  4. Backitup /Nas Problem
backitupnaszugriffsrechte
5 Beiträge 2 Kommentatoren 1.6k Aufrufe 1 Beobachtet
  • E Offline
    ecki945
    Will mich hier auch mal anschließen mit Problemen mit Backitup:
    Installiert habe ich nach Anleitung von https://haus-automatisierung.com/software/iobroker/2018/11/09/iobroker-tutorial-reihe-part-15-backup-auf-nas.html. Das Backup soll auf ein NAS kopiert werden. Macht er aber nicht. Hat wohl mit irgendwelchen Admin Rechten zu tun?
    Installiert ist alles auf nem Pi3+.
    NPN Version 6.41
    node-vs 8.51
    iobroker 1.5.7
    Wenn ich mit ohne root rechte die standard sicherung starte, kommt folgende Meldung:
    Gestartet...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****"}
    [ERROR] [mount] - [undefined mount: only root can use "--options" option
    [ERROR] [mount] - [IGNORED] Error: Command failed: mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups
    [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups"}},"done":[],"types":[]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_02_23-19_19_11_backupiobroker.tar.gz
    [DEBUG] [minimal] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [DEBUG] [cifs] - done
    [DEBUG] [clean] start with {"deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_02_23-19_19_11_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups"}},"done":["minimal"],"types":["minimal"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"systemLang":"de","time":"23. Februar 2019 um 19:19 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [telegram] - done
    [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_02_23-19_19_11_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups"}},"done":["minimal"],"types":["minimal"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"23. Februar 2019 um 19:19 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [history] - backitup.0.history.html
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups"}
    Mit sudo Rechten:
    Gestartet...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****"}
    Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
    Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
        #1) Respektieren Sie die Privatsphäre anderer.
        #2) Denken Sie nach, bevor Sie tippen.
        #3) Mit großer Macht kommt große Verantwortung.
    sudo: Kein TTY vorhanden und kein »askpass«-Programm angegeben
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups
    [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups"}},"done":[],"types":[]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_02_23-19_21_23_backupiobroker.tar.gz
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_02_23-19_21_23_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups"}},"done":["minimal"],"types":["minimal"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"systemLang":"de","time":"23. Februar 2019 um 19:21 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_02_23-19_21_23_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount -t cifs -o username=Backup,password=xxxx,rw,file_mode=0777,dir_mode=0777 //DISKSTATION1/BackupRPI/Standard /opt/iobroker/backups"}},"done":["minimal"],"types":["minimal"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"700bea16ce"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"23. Februar 2019 um 19:21 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//DISKSTATION1","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/BackupRPI/Standard","dirMinimal":"BackupRPI/Standard","dirTotal":"BackupRPI/Komplett","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups"}
    Lokal auf der Platte kann ich die Sicherung finden.
    Wer weiß rat?
    • E ecki945
      NPN Version 6.41
      node-vs 8.51
      iobroker 1.5.7
      Gestartet...
      Mit sudo Rechten:
      Gestartet...
      Wer weiß rat?
      simatecS Offline
      simatecS Offline
      simatec
      @ecki945
      Ich finde es echte schade, dass ihr immer wieder backitup die Schuld gebt und schreibt „Ich schließe mich den Problemen mit backitup an“ 😖😖
      Das sind keine Probleme von backitup!!!
      Es ist einzig und allein ein Problem eures Systems.
      Die Suchfunktion hätte hier sicher Aufschluss ergeben.
      https://forum.iobroker.net/post/231053
      Installiere den Fix laut Anleitung ubd deine Probleme sind behoben ...
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • E Offline
        ecki945
        Dank dir. hat funktioniert
        • E ecki945
          simatecS Offline
          simatecS Offline
          simatec
          @ecki945
          Bitte setze dann das Thema auf gelöst ...
          • E Offline
            ecki945
            newby frage, wie geht das?
