  4. SQL-Adapter 1.9.4. lässt sich nicht installieren: ERROR: Cannot find io-package.json in null
adapterfehlermeldung
8 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • MatzebhvM Offline
    MatzebhvM Offline
    Matzebhv
    Moin,
    habe als Repository latest eingestellt. Seit heute Morgen wird mir der SQL-Adapter 1.9.4 verfügbar angezeigt.
    Ein Update wird allerdings mit einem Fehler quittiert.
    $ ./iobroker upgrade sql
    Update sql from @1.9.2 to @1.9.4
    host.raspberry Adapter "system.adapter.sql.0" is stopped.
    NPM version: 6.5.0
    npm install iobroker.sql@1.9.4 --production --save --prefix "/opt/iobroker" (System call)
    gyp
     ERR! build error
    gyp ERR! stack Error: not found: makegyp ERR! stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
    gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
    gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
    gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
    gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
    gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)
    gyp ERR! System Linux 4.9.0-8-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd
     /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v8.15.0
    gyp
     ERR! node-gyp -v v3.8.0gyp
     ERR! not ok
    gyp
     ERR! build error
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp
     info it worked if it ends with ok
    node-pre-gyp verb cli [ '/usr/bin/node',node-pre-gyp verb cli   '/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp',
    node-pre-gyp verb cli   'install',
    node-pre-gyp verb cli   '--fallback-to-build' ]
    node-pre-gyp info using node-pre-gyp@0.6.32
    node-pre-gyp info using node@8.15.0 | linux | x64
    node-pre-gyp verb command install []
    node-pre-gyp info check checked for "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" (not found)
    node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-x64.tar.gz
    node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-x64.tar.gznode-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-x64.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.15.0 (node-v57 ABI) (falling back to source compile with node-gyp)
    node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-x64.tar.gz
    node-pre-gyp verb command build [ 'rebuild' ]
    gyp
     ERR! build error gyp ERR! stack Error: not found: make
    gyp
    ERR! stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
    gyp
     ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)gyp
     ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release"
    gyp
     ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialportgyp ERR! node -v v8.15.0
    gyp
    ERR! node-gyp -v v3.8.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.9.0-8-amd64
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport
    node-pre-gyp ERR! node -v v8.15.0
    node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    node-pre-gyp ERR! not ok
    gyp
     ERR! build error
    gyp ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! not ok
    gyp
     ERR! build error
    gyp ERR!
     stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
    gyp ERR!
    stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16gyp ERR!
    stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
    gyp
     ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)gyp ERR! System Linux 4.9.0-8-amd64
    gyp ERR! cwd /opt/iobroker/node_modules/mmmagic
    gyp ERR! not ok
    npm
     WARN
    optional
     SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/browser-serialport):
    npm
    WARN
    optional
     SKIPPING OPTIONAL DEPENDENCY: Error while executing:
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: undefined ls-remote -h -t git://github.com/noopkat/browser-serialport.gitnpm WARN optional SKIPPING OPTIONAL DEPENDENCY:
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: undefined
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: No git binary found in $PATH
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/stk500):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Error while executing:
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: undefined ls-remote -h -t git://github.com/noopkat/js-stk500v1.git
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/package.json'
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! mmmagic@0.5.2 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the mmmagic@0.5.2 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2019-02-25T16_39_57_677Z-debug.log
    host.raspberry Adapter "system.adapter.sql.0" is started
    ERROR: process exited with code 10
    Hat das noch wer?
    Matze
      dmode
      Hi Matze, hi zusammen,
      ich habe das gleiche Problem.
      Ich habe versucht ein Rollback über das Backuptool zu machen. Klappt leider nicht :-(
      Als Newbee bin ich jetzt etwas verzweifelt
      Dirk
      • surfer09S Offline
        surfer09S Offline
        surfer09
        Hi zusammen!
        ich habe das gleiche Problem! Ich wollte den Adapter nach dem Versuch neu installieren, weil er nicht mehr korrekt angezeigt wurde. Jetzt bekomme ich ihn auch nicht neu installiert.
        Gruß surfer
          dmode
          Moin zusammen,
          ich glaub das hat mit den (root)rechten zu tun
          ioBroker Installation "Fixer" Beta verfügbar
          ich blicks aber noch nicht :-(
          Dirk
          • arteckA Offline
            arteckA Offline
            arteck
            versuch mal von hinten im Ordner
            /opt/iobroker
            sudo npm install https://github.com/ioBroker/ioBroker.sql
            ausführen
            • surfer09S Offline
              surfer09S Offline
              surfer09
              Wie würde ich denn unter Windows vorgehen? Ich habe den Adapter gestern komplett gelöscht in der Hoffnung, dass das Teil danach wieder funktioniert. Jetzt bekomme ich ihn aber nicht mehr installiert. Anbei die LOG-Dateien.
              LOG.pdf
              2019-02-26T17_58_48_656Z-debug.log
              • MatzebhvM Offline
                MatzebhvM Offline
                Matzebhv
                Ich hab im Moment keine Zeit zu basteln, ihr könnt aber jederzeit wieder die funktionierende Version 1.9.2 installieren.
                Experten-Modus ein und über das + die ältere Version installieren.
                Matze
                • surfer09S Offline
                  surfer09S Offline
                  surfer09
                  Super, ich danke dir Matze! Ich wusste nicht, wie ich die alte Version wieder installieren kann.
                  Danke für die schnelle Rückmeldung!
                  Gruß surfer 😉
