  4. Warnings bei der Installation auf Debian 10
debian 10installationwarning
3 Beiträge 2 Kommentatoren 1.0k Aufrufe
  • CKMartensC Offline
    CKMartensC Offline
    CKMartens
    ich habe heute ioBroker auf einem neuen Debian 10 als Testsystem installiert. Node und Nodejs sind in der version 10.16.3 installiert. Installiert wurde als root. Beim Step 3 kam folgende Meldung:
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka             ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/main.cpp: At global scope:
    /root/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_re            gister_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /root/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
    In file included from /root/.node-gyp/10.16.3/include/node/node.h:63,
    /root/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCal            lbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /root/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here
    /root/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {a            ka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /root/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCal            lbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /root/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {ak            a ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    Die Installation ist danach problemlos durchgelaufen und ioBroker scheint auch fehlerfrei zu funktionieren.
    FredFF 1 Antwort Letzte Antwort
    • CKMartensC CKMartens
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      schrieb am zuletzt editiert von FredF
      @CKMartens
      Probier mal die root Rechte mit
      su -
      und dann die Installation durchzuführen
      CKMartensC 1 Antwort Letzte Antwort
      • FredFF FredF
        @CKMartens
        su -
        CKMartensC Offline
        CKMartensC Offline
        CKMartens
        @FredF
        Die Installation hat ja funktioniert und ich richte diese Installation von iobroker gerade als Testsystem ein.
        Sollte nur ein Hinweis an die Entwickler sein.
