                      sudo reboot
                      4- Fertig :-)
                      @dbweb Danke ;-)
                      LatziL Online
                      LatziL Online
                      Latzi
                      4- Fertig
                      und es funktioniert, vielen Dank @wawyo !
                      • K Offline
                        Kanufreak
                        Hallo wawyo,
                        auf der von dir geänderten Admin-Seite gibt es doch ein Feld für den TCP-Port, ich dachte das genügt.
                        Ich habe jetzt trotzdem im Pfad zusätzlich mal den Port mit angegeben, ohne Erfolg.
                        Der Fehler tritt erst seit den letzten Systemupdates vom RaspberryPi4 bzw. IoBroker auf. Welches Update es jetzt genau war, kann ich leider nicht mehr sagen. Hier noch die Systeminfos.
                        Platform: linux
                        os: linux
                        Architecture: arm
                        CPUs: 4
                        Speed: 1500 MHz
                        Model: ARMv7 Processor rev 3 (v7l)
                        RAM: 3.8 GB
                        System uptime: 01:41:22
                        Node.js: v10.19.0
                        NPM: 6.13.4
                        Disk size: 28.2 GiB
                        Disk free: 23.7 GiB
                        adapters count: 322
                        Uptime: 01:41:06
                        Active instances: 35
                        wawyoW 1 Antwort Letzte Antwort
                        • K Kanufreak
                          Hallo wawyo,
                          Platform: linux
                          os: linux
                          Architecture: arm
                          CPUs: 4
                          Speed: 1500 MHz
                          RAM: 3.8 GB
                          Node.js: v10.19.0
                          NPM: 6.13.4
                          Disk size: 28.2 GiB
                          Disk free: 23.7 GiB
                          adapters count: 322
                          Uptime: 01:41:06
                          wawyoW Offline
                          wawyoW Offline
                          wawyo
                          @Kanufreak ich tendiere zu fehlende Ressourcen.
                          An deiner Stelle würde ich alles neu aufbauen;
                          • ffmpeg deinstallieren.
                          • Iobroker rtspStream aus der Liste deinstallieren.
                          • Iobroker neustarten.
                          • ffmpeg installieren.
                            => Achtung! Mit 'J' bestätigen.
                          • Iobroker rtspStream downloaden.
                          • Iobroker rtspStream installieren.
                          • Wenn gewünscht, Dateien austauschen.
                          Vielleicht hilft es 😊
                          Achtung! Bitte Backup erstellen.
                          sudo iobroker backup
                          sudo apt-get autoremove ffmpeg
                          sudo iobroker del iobroker rtspstream
                          sudo reboot
                          sudo apt-get update
                          sudo apt-get install ffmpeg
                          sudo apt-get install lame
                          sudo npm install https://github.com/dbweb-ch/ioBroker.rtspStream
                          Iobroker rtspStream Adapter installieren
                          sudo wget -P /opt/iobroker/node_modules/iobroker.rtspStream/ https://forum.iobroker.net/assets/uploads/files/1581488900029-main.js
                          sudo wget -P /opt/iobroker/iobroker-data/files/rtspStream.admin/ https://forum.iobroker.net/assets/uploads/files/1581456034239-index_m.html
                          sudo mv -b /opt/iobroker/node_modules/iobroker.rtspStream/1581488900029-main.js /opt/iobroker/node_modules/iobroker.rtspStream/main.js
                          sudo mv -b /opt/iobroker/iobroker-data/files/rtspStream.admin/1581456034239-index_m.html /opt/iobroker/iobroker-data/files/rtspStream.admin/index_m.html
                          sudo iobroker reboot
                          K 1 Antwort Letzte Antwort
                          • tob1T Offline
                            tob1T Offline
                            tob1
                            schrieb am zuletzt editiert von tob1
                            nachdem ich einige Wochen mit motioneye, motioneyeOS, iSpy und Xeoma herumgespielt/ausprobiert habe und nicht wirklich zufrieden war, bin ich begeistert von diesem Adapter!
                            Mit der Erweiterung und Anleitung von @wawyo läuft der Stream richtig gut in meiner VIS. Der Zeitversatz ist minimal und der Stream läuft nahezu ruckelfrei.
                            Da ich in meiner Visualisierung (auf Wandtablet) im Homescreen ein kleines Fenster mit dem Livestream habe und dazu noch einen weiteren View mit quasi einem "Vollbild" des Streams, habe ich einfach gemäß der o.g. Anleitung einen zweiten Stream mit anderer Auflösung eingerichtet.
                            Einzig die Bildqualität ist nicht wie so wie im originalen RTSP Stream.
                            Damit kann ich aber erstmal leben. Eventuell habe ich auch nur falsche Einstellungen an der Kamera oder am Adapter vorgenommen?! Ich werde noch ein bisschen weiter ausprobieren.
                            In den nächsten Tagen soll noch eine neue Kamera geliefert werden, sodass ich dann mit dem Adapter weiter rumspielen werde.
                            Da meine Kenntnisse in Sachen Programmierung etc. gen null gehen, bitte ich dazu noch um kurze Hilfe.
                            Kann ich die beiden Dateien main.js und index_m.html "einfach" um "Stream 4" erweitern?
                            Also nochmal:
                            besten Dank an @dbweb und @wawyo für die tolle Arbeit! :-)
                            Grüße,
                            Tobias
                            edit:
                            Vielleicht nicht ganz unwichtig? mein (Proxmox) System:
                            i5-6500, 8GB DDR4, SSD,
                            iOBroker in Debian ohne Desktop installiert.
                            CPU Auslastung liegt bei durschn. 12%
                            RAM bei 1,4 GB
                            Stromverbrauch konstant bei 21W
                            Die aktuell genutzte Kamera ist eine Foscam FI9900P
                            dbwebD E 2 Antworten Letzte Antwort
                            • tob1T tob1
                              Also nochmal:
                              Grüße,
                              Tobias
                              edit:
                              RAM bei 1,4 GB
                              dbwebD Offline
                              dbwebD Offline
                              dbweb
                              @wawyo danke dir.
                              Habe nun Version 0.0.2 gemacht. Habe ein paar Dinge von dir genommen (v.a. Auflösung), hab die Anzahl Streams aber dynamisch konfigurierbar gemacht, d.h. ihr könnt so viele Streams erstellen wie ihr wollt.
                              Zudem kann man weitere ffmpeg-optionen anhängen, einfach Optionen als validen json-code eintragen. Im log sieht man dann, welche Optionen beim Stream wirklich gesetzt wurden.
                              Wenn der Stream häufiger abbricht, kann man das mit einer der zig ffmpeg-Optionen evtl. stabiler machen.
                              tob1T 1 Antwort Letzte Antwort
                              • tob1T tob1
                                Also nochmal:
                                Grüße,
                                Tobias
                                edit:
                                RAM bei 1,4 GB
                                el_malto
                                @tob1 sagte in Test Adapter rtspStream v0.0.x GitHub:
                                Du brauchst dafür keine zwei Streams im Adapter einrichten. Du kannst bei beiden Views den gleichen Stream verwenden. Die Auflösung die du im Adapter angibst, ist die Auslösung in der ffmpeg den Stream convertiert. Wenn du den Stream in Vollbild angucken willst, würde ich im Adapter auch die volle Auflösung der Kamera einstellen um auch die beste Qualität zu haben. In der VIS kannst du das Widget ja in der Größe frei skalieren.
                                • dbwebD dbweb
                                  @wawyo danke dir.
                                  tob1T Offline
                                  tob1T Offline
                                  tob1
                                  @dbweb
                                  die Neuerungen haben mich natürlich sofort neugierig gemacht und ich habe den Adapter gelöscht und die neue Version über github link installiert.
                                  Leider bekomme ich nun kein Bild mehr angezeigt:
                                  Meine Einstellungen sehen wie folgt aus:
                                  (Url getestet in VLC, funktioniert. Port habe ich so übernommen, aber auch mal mit zB Port 88 aus dem "fix" von wawyo ausprobiert.)
                                  und das spuckt der log im debug mode aus:
                                  rtspStream.0	2020-02-13 17:36:37.856	debug	(17232) sendTo "getStreams" to system.adapter.admin.0 from system.adapter.rtspStream.0
                                  rtspStream.0	2020-02-13 17:36:37.846	debug	(17232) Got a Message: getStreams
                                  rtspStream.0	2020-02-13 17:34:00.267	debug	(17232) system.adapter.admin.0: logging true
                                  rtspStream.0	2020-02-13 17:33:59.475	debug	(17232) system.adapter.admin.0: logging false
                                  rtspStream.0	2020-02-13 17:33:57.095	info	(17232) Stream Einfahrt starting Server on Port 8083
                                  rtspStream.0	2020-02-13 17:33:57.094	info	(17232) Stream Einfahrt using TcpPort 554
                                  rtspStream.0	2020-02-13 17:33:57.049	info	(17232) Number of streams: 1
                                  rtspStream.0	2020-02-13 17:33:57.025	debug	(17232) Starting rtsp Stream
                                  rtspStream.0	2020-02-13 17:33:57.015	info	(17232) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.rtspStream, node: v10.19.0
                                  rtspStream.0	2020-02-13 17:33:56.410	debug	(17232) statesDB connected
                                  rtspStream.0	2020-02-13 17:33:56.410	debug	(17232) States connected to redis: 127.0.0.1:9000
                                  rtspStream.0	2020-02-13 17:33:56.403	debug	(17232) States create System PubSub Client
                                  rtspStream.0	2020-02-13 17:33:56.402	debug	(17232) States create User PubSub Client
                                  rtspStream.0	2020-02-13 17:33:56.399	debug	(17232) Redis States: Use Redis connection: 127.0.0.1:9000
                                  rtspStream.0	2020-02-13 17:33:56.398	debug	(17232) objectDB connected
                                  rtspStream.0	2020-02-13 17:33:56.396	debug	(17232) Objects connected to redis: 127.0.0.1:9001
                                  rtspStream.0	2020-02-13 17:33:56.389	debug	(17232) Objects client initialize lua scripts
                                  rtspStream.0	2020-02-13 17:33:56.389	debug	(17232) Objects create User PubSub Client
                                  rtspStream.0	2020-02-13 17:33:56.389	debug	(17232) Objects create System PubSub Client
                                  rtspStream.0	2020-02-13 17:33:56.388	debug	(17232) Objects client ready ... initialize now
                                  rtspStream.0	2020-02-13 17:33:56.371	debug	(17232) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  rtspStream.0	2020-02-13 17:33:54.090	info	(17099) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  rtspStream.0	2020-02-13 17:33:54.089	info	(17099) terminating
                                  rtspStream.0	2020-02-13 17:33:53.588	info	(17099) Got terminate signal TERMINATE_YOURSELF
                                  @el_malto
                                  Werde mir das nochmal ansehen sobald der Adapter wieder bei mir läuft!
                                  Zuerst hatte ich das auch so, mit dem iFrame Widget. allerdings waren dann bei zu hoher Auflösung immer die Scroll-Buttons am Widget und das Bild nicht auf die Widgetgröße skaliert.
                                  Danke dir schon mal für den Tipp!
                                  dbwebD 1 Antwort Letzte Antwort
                                  • tob1T tob1
                                    @dbweb
                                    @el_malto
                                    dbwebD Offline
                                    dbwebD Offline
                                    dbweb
                                    @tob1 kannst du mal beide ports ändern, z.b. 555 und 8086? Hatte das beim testen auch mal, ist aber nach portänderung nicht mehr aufgetaucht.
                                    • dbwebD dbweb
                                      dbwebD Offline
                                      dbwebD Offline
                                      dbweb
                                      Ah und du hast "startStream" in den Objekten bei dem Stream auf true gesetzt?
                                      • dbwebD dbweb
                                        tob1T Offline
                                        tob1T Offline
                                        tob1
                                        @dbweb said in Test Adapter rtspStream v0.0.x GitHub:
                                        @dbweb
                                        Ports habe ich geändert, leider kein Erfolg.
                                        @dbweb
                                        das stand schon auf true. habe ich aber nochmal auf false und wieder zurück geändert.
                                        Auch Adapter neugestartet etc. habe ich, leider auch noch nicht erfolgreich.
                                        • tob1T Offline
                                          tob1T Offline
                                          tob1
                                          wie gesagt, ich habe relativ wenig Ahnung von der Materie...
                                          Hilft es dir wenn ich den Quelltext der StreamURL dir mitteile?
                                          quelltext.txt
