  4. JS-Controller Upgrade Fehler
js-controllerupgradeerror
27 Beiträge 6 Kommentatoren 4.1k Aufrufe 4 Beobachtet
  • G Offline
    Granten
    schrieb am zuletzt editiert von Granten
    nach dem Update des JS-Controllers von 1.4.2 auf 1.5.7 habe ich folgendes im Log erhalten. Der iobroker lässt sich nicht mehr starten.
    root@ioBroker:/home/marko# iobroker upgrade self
    Update js-controller from @1.4.2 to @1.5.7
    NPM version: 3.10.10
    npm install iobroker.js-controller@1.5.7 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
     #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.0-8-686-pae
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v6.16.0
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none was installed.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    Host "ioBroker" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    root@ioBroker:/home/marko# iobroker start
    Starting iobroker controller daemon...
    /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                throw new Error(msg.error);
    Error: TypeError: Cannot set property DailyRotateFile of #<Object> which has only a getter
        at Object.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:184:36)
        at Module._compile (module.js:577:32)
        at Object.Module._extensions..js (module.js:586:10)
        at Module.load (module.js:494:32)
        at tryModuleLoad (module.js:453:12)
        at Function.Module._load (module.js:445:3)
        at Module.require (module.js:504:17)
        at require (internal/module.js:20:19)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:7:25)
        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
        at process.nextTick (internal/child_process.js:787:12)
        at _combinedTickCallback (internal/process/next_tick.js:73:7)
        at process._tickCallback (internal/process/next_tick.js:104:9)
    Kann mir jemand bei dem Problem helfen?
    • G Granten
      gyp ERR! not ok
      @Granten sagte in JS-Controller Upgrade Fehler:
      das ist aber uralt!
      auch
      node -v v6.16.0
      ist nicht mehr up to date!
      Im Moment sollte node v8.15.x und npm v6.9.0 sein, wobei node mit dem von dir angestrebten controller dann auch v10.x sein darf
      • G Offline
        Granten
        Ok das könnte ein guter Grund sein. Ich habe es schonmal versucht beides upzudaten. Aber dabei habe ich auch irgend was falsch gemacht. Gibt es eine aktuelle Anleitung dazu oder kannst du mir kurz sagen wie ich vorgehen muss?
        • arteckA Offline
          arteckA Offline
          arteck
          im ernst .. es gibt mahrere Threads dafür.. sogar einer der parallel läuft.. mensch wozu haben wir die Suchfunktion...
          ich verstehe so was nicht...
          G 1 Antwort Letzte Antwort
          -1
          • arteckA arteck
            Granten
            @arteck sehr hilfreich aber auch sau unnötig 🤦
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              http://www.iobroker.net/docu/?page_id=8323&lang=de
              • G Offline
                Granten
                Die Anleitung ist zwar echt gut, hilft mir nur leider nicht. Ich hab es 3 mal versucht. jetzt habe ich noch niedrigere Versionen installiert...
                node -v
                v8.15.0
                nodejs -v
                v4.8.2
                npm -v
                6.4.1
                Kann es sein dass beim Befehl
                sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                die falsche Repo genommen wird? Oder warum habe ich jetzt nodejs 4.8.2?
                • wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  Welches Betriebssystem hast du denn?
                  Und was ergibt die Abfrage nach dem entfernen der "alten" Versionen?
                  • G Offline
                    Granten
                    Ich habe jetzt nochmal vom stand von letzter nacht (sicherung) angefangen. folgendes kam im log dabei raus:
                    root@ioBroker:/home/marko# node -v
                    v6.16.0
                    root@ioBroker:/home/marko# nodejs -v
                    v6.16.0
                    root@ioBroker:/home/marko# npm -v
                    3.10.10
                    root@ioBroker:/home/marko# apt-get --purge remove node
                    Paket »node« ist nicht installiert, wird also auch nicht entfernt.
                    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                    root@ioBroker:/home/marko# apt-get --purge remove nodejs
                    Die folgenden Pakete werden ENTFERNT:
                      nodejs*
                    0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
                    Nach dieser Operation werden 49,2 MB Plattenplatz freigegeben.
                    Möchten Sie fortfahren? [J/n] j
                    (Lese Datenbank ... 41708 Dateien und Verzeichnisse sind derzeit installiert.)
                    Entfernen von nodejs (6.16.0-1nodesource1) ...
                    dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/generator« nicht leer, wird daher nicht gelöscht
                    Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                    root@ioBroker:/home/marko# apt-get autoremove
                    root@ioBroker:/home/marko# reboot
                    Using username "marko".
                    marko@192.168.0.89's password:
                    Linux ioBroker 4.9.0-8-686-pae #1 SMP Debian 4.9.144-3.1 (2019-02-19) i686
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Tue Mar 26 13:09:42 2019 from 192.168.0.10
                    marko@ioBroker:~$ su
                    Passwort:
                    root@ioBroker:/home/marko# curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                    ## Installing the NodeSource Node.js 10.x repo...
                    ## Populating apt-get cache...
                    + apt-get update
                    Holen:1 http://security.debian.org/debian-security stretch/updates InRelease [94,3 kB]
                    OK:2 https://deb.nodesource.com/node_6.x stretch InRelease
                    Ign:3 http://ftp.de.debian.org/debian stretch InRelease
                    Holen:4 http://ftp.de.debian.org/debian stretch-updates InRelease [91,0 kB]
                    Holen:5 http://security.debian.org/debian-security stretch/updates/main Sources [197 kB]
                    OK:6 http://ftp.de.debian.org/debian stretch Release
                    Holen:7 http://security.debian.org/debian-security stretch/updates/main i386 Packages [482 kB]
                    Holen:8 http://security.debian.org/debian-security stretch/updates/main Translation-en [213 kB]
                    Es wurden 1.077 kB in 1 s geholt (917 kB/s).
                    ## Confirming "stretch" is supported...
                    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/stretch/Release'
                    ## Adding the NodeSource signing key to your keyring...
                    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                    OK
                    ## Creating apt sources list file for the NodeSource Node.js 10.x repo...
                    + echo 'deb https://deb.nodesource.com/node_10.x stretch main' > /etc/apt/sources.list.d/nodesource.list
                    + echo 'deb-src https://deb.nodesource.com/node_10.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
                    ## Running `apt-get update` for you...
                    + apt-get update
                    OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                    Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                    OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                    OK:4 http://ftp.de.debian.org/debian stretch Release
                    Holen:5 https://deb.nodesource.com/node_10.x stretch InRelease [4.585 B]
                    Es wurden 4.585 B in 0 s geholt (10,5 kB/s).
                    ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
                    ## You may also need development tools to build native addons:
                         sudo apt-get install gcc g++ make
                    ## To install the Yarn package manager, run:
                         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                         sudo apt-get update && sudo apt-get install yarn
                    root@ioBroker:/home/marko# apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                    libavahi-compat-libdnssd-dev ist schon die neueste Version (0.6.32-2).
                    build-essential ist schon die neueste Version (12.3).
                    The following additional packages will be installed:
                      libuv1
                    Die folgenden NEUEN Pakete werden installiert:
                      libpam0g-dev libudev-dev libuv1 nodejs
                    0 aktualisiert, 4 neu installiert, 0 zu entfernen und 6 nicht aktualisiert.
                    Es müssen 3.790 kB an Archiven heruntergeladen werden.
                    Nach dieser Operation werden 14,3 MB Plattenplatz zusätzlich benutzt.
                    Holen:1 http://security.debian.org/debian-security stretch/updates/main i386 libudev-dev i386 232-25+deb9u9 [91,9 kB]
                    Holen:2 http://ftp.de.debian.org/debian stretch/main i386 libpam0g-dev i386 1.1.8-3.6 [187 kB]
                    Holen:3 http://ftp.de.debian.org/debian stretch/main i386 libuv1 i386 1.9.1-3 [89,8 kB]
                    Holen:4 http://ftp.de.debian.org/debian stretch/main i386 nodejs i386 4.8.2~dfsg-1 [3.422 kB]
                    Es wurden 3.790 kB in 0 s geholt (6.671 kB/s).
                    Vormals nicht ausgewähltes Paket libudev-dev:i386 wird gewählt.
                    (Lese Datenbank ... 38704 Dateien und Verzeichnisse sind derzeit installiert.)
                    Vorbereitung zum Entpacken von .../libudev-dev_232-25+deb9u9_i386.deb ...
                    Entpacken von libudev-dev:i386 (232-25+deb9u9) ...
                    Vormals nicht ausgewähltes Paket libpam0g-dev:i386 wird gewählt.
                    Vorbereitung zum Entpacken von .../libpam0g-dev_1.1.8-3.6_i386.deb ...
                    Entpacken von libpam0g-dev:i386 (1.1.8-3.6) ...
                    Vormals nicht ausgewähltes Paket libuv1:i386 wird gewählt.
                    Vorbereitung zum Entpacken von .../libuv1_1.9.1-3_i386.deb ...
                    Entpacken von libuv1:i386 (1.9.1-3) ...
                    Vormals nicht ausgewähltes Paket nodejs wird gewählt.
                    Vorbereitung zum Entpacken von .../nodejs_4.8.2~dfsg-1_i386.deb ...
                    Entpacken von nodejs (4.8.2~dfsg-1) ...
                    libpam0g-dev:i386 (1.1.8-3.6) wird eingerichtet ...
                    libuv1:i386 (1.9.1-3) wird eingerichtet ...
                    Trigger für libc-bin (2.24-11+deb9u4) werden verarbeitet ...
                    libudev-dev:i386 (232-25+deb9u9) wird eingerichtet ...
                    nodejs (4.8.2~dfsg-1) wird eingerichtet ...
                    update-alternatives: /usr/bin/nodejs wird verwendet, um /usr/bin/js (js) im automatischen Modus bereitzustellen
                    Last login: Tue Mar 26 13:11:09 2019 from 192.168.0.10
                    Passwort:
                    bash: node: Kommando nicht gefunden.
                    v4.8.2
                    bash: npm: Kommando nicht gefunden.
                    root@ioBroker:/home/marko# sudo ln -s /usr/local/bin/nodejs /usr/bin/node
                    root@ioBroker:/home/marko# ln -s /usr/local/bin/nodejs /usr/bin/node
                    ln: die symbolische Verknüpfung '/usr/bin/node' konnte nicht angelegt werden: Die Datei existiert bereits
                    jetzt lassen sich nicht einmal mehr die versionen abrufen, obwohl ich den fix in der anleitung versucht habe...
                    • liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      eine kurze frage - ist es eigentlich wichtig, in welchen verzeichnis man ist, bei der installation oder deinstallation von node und npm ?
                      steht nicht in anleitung
                      • wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        Kannst du die Schritte mal so ausführen:
                        sudo apt update && sudo apt upgrade
                        node -v
                        nodejs -v
                        npm -v
                        sudo apt-get --purge remove node
                        sudo apt-get --purge remove nodejs
                        sudo apt-get autoremove
                        sudo reboot
                        Wenn hier noch etwas kommt bei der Abfrage gibt es noch ein anderes Problem
                        node -v
                        nodejs -v
                        npm -v
                        dann mal bitte
                        which node
                        Wenn hier im letzten Abschnitt die Node/Nodejs/NPM Abfrage nicht das gewünschte Ergebnis liefert müssen wir weiter suchen.
                        node -v
                        nodejs -v
                        npm -v
                        • G Offline
                          Granten
                          hier das ergebnis davon:
                          Last login: Tue Mar 26 14:08:27 2019 from 192.168.0.10
                          marko@ioBroker:~$ sudo apt update && sudo apt upgrade
                          [sudo] Passwort für marko:
                          Ign:1 http://ftp.de.debian.org/debian stretch InRelease
                          Holen:2 http://security.debian.org/debian-security stretch/updates InRelease [94,3 kB]
                          Holen:3 http://ftp.de.debian.org/debian stretch-updates InRelease [91,0 kB]
                          OK:5 https://deb.nodesource.com/node_6.x stretch InRelease
                          Holen:6 http://security.debian.org/debian-security stretch/updates/main Sources [197 kB]
                          Es wurden 1.077 kB in 1 s geholt (871 kB/s).
                          Aktualisierung für 6 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                          Paketaktualisierung (Upgrade) wird berechnet... Fertig
                          Die folgenden Pakete werden aktualisiert (Upgrade):
                            libldb1 libssl1.0.2 openssh-client openssh-server openssh-sftp-server python-ldb
                          6 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 2.555 kB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 6.144 B Plattenplatz zusätzlich benutzt.
                          Holen:1 http://security.debian.org/debian-security stretch/updates/main i386 libssl1.0.2 i386 1.0.2r-1~deb9u1 [1.130 kB]
                          Holen:2 http://security.debian.org/debian-security stretch/updates/main i386 openssh-sftp-server i386 1:7.4p1-10+deb9u6 [45,0 kB]
                          Holen:3 http://security.debian.org/debian-security stretch/updates/main i386 openssh-server i386 1:7.4p1-10+deb9u6 [374 kB]
                          Holen:4 http://security.debian.org/debian-security stretch/updates/main i386 openssh-client i386 1:7.4p1-10+deb9u6 [845 kB]
                          Holen:5 http://security.debian.org/debian-security stretch/updates/main i386 python-ldb i386 2:1.1.27-1+deb9u1 [36,4 kB]
                          Holen:6 http://security.debian.org/debian-security stretch/updates/main i386 libldb1 i386 2:1.1.27-1+deb9u1 [124 kB]
                          Es wurden 2.555 kB in 0 s geholt (9.375 kB/s).
                          Lese Changelogs... Fertig
                          Vorkonfiguration der Pakete ...
                          Vorbereitung zum Entpacken von .../0-libssl1.0.2_1.0.2r-1~deb9u1_i386.deb ...
                          Entpacken von libssl1.0.2:i386 (1.0.2r-1~deb9u1) über (1.0.2q-1~deb9u1) ...
                          Vorbereitung zum Entpacken von .../1-openssh-sftp-server_1%3a7.4p1-10+deb9u6_i386.deb ...
                          Entpacken von openssh-sftp-server (1:7.4p1-10+deb9u6) über (1:7.4p1-10+deb9u5) ...
                          Vorbereitung zum Entpacken von .../2-openssh-server_1%3a7.4p1-10+deb9u6_i386.deb ...
                          Entpacken von openssh-server (1:7.4p1-10+deb9u6) über (1:7.4p1-10+deb9u5) ...
                          Vorbereitung zum Entpacken von .../3-openssh-client_1%3a7.4p1-10+deb9u6_i386.deb ...
                          Entpacken von openssh-client (1:7.4p1-10+deb9u6) über (1:7.4p1-10+deb9u5) ...
                          Vorbereitung zum Entpacken von .../4-python-ldb_2%3a1.1.27-1+deb9u1_i386.deb ...
                          Entpacken von python-ldb (2:1.1.27-1+deb9u1) über (2:1.1.27-1+b1) ...
                          Vorbereitung zum Entpacken von .../5-libldb1_2%3a1.1.27-1+deb9u1_i386.deb ...
                          Entpacken von libldb1:i386 (2:1.1.27-1+deb9u1) über (2:1.1.27-1+b1) ...
                          libldb1:i386 (2:1.1.27-1+deb9u1) wird eingerichtet ...
                          libssl1.0.2:i386 (1.0.2r-1~deb9u1) wird eingerichtet ...
                          Trigger für systemd (232-25+deb9u9) werden verarbeitet ...
                          openssh-client (1:7.4p1-10+deb9u6) wird eingerichtet ...
                          python-ldb (2:1.1.27-1+deb9u1) wird eingerichtet ...
                          openssh-sftp-server (1:7.4p1-10+deb9u6) wird eingerichtet ...
                          openssh-server (1:7.4p1-10+deb9u6) wird eingerichtet ...
                          marko@ioBroker:~$ node -v
                          v6.16.0
                          marko@ioBroker:~$ nodejs -v
                          v6.16.0
                          marko@ioBroker:~$ npm -v
                          3.10.10
                          marko@ioBroker:~$ sudo apt-get --purge remove node
                          marko@ioBroker:~$ sudo apt-get --purge remove nodejs
                            nodejs*
                          (Lese Datenbank ... 41706 Dateien und Verzeichnisse sind derzeit installiert.)
                          marko@ioBroker:~$ sudo apt-get autoremove
                          marko@ioBroker:~$ sudo reboot
                          Last login: Tue Mar 26 14:09:21 2019 from 192.168.0.10
                          -bash: node: Kommando nicht gefunden.
                          -bash: nodejs: Kommando nicht gefunden.
                          -bash: npm: Kommando nicht gefunden.
                          marko@ioBroker:~$ which node
                          marko@ioBroker:~$ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                          + apt-get update
                          OK
                          + apt-get update
                          Es wurden 4.585 B in 0 s geholt (10,4 kB/s).
                          marko@ioBroker:~$ sudo apt-get install -y nodejs
                            libuv1
                            libuv1 nodejs
                          0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 3.512 kB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 13,7 MB Plattenplatz zusätzlich benutzt.
                          Holen:1 http://ftp.de.debian.org/debian stretch/main i386 libuv1 i386 1.9.1-3 [89,8 kB]
                          Holen:2 http://ftp.de.debian.org/debian stretch/main i386 nodejs i386 4.8.2~dfsg-1 [3.422 kB]
                          Es wurden 3.512 kB in 0 s geholt (6.414 kB/s).
                          (Lese Datenbank ... 38702 Dateien und Verzeichnisse sind derzeit installiert.)
                          v4.8.2
                          marko@ioBroker:~$ sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev
                          Es müssen 279 kB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 570 kB Plattenplatz zusätzlich benutzt.
                          Es wurden 279 kB in 0 s geholt (1.330 kB/s).
                          (Lese Datenbank ... 38769 Dateien und Verzeichnisse sind derzeit installiert.)
                          marko@ioBroker:~$ reboot
                          -bash: reboot: Kommando nicht gefunden.
                          Last login: Tue Mar 26 14:11:04 2019 from 192.168.0.10
                          v4.8.2
                          marko@ioBroker:~$
                          der erste block hat gut funktioniert. danach kamen keine versionen mehr. das "wich node" verstehe ich nicht. bei der installation danach nimmt er mal wieder die 4.xx version. warum auch immer. npm -v funktioniert auch nicht mehr
                          • wendy2702W Online
                            wendy2702W Online
                            wendy2702
                            OK.
                            du hast eine i386 architektur mit 32bit wie es aussieht --> https://github.com/nodejs/help/issues/1384
                            Dafür gibt es keine "fertigen" Pakete mehr von Node
                            • wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              Schau mal hier:
                              https://debianforum.de/forum/viewtopic.php?t=172240
                              • G Offline
                                Granten
                                woran hast du denn die version erkannt?
                                Dann wäre es wohl sinnvoll die zu wechseln oder? auf 64bit?
                                • G Granten
                                  v6.16.0
                                  v6.16.0
                                  3.10.10
                                    nodejs*
                                  Passwort:
                                  + apt-get update
                                  OK
                                  + apt-get update
                                    libuv1
                                  Passwort:
                                  v4.8.2
                                  wendy2702W Online
                                  wendy2702W Online
                                  wendy2702
                                  Daran...
                                  hätte ich auch schon im ersten log sehen können/müssen ... Sorry 😳
                                  64bit würde dann wahrscheinlich sinn machen.
                                  • G Offline
                                    Granten
                                    Ok. Dann installiere ich mal eine VM mit 64bit. Oh man das hätte ich mir sparen können.... Was ist denn der beste weg um die Daten des iobrokers zu übernehmen? Ordner kopieren?
                                    • wendy2702W Online
                                      wendy2702W Online
                                      wendy2702
                                      Backup / Restore würde ich machen.
                                      • liv-in-skyL liv-in-sky
                                        @liv-in-sky
                                        Nein!
                                        • wendy2702W wendy2702
                                          Granten
                                          @wendy2702 hab ich ehrlich gesagt noch nie versucht. aber es gibt immer ein erstes mal. ich würde dann eine neue, saubere installation mit den neusten versionen durchführen und danach das restore ausführen. ist das so richtig?
