  4. Javascript Adapter startet nicht
javascript adapter rot
3 Beiträge 2 Kommentatoren 448 Aufrufe
  • N Offline
    N Offline
    new12345
    Ich habe heute den js controller auf 1.5.8 aktulisiert und seitdem startet der Adapter nicht mehr. Das log liefert folgende Error Meldungen:
    host.raspberrypi	2019-05-15 00:08:17.307	error	instance system.adapter.javascript.0 terminated with code 1 ()
    host.raspberrypi	2019-05-15 00:08:17.307	error	Caught by controller[0]: at bootstrap_node.js:625:3
    host.raspberrypi	2019-05-15 00:08:17.307	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
    host.raspberrypi	2019-05-15 00:08:17.307	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
    host.raspberrypi	2019-05-15 00:08:17.307	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:08:17.307	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:08:17.307	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:52:23)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:08:17.306	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2019-05-15 00:08:17.305	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:08:17.304	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:08:17.304	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:08:17.304	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:08:17.304	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2019-05-15 00:08:17.304	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:9:12)
    host.raspberrypi	2019-05-15 00:08:17.304	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2019-05-15 00:08:17.303	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2019-05-15 00:08:17.303	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:08:17.303	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:08:17.303	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:08:17.303	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:08:17.303	error	Caught by controller[0]: at Module._compile (module.js:617:28)
    host.raspberrypi	2019-05-15 00:08:17.302	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    host.raspberrypi	2019-05-15 00:08:17.302	error	Caught by controller[0]: at createScript (vm.js:80:10)
    host.raspberrypi	2019-05-15 00:08:17.302	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
    host.raspberrypi	2019-05-15 00:08:17.302	error	Caught by controller[0]: ^
    host.raspberrypi	2019-05-15 00:08:17.301	error	Caught by controller[0]: Object.keys(url.query)vorEacH(functIon(cey){
    host.raspberrypi	2019-05-15 00:08:17.301	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2/index.js:204
    host.raspberrypi	2019-05-15 00:08:15.040	info	instance system.adapter.javascript.0 started with pid 28314
    host.raspberrypi	2019-05-15 00:07:45.042	info	Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi	2019-05-15 00:07:45.041	error	instance system.adapter.javascript.0 terminated with code 1 ()
    host.raspberrypi	2019-05-15 00:07:45.041	error	Caught by controller[0]: at bootstrap_node.js:625:3
    host.raspberrypi	2019-05-15 00:07:45.041	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
    host.raspberrypi	2019-05-15 00:07:45.041	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
    host.raspberrypi	2019-05-15 00:07:45.038	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:07:45.038	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:07:45.038	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:07:45.038	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:07:45.037	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2019-05-15 00:07:45.029	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:52:23)
    host.raspberrypi	2019-05-15 00:07:45.029	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2019-05-15 00:07:45.029	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
    host.raspberrypi	2019-05-15 00:07:45.028	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2019-05-15 00:07:45.027	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:9:12)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2019-05-15 00:07:45.026	error	Caught by controller[0]: at Module._compile (module.js:617:28)
    host.raspberrypi	2019-05-15 00:07:45.025	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    host.raspberrypi	2019-05-15 00:07:45.025	error	Caught by controller[0]: at createScript (vm.js:80:10)
    host.raspberrypi	2019-05-15 00:07:45.025	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
    host.raspberrypi	2019-05-15 00:07:45.025	error	Caught by controller[0]: ^
    host.raspberrypi	2019-05-15 00:07:45.025	error	Caught by controller[0]: Object.keys(url.query)vorEacH(functIon(cey){
    host.raspberrypi	2019-05-15 00:07:45.024	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2/index.js:204
    host.raspberrypi	2019-05-15 00:07:42.678	info	instance system.adapter.javascript.0 started with pid 27760
    host.raspberrypi	2019-05-15 00:07:12.661	info	Restart adapter system.adapter.javascript.0 because enabled
    Kann mir hier jemand helfen?
    Herzlichen Dank!
    LG
    • sigi234S Online
      sigi234S Online
      sigi234
      Neu gestartet?
      Immer Daten sichern!
      • N Offline
        N Offline
        new12345
        schrieb am zuletzt editiert von new12345
        Mehrmals, ich habe auch schon mehrmals de und re-installiert
