  4. INFO / ACHTUNG : Zwave-Adapter
info
64 Beiträge 20 Kommentatoren 14.7k Aufrufe 15 Beobachtet
  • K Offline
    koema
    #61
    ich habe beim zwave Adapter diesen Fehler:
    host.IOBrokerKoema02 2019-12-15 15:31:55.322 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3) code: 'MODULE_NOT_FOUND' }
    host.IOBrokerKoema02 2019-12-15 15:31:55.322 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.IOBrokerKoema02 2019-12-15 15:31:55.322 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.IOBrokerKoema02 2019-12-15 15:31:55.321 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.IOBrokerKoema02 2019-12-15 15:31:55.321 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.IOBrokerKoema02 2019-12-15 15:31:55.321 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19)
    host.IOBrokerKoema02 2019-12-15 15:31:55.320 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.IOBrokerKoema02 2019-12-15 15:31:55.320 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.IOBrokerKoema02 2019-12-15 15:31:55.320 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    host.IOBrokerKoema02 2019-12-15 15:31:55.319 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    host.IOBrokerKoema02 2019-12-15 15:31:55.318 error Caught by controller[0]: { Error: Cannot find module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
    zwave.0 2019-12-15 15:31:54.708 info (14335) Terminated (NO_ERROR): Without reason
    zwave.0 2019-12-15 15:31:54.706 info (14335) terminating
    zwave.0 2019-12-15 15:31:54.637 error (14335) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node' at Function.Module._resolveFilename (internal
    zwave.0 2019-12-15 15:31:54.636 error (14335) uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
    Ich habe alle Anleitungen und Fixversuche durchgeführt. Ich habe Instanz und Adapter deinstalliert und neu installiert.
    Alles nutzt nix. Brauche Hilfe.
    Danke schon mal!
    • K koema
      Danke schon mal!
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #62
      @koema
      Hast du das schon probiert?
      cd /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared
      npm install --production
      Warum sudo böse ist: https://forum.iobroker.net/post/17109
      K 1 Antwort Letzte Antwort
      • AlCalzoneA AlCalzone
        @koema
        koema
        #63
        @AlCalzone sagte in INFO / ACHTUNG : Zwave-Adapter:
        Hallo AlCalzone,
        danke für die Antwort. Bisher noch nicht.
        Habe es gerade probiert und der Fehler ist leider geblieben.
        Ich bin nahe dran den Pi neu aufzusetzen.
        MFG
        • K koema
          Hallo AlCalzone,
          MFG
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #64
          @koema sagte in INFO / ACHTUNG : Zwave-Adapter:
          Dann gibt der Log-Output des genanntes Befehl sicher einen Hinweis.
