  4. Alexa2 Adapter gelb: Error: no csrf found
erroralexa 2 adapter
3 Beiträge 3 Kommentatoren 778 Aufrufe 2 Beobachtet
  • C Offline
    Cool-runner1990
    Hallo zusammen, seit gestern ist mein Alexa2 Adapter gelb und ich krieg ihn nicht mehr zum laufen..
    der Log spuckt folgendes aus:
    host.raspberrypi 2019-06-18 19:24:23.771 info instance system.adapter.javascript.0 started with pid 18935
    host.raspberrypi 2019-06-18 19:23:53.747 info Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi 2019-06-18 19:23:53.747 error instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    host.raspberrypi 2019-06-18 19:23:49.669 info instance system.adapter.javascript.0 started with pid 18352
    rpi2.0 2019-06-18 19:23:44.314 error No Value found for cpu_frequency
    host.raspberrypi 2019-06-18 19:23:19.619 info Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi 2019-06-18 19:23:19.619 error instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    host.raspberrypi 2019-06-18 19:23:15.715 info instance system.adapter.javascript.0 started with pid 17730
    host.raspberrypi 2019-06-18 19:22:45.696 info Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi 2019-06-18 19:22:45.695 error instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    rpi2.0 2019-06-18 19:22:43.997 error No Value found for cpu_frequency
    host.raspberrypi 2019-06-18 19:22:41.500 info instance system.adapter.javascript.0 started with pid 17103
    alexa2.0 2019-06-18 19:22:29.001 error Error: no csrf found
    alexa2.0 2019-06-18 19:22:29.000 error Error: no csrf found. Check configuration of cookie
    alexa2.0 2019-06-18 19:22:28.998 debug Alexa-Remote: cookie was provided
    alexa2.0 2019-06-18 19:22:28.995 debug Alexa-Remote: Use as Base-URL: alexa.amazon.de
    alexa2.0 2019-06-18 19:22:28.994 debug Alexa-Remote: Use as Login-Amazon-URL: amazon.de
    alexa2.0 2019-06-18 19:22:28.994 debug Alexa-Remote: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
    alexa2.0 2019-06-18 19:22:28.183 debug Schedule restart: 15 3 * * *
    alexa2.0 2019-06-18 19:22:27.984 info starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.11.3
    alexa2.0 2019-06-18 19:22:27.934 debug statesDB connected
    alexa2.0 2019-06-18 19:22:27.887 debug objectDB connected
    host.raspberrypi 2019-06-18 19:22:26.529 info instance system.adapter.alexa2.0 started with pid 16809
    host.raspberrypi 2019-06-18 19:22:24.072 info instance system.adapter.alexa2.0 terminated with code 0 (OK)
    alexa2.0 2019-06-18 19:22:24.028 info terminating
    yahka.0 2019-06-18 19:22:24.013 info objectChange system.adapter.alexa2.0 {"_id":"system.adapter.alexa2.0","type":"instance","common":{"name":"alexa2","version":"1.1.3","title":"Alexa2 (Amazon Echo)","desc":"Remote control for Alexa (Am
    host.raspberrypi 2019-06-18 19:22:23.994 info stopInstance system.adapter.alexa2.0 killing pid 16220
    host.raspberrypi 2019-06-18 19:22:23.993 info stopInstance system.adapter.alexa2.0
    alexa2.0 2019-06-18 19:22:29.008 error Error: no csrf found
    alexa2.0 2019-06-18 19:22:29.008 error Error: no csrf found. Check configuration of cookie
    alexa2.0 2019-06-18 19:22:29.008 debug Alexa-Remote: cookie was provided
    alexa2.0 2019-06-18 19:22:29.008 debug Alexa-Remote: Use as Base-URL: alexa.amazon.de
    alexa2.0 2019-06-18 19:22:29.007 debug Alexa-Remote: Use as Login-Amazon-URL: amazon.de
    alexa2.0 2019-06-18 19:22:29.006 debug Alexa-Remote: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
    Ich habe leider keinen plan was ich machen soll.
    Jemand ne Ahnung? :)
    • sigi234S Online
      sigi234S Online
      sigi234
      https://forum.iobroker.net/topic/17158/iobroker-alexa2-v2-0-alpha-status-github-version/466
      Immer Daten sichern!
      • ICEMANI Offline
        ICEMANI Offline
        ICEMAN
        Bei mir das Selbe.... ☹
        Eric der ICEMAN
        Installationsfixer: curl -sL https://iobroker.net/fix.sh | bash -
        • Raspberry Pi 4B 4GB mit SSD
        • Hue Devices
        • Homematic CCU 3
        • Sonoff Schalter und Steckdosen
        • Shelly Komponenten
