    6.4k
7.5k Beiträge 335 Kommentatoren 11.6m Aufrufe 254 Beobachtet
  • TolkinT Offline
    TolkinT Offline
    Tolkin
    #5721
    Muss auch noch mal was hier fragen. Ich habe im ShutterControl eingestellt, dass alle Rollos Abends auf Helligkeitssensor herunterfahren. Bis auf das Rollo "Eltern" "Bad" und "Kind2" fahren auch alle sauber runter. Kann mir jemand sagen, warum das bei den drei Rollos nicht der Fall ist ?
    shuttercontrol.0
    2023-04-21 20:55:00.003	debug	Sun Elevation: -2.9°
    shuttercontrol.0
    2023-04-21 20:55:00.003	debug	Sun Azimut: 293°
    shuttercontrol.0
    2023-04-21 20:55:00.003	debug	calculate astrodata ...
    shuttercontrol.0
    2023-04-21 20:54:25.839	debug	Brightness State Down is: true
    shuttercontrol.0
    2023-04-21 20:54:15.838	debug	Brightness sensor value: 2.52
    shuttercontrol.0
    2023-04-21 20:54:15.837	debug	Lightsensor changed: hm-rpc.1.000D5BE9A46AD7.1.AVERAGE_ILLUMINATION Value: 4.32
    shuttercontrol.0
    2023-04-21 20:52:20.570	debug	Brightness State Down is: true
    shuttercontrol.0
    2023-04-21 20:52:10.569	debug	Brightness sensor value: 4.39
    shuttercontrol.0
    2023-04-21 20:50:02.198	debug	Shutter Rollade Bad was moved manually to: 13% - prevent trigger from driving back
    shuttercontrol.0
    2023-04-21 20:50:02.197	debug	save current height after State Check: 13% from Rollade Bad
    shuttercontrol.0
    2023-04-21 20:50:01.196	debug	Rollade Bad Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    2023-04-21 20:50:01.195	debug	Rollade Bad drived manually to 13. Old value = 8. New value = 13
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 currentShutterStateTime: 60 seconds
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 currentShutterState: activated
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 oldHeight: 8 %
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 currentHeight: 8 %
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 triggerAction: Manu_Mode
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 currentAction: Manu_Mode
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 shutterState: 13 %
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#1 shutterName: Rollade Bad
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	Shutter state changed: Rollade Bad old value = 8 new value = 13
    shuttercontrol.0
    2023-04-21 20:50:01.152	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:50:00.911	debug	Brightness State Down is: true
    shuttercontrol.0
    2023-04-21 20:50:00.004	debug	Sun Elevation: -2.2°
    shuttercontrol.0
    2023-04-21 20:50:00.004	debug	Sun Azimut: 292°
    shuttercontrol.0
    2023-04-21 20:50:00.004	debug	calculate astrodata ...
    shuttercontrol.0
    2023-04-21 20:49:50.910	debug	Brightness sensor value: 6.65
    shuttercontrol.0
    2023-04-21 20:49:50.909	debug	Lightsensor changed: hm-rpc.1.000D5BE9A46AD7.1.AVERAGE_ILLUMINATION Value: 11.13
    shuttercontrol.0
    2023-04-21 20:49:14.612	debug	Rollade Wohnzimmer4 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:49:14.612	debug	Shutter state changed: Rollade Wohnzimmer4 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:49:14.611	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:49:03.867	debug	Rollade Wohnzimmer 3 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:49:03.867	debug	Shutter state changed: Rollade Wohnzimmer 3 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:49:03.866	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:49:02.187	debug	Rollade Kind 1 Old value = 99. New value = 6. automatic is active
    shuttercontrol.0
    2023-04-21 20:49:02.187	debug	Shutter state changed: Rollade Kind 1 old value = 99 new value = 6
    shuttercontrol.0
    2023-04-21 20:49:02.186	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:49:01.152	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:48:59.459	debug	Rollade Wohnzimmer 2 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:59.459	debug	Shutter state changed: Rollade Wohnzimmer 2 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:59.459	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:59.273	debug	Rollade Kind 1 Old value = 99. New value = 6. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:59.273	debug	Shutter state changed: Rollade Kind 1 old value = 99 new value = 6
    shuttercontrol.0
    2023-04-21 20:48:59.273	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:57.266	debug	Rollade Wohnzimmer 1 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:57.265	debug	Shutter state changed: Rollade Wohnzimmer 1 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:57.265	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:55.452	debug	Rollade Esszimmer Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:55.452	debug	Shutter state changed: Rollade Esszimmer old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:55.451	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:40.823	debug	Rollade Kind 1 Old value = 99. New value = 6. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:40.823	debug	Shutter state changed: Rollade Kind 1 old value = 99 new value = 6
    shuttercontrol.0
    2023-04-21 20:48:40.823	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:40.560	debug	Rollade Kind 1 Old value = 99. New value = 6. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:40.560	debug	Shutter state changed: Rollade Kind 1 old value = 99 new value = 6
    shuttercontrol.0
    2023-04-21 20:48:40.559	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:40.188	debug	Rollade Kind 1 Old value = 99. New value = 6. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:40.188	debug	Shutter state changed: Rollade Kind 1 old value = 99 new value = 6
    shuttercontrol.0
    2023-04-21 20:48:40.187	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:40.141	debug	Rollade Küche 2 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:40.141	debug	Shutter state changed: Rollade Küche 2 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:40.140	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:38.607	debug	Rollade Küche 1 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:38.607	debug	Shutter state changed: Rollade Küche 1 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:38.606	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:38.252	debug	Rollade Wohnzimmer4 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:38.252	debug	Shutter state changed: Rollade Wohnzimmer4 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:38.250	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:38.202	debug	Rollade HWR Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:38.202	debug	Shutter state changed: Rollade HWR old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:38.201	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:38.085	debug	Rollade Wohnzimmer4 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:38.085	debug	Shutter state changed: Rollade Wohnzimmer4 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:38.084	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:36.059	debug	Rollade Wohnzimmer 3 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:36.059	debug	Shutter state changed: Rollade Wohnzimmer 3 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:36.058	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:36.037	debug	Rollade Wohnzimmer 3 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:36.037	debug	Shutter state changed: Rollade Wohnzimmer 3 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:36.037	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:34.860	debug	Rollade Wohnzimmer 2 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:34.860	debug	Shutter state changed: Rollade Wohnzimmer 2 old value = 100 new value = 0
    shuttercontrol.0
    shuttercontrol.0
    shuttercontrol.0
    2023-04-21 20:48:34.859	debug	Rollade Gäste WC Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:34.859	debug	Shutter state changed: Rollade Gäste WC old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:34.859	debug	Rollade Büro Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:34.859	debug	Shutter state changed: Rollade Büro old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:34.859	debug	Rollade Wohnzimmer 1 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:34.859	debug	Shutter state changed: Rollade Wohnzimmer 1 old value = 100 new value = 0
    shuttercontrol.0
    shuttercontrol.0
    2023-04-21 20:48:34.858	debug	Shutter state changed: Rollade Wohnzimmer 1 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:34.052	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:33.989	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:32.272	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:32.026	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:31.897	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:31.738	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:27.040	debug	Rollade Esszimmer Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:27.040	debug	Shutter state changed: Rollade Esszimmer old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:27.039	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:27.021	debug	Rollade Esszimmer Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:27.021	debug	Shutter state changed: Rollade Esszimmer old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:27.020	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:25.000	debug	Rollade HWR Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:25.000	debug	Shutter state changed: Rollade HWR old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:24.999	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:24.974	debug	Rollade HWR Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:24.974	debug	Shutter state changed: Rollade HWR old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:24.973	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:22.942	debug	Rollade Küche 2 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:22.942	debug	Shutter state changed: Rollade Küche 2 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:22.941	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:22.922	debug	Rollade Küche 2 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:22.922	debug	Shutter state changed: Rollade Küche 2 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:22.922	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:21.058	debug	Rollade Küche 1 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:21.057	debug	Shutter state changed: Rollade Küche 1 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:21.057	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:20.873	debug	Rollade Küche 1 Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:20.873	debug	Shutter state changed: Rollade Küche 1 old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:20.872	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:18.842	debug	Rollade Gäste WC Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:18.841	debug	Shutter state changed: Rollade Gäste WC old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:18.841	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:18.825	debug	Rollade Gäste WC Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:18.825	debug	Shutter state changed: Rollade Gäste WC old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:18.825	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:17.066	debug	Rollade Büro Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:17.066	debug	Shutter state changed: Rollade Büro old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:17.065	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:16.777	debug	Rollade Büro Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    2023-04-21 20:48:16.777	debug	Shutter state changed: Rollade Büro old value = 100 new value = 0
    shuttercontrol.0
    2023-04-21 20:48:16.776	debug	#0 wait for shutter check end
    shuttercontrol.0
    2023-04-21 20:48:14.610	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:48:03.867	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:48:02.186	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:59.458	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:59.272	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:57.264	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:55.450	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:46.279	debug	check xmas for Rollade Kind 2
    shuttercontrol.0
    2023-04-21 20:47:46.279	debug	Rollade Kind 2 in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:46.279	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:46.279	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:46.279	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:46.279	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:44.235	debug	check xmas for Rollade Bad
    shuttercontrol.0
    2023-04-21 20:47:44.235	debug	Rollade Bad in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:44.235	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:44.235	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:44.235	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:44.235	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:42.191	debug	check xmas for Rollade Eltern
    shuttercontrol.0
    2023-04-21 20:47:42.191	debug	Rollade Eltern in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:42.191	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:42.191	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:42.191	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:42.190	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:40.822	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:40.559	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:40.190	debug	save current height: 6% from Rollade Kind 1
    shuttercontrol.0
    2023-04-21 20:47:40.190	debug	last automatic Action for Rollade Kind 1: Down_Brightness
    shuttercontrol.0
    2023-04-21 20:47:40.187	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:40.140	info	Lightsensor #9 Set ID: Rollade Kind 1 value: 6%
    shuttercontrol.0
    2023-04-21 20:47:40.140	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:40.134	debug	check xmas for Rollade Kind 1
    shuttercontrol.0
    2023-04-21 20:47:40.134	debug	Rollade Kind 1 in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:40.134	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:40.134	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:40.134	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:40.134	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:38.606	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:38.250	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:38.201	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:38.133	debug	save current height: 0% from Rollade Wohnzimmer4
    shuttercontrol.0
    2023-04-21 20:47:38.133	debug	last automatic Action for Rollade Wohnzimmer4: Down_Brightness
    shuttercontrol.0
    2023-04-21 20:47:38.085	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:38.082	info	Lightsensor #9 Set ID: Rollade Wohnzimmer4 value: 0%
    shuttercontrol.0
    2023-04-21 20:47:38.040	debug	check xmas for Rollade Wohnzimmer4
    shuttercontrol.0
    2023-04-21 20:47:38.040	debug	Rollade Wohnzimmer4 in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:38.039	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:38.039	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:38.039	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:38.039	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:36.058	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:36.039	debug	save current height: 0% from Rollade Wohnzimmer 3
    shuttercontrol.0
    2023-04-21 20:47:36.039	debug	last automatic Action for Rollade Wohnzimmer 3: Down_Brightness
    shuttercontrol.0
    2023-04-21 20:47:36.036	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:36.034	info	Lightsensor #9 Set ID: Rollade Wohnzimmer 3 value: 0%
    shuttercontrol.0
    2023-04-21 20:47:35.993	debug	check xmas for Rollade Wohnzimmer 3
    shuttercontrol.0
    2023-04-21 20:47:35.993	debug	Rollade Wohnzimmer 3 in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:35.992	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:35.992	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:35.992	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:35.992	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:34.052	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:33.991	debug	save current height: 0% from Rollade Wohnzimmer 2
    shuttercontrol.0
    2023-04-21 20:47:33.991	debug	last automatic Action for Rollade Wohnzimmer 2: Down_Brightness
    shuttercontrol.0
    2023-04-21 20:47:33.988	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:33.986	info	Lightsensor #9 Set ID: Rollade Wohnzimmer 2 value: 0%
    shuttercontrol.0
    2023-04-21 20:47:33.945	debug	check xmas for Rollade Wohnzimmer 2
    shuttercontrol.0
    2023-04-21 20:47:33.945	debug	Rollade Wohnzimmer 2 in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:33.945	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:33.945	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:33.945	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:33.945	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:32.272	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:32.025	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:31.944	debug	save current height: 0% from Rollade Wohnzimmer 1
    shuttercontrol.0
    2023-04-21 20:47:31.944	debug	last automatic Action for Rollade Wohnzimmer 1: Down_Brightness
    shuttercontrol.0
    2023-04-21 20:47:31.898	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:31.737	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:31.106	info	Lightsensor #9 Set ID: Rollade Wohnzimmer 1 value: 0%
    shuttercontrol.0
    2023-04-21 20:47:29.085	debug	check xmas for Rollade Wohnzimmer 1
    shuttercontrol.0
    2023-04-21 20:47:29.085	debug	Rollade Wohnzimmer 1 in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:29.085	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:29.085	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:29.085	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:29.085	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:27.084	debug	save current height: 0% from Rollade Esszimmer
    shuttercontrol.0
    2023-04-21 20:47:27.084	debug	last automatic Action for Rollade Esszimmer: Down_Brightness
    shuttercontrol.0
    2023-04-21 20:47:27.039	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:27.020	debug	#0 wait for shutter check started
    shuttercontrol.0
    2023-04-21 20:47:27.019	info	Lightsensor #8 Set ID: Rollade Esszimmer value: 0%
    shuttercontrol.0
    2023-04-21 20:47:26.976	debug	check xmas for Rollade Esszimmer
    shuttercontrol.0
    2023-04-21 20:47:26.976	debug	Rollade Esszimmer in summer time down false
    shuttercontrol.0
    2023-04-21 20:47:26.976	debug	we are in period
    shuttercontrol.0
    2023-04-21 20:47:26.976	debug	End Sat Sep 30 2023
    shuttercontrol.0
    2023-04-21 20:47:26.976	debug	Start Wed Mar 01 2023
    shuttercontrol.0
    2023-04-21 20:47:26.975	debug	check in time 01.03. 30.09.
    shuttercontrol.0
    2023-04-21 20:47:26.732	debug	Brightness State Down is: true
    shuttercontrol.0
    2023-04-21 20:47:24.999	debug	#0 wait for shutter check started
    • Michael SauerM Michael Sauer
      @simatec
      So wie es aussieht versucht der shuttercontrol Adapter das falsche Format in die Shelly Variable zu schreiben.
      2021-11-16 16:37:00.077 - info: shuttercontrol.0 (25035) #17 Set ID: Esszimmer Shutter left value: 50%
      2021-11-16 16:37:00.083 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Esszimmer.Shutter.left.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:00.107 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#40F52022AD50#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:00.119 - error: shelly.0 (8611) Datatype for SHSW-25#40F52022AD50#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:00.296 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Esszimmer.Shutter.Esszimmer_Rollladen" has to be type "number" but received type "string"
      2021-11-16 16:37:02.073 - info: shuttercontrol.0 (25035) #17 Set ID: Esszimmer Shutter right value: 50%
      2021-11-16 16:37:02.075 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Esszimmer.Shutter.right.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:02.085 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C4A7A3#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:02.089 - error: shelly.0 (8611) Datatype for SHSW-25#C4A7A3#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:02.284 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Esszimmer.Shutter.Esszimmer_Rollladen" has to be type "number" but received type "string"
      2021-11-16 16:37:04.074 - info: shuttercontrol.0 (25035) #17 Set ID: Küche Shutter right value: 59%
      2021-11-16 16:37:04.077 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Küche.Shutter.right.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:04.087 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C47EF7#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:04.091 - error: shelly.0 (8611) Datatype for SHSW-25#C47EF7#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:04.287 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Küche.Shutter.Küche_Rolladen" has to be type "number" but received type "string"
      2021-11-16 16:37:06.073 - info: shuttercontrol.0 (25035) #17 Set ID: Küche Shutter left value: 50%
      2021-11-16 16:37:06.075 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Küche.Shutter.left.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:06.085 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C45BD6#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:06.089 - error: shelly.0 (8611) Datatype for SHSW-25#C45BD6#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:08.074 - info: shuttercontrol.0 (25035) #17 Set ID: Wohnzimmer Shutter right value: 0%
      2021-11-16 16:37:08.284 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Wohnzimmer_Rolladen" has to be type "number" but received type "string"
      2021-11-16 16:37:10.074 - info: shuttercontrol.0 (25035) #17 Set ID: Wohnzimmer Shutter left value: 80%
      2021-11-16 16:37:10.080 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.left.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:10.092 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C4D14F#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:10.096 - error: shelly.0 (8611) Datatype for SHSW-25#C4D14F#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:12.073 - info: shuttercontrol.0 (25035) #17 Set ID: Büro links value: 40%
      2021-11-16 16:37:12.077 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Büro_left.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:12.085 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#40F5200469DA#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:12.089 - error: shelly.0 (8611) Datatype for SHSW-25#40F5200469DA#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:14.074 - info: shuttercontrol.0 (25035) #17 Set ID: Büro mitte value: 40%
      2021-11-16 16:37:14.078 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Büro_center.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:14.087 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#84CCA8A115DC#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:14.091 - error: shelly.0 (8611) Datatype for SHSW-25#84CCA8A115DC#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:16.075 - info: shuttercontrol.0 (25035) #17 Set ID: Büro rechts value: 40%
      2021-11-16 16:37:16.079 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Büro_right.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:16.087 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#40F52004A0D1#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:16.091 - error: shelly.0 (8611) Datatype for SHSW-25#40F52004A0D1#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:18.015 - info: shuttercontrol.0 (25035) #26 Set ID: Schlafzimmer links value: 50%
      2021-11-16 16:37:18.018 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#B939B4#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:18.023 - error: shelly.0 (8611) Datatype for SHSW-25#B939B4#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:18.025 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Schlafzimmer.Shutter.left.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:20.014 - info: shuttercontrol.0 (25035) #26 Set ID: Schlafzimmer rechts value: 50%
      2021-11-16 16:37:20.018 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#76CB7A#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:20.022 - error: shelly.0 (8611) Datatype for SHSW-25#76CB7A#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:20.029 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Schlafzimmer.Shutter.right.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:22.026 - info: shuttercontrol.0 (25035) #26 Set ID: Spielzimmer value: 50%
      2021-11-16 16:37:22.030 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#76C3C3#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:22.036 - error: shelly.0 (8611) Datatype for SHSW-25#76C3C3#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:22.038 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Spielzimmer.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:24.025 - info: shuttercontrol.0 (25035) #26 Set ID: Kinderzimmer value: 50%
      2021-11-16 16:37:24.028 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#E098068CEDDB#1.Shutter.Position" has to be type "number" but received type "string"
      2021-11-16 16:37:24.032 - error: shelly.0 (8611) Datatype for SHSW-25#E098068CEDDB#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
      2021-11-16 16:37:24.038 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Kinderzimmer.Shutter.Position" has to be type "number" but received type "string"
      erazor86
      #5722
      @michael-sauer said in Test Adapter shuttercontrol v1.4.x:
      @simatec
      Ich habe genau das gleiche Problem, allerdings nicht bei der xmas Einstellung, sondern nur bei dem Fenstern, wo ich den Frostschutz aktiviert habe... Gibt es dazu eine Lösung?
      Wie kann ich den debug Mode aktivieren um die mehr Infos zu liefern?
      da_WoodyD E 2 Antworten Letzte Antwort
      • simatecS simatec
        @martybr dann kennst du ja die Funktion und weißt, dass der Wert true sein muss
        MartyBr
        #5723
        @simatec
        Hier die Rückantwort:
        Das Rollo ist gestern Abend und heute Morgen einwandfrei runter und hoch gelaufen. Es gab keine Probleme mit dem Modus "manu_mode".
        SunProtect ist gestern auch sauber gefahren.
        Also alles gut von meiner Seite. 👍
        Martin
        Intel NUCs mit Proxmox / Iobroker als VM unter Debian
        Raspeberry mit USB Leseköpfen für Smartmeter
        Homematic und Homematic IP
        • F Offline
          firebowl
          #5724
          Bei mir läuft jetzt auch wieder alles wie es soll. Vielen Dank für die Unterstützung!
          • W Offline
            W Offline
            WeiserWolf
            schrieb am zuletzt editiert von WeiserWolf
            #5725
            @simatec Ich speiel seit einiger Zeit mit der 1.4.28 und bisher funktioniert alles einwandfrei... außer das End of sunProtect konnte ich noch nicht triggern, aber andere bestätigen ja das es klappt. Ich hoffe es läuft bei mir auch :)
            Vielen Dank für den Super Adapter!
            • E erazor86
              @simatec
              da_WoodyD Offline
              da_WoodyD Offline
              da_Woody
              #5726
              @erazor86 sagte in Test Adapter shuttercontrol v1.4.x:
              wie immer. im adapter debug aktivieren.
              gruß vom Woody
              • W WeiserWolf
                simatecS Offline
                simatecS Offline
                simatec
                #5727
                @weiserwolf Bitte deine Config als json posten und bitte dazu schreiben, welche Rollläden nicht aus dem Sonnenschutz fahren
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                • MichMeinM Offline
                  MichMeinM Offline
                  MichMein
                  #5728
                  @simatec hast du den Wunsch / Vorschlag von @eurofinder gelesen? Ich habe auch schon mal daran gedacht, wäre ein tolles Feature.
                  erster Beitrag
                  zweiter Beitrag
                  Vielen Dank und ein schönes Wochenende
                  Gruß Michael
                  Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                  • E erazor86
                    @simatec
                    erazor86
                    #5729
                    @erazor86 said in Test Adapter shuttercontrol v1.4.x:
                    @simatec
                    anbei mein protokoll-Auszug:
                    2023-04-22 23:40:52.601 - debug: shuttercontrol.0 (25598) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2023-04-22 23:40:52.649 - debug: shuttercontrol.0 (25598) Objects client ready ... initialize now
                    2023-04-22 23:40:52.652 - debug: shuttercontrol.0 (25598) Objects create System PubSub Client
                    2023-04-22 23:40:52.653 - debug: shuttercontrol.0 (25598) Objects create User PubSub Client
                    2023-04-22 23:40:52.702 - debug: shuttercontrol.0 (25598) Objects client initialize lua scripts
                    2023-04-22 23:40:52.710 - debug: shuttercontrol.0 (25598) Objects connected to redis: 127.0.0.1:9001
                    2023-04-22 23:40:52.767 - debug: shuttercontrol.0 (25598) Redis States: Use Redis connection: 127.0.0.1:9000
                    2023-04-22 23:40:52.784 - debug: shuttercontrol.0 (25598) States create System PubSub Client
                    2023-04-22 23:40:52.786 - debug: shuttercontrol.0 (25598) States create User PubSub Client
                    2023-04-22 23:40:52.815 - debug: shuttercontrol.0 (25598) States connected to redis: 127.0.0.1:9000
                    2023-04-22 23:40:52.893 - debug: shuttercontrol.0 (25598) Plugin sentry Initialize Plugin (enabled=true)
                    2023-04-22 23:40:52.910 - info: shuttercontrol.0 (25598) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2023-04-22 23:40:53.378 - info: shuttercontrol.0 (25598) starting. Version 1.4.23 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v16.19.0, js-controller: 4.0.24
                    2023-04-22 23:40:53.433 - debug: shuttercontrol.0 (25598) shutter Config Check started
                    2023-04-22 23:40:53.435 - debug: shuttercontrol.0 (25598) shutter Config Check successfully completed
                    2023-04-22 23:40:53.443 - debug: shuttercontrol.0 (25598) trigger for outside temperature: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL
                    2023-04-22 23:40:53.445 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rollade_Wohnzimmer_groß.SET
                    2023-04-22 23:40:53.445 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rollade_Wohnzimmer_klein.SET
                    2023-04-22 23:40:53.446 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rollade_Esszimmer.SET
                    2023-04-22 23:40:53.446 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Küche_klein.SET
                    2023-04-22 23:40:53.447 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Küche_groß.SET
                    2023-04-22 23:40:53.448 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Büro_Straße.SET
                    2023-04-22 23:40:53.449 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Büro_Einfahrt.SET
                    2023-04-22 23:40:53.449 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Gäste-Wc.SET
                    2023-04-22 23:40:53.450 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_HWR.SET
                    2023-04-22 23:40:53.451 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Werkstatt.SET
                    2023-04-22 23:40:53.451 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Badezimmer.SET
                    2023-04-22 23:40:53.452 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Schlafzimmer.SET
                    2023-04-22 23:40:53.452 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Ankleidezimmer.SET
                    2023-04-22 23:40:53.452 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Elias.SET
                    2023-04-22 23:40:53.453 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Kinderzimmer_2.SET
                    2023-04-22 23:40:53.507 - debug: shuttercontrol.0 (25598) Wohnzimmer_groß: save settings
                    2023-04-22 23:40:53.623 - debug: shuttercontrol.0 (25598) Wohnzimmer_klein: save settings
                    2023-04-22 23:40:53.724 - debug: shuttercontrol.0 (25598) Esszimmer: save settings
                    2023-04-22 23:40:53.826 - debug: shuttercontrol.0 (25598) Küche_klein: save settings
                    2023-04-22 23:40:53.928 - debug: shuttercontrol.0 (25598) Küche_groß: save settings
                    2023-04-22 23:40:54.029 - debug: shuttercontrol.0 (25598) Büro_Straße: save settings
                    2023-04-22 23:40:54.178 - debug: shuttercontrol.0 (25598) Büro_Einfahrt: save settings
                    2023-04-22 23:40:54.317 - debug: shuttercontrol.0 (25598) Gäste-WC: save settings
                    2023-04-22 23:40:54.452 - debug: shuttercontrol.0 (25598) HWR: save settings
                    2023-04-22 23:40:54.554 - debug: shuttercontrol.0 (25598) Werkstatt: save settings
                    2023-04-22 23:40:54.655 - debug: shuttercontrol.0 (25598) Badezimmer: save settings
                    2023-04-22 23:40:54.756 - debug: shuttercontrol.0 (25598) Schlafzimmer: save settings
                    2023-04-22 23:40:54.857 - debug: shuttercontrol.0 (25598) Ankleidezimmer: save settings
                    2023-04-22 23:40:54.958 - debug: shuttercontrol.0 (25598) Elias: save settings
                    2023-04-22 23:40:55.059 - debug: shuttercontrol.0 (25598) Kinderzimmer_2: save settings
                    2023-04-22 23:40:56.644 - debug: shuttercontrol.0 (25598) Travel times of the shutters are calculated
                    2023-04-22 23:40:56.646 - debug: shuttercontrol.0 (25598) calculate astrodata ...
                    2023-04-22 23:40:56.646 - debug: shuttercontrol.0 (25598) goldenHourEnd today: 07:12
                    2023-04-22 23:40:56.648 - debug: shuttercontrol.0 (25598) goldenHour today: 19:54
                    2023-04-22 23:40:56.649 - debug: shuttercontrol.0 (25598) current day: 6
                    2023-04-22 23:40:56.649 - debug: shuttercontrol.0 (25598) Sunrise today: 06:27
                    2023-04-22 23:40:56.650 - debug: shuttercontrol.0 (25598) Sunset today: 20:38
                    2023-04-22 23:40:56.651 - debug: shuttercontrol.0 (25598) Starting up shutters GoldenHour area: 07:12
                    2023-04-22 23:40:56.652 - debug: shuttercontrol.0 (25598) Shutdown shutters GoldenHour area: 20:24
                    2023-04-22 23:40:56.652 - debug: shuttercontrol.0 (25598) Starting up shutters Sunrise area: 06:27
                    2023-04-22 23:40:56.652 - debug: shuttercontrol.0 (25598) Shutdown shutters Sunset area: 21:08
                    2023-04-22 23:40:56.707 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 07:30
                    2023-04-22 23:40:56.708 - debug: shuttercontrol.0 (25598) check IsEqual : 07:30 07:30
                    2023-04-22 23:40:56.709 - debug: shuttercontrol.0 (25598) yes, IsEqual : 07:30 07:30
                    2023-04-22 23:40:56.709 - debug: shuttercontrol.0 (25598) Starting up shutters living area: 07:30 debug 12
                    2023-04-22 23:40:56.730 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 09:00
                    2023-04-22 23:40:56.731 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 08:30
                    2023-04-22 23:40:56.731 - debug: shuttercontrol.0 (25598) check IsEqual : 08:30 09:00
                    2023-04-22 23:40:56.732 - debug: shuttercontrol.0 (25598) check IsEqual : 06:27 09:00
                    2023-04-22 23:40:56.733 - debug: shuttercontrol.0 (25598) check IsEarlier : 06:27 08:30
                    2023-04-22 23:40:56.733 - debug: shuttercontrol.0 (25598) yes, IsEarlier : 06:27 08:30
                    2023-04-22 23:40:56.734 - debug: shuttercontrol.0 (25598) Starting up shutters sleep area: 08:30 debug 14
                    2023-04-22 23:40:56.753 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 10:00
                    2023-04-22 23:40:56.753 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 09:00
                    2023-04-22 23:40:56.754 - debug: shuttercontrol.0 (25598) check IsEqual : 09:00 10:00
                    2023-04-22 23:40:56.754 - debug: shuttercontrol.0 (25598) check IsEqual : 06:27 10:00
                    2023-04-22 23:40:56.754 - debug: shuttercontrol.0 (25598) check IsEarlier : 06:27 09:00
                    2023-04-22 23:40:56.755 - debug: shuttercontrol.0 (25598) yes, IsEarlier : 06:27 09:00
                    2023-04-22 23:40:56.755 - debug: shuttercontrol.0 (25598) Starting up shutters children area: 09:00 debug 14
                    2023-04-22 23:40:56.760 - debug: shuttercontrol.0 (25598) check IsEarlier : 23:00 21:08
                    2023-04-22 23:40:56.760 - debug: shuttercontrol.0 (25598) check IsLater : 23:00 21:08
                    2023-04-22 23:40:56.760 - debug: shuttercontrol.0 (25598) yes, IsLater : 23:00 21:08
                    2023-04-22 23:40:56.761 - debug: shuttercontrol.0 (25598) Shutdown shutters living area: 21:08 debug 4
                    2023-04-22 23:40:56.761 - debug: shuttercontrol.0 (25598) shutterDownLiving
                    2023-04-22 23:40:56.770 - debug: shuttercontrol.0 (25598) Shutdown shutters children area: 19:15 debug 3
                    2023-04-22 23:40:56.780 - debug: shuttercontrol.0 (25598) Shutdown shutters sleep area: 21:08 debug 4
                    2023-04-22 23:40:56.797 - debug: shuttercontrol.0 (25598) late down at 00:00
                    2023-04-22 23:40:56.799 - debug: shuttercontrol.0 (25598) complete down at 00:00
                    2023-04-22 23:41:43.353 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Close, sourceObj={"type":"state","common":{"name":"Close","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Close","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411742855}
                    2023-04-22 23:41:43.354 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Open, sourceObj={"type":"state","common":{"name":"Open","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Open","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411742855}
                    2023-04-22 23:41:43.354 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Position, sourceObj={"type":"state","common":{"name":"Position","type":"number","role":"level.blind","read":true,"write":true,"unit":"%","min":0,"max":100},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Position","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411743113}
                    2023-04-22 23:41:43.757 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Pause, sourceObj={"type":"state","common":{"name":"Pause","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Pause","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411742855}
                    2023-04-22 23:41:43.759 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.state, sourceObj={"type":"state","common":{"name":"Roller state","type":"string","role":"state","read":true,"write":true,"states":{"close":"close","open":"open","stop":"stop"}},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.state","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411763010}
                    2023-04-22 23:41:43.759 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Close, sourceObj={"type":"state","common":{"name":"Close","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Close","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
                    2023-04-22 23:41:43.760 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Open, sourceObj={"type":"state","common":{"name":"Open","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Open","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
                    2023-04-22 23:41:43.760 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Position, sourceObj={"type":"state","common":{"name":"Position","type":"number","role":"level.blind","read":true,"write":true,"unit":"%","min":0,"max":100},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Position","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
                    2023-04-22 23:41:43.761 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Pause, sourceObj={"type":"state","common":{"name":"Pause","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Pause","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
                    2023-04-22 23:41:43.772 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76C797#1.Shutter.Position, sourceObj={"type":"state","common":{"name":"Position","type":"number","role":"level.blind","read":true,"write":true,"unit":"%","min":0,"max":100},"native":{},"_id":"shelly.0.SHSW-25#76C797#1.Shutter.Position","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411754193}
                    2023-04-22 23:42:00.090 - debug: shuttercontrol.0 (25598) Alarm Frost changed: false
                    2023-04-22 23:42:00.096 - debug: shuttercontrol.0 (25598) start shutterAlarm
                    2023-04-22 23:42:00.097 - debug: shuttercontrol.0 (25598) start pendingAlarm to check if an alarm is currently pending (exept frost)
                    2023-04-22 23:42:00.098 - debug: shuttercontrol.0 (25598) status alarm pending for alias.0.Shellys.Rolladen_Kinderzimmer_2.SET: false
                    2023-04-22 23:42:01.131 - debug: shuttercontrol.0 (25598) shutter alarm frost endet and no other alarm is pending Kinderzimmer 2 already at: 0% - setting current action: down
                    2023-04-22 23:42:18.432 - info: jarvis.0 (4801) Client with IP 192.168.178.139 disconnected.
                    2023-04-22 23:42:41.705 - info: admin.0 (16939) ==> Connected system.user.admin from ::ffff:192.168.178.148
                    2023-04-22 23:43:07.275 - info: admin.0 (16939) <== Disconnect system.user.admin from ::ffff:192.168.178.148
                    2023-04-22 23:44:00.151 - debug: shuttercontrol.0 (25598) Alarm Frost changed: false
                    2023-04-22 23:44:00.151 - debug: shuttercontrol.0 (25598) start shutterAlarm
                    2023-04-22 23:44:00.152 - debug: shuttercontrol.0 (25598) start pendingAlarm to check if an alarm is currently pending (exept frost)
                    2023-04-22 23:44:00.152 - debug: shuttercontrol.0 (25598) status alarm pending for alias.0.Shellys.Rolladen_Kinderzimmer_2.SET: false
                    2023-04-22 23:44:01.224 - debug: shuttercontrol.0 (25598) shutter alarm frost endet and no other alarm is pending Kinderzimmer 2 already at: 0% - setting current action: down
                    2023-04-22 23:44:08.398 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.4
                    2023-04-22 23:44:23.429 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.5
                    2023-04-22 23:44:38.436 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.4
                    2023-04-22 23:44:43.397 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.5
                    2023-04-22 23:44:53.436 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.4
                    2023-04-22 23:45:00.042 - debug: shuttercontrol.0 (25598) calculate astrodata ...
                    2023-04-22 23:45:00.044 - debug: shuttercontrol.0 (25598) Sun Azimut: 331.3°
                    2023-04-22 23:45:00.045 - debug: shuttercontrol.0 (25598) Sun Elevation: -23.1°
                    2023-04-22 23:46:00.130 - debug: shuttercontrol.0 (25598) Alarm Frost changed: false
                    2023-04-22 23:46:00.131 - debug: shuttercontrol.0 (25598) start shutterAlarm
                    2023-04-22 23:46:00.131 - debug: shuttercontrol.0 (25598) start pendingAlarm to check if an alarm is currently pending (exept frost)
                    2023-04-22 23:46:00.131 - debug: shuttercontrol.0 (25598) status alarm pending for alias.0.Shellys.Rolladen_Kinderzimmer_2.SET: false
                    2023-04-22 23:46:01.160 - debug: shuttercontrol.0 (25598) shutter alarm frost endet and no other alarm is pending Kinderzimmer 2 already at: 0% - setting current action: down
                      Tottbeck
                      #5730
                      Hallo, ich habe gestern auf die Version v1.4.23 aktualisiert. (von 1.4.18)
                      Jetzt fuhren heute meine Rolladen zwar in den Sonnenschutz ("Sunprotect #414") aber nicht mehr raus.
                      Ich lasse die über die "Außentemperatur/Lichtsensor und Himmelsrichtung" steuern, wobei ich für die Außentemperatur ein gefiltertetes Powersignal meiner PV-Anlage als Trigger nehme. Hat bisher auch gut funktioniert.
                      Spätestens wenn die Himmelsrichtung nicht mehr passt, hätte hochgefahren werden müssen, aber das Event "Sunprotect #415" fehlt bei allen Rolläden. Bei 'autoState' stehen die im "Manu_Mode" habe ich dann gesehen, obwohl die nicht manuell verfahren wurden. 🤔
                      Habe sie dann wieder in der AutoMode gezwungen. Danach sind die Rolladen die dann aus dem Sonnenschutz fuhren sofort wieder im "Manu_Mode" gelandet. Gibt es evtl. ein Feedback vom Shellys, was ihn durcheinander bringt? Das war mit der alten Version definitiv nicht.
                      F 1 Antwort Letzte Antwort
                      • T Tottbeck
                        firebowl
                        #5731
                        @tottbeck nimm die 1.4.28
                        • F firebowl
                          Tottbeck
                          #5732
                          @firebowl
                          OK, danke ist nun installiert. Dann ist die 1.4.23 wohl doch nicht so stable.
                          Mal schauen was morgen passiert.
                          • rtwlR Online
                            rtwlR Online
                            rtwl
                            #5733
                            @simatec wann kommt denn die 28er ins stable? Die "instabile" 23er ist aktuell dort zu finden.
                            -Peter
                            • rtwlR rtwl
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #5734
                              @rtwl Die v1.4.28 kommt garnicht ins Stable... Und grundsätzlich kommen Versionen ins Stable, wenn die Beta Tests erfolgreich abgeschlossen sind
                              • rtwlR Online
                                rtwlR Online
                                rtwl
                                #5735
                                okay anders gefragt:
                                wann kommt eine neue Version anstelle der 23er ins stable welche nicht den Fehler aufweist, dass die Rollläden im manu_mode landen nach dem sie in den Sonnenschutz gefahren sind?
                                -Peter
                                RaspiUserR simatecS 2 Antworten Letzte Antwort
                                • rtwlR rtwl
                                  RaspiUserR Online
                                  RaspiUserR Online
                                  RaspiUser
                                  #5736
                                  @rtwl
                                  ... schließe mich deiner Frage an ...
                                  • rtwlR rtwl
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #5737
                                    @rtwl sagte in Test Adapter shuttercontrol v1.4.x:
                                    Hatte ich doch in meinem letzten Post geschrieben.
                                    Wenn die Beta Versionen soweit getestet sind, dass sie Fehlerfrei sind.
                                    Wann das ist, kann man nicht in Tage oder Wochen definieren.
                                    Die aktuelle Beta 1.4.29 sieht recht gut aus.
                                    Wenn ihr nicht warten wollt, installiert die Version aus der Beta Repo
                                      steimi
                                      schrieb am zuletzt editiert von steimi
                                      #5738
                                      @simatec
                                      Ich habe immer wieder Probleme mit shuttercontrol das Rollladen nicht so fahren wie ich mir das vorstelle.
                                      1. Heute morgen z.B. hat Junior vor der upChildren-Zeit ein Fenster (KZ_2_F1) geöffnet, das Rollo ist dann hochgefahren. Er hat es nach der upChildren-Zeit geschlossen. Das Fenster wurde aber bei Durchlauf von Shuttercontrol während der upChildren-Zeit nicht neu gesetzt. Ich bin davon ausgegangen, dass das Fenster beim Durchlauf auf 100% und 'nicht getriggert' gesetzt wird. Das Rollo ist dann anschliessend wieder runter gefahren.
                                      2. Ich habe im Kinderzimmer (z.B. KZ_1_F1) Dreh/Kippsensoren an den Fenster(griffen). Ich öffne das Fenster vor der downChildren-Zeit zum Lüften. Wenn ich nach der downChildren-Zeit das Fenster schliesse und sofort in den Kippmodus bringe hatte ich gehofft, das das Fenster dann sofort ich die Lüftungsstellung fährt. Das Fenster schliesst jedoch. Was habe ich falsch konfiguriert
                                      2023-04-27 05:20:00.004 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                      2023-04-27 05:20:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 60.5°
                                      2023-04-27 05:20:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -5.2°
                                      2023-04-27 05:25:00.006 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                      2023-04-27 05:25:00.006 - debug: shuttercontrol.0 (1088236) Sun Azimut: 61.5°
                                      2023-04-27 05:25:00.006 - debug: shuttercontrol.0 (1088236) Sun Elevation: -4.6°
                                      2023-04-27 05:27:51.968 - debug: shuttercontrol.0 (1088236) TriggerID changed: hm-rpc.0.0007DF29950C05.1.STATE Value: 2
                                      2023-04-27 05:27:51.971 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter conversion is:false
                                      2023-04-27 05:27:52.016 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter current state.val is:20
                                      2023-04-27 05:27:52.016 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger drive-up is:100
                                      2023-04-27 05:27:52.016 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger change is:upDown
                                      2023-04-27 05:27:52.017 - debug: shuttercontrol.0 (1088236) #1 save trigger height: 20% for device KZ_2_F1
                                      2023-04-27 05:27:52.017 - debug: shuttercontrol.0 (1088236) #1 save trigger action: none for device KZ_2_F1
                                      2023-04-27 05:27:52.017 - info: shuttercontrol.0 (1088236) #1 Set ID: KZ_2_F1 value: 100%
                                      2023-04-27 05:27:52.018 - debug: shuttercontrol.0 (1088236) #1 current height: 100% for device KZ_2_F1
                                      2023-04-27 05:27:52.018 - debug: shuttercontrol.0 (1088236) #1 current action: triggered for device KZ_2_F1
                                      2023-04-27 05:27:52.018 - info: shuttercontrol.0 (1088236) triggered #1 Set ID: KZ_2_F1 value: 100%
                                      2023-04-27 05:27:52.066 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:27:52.076 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:27:52.077 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_2_F1 old value = 20 new value = 100
                                      2023-04-27 05:27:52.077 - debug: shuttercontrol.0 (1088236) KZ_2_F1 Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:27:52.126 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - window is still open -> driving now to :100
                                      2023-04-27 05:30:00.004 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                      2023-04-27 05:30:00.005 - debug: shuttercontrol.0 (1088236) Sun Azimut: 62.5°
                                      2023-04-27 05:30:00.005 - debug: shuttercontrol.0 (1088236) Sun Elevation: -3.9°
                                      2023-04-27 05:31:00.015 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:00.016 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.Kueche_F1: false
                                      2023-04-27 05:31:00.016 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:00.017 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_1_F1: false
                                      2023-04-27 05:31:00.028 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: Kueche_F1_Rollo value: 100%
                                      2023-04-27 05:31:00.038 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: KZ_1_F1 value: 100%
                                      2023-04-27 05:31:00.048 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:00.052 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:00.059 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:00.064 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:00.067 - debug: shuttercontrol.0 (1088236) Shutter state changed: Kueche_F1_Rollo old value = 20 new value = 100
                                      2023-04-27 05:31:00.068 - debug: shuttercontrol.0 (1088236) Kueche_F1_Rollo Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:00.073 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_1_F1 old value = 20 new value = 100
                                      2023-04-27 05:31:00.075 - debug: shuttercontrol.0 (1088236) KZ_1_F1 Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:00.080 - debug: shuttercontrol.0 (1088236) last automatic Action for Kueche_F1_Rollo: up_LivingTime
                                      2023-04-27 05:31:00.081 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 Kueche_F1_Rollo old height: 20% new height: 100%
                                      2023-04-27 05:31:00.081 - debug: shuttercontrol.0 (1088236) last automatic Action for KZ_1_F1: up_ChidrenTime
                                      2023-04-27 05:31:00.081 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 KZ_1_F1 old height: 20% new height: 100%
                                      2023-04-27 05:31:01.081 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:01.081 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.Kueche_F2: false
                                      2023-04-27 05:31:01.082 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:01.082 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_2_F1: false
                                      2023-04-27 05:31:01.123 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: Kueche_F2_Rollo value: 100%
                                      2023-04-27 05:31:01.125 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: Buero_F1 value: 100%
                                      2023-04-27 05:31:01.128 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:01.131 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:01.138 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:01.139 - debug: shuttercontrol.0 (1088236) Shutter state changed: Kueche_F2_Rollo old value = 20 new value = 100
                                      2023-04-27 05:31:01.139 - debug: shuttercontrol.0 (1088236) Kueche_F2_Rollo Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:01.142 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:01.144 - debug: shuttercontrol.0 (1088236) Shutter state changed: Buero_F1 old value = 0 new value = 100
                                      2023-04-27 05:31:01.145 - debug: shuttercontrol.0 (1088236) Buero_F1 Old value = 0. New value = 100. automatic is active
                                      2023-04-27 05:31:01.145 - debug: shuttercontrol.0 (1088236) last automatic Action for Kueche_F2_Rollo: up_LivingTime
                                      2023-04-27 05:31:01.145 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 Kueche_F2_Rollo old height: 20% new height: 100%
                                      2023-04-27 05:31:01.189 - debug: shuttercontrol.0 (1088236) last automatic Action for Buero_F1: up_ChidrenTime
                                      2023-04-27 05:31:01.189 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 Buero_F1 old height: 0% new height: 100%
                                      2023-04-27 05:31:02.145 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:02.145 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F1: false
                                      2023-04-27 05:31:02.188 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F1_Rollo value: 100%
                                      2023-04-27 05:31:02.192 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:02.194 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: Buero_F2 value: 100%
                                      2023-04-27 05:31:02.202 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:02.203 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F1_Rollo old value = 20 new value = 100
                                      2023-04-27 05:31:02.203 - debug: shuttercontrol.0 (1088236) WZ_F1_Rollo Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:02.205 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:02.210 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F1_Rollo: up_LivingTime
                                      2023-04-27 05:31:02.210 - debug: shuttercontrol.0 (1088236) shutterUpLiving #1 WZ_F1_Rollo old height: 20% new height: 100%
                                      2023-04-27 05:31:02.215 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:02.216 - debug: shuttercontrol.0 (1088236) Shutter state changed: Buero_F2 old value = 50 new value = 100
                                      2023-04-27 05:31:02.216 - debug: shuttercontrol.0 (1088236) Buero_F2 Old value = 50. New value = 100. automatic is active
                                      2023-04-27 05:31:02.259 - debug: shuttercontrol.0 (1088236) last automatic Action for Buero_F2: up_ChidrenTime
                                      2023-04-27 05:31:02.259 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 Buero_F2 old height: 50% new height: 100%
                                      2023-04-27 05:31:03.210 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:03.210 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F2: false
                                      2023-04-27 05:31:03.251 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F2_Rollo value: 100%
                                      2023-04-27 05:31:03.259 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:03.260 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_3_F1: false
                                      2023-04-27 05:31:03.262 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:03.272 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:03.273 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F2_Rollo old value = 20 new value = 100
                                      2023-04-27 05:31:03.274 - debug: shuttercontrol.0 (1088236) WZ_F2_Rollo Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:03.320 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F2_Rollo: up_LivingTime
                                      2023-04-27 05:31:03.320 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F2_Rollo old height: 20% new height: 100%
                                      2023-04-27 05:31:04.274 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:04.274 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_3_F2: false
                                      2023-04-27 05:31:04.319 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: KZ_2_F2 value: 100%
                                      2023-04-27 05:31:04.321 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:04.321 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F3: false
                                      2023-04-27 05:31:04.323 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:04.333 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:04.334 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F3_Rollo value: 100%
                                      2023-04-27 05:31:04.334 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_2_F2 old value = 20 new value = 100
                                      2023-04-27 05:31:04.334 - debug: shuttercontrol.0 (1088236) KZ_2_F2 Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:04.381 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:04.390 - debug: shuttercontrol.0 (1088236) last automatic Action for KZ_2_F2: up_ChidrenTime
                                      2023-04-27 05:31:04.390 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 KZ_2_F2 old height: 20% new height: 100%
                                      2023-04-27 05:31:04.393 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:04.394 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F3_Rollo old value = 20 new value = 100
                                      2023-04-27 05:31:04.394 - debug: shuttercontrol.0 (1088236) WZ_F3_Rollo Old value = 20. New value = 100. automatic is active
                                      2023-04-27 05:31:04.395 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F3_Rollo: up_LivingTime
                                      2023-04-27 05:31:04.396 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F3_Rollo old height: 20% new height: 100%
                                      2023-04-27 05:31:05.396 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:05.396 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F4: false
                                      2023-04-27 05:31:05.439 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F4_Rollo value: 100%
                                      2023-04-27 05:31:05.485 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:05.495 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:05.496 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F4_Rollo old value = 0 new value = 100
                                      2023-04-27 05:31:05.496 - debug: shuttercontrol.0 (1088236) WZ_F4_Rollo Old value = 0. New value = 100. automatic is active
                                      2023-04-27 05:31:05.611 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F4_Rollo: up_LivingTime
                                      2023-04-27 05:31:05.611 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F4_Rollo old height: 0% new height: 100%
                                      2023-04-27 05:31:06.611 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:06.611 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F5: false
                                      2023-04-27 05:31:06.825 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F5_Rollo value: 100%
                                      2023-04-27 05:31:07.011 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:07.021 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:07.022 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F5_Rollo old value = 0 new value = 100
                                      2023-04-27 05:31:07.022 - debug: shuttercontrol.0 (1088236) WZ_F5_Rollo Old value = 0. New value = 100. automatic is active
                                      2023-04-27 05:31:07.073 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F5_Rollo: up_LivingTime
                                      2023-04-27 05:31:07.073 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F5_Rollo old height: 0% new height: 100%
                                      2023-04-27 05:31:08.074 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:08.074 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F6: false
                                      2023-04-27 05:31:08.119 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F6_Rollo value: 100%
                                      2023-04-27 05:31:08.165 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:08.176 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:08.177 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F6_Rollo old value = 0 new value = 100
                                      2023-04-27 05:31:08.177 - debug: shuttercontrol.0 (1088236) WZ_F6_Rollo Old value = 0. New value = 100. automatic is active
                                      2023-04-27 05:31:08.227 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F6_Rollo: up_LivingTime
                                      2023-04-27 05:31:08.227 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F6_Rollo old height: 0% new height: 100%
                                      2023-04-27 05:31:09.227 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:09.227 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.Bad_EG_F1: false
                                      2023-04-27 05:31:09.271 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: Bad_EG_F1_Rollo value: 100%
                                      2023-04-27 05:31:09.317 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:09.327 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:09.328 - debug: shuttercontrol.0 (1088236) Shutter state changed: Bad_EG_F1_Rollo old value = 0 new value = 100
                                      2023-04-27 05:31:09.328 - debug: shuttercontrol.0 (1088236) Bad_EG_F1_Rollo Old value = 0. New value = 100. automatic is active
                                      2023-04-27 05:31:09.374 - debug: shuttercontrol.0 (1088236) last automatic Action for Bad_EG_F1_Rollo: up_LivingTime
                                      2023-04-27 05:31:09.375 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 Bad_EG_F1_Rollo old height: 0% new height: 100%
                                      2023-04-27 05:31:10.375 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                                      2023-04-27 05:31:10.375 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.HWR_F1: false
                                      2023-04-27 05:31:10.419 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: HWR_F1_Rollo value: 100%
                                      2023-04-27 05:31:10.430 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:31:10.440 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:31:10.440 - debug: shuttercontrol.0 (1088236) Shutter state changed: HWR_F1_Rollo old value = 0 new value = 100
                                      2023-04-27 05:31:10.441 - debug: shuttercontrol.0 (1088236) HWR_F1_Rollo Old value = 0. New value = 100. automatic is active
                                      2023-04-27 05:31:10.486 - debug: shuttercontrol.0 (1088236) last automatic Action for HWR_F1_Rollo: up_LivingTime
                                      2023-04-27 05:31:10.486 - debug: shuttercontrol.0 (1088236) shutterUpLiving #1 HWR_F1_Rollo old height: 0% new height: 100%
                                      2023-04-27 05:35:00.004 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                      2023-04-27 05:35:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 63.5°
                                      2023-04-27 05:35:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -3.2°
                                      2023-04-27 05:35:24.446 - debug: shuttercontrol.0 (1088236) TriggerID changed: hm-rpc.0.0007DF299508E8.1.STATE Value: 2
                                      2023-04-27 05:35:24.446 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter conversion is:false
                                      2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter current state.val is:100
                                      2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter trigger drive-up is:100
                                      2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter trigger change is:upDown
                                      2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) #2 save trigger action: up for device: KZ_1_F1
                                      2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) #2 save trigger height: 100% for device: KZ_1_F1
                                      2023-04-27 05:39:59.693 - debug: shuttercontrol.0 (1088236) outsidetemperature changed: 0_userdata.0.Wetter_Klima.var_weather_temperature_sun_gleitend Value: -5.8
                                      2023-04-27 05:40:00.003 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                      2023-04-27 05:40:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 64.5°
                                      2023-04-27 05:40:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -2.5°
                                      2023-04-27 05:45:00.003 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                      2023-04-27 05:45:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 65.5°
                                      2023-04-27 05:45:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -1.8°
                                      2023-04-27 05:47:51.537 - debug: shuttercontrol.0 (1088236) TriggerID changed: hm-rpc.0.0007DF29950C05.1.STATE Value: 0
                                      2023-04-27 05:47:51.538 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter conversion is:false
                                      2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter current state.val is:100
                                      2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter current Height is:100
                                      2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger Height is:20
                                      2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger Action is:none
                                      2023-04-27 05:47:51.581 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger Change is:upDown
                                      2023-04-27 05:47:51.623 - info: shuttercontrol.0 (1088236) Window is still closed -> drive to last height: Set ID: KZ_2_F1 value: 20%
                                      2023-04-27 05:47:51.670 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                                      2023-04-27 05:47:51.681 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                                      2023-04-27 05:47:51.681 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_2_F1 old value = 100 new value = 20
                                      2023-04-27 05:47:51.681 - debug: shuttercontrol.0 (1088236) KZ_2_F1 Old value = 100. New value = 20. automatic is active
                                      2023-04-27 05:47:51.730 - debug: shuttercontrol.0 (1088236) save back trigger action: none for device: KZ_2_F1
                                      2023-04-27 05:50:00.005 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                                        "_id": "system.adapter.shuttercontrol.0",
                                        "common": {
                                          "name": "shuttercontrol",
                                          "version": "1.4.29",
                                          "title": "shuttercontrol",
                                          "authors": [
                                            "simatec <shuttercontrol@simateccloud.de>"
                                          "keywords": [
                                            "ioBroker",
                                            "Smart Home",
                                            "home automation",
                                            "Rollladen",
                                            "Jalousie",
                                            "Rollladensteuerung"
                                          "license": "MIT",
                                          "platform": "Javascript/Node.js",
                                          "main": "main.js",
                                          "icon": "shuttercontrol.png",
                                          "enabled": true,
                                          "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                                          "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                                          "loglevel": "debug",
                                          "mode": "daemon",
                                          "type": "climate-control",
                                          "compact": true,
                                          "materialize": true,
                                          "connectionType": "local",
                                          "dataSource": "push",
                                          "stopBeforeUpdate": true,
                                          "adminUI": {
                                            "config": "materialize"
                                          "plugins": {
                                            "sentry": {
                                              "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                                          "installedFrom": "iobroker.shuttercontrol@1.4.29",
                                          "installedVersion": "1.4.29",
                                          "host": "iobroker"
                                        "native": {
                                          "livingAutomatic": "livingSunriseSunset",
                                          "W_shutterDownLiving": "22:00",
                                          "W_shutterUpLivingMin": "05:00",
                                          "W_shutterUpLivingMax": "06:00",
                                          "driveDelayUpLiving": "1",
                                          "WE_shutterDownLiving": "22:00",
                                          "WE_shutterUpLivingMin": "07:00",
                                          "WE_shutterUpLivingMax": "07:30",
                                          "sleepAutomatic": "sleepSunriseSunset",
                                          "W_shutterDownSleep": "21:30",
                                          "W_shutterUpSleepMin": "06:00",
                                          "W_shutterUpSleepMax": "07:00",
                                          "driveDelayUpSleep": "0",
                                          "WE_shutterDownSleep": "22:00",
                                          "WE_shutterUpSleepMin": "07:00",
                                          "WE_shutterUpSleepMax": "07:30",
                                          "childrenAutomatic": "childrenSunriseSunset",
                                          "W_shutterDownChildren": "19:30",
                                          "W_shutterUpChildrenMin": "05:30",
                                          "W_shutterUpChildrenMax": "06:00",
                                          "driveDelayUpChildren": "1",
                                          "WE_shutterDownChildren": "20:00",
                                          "WE_shutterUpChildrenMin": "08:00",
                                          "WE_shutterUpChildrenMax": "08:00",
                                          "latitude": "xx.xxxxxxxx",
                                          "longitude": "xx.xxxxxxxx",
                                          "sunProtEndElevation": "15",
                                          "astroDelayUp": "-20",
                                          "astroDelayDown": "23",
                                          "driveDelayUpAstro": "0",
                                          "SummerStart": "01.03.",
                                          "SummerEnd": "30.09.",
                                          "XMasStart": "01.12.",
                                          "XMasEnd": "06.01.",
                                          "publicHolidays": true,
                                          "publicHolInstance": "feiertage.0",
                                          "HolidayDP": "ical.0.events.0.today.Urlaub",
                                          "lightsensorDown": "400",
                                          "lightsensorUp": "500",
                                          "lightsensorUpTime": "06:00",
                                          "lightsensorDownTime": "17:30",
                                          "lightsensorUpDown": "",
                                          "schoolfree": true,
                                          "schoolfreeInstance": "schoolfree.0",
                                          "schoolfreeDP": "",
                                          "schoolfreeChildrenArea": true,
                                          "schoolfreeSleepArea": false,
                                          "schoolfreeLivingArea": false,
                                          "LateAllDown": false,
                                          "LateAllDownTime": "22:15",
                                          "betweenPositionTime": "22:00",
                                          "noGoTime": "0",
                                          "currentShutterState": false,
                                          "currentShutterStateTime": "30",
                                          "triggerAutoSleep": "",
                                          "triggerAutoLiving": "",
                                          "triggerAutoChildren": "",
                                          "alarmWind1Level": "100",
                                          "alarmWind1": "",
                                          "alarmWind2Level": "100",
                                          "alarmWind2": "",
                                          "alarmRainLevel": "100",
                                          "alarmRain": "",
                                          "alarmFrostLevel": "20",
                                          "alarmFrost": "0_userdata.0.Wetter_Klima.var_weather_frost",
                                          "alarmFireLevel": "100",
                                          "alarmFire": "",
                                          "events": [
                                              "enabled": true,
                                              "shutterName": "Kueche_F1_Rollo",
                                              "name": "0_userdata.0.Rollladen.Kueche_F1",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "typeDown": "living",
                                              "type": "outside temperature and direction",
                                              "heightDownSun": "30",
                                              "direction": "110",
                                              "directionRange": "50",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "outsideTempSensor": "0_userdata.0.Wetter_Klima.var_weather_temperature_sun_gleitend",
                                              "tempOutside": "37",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "triggerState": "none",
                                              "triggerStateTilted": "none",
                                              "triggerDrive": "100",
                                              "triggerDriveTildet": "20",
                                              "triggerChange": "off",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "hysteresisOutside": "15",
                                              "hysteresisInside": "5",
                                              "hysteresisLight": "5",
                                              "currentAction": "",
                                              "currentHeight": "",
                                              "oldHeight": "",
                                              "firstCompleteUp": "",
                                              "triggerHeight": "",
                                              "LateDown": false,
                                              "inSummerNotDown": false,
                                              "KeepSunProtect": true,
                                              "triggerAction": "",
                                              "driveAfterClose": true,
                                              "useXmasLevel": false,
                                              "XmasLevel": "",
                                              "betweenPosition": false,
                                              "betweenPositionLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "sunProtectEndDely": "2",
                                              "sunProtectEndtimerid": "",
                                              "enableAlarmWind1": false,
                                              "enableAlarmWind2": false,
                                              "enableAlarmRain": false,
                                              "enableAlarmFrost": true,
                                              "enableAlarmFire": false,
                                              "alarmTriggerAction": "",
                                              "alarmTriggerLevel": "",
                                              "lastAutoAction": ""
                                              "enabled": true,
                                              "shutterName": "Kueche_F2_Rollo",
                                              "name": "0_userdata.0.Rollladen.Kueche_F2",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "direction": "200",
                                              "directionRange": "75",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "triggerState": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "sunProtectEndDely": "5",
                                              "enabled": true,
                                              "shutterName": "WZ_F1_Rollo",
                                              "name": "0_userdata.0.Rollladen.WZ_F1",
                                              "triggerID": "0_userdata.0.Rollladen.Dummy_Fensterkontakt",
                                              "typeUp": "living",
                                              "direction": "200",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "WZ_F2_Rollo",
                                              "name": "0_userdata.0.Rollladen.WZ_F2",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "heightDownSun": "15",
                                              "direction": "290",
                                              "directionRange": "90",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "driveAfterClose": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "WZ_F3_Rollo",
                                              "name": "0_userdata.0.Rollladen.WZ_F3",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "heightDownSun": "25",
                                              "direction": "245",
                                              "directionRange": "55",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "triggerDriveTildet": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "WZ_F4_Rollo",
                                              "name": "0_userdata.0.Rollladen.WZ_F4",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "type": "off",
                                              "heightDownSun": "20",
                                              "direction": "290",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "KeepSunProtect": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "sunProtectEndDely": "0",
                                              "enabled": true,
                                              "shutterName": "WZ_F5_Rollo",
                                              "name": "0_userdata.0.Rollladen.WZ_F5",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "heightDownSun": "35",
                                              "direction": "335",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "WZ_F6_Rollo",
                                              "name": "0_userdata.0.Rollladen.WZ_F6",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "direction": "290",
                                              "directionRange": "70",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "Bad_EG_F1_Rollo",
                                              "name": "0_userdata.0.Rollladen.Bad_EG_F1",
                                              "triggerID": "",
                                              "typeUp": "living",
                                              "heightDownSun": "40",
                                              "direction": "20",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "HWR_F1_Rollo",
                                              "name": "0_userdata.0.Rollladen.HWR_F1",
                                              "triggerID": "hm-rpc.0.00109D898C3CC9.1.STATE",
                                              "typeUp": "living",
                                              "direction": "20",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "triggerChange": "upDown",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "KZ_1_F1",
                                              "name": "0_userdata.0.Rollladen.OG_1_F1",
                                              "triggerID": "hm-rpc.0.0007DF299508E8.1.STATE",
                                              "typeUp": "children",
                                              "typeDown": "children",
                                              "direction": "200",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "tempOutside": "33",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "triggerStateTilted": "1",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "betweenPositionLevel": "50",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "Buero_F1",
                                              "name": "0_userdata.0.Rollladen.OG_2_F1",
                                              "triggerID": "hm-rpc.0.0007DF29950946.1.STATE",
                                              "direction": "200",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "0",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "Buero_F2",
                                              "name": "0_userdata.0.Rollladen.OG_2_F2",
                                              "triggerID": "hm-rpc.0.0007DF29950BFB.1.STATE",
                                              "direction": "290",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "tempOutside": "36",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "50",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enableAlarmFrost": false,
                                              "enabled": true,
                                              "shutterName": "KZ_2_F1",
                                              "name": "0_userdata.0.Rollladen.OG_3_F1",
                                              "triggerID": "hm-rpc.0.0007DF29950C05.1.STATE",
                                              "direction": "290",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                              "enabled": true,
                                              "shutterName": "KZ_2_F2",
                                              "name": "0_userdata.0.Rollladen.OG_3_F2",
                                              "triggerID": "hm-rpc.0.0007DF29950C91.1.STATE",
                                              "direction": "20",
                                              "tempInside": "23",
                                              "tempSensor": "",
                                              "tempOutside": "40",
                                              "lightSensor": "",
                                              "valueLight": "15",
                                              "heightUp": "100",
                                              "heightDown": "0",
                                              "elevation": "8",
                                              "autoDrive": "off",
                                              "oldHeight": "",
                                              "LateDown": false,
                                              "XmasLevel": "",
                                              "trigDelyUp": "",
                                              "trigDelyDown": "",
                                      • E Offline
                                        erazor86
                                        #5739
                                        @simatec
                                        ich habe bis vor kurzem meine Rolladen direkt über shelly gesteuert. Jedoch habe ich letztes Wochenende, aufgrund mehr Funktionsumfang wie Frostschutz etc., auf deinen Adapter in 23er Version umgestellt.
                                        Ich habe den Frostschutz bei diversen Rolladen aktiviert, wo es bei mir im Winter schonmal zerrissene Panzer gegeben hat, da der interne Motorschutz der Rollade nicht sensibel genug war.
                                        Genau bei diesen Rolladen hatte ich nach der ersten Nacht diverse Fehlermeldungen, dass ein falscher Wert geschrieben wurde. Siehe Post
                                        Nachdem ich den Debug-Modus aktiviert und wieder auf Info umgestellt habe, waren komischerweise die Fehlermeldungen nicht mehr aufgekommen.
                                        Jedoch hatte ich folgende Auffälligkeiten an den Fenstern mit eingestelltem aber nicht aktivem Frostschutz:
                                        Mittags habe ich die Rollade bei meinem Sohn manuell für seinen Mittagsschlaf runtergefahren. Kurz darauf (ca. 1-2min) fuhr die Rollade grundlos wieder auf 100% (offen). An der Rollade ist kein Sonnenschutz etc. eingestellt. Diesen Fehlerfall konnte ich an allen Rolladen mit eingestelltem, aber derzeit nich aktiven Frostschutz, nachstellen. Habe ich den Haken für Frostschutz entfernt, blieben die Rolladen unten.
                                        Der Frostschutz ist so eingestellt, dass bei aktivem Frostschutz der Rolladen auf 0% stehen bleiben soll.
                                        Weiterhin habe ich getestet ob der Rolladenfrostschutz funktioniert, indem ich den Schwellwert hoch gesetzt habe. Also auch bei +10° hatte ich den Frostschutz dann auf "wahr" stehen. Eigentlich hatte ich erwartet, dass der Rolladen dann morgens nicht öffnet und stattdessen bei 0% stehen bleibt, jedoch hat die Rollade wie auch sonst ohne Frostschutz normal im Automatik geöffnet. Ansonsten habe ich keine extra Alarme eingestellt.
                                        Ist der Fehler bekannt? Habe ich ggf. einen Denkfehler und hier etwas falsch eingestellt?
                                        • E erazor86
                                          @simatec
                                          steimi
                                          #5740
                                          @erazor86 mit Frostschutz gab es in den letzten Betas noch Fehlerbeseitigungen. Vlt mal auf die aktuelle Beta 1.4..29 wechseln und probieren.
                                          E 1 Antwort Letzte Antwort
