  4. Web Adapter Maximum call stack size exceeded
web adapter
3 Beiträge 2 Kommentatoren 553 Aufrufe 1 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    ich hätte da ein Problem
    host.iobroker	2019-03-12 15:47:36.742	error	instance system.adapter.web.0 terminated with code 0 (OK)
    Caught	2019-03-12 15:47:36.742	error	by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    Caught	2019-03-12 15:47:36.742	error	by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    Caught	2019-03-12 15:47:36.742	error	by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    Caught	2019-03-12 15:47:36.742	error	by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
    Caught	2019-03-12 15:47:36.741	error	by controller[0]: RangeError: Maximum call stack size exceeded
    web.0	2019-03-12 15:47:36.698	error	uncaught exception: Maximum call stack size exceeded
    js-controller 1.5.3
    web 2.4.1
      amnesia106
      schrieb am zuletzt editiert von amnesia106
      Genau das gleiche Problem habe ich auch nach der installation von Grafana in Verbindung mit dem Proxy Adapter. Deaktiviere ich den Proxy, läuft der Web.0 wieder. Es ist auch so, dass der Web.0 nicht sofort nach aktivieren des Proxy adapters abstürzt, sondern eher sporadisch.
      Flot scheint davon auch betroffen zu sein. Wenn ich flot aufrufe, stürzt auch alles ab. Mittlerweile trotz deaktivierten Proxy adapter
      • arteckA Offline
        arteckA Offline
        arteck
        @arteck sagte in Web Adapter Maximum call stack size exceeded:
        xceeded
        socket io ist der übeltäter..
