  4. Test Adapter Hue v2.4.x
    6.6k
huetestingtester
27 Beiträge 3 Kommentatoren 2.4k Aufrufe 7 Beobachtet
  • foxriver76F foxriver76
    @Negalein Finde kein colorpicker Widget in vis, ist das aus einem Adapter oder wie heißt es genau?
    Habe probiert genau den Befehl zu senden wie es dein Widget tut:
    {"transitiontime":1,"xy":"0.5255681818181818,0.86015625","level":100}
    So schaut das dann aus:
    2019-12-19 18:30:21.865 - debug: hue.0 (30635) stateChange hue.0.Nachttisch_Eins.command {"val":"{\"transitiontime\":1,\"xy\":\"0.5255681818181818,0.86015625\",\"level\":100}","ack":false,"ts":1576776621847,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1576776342881}
    2019-12-19 18:30:21.927 - debug: hue.0 (30635) final lightState for Nachttisch Eins:{"bri":254,"on":true,"xy":"0.33270596590909096,0.667294034090909","r":161,"g":254,"b":0,"transitiontime":1,"colormode":"xy","level":100}
    2019-12-19 18:30:22.038 - debug: hue.0 (30635) lights.setLightState:24:01b16972126b418291bcb104deda7a1b result: true
    2019-12-19 18:30:22.191 - debug: hue.0 (30635) polling light Nachttisch Eins (24) with prio 3
    2019-12-19 18:30:22.245 - debug: hue.0 (30635) lights.getLightById:24:94d8ee07882199f19e536e846e91773d result: {"_rawData":{"state":{"on":true,"bri":254,"hue":19723,"sat":254,"effect":"none","xy":[0.3327,0.6673],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-12-19T09:41:55"},"type":"Extended color light","name":"Nachttisch Eins","modelid":"LCT026","manufacturername":"Philips","productname":"Hue go","capabilities":{"certified":true,"control":{"mindimlevel":70,"maxlumen":400,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huego","function":"decorative","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:06:f9:66:50-0b","swversion":"1.56.8_r30456","swconfigid":"AF1CA01E","productid":"Philips-LCT026-1-HueGo_v2"},"_id":24,"mappedColorGamut":"C"}
    2019-12-19 18:30:22.327 - debug: hue.0 (30635) updated lighstate(24) after change
    Bei dir werden aber zusätzliche State changes für je rgb direkt ausgelöst, zu dem State existiert kein Objekt (soll auch nicht). Entweder hast du ein Skript laufen, oder das Widget macht da was komisches. Siehe deine getriggerten State Changes:
    hue.0	2019-12-18 17:42:05.047	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.b {"val":0,"ack":false,"ts":1576687325041,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325041}
    hue.0	2019-12-18 17:42:05.046	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.g {"val":255,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
    hue.0	2019-12-18 17:42:05.044	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.r {"val":162,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
    hue.0	2019-12-18 17:42:05.037	debug	(18324) stateChange hue.0.Wintergarten.command {"val":"{\"transitiontime\":1,\"xy\":\"0.5255681818181818,0.86015625\",\"level\":100}","ack":false,"ts":1576687325032,"q":0,"from":"system.adapter.web.0"
    Leider ist dein Log abgeschnitten, wenn du Log herunterladen klickst oder direkt aus dem File kopierst, werden die Zeilen nicht abgeschnitten.
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @foxriver76 sagte in Test Adapter Hue v2.4.x:
    Es ist das vis-colorpicker.0
    Kein Script dafür in Verwendung.
    hier das Debug-Log von gestern um 17:42 ca.
    new 3.txt
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      new 3.txt
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      @Negalein
      2019-12-18 17:42:05.044  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.r {"val":162,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
      2019-12-18 17:42:05.046  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.g {"val":255,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
      2019-12-18 17:42:05.047  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.b {"val":0,"ack":false,"ts":1576687325041,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325041}
      Wird auf jeden Fall durch web gesetzt.
      Videotutorials & mehr
      • foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @Negalein In deinem Widget, unter der Konfiguration von 'Allgemein' gibt es RGB als Reiter, da sind deine DP falsch gesetzt.
          @Negalein
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          komisch!
          Wintergarten hab ich definitiv mit dem Widget geschaltet.
          Ist sonst nirgends eingebaut.
          also R G B dann komplett raus?
            komisch!
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            @Negalein Ne, aber da steht ja überall hue.0.Phillips_hue.Wintergarten... die neue Struktur ist ja nur noch hue.0.Wintergarten.... Einfach entsprechend anpassen, hast du da wohl übersehen gehabt.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              Ahhhh, hab ich tatsächlich übersehen.
              Danke, werde wieder berichten.
                foxriver76F Offline
                foxriver76
                schrieb am zuletzt editiert von foxriver76
                Hier gehts weiter.
                Hier darf bitte zugemacht werden. Danke.
