  4. [gelöst] Adapterinstallation - node gyp error
node-pre-gyp erradapter installationinstallation
47 Beiträge 6 Kommentatoren 8.3k Aufrufe 5 Beobachtet
    Sundance
    schrieb am zuletzt editiert von Sundance
    Guten Abend zusammen,
    ich habe aktuell einige Probleme, manche Adapter zu installieren - aktuell scheitere ich sowohl über Admin als auch über die Konsole, denn iobroker.roomba Adapter zu installieren. Im Log sehe ich auch zahlreiche Probleme, kann aber keines davon identifizieren, bzw. habe keine passende Lösung gefunden.
    Hier das Log:
    root@HOME:/home/pi# iobroker install iobroker.roomba
    NPM version: 6.7.0
    npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v67-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@11.6.0 (node-v67 ABI, glibc) (falling back to source compile with node-gyp)
    ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
    ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data > imgdOffset, "image data overlaps with another structure");
    ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
     #define E(cond, msg) if(cond) return setErr(msg)
    ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data + imgdSize > len, "not enough image data");
    ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_x = abs(transforms[1]);
    In file included from /usr/include/c++/6/cstdlib:75:0,
                     from /usr/include/c++/6/ext/string_conversions.h:41,
                     from /usr/include/c++/6/bits/basic_string.h:5417,
                     from /usr/include/c++/6/string:52,
                     from /usr/include/c++/6/stdexcept:39,
                     from /usr/include/c++/6/array:39,
                     from /usr/include/c++/6/tuple:39,
                     from /usr/include/c++/6/functional:55,
                     from /usr/include/c++/6/memory:79,
                     from /home/iobroker/.node-gyp/11.6.0/include/node/v8.h:21,
                     from /home/iobroker/.node-gyp/11.6.0/include/node/node.h:63,
                     from ../../nan/nan.h:54,
                     from ../src/backend/Backend.h:6,
                     from ../src/Canvas.h:5,
                     from ../src/CanvasRenderingContext2d.h:6,
                     from ../src/CanvasRenderingContext2d.cc:3:
    /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
     extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
    In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
    /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
       abs(long long __x) { return __builtin_llabs (__x); }
    /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
       abs(long __i) { return __builtin_labs(__i); }
    ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_y = abs(transforms[2]);
    make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:188:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
    gyp ERR! System Linux 4.19.57-v7+
    gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v67"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v11.6.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v67' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:188:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:978:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:265:5)
    node-pre-gyp ERR! System Linux 4.19.57-v7+
    node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v11.6.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.5.0 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2019-08-07T21_50_42_069Z-debug.log
    host.HOME Adapter directory "null" does not exists
    Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    root@HOME:/home/pi#
    Ich möchte ungern rumprobieren und "verschlimmbessern" - daher hoffe ich, dass mir von euch jemand auf die Sprünge helfen kann. Hier noch die Versionen von npm und node, wenn es hilft:
    root@HOME:/home/pi# node -v
    v11.6.0
    root@HOME:/home/pi# npm -v
    6.7.0
    Recht herzlichen Dank vorab für jegliche Unterstützung!
    Grüße
    Sundance
      dna909
      Du hast eine Entwicklerversion von Node installiert. Nimm mal ne 8er oder 10er und probier dann noch mal.
      Gruß dna909
      Intel NUC7PJYH mit Proxmox, Odroid U2, CCU2, Philips Hue, ESP8266, Xiaomi Robot, Google Chromecast Audio, Instar 6012HD, Bosch HNG6764S6
      • D dna909
        Gruß dna909
        Sundance
        @dna909 - da bin ich schon mit meinem Latein am Ende. Was ist der sicherste Weg, meine Node Version auf die 10 "downzugraden", ohne mir dabei irgendwas anderes zu zerschießen? Ich habe da leider kaum Erfahrung...
        Danke vorab für deine Hilfe!
        Beste Grüße
        Sundance
          dna909
          Dazu empfehle ich Dir folgenden Thread:
          https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
          damit sollte das eigentlich funktionieren.
          dna909
            Sundance
            @dna909 - danke für den Thread, bin es mal durchgegangen. Allerdings zeigt mir die Konsolo eine Meldung an, dass bereits eine neuere Version installiert ist.
            Muss ich die alte Version vorher komplett löschen, wie weiter unten im Thread beschrieben, oder gibt es einen anderen bzw. besseren Weg das zu lösen?
            Vielen Dank
            Grüße
            sundance
            • S Sundance
              Hier das Log:
              NPM version: 6.7.0
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              root@HOME:/home/pi#
              v11.6.0
              6.7.0
              Grüße
              Sundance
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
              Sundance
              • GlasfaserG Glasfaser
                Sundance
                Sundance
                @Glasfaser Danke für den Hinweis, den Thread hatte ich soweit durch und auch die Libraries gemäß Angaben vorher aktualisiert.. leider bleibt das Resultat gleich. Ich denke ich werde an meiner node version schrauben müssen...
                • S Sundance
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  @Sundance
                  NPM Version 6.7.0 ... mhhh ?? ... Zeig mal : nodejs -v
                  sudo apt-get --purge remove node
                  sudo apt-get --purge remove nodejs
                  sudo apt-get autoremove
                  sudo reboot
                  curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                  sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                  sudo reboot
                  cd /opt/iobroker
                  und dann noch npm rebuild und wieder reboot.
                  Kenn dein System nicht ... dann eventuell noch :
                  curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash -
                    Sundance
                    @Glasfaser - mein nodejs -v sagt:
                    pi@HOME:~ $ nodejs -v
                    v10.16.2
                    Soll ich deinen Vorschlag unabhängig davon testen, oder soll ich vorher noch was eine andere NPM version installieren oder sowas?
                    Danke für deine Hilfe..
                    Beste Grüße
                    Sundance
                    • S Sundance
                      v10.16.2
                      Beste Grüße
                      Sundance
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      @Sundance
                      Die Versionen passen nicht zusammen .
                      nimm meinen Vorschlag ...
                      ( kann dir leider nur halb helfen da ich eine Synology habe unter Docker deshalb nimm den Thread was dir dna909 vorgeschlagen hat .)
                        Sundance
                        @Glasfaser - dein Vorschlag hat soweit erstmal super funktioniert, ich habe jetzt folgende Versionen:
                        Node v10.16.2
                        NPM 6.9.0
                        Allerdings habe ich jetzt wieder ein anderes Problem, nämlich mit dem Zigbee Adapter:
                        error: Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
                        error: Caught by controller[0]: throw e
                        error: Caught by controller[0]: ^
                        error: Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                        error: Caught by controller[0]: was compiled against a different Node.js version using
                        error: Caught by controller[0]: NODE_MODULE_VERSION 67. This version of Node.js requires
                        error: Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                        error: Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                        error: Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                        error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                        error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        error: Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                        error: Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                        error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
                        error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:1:36)
                        error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                        error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                        error: host.HOME instance system.adapter.zigbee.0 terminated with code 1 ()
                        das war eigentlich mal behoben, ist jetzt aber wieder da.. hat wohl offenbar mit dem Serialport zu tun. Hast du da zufällig auch eine Idee?
                        Danke und beste Grüße
                        Sundance
                        • S Sundance
                          Node v10.16.2
                          NPM 6.9.0
                          Sundance
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          @Sundance
                          Versuch mal :
                          npm rebuild
                            @Sundance
                            Versuch mal :
                            npm rebuild
                            Sundance
                            @Glasfaser - das Serialport Problem konnte ich mit deinem ersten Vorschlag jetzt lösen. Allerdings ist das ursprüngliche problem, nämlich die iobroker.roomba Adapterinstallation leider immernoch ein Problem.. ich bekomme die gleiche Fehlermeldung:
                            pi@HOME:~ $ iobroker install iobroker.roomba
                            NPM version: 6.9.0
                            node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
                            node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                                             from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                                             from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
                            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                            gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                            gyp ERR! node -v v10.16.2
                            gyp ERR! not ok
                            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
                            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                            node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                            node-pre-gyp ERR! node -v v10.16.2
                            npm ERR! errno 1
                            npm ERR!
                            npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T10_20_42_621Z-debug.log
                            Kann ich die canvas Installation irgendwie manuell machen, damit sich der Installer nicht daran aufhängt? Oder ist die Wurzel des Problems woanders?
                            Danke nochmal für deine Hilfe..
                            Beste Grüße
                            sundance
                            • S Sundance
                              NPM version: 6.9.0
                              gyp ERR! not ok
                              npm ERR! errno 1
                              npm ERR!
                              Beste Grüße
                              sundance
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              @Sundance
                              Welche Versin von Js-controller hast du ?
                                @Sundance
                                Sundance
                                @Glasfaser ich habe aktuell die 1.5.14 installiert.
                                • S Sundance
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  @Sundance
                                  Wie sieht es hiermit aus
                                  Installationsanweisungen folgen !!!
                                  Link Text
                                    @Sundance
                                    Link Text
                                    Sundance
                                    @Glasfaser Ja, das hatte ich schon probiert vorhin.. ironischerweise kommen bei der Canvas installation gemäß dem Befehl aus der Installationsanleitung die gleichen Fehler (zumindest auf den ersten Blick):
                                    root@HOME:~# cd /opt/iobroker
                                    root@HOME:/opt/iobroker# sudo npm install canvas --unsafe-perm=true
                                    > canvas@2.5.0 install /opt/iobroker/node_modules/canvas
                                    make: Entering directory '/opt/iobroker/node_modules/canvas/build'
                                      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                                      COPY Release/canvas-postbuild.node
                                      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                                      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                                      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                                      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                                      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                                      CXX(target) Release/obj.target/canvas/src/Backends.o
                                      CXX(target) Release/obj.target/canvas/src/Canvas.o
                                      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                                      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                                      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                                                     from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                                                     from /root/.node-gyp/10.16.2/include/node/node.h:63,
                                    canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
                                    make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
                                    gyp ERR! not ok
                                    npm ERR! errno 1
                                    npm ERR!
                                    npm ERR!     /root/.npm/_logs/2019-08-08T11_38_50_244Z-debug.log
                                    Allerdings steht in der Anleitung auch, dass man Canvas in den iobroker.roomba Ordner erstellen soll. Der existiert aber bei mir (noch) nicht, zumindest nicht in /opt/iobroker/node_modules/ - oder muss der woanders hin? Muss ich den vorher händisch erstellen, oder bringt das nix?
                                    Sorry, ich bin lost :D Danke für deine Geduld
                                    Beste Grüße
                                    Florian
                                    • S Sundance
                                      gyp ERR! not ok
                                      npm ERR! errno 1
                                      npm ERR!
                                      Beste Grüße
                                      Florian
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      @Sundance
                                      Hast Du eingentlich schon mal wieder versucht roomba über die Konsole ganz normal zu installieren !?
                                        @Sundance
                                        Sundance
                                        @Glasfaser Ja, habe es grade nochmal probiert.. aber die Fehler bleiben leider bestehen. Die Canvas Installation schlägt nachwievor fehl.. manuell installiert bekomme ich sie auch nicht.
                                        Ich habe grade nochmal die Verzeichnisberechtigungen "bereinigt", aber es hat leider nicht geholfen.
                                        Hast du noch eine Idee? In meinem letzten Installations-log Scheint es auch Probleme zu geben, einfache Ordner zu erstellen:
                                        gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.2"
                                        gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                                        gyp ERR! configure error
                                        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                                        Es hilft nicht, diese Ordner händisch zu erstellen, oder?
                                        • S Sundance
                                          sigi234S Online
                                          sigi234S Online
                                          sigi234
                                          einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash -
                                          Immer Daten sichern!
