  4. JS-Controller Upgrade Fehler
js-controllerupgradeerror
27 Beiträge 6 Kommentatoren 4.1k Aufrufe 4 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    wendy2702
    Ja.
    Gibt hier einige Einträge die das beschreiben.
    Musst mal suchen... bin nur am Handy unterwegs... da is es bisschen mühselig
    G 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      Ja.
      Granten
      schrieb am zuletzt editiert von Granten
      @wendy2702 ja ich schau mal. kann eigentlich nicht so schwer sein.
      jetzt hab ich gleich bei der installation fehler bekommen.....
      marko@ioBroker64:~$     node -v
      v10.15.3
      marko@ioBroker64:~$     nodejs -v
      v10.15.3
      marko@ioBroker64:~$     npm -v
      6.4.1
      marko@ioBroker64:~$
      marko@ioBroker64:~$
      marko@ioBroker64:~$
      marko@ioBroker64:~$ curl -sL https://iobroker.net/install.sh | bash -
          Welcome to the ioBroker installer!
          Installer version: 2019-03-15
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      [sudo] Passwort für marko:
      Installed acl
      Installed libcap2-bin
      Installed git
      Installed unzip
          Creating ioBroker user and directory (2/4)
      User iobroker created
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      In file included from ../node_modules/nan/nan.h:190:0,
                       from ../src/unix_dgram.cc:5:
      ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
      ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
         return obj->ForceSet(GetCurrentContext(), key, value, attribs);
      In file included from ../src/unix_dgram.cc:5:0:
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, func, argc, argv);
      In file included from ../node_modules/nan/nan.h:47:0,
      /home/marko/.node-gyp/10.15.3/include/node/node.h:177:50: note: declared here
                       NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /home/marko/.node-gyp/10.15.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
           __attribute__((deprecated(message))) declarator
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      /home/marko/.node-gyp/10.15.3/include/node/node.h:170:50: note: declared here
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, method, argc, argv);
      /home/marko/.node-gyp/10.15.3/include/node/node.h:163:50: note: declared here
      ../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
      ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         domain      = info[0]->Int32Value();
      In file included from /home/marko/.node-gyp/10.15.3/include/node/v8.h:26:0,
                       from /home/marko/.node-gyp/10.15.3/include/node/node.h:63,
                       from ../node_modules/nan/nan.h:47,
      /home/marko/.node-gyp/10.15.3/include/node/v8.h:2478:46: note: declared here
         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      /home/marko/.node-gyp/10.15.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         type        = info[1]->Int32Value();
      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         protocol    = info[2]->Int32Value();
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         fd = info[0]->Int32Value();
      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[1]);
      /home/marko/.node-gyp/10.15.3/include/node/v8.h:2892:28: note: declared here
                         explicit Utf8Value(Local<v8::Value> obj));
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         buf = info[1]->ToObject();
      In file included from /home/marko/.node-gyp/10.15.3/include/node/node.h:63:0,
      /home/marko/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         offset = info[2]->Uint32Value();
      /home/marko/.node-gyp/10.15.3/include/node/v8.h:2477:47: note: declared here
         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         length = info[3]->Uint32Value();
      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[4]);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.9.0-8-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! node -v v10.15.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
          Finalizing installation (4/4)
      Enabling autostart...
      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
      Autostart enabled!
          ioBroker was installed successfully
          Open http://192.168.0.112:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      muss ich die beachten oder kann ich die ignorieren?
      EDIT: folgendes kommt beim upgrade von 1.4.2 auf 1.5.7 raus:
      Update js-controller from @1.4.2 to @1.5.7
      NPM version: 6.4.1
      npm install iobroker.js-controller@1.5.7 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:177:50: note: declared here
      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:170:50: note: declared here
      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:163:50: note: declared here
      In file included from /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:26:0,
                       from /home/iobroker/.node-gyp/10.15.3/include/node/node.h:63,
      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2478:46: note: declared here
      /home/iobroker/.node-gyp/10.15.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2892:28: note: declared here
      In file included from /home/iobroker/.node-gyp/10.15.3/include/node/node.h:63:0,
      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2477:47: note: declared here
      gyp ERR! not ok
      ../src/main.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/main.cpp:26:71: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
               DiskUsage result = GetDiskUsage(*v8::String::Utf8Value(info[0]));
                       from ../../nan/nan.h:53,
                       from ../src/main.cpp:3:
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      Host "ioBroker64" (linux) updated
      Execute: chmod -R 777 /opt/iobroker
      Chmod finished. Restart controller
      Starting node restart.js
      auch hier wieder die errors. mach ich irgend was falsch?
      • wendy2702W Online
        wendy2702W Online
        wendy2702
        Die Warning kannst du erstmal ignorieren.
        Läuft iobroker denn jetzt bzw. Lässt er sich starten?
          Granten
          @wendy2702 Ja das funktioniert =)
          nur diese warnungen kommen bei jeder installation einer instanz. sind die wirklich unbedenklich?
          • G Granten
            @Granten
            Ja!
            Die sollten deswegen eigentlich unterdrückt werden.
            Es sind auch nur WARN keine ERR
              @Granten
              Ja!
              Granten
              @Homoran Das ist nicht ganz richtig. Es stehen auch fast ganz unten bei meinem 2. Block mehrere ERR.
              Sollten unterdrückt werden? Habe ich da was falsch gemacht oder unterdrückt die Software das einfach nur noch nicht?
              BluefoxB 1 Antwort Letzte Antwort
              • G Granten
                BluefoxB Offline
                BluefoxB Offline
                Участник @Granten написал в JS-Controller Upgrade Fehler:
                Das Modul ist optional
