  4. Test Adapter Hue v2.4.x
    6.6k
huetestingtester
27 Beiträge 3 Kommentatoren 2.4k Aufrufe 7 Beobachtet
  • NegaleinN Negalein
    @foxriver76 sagte in Test Adapter Hue v2.4.x:
    Kannst du mal ein Screenshot oder die Beschreibung des Objektes zeigen, das angeblich nicht existiert.
    Das war jetzt zB beim ändern der Farbe von der Gruppe Wohnzimmer
    hue.0	2019-12-18 23:49:36.777	error	(23583) Error: obj "Philips_hue.Wohnzimmer" in callback getObject is null or undefined
    hue.0	2019-12-18 23:49:36.776	error	(23583) Error: obj "Philips_hue.Wohnzimmer" in callback getObject is null or undefined
    Die Farbe wird aber geändert.
    Widget = HUE Color Picker
    RAW von hue.0.Wohnzimmer
      "from": "system.adapter.hue.0",
      "user": "system.user.admin",
      "ts": 1570209750932,
      "common": {
        "name": "Wohnzimmer",
        "role": "Room"
      "native": {
        "id": "6",
        "type": "Room",
        "lights": [
          "3",
          "4",
          "5",
          "7"
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
      "_id": "hue.0.Wohnzimmer",
      "type": "channel"
    hue.0.Wohnzimmer.command
      "ts": 1570209750917,
      "common": {
        "name": "Wohnzimmer.command",
        "type": "string",
        "role": "command",
        "read": true,
        "write": true
      "native": {
        "id": "6"
      "acl": {
        "object": 1636,
        "state": 1636
      "_id": "hue.0.Wohnzimmer.command",
      "type": "state"
    hue.0.Wohnzimmer.xy
      "_id": "hue.0.Wohnzimmer.xy",
      "type": "state",
      "common": {
        "name": "Wohnzimmer.xy",
        "read": true,
        "write": true,
        "type": "string",
        "role": "level.color.xy"
      "native": {
        "id": "6"
      "ts": 1570209750881,
      "acl": {
        "object": 1636,
        "state": 1636,
    hue.0.Wohnzimmer.level
      "ts": 1570209750922,
      "common": {
        "name": "Wohnzimmer.level",
        "type": "number",
        "role": "level.dimmer",
        "min": 0,
        "max": 100,
        "read": true,
        "write": true,
        "smartName": false,
        "custom": {
          "virtualpowermeter.0": {
            "enabled": true,
            "maxpower": 38,
            "group": "light",
            "idEnergyPower": "Virtual_Energy_Power",
            "idEnergyTotal": "Virtual_Energy_Total"
      "native": {
        "id": "6"
      "acl": {
        "object": 1636,
        "state": 1636
      "_id": "hue.0.Wohnzimmer.level",
      "type": "state"
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    @Negalein ok sehe das Problem er probiert bridge-Name.gerät abzufragen dabei hast du die neue Struktur ohne den Bridge Namen.
    Kannst du mir sagen wie du den schaltvorgang vornimmst.
    Videotutorials & mehr
    • foxriver76F foxriver76
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      Entweder zB "Alexa, Licht ein" oder über Widgets aus VIS
      ° Fixer ---> iob fix
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @Negalein ich meine gerade speziell um den Fehler zu erzeugen. Eigentlich baut er die Id die er dort loggt 1 zu 1 aus dem geänderten State zusammen.
        Auch steht im Log StateChange mit dem Bridge Namen, kann es sein dass du ein State nach dem Alten Muster setzt, dessen Objekt es eigentlich nicht mehr gibt.
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Als ich auf die neue Struktur umgestiegen bin, hab ich vorher alles unter hue.0 gelöscht.
          Hab den Fehler gerade produzieren können.
          Es tritt auf, wenn ich mit dem Widget "HUE Color Picker" die Farbe ändere.
          hue.0	2019-12-19 10:39:18.127	error	(15073) Error: obj "Philips_hue.Wohnzimmer" in callback getObject is null or undefined
          hue.0	2019-12-19 10:39:18.126	error	(15073) Error: obj "Philips_hue.Wohnzimmer" in callback getObject is null or undefined
          Command ID = Wohnzimmer.command
          XY ID = Wohnzimmer.xy
          Level ID = Wohnzimmer..level
          Config im Adapter sieht so aus:
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            @Negalein k probiere es heute Abend mal nachzustellen bei mir.
            Kannst du mir noch ein Screen der Widget Config zeigen.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                @Negalein Finde kein colorpicker Widget in vis, ist das aus einem Adapter oder wie heißt es genau?
                Habe probiert genau den Befehl zu senden wie es dein Widget tut:
                {"transitiontime":1,"xy":"0.5255681818181818,0.86015625","level":100}
                So schaut das dann aus:
                2019-12-19 18:30:21.865 - debug: hue.0 (30635) stateChange hue.0.Nachttisch_Eins.command {"val":"{\"transitiontime\":1,\"xy\":\"0.5255681818181818,0.86015625\",\"level\":100}","ack":false,"ts":1576776621847,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1576776342881}
                2019-12-19 18:30:21.927 - debug: hue.0 (30635) final lightState for Nachttisch Eins:{"bri":254,"on":true,"xy":"0.33270596590909096,0.667294034090909","r":161,"g":254,"b":0,"transitiontime":1,"colormode":"xy","level":100}
                2019-12-19 18:30:22.038 - debug: hue.0 (30635) lights.setLightState:24:01b16972126b418291bcb104deda7a1b result: true
                2019-12-19 18:30:22.191 - debug: hue.0 (30635) polling light Nachttisch Eins (24) with prio 3
                2019-12-19 18:30:22.245 - debug: hue.0 (30635) lights.getLightById:24:94d8ee07882199f19e536e846e91773d result: {"_rawData":{"state":{"on":true,"bri":254,"hue":19723,"sat":254,"effect":"none","xy":[0.3327,0.6673],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-12-19T09:41:55"},"type":"Extended color light","name":"Nachttisch Eins","modelid":"LCT026","manufacturername":"Philips","productname":"Hue go","capabilities":{"certified":true,"control":{"mindimlevel":70,"maxlumen":400,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huego","function":"decorative","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:06:f9:66:50-0b","swversion":"1.56.8_r30456","swconfigid":"AF1CA01E","productid":"Philips-LCT026-1-HueGo_v2"},"_id":24,"mappedColorGamut":"C"}
                2019-12-19 18:30:22.327 - debug: hue.0 (30635) updated lighstate(24) after change
                Bei dir werden aber zusätzliche State changes für je rgb direkt ausgelöst, zu dem State existiert kein Objekt (soll auch nicht). Entweder hast du ein Skript laufen, oder das Widget macht da was komisches. Siehe deine getriggerten State Changes:
                hue.0	2019-12-18 17:42:05.047	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.b {"val":0,"ack":false,"ts":1576687325041,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325041}
                hue.0	2019-12-18 17:42:05.046	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.g {"val":255,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
                hue.0	2019-12-18 17:42:05.044	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.r {"val":162,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
                hue.0	2019-12-18 17:42:05.037	debug	(18324) stateChange hue.0.Wintergarten.command {"val":"{\"transitiontime\":1,\"xy\":\"0.5255681818181818,0.86015625\",\"level\":100}","ack":false,"ts":1576687325032,"q":0,"from":"system.adapter.web.0"
                Leider ist dein Log abgeschnitten, wenn du Log herunterladen klickst oder direkt aus dem File kopierst, werden die Zeilen nicht abgeschnitten.
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  Es ist das vis-colorpicker.0
                  Kein Script dafür in Verwendung.
                  hier das Debug-Log von gestern um 17:42 ca.
                  new 3.txt
                    new 3.txt
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @Negalein
                    2019-12-18 17:42:05.044  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.r {"val":162,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
                    2019-12-18 17:42:05.046  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.g {"val":255,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
                    2019-12-18 17:42:05.047  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.b {"val":0,"ack":false,"ts":1576687325041,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325041}
                    Wird auf jeden Fall durch web gesetzt.
                    • foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      @Negalein In deinem Widget, unter der Konfiguration von 'Allgemein' gibt es RGB als Reiter, da sind deine DP falsch gesetzt.
                        @Negalein
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        komisch!
                        Wintergarten hab ich definitiv mit dem Widget geschaltet.
                        Ist sonst nirgends eingebaut.
                        also R G B dann komplett raus?
                          komisch!
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          @Negalein Ne, aber da steht ja überall hue.0.Phillips_hue.Wintergarten... die neue Struktur ist ja nur noch hue.0.Wintergarten.... Einfach entsprechend anpassen, hast du da wohl übersehen gehabt.
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            Ahhhh, hab ich tatsächlich übersehen.
                            Danke, werde wieder berichten.
                              foxriver76F Offline
                              foxriver76
                              Hier gehts weiter.
                              Hier darf bitte zugemacht werden. Danke.
