  4. soll ich an developer schicken...
homematichm-rpcinfo to developer
3 Beiträge 2 Kommentatoren 255 Aufrufe 2 Beobachtet
  • a200A Offline
    a200A Offline
    a200
    Moin,
    habe heute folgende Meldung erhalten. Kann jemand was damit anfangen?
    2019-04-10 21:16:26.565  - warn: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SRH.MAINTENANCE.2"
    2019-04-10 21:16:26.565  - warn: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SABOTAGE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":
    "SABOTAGE","TYPE":"BOOL","DEFAULT":false},"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"D
    UTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST"
    ,"TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"O
    PERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"OPERATING_VOLTA
    GE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_CODE":{"MIN":0,
    "OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
    2019-04-10 21:16:26.655  - warn: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SRH.ROTARY_HANDLE_TRANSCEIVER.2"
    2019-04-10 21:16:26.655  - warn: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"MIN":"CLOSED","OPERATIONS":5,"MAX":"OPEN","FLAGS":1,"ID
    ":"STATE","TYPE":"ENUM","DEFAULT":"CLOSED","VALUE_LIST":["CLOSED","TILTED","OPEN"],"CONTROL":"RHS.STATE"}}}
    • sigi234S Online
      sigi234S Online
      sigi234
      @a200 sagte in soll ich an developer schicken...:
      hm-rpc.2
      Link Text
      Neu issue machen.......
      Immer Daten sichern!
      a200A 1 Antwort Letzte Antwort
      • sigi234S sigi234
        hm-rpc.2
        Link Text
        a200A Offline
        a200A Offline
        a200
        @sigi234 danke, fertig.
