  4. Probleme mit ZWave 1.7.2
zwave
5 Beiträge 2 Kommentatoren 433 Aufrufe 1 Beobachtet
  • L Offline
    LaplaceII
    Hallo, ich habe auf iobroker.zwave auf Version 1.7.2 gebracht (Rock64, JS Controller 2.1.1, npm 6.11.3, node.js 10.17.0). Leider bekomme ich kein grünes Licht bei den Instanzen (sudo ldconfig mehrfach ausgeführt, System mehrfach neu gestartet, auch alte Versionen funktionieren leider nicht mehr). Folgende Meldung erscheint im Log:
    host.rock64	2019-12-01 22:27:39.662	info	instance system.adapter.zwave.0 terminated with code 0 (NO_ERROR)
    host.rock64	2019-12-01 22:27:39.661	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3) code: 'MODULE_NOT_FOUND' }
    host.rock64	2019-12-01 22:27:39.661	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.rock64	2019-12-01 22:27:39.660	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.rock64	2019-12-01 22:27:39.660	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.rock64	2019-12-01 22:27:39.659	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.rock64	2019-12-01 22:27:39.659	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19)
    host.rock64	2019-12-01 22:27:39.658	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.rock64	2019-12-01 22:27:39.658	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.rock64	2019-12-01 22:27:39.658	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    host.rock64	2019-12-01 22:27:39.657	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    host.rock64	2019-12-01 22:27:39.656	error	Caught by controller[0]: { Error: Cannot find module '/opt/iobroker/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
    zwave.0	2019-12-01 22:27:39.097	info	(6810) Terminated (NO_ERROR): Without reason
    zwave.0	2019-12-01 22:27:39.094	info	(6810) terminating
    zwave.0	2019-12-01 22:27:38.967	error	(6810) Error: Cannot find module '/opt/iobroker/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15
    zwave.0	2019-12-01 22:27:38.964	error	(6810) uncaught exception: Cannot find module '/opt/iobroker/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
    zwave.0	2019-12-01 22:27:33.317	info	(6810) starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
    host.rock64	2019-12-01 22:27:30.068	info	instance system.adapter.zwave.0 started with pid 6810
    Hat jemand eine Idee, bevor ich das System neu aufsetze? Backup hat leider auch nicht funktioniert...
    • L LaplaceII
      Hallo, leider noch keine Besserung eingetreten, selbst die Neuinstallation des Systems hat nichts gebracht. Wäre um jede Hilfe dankbar!
      arteckA Offline
      arteckA Offline
      arteck
      @LaplaceII da wurde das openzwave nicht kompiliert.. hast du was abgebrochen bei der installation .. das kann so 20 min dauern bis der rock damit fertig ist
      ansonsten mach mal
      cd /opt/iobroker/node_modules/openzwave-shared
      make
      make install
      ldconfig
      und schau dir die Ausgaben von den Befehlen an .. nicht einfach stupide diese Ausführen
      • L Offline
        LaplaceII
        • L LaplaceII
          arteckA Offline
          arteckA Offline
          arteck
          ansonsten mach mal
          make
          make install
          ldconfig
          • L Offline
            LaplaceII
            Danke, ich probiere es nochmal aus....wahrscheinlich war ich zu ungeduldig 😬
            • L Offline
              LaplaceII
              Jetzt hat es funktioniert, danke!
