  4. [Vorstellung] Meine zweite Visualisierung
    apollon77A
vistemplate
1.3k Beiträge 148 Kommentatoren 750.9k Aufrufe 157 Beobachtet
  • K Kuddel
    @gfrene
    Skript für die Zonenreinung:
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="A3mcx,(O{KZ0SAwINJkl" x="-362.00000000000057" y="10037.5">
      <value name="OID0">
        <shadow type="field_oid" id="=^9T:bBq#a4Q,Nh;+#c=">
          <field name="oid">javascript.0.NoNo.Zonen_Reinigung</field>
        </shadow>
      </value>
      <statement name="STATEMENT">
        <block type="variables_set" id="?Vkt^R1:a?ZRu{JyI(Vh">
          <field name="VAR">Buero</field>
          <value name="VALUE">
            <block type="text" id="a=(?PpOyB5iGBLjQ6Aap">
              <field name="TEXT">app_zoned_clean;[[18471,19907,22571,23007,1]]</field>
            </block>
          </value>
          <next>
            <block type="variables_set" id="sYCBkY(T4jb-]X+2Eak,">
              <field name="VAR">Flur</field>
                <block type="text" id="%-KCb~RlSSjV6q_]/?j*">
                  <field name="TEXT">app_zoned_clean;[[22637,19580,29787,25130,2]]</field>
                </block>
              </value>
              <next>
                <block type="variables_set" id=";M*u(QADG3GbZdCgq8GG">
                  <field name="VAR">GaesteWC</field>
                    <block type="text" id="lS%?^.}[p`XS/bXa8f#g">
                      <field name="TEXT">app_zoned_clean;[[28009,25008,29709,26458,2]]</field>
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id="H#[grBDiKs9O6?Cx9J4#">
                      <field name="VAR">Kueche</field>
                        <block type="text" id="qSyl{KE}K,}iq}DCvI!1">
                          <field name="TEXT">app_zoned_clean;[[26727,25000,29777,29250,2]]</field>
                        </block>
                      </value>
                      <next>
                        <block type="variables_set" id="q[mk=w]QG/B:uT%rh)%7">
                          <field name="VAR">Wohnzimmer</field>
                            <block type="text" id="Qd0=lq+^}-*HGJNu^hHE">
                              <field name="TEXT">app_zoned_clean;[[18626,25160,25976,29110,2],[18569,23306,22519,25106,2]]</field>
                            </block>
                          </value>
                          <next>
                            <block type="controls_if" id="lH-2B:yzLcZ]@Mk~(nc]">
                              <value name="IF0">
                                <block type="logic_compare" id="Bp2=TLQfL3|kHV=a:vvq">
                                  <field name="OP">EQ</field>
                                  <value name="A">
                                    <block type="get_value" id="Hmzyi5vAP`/`|r8fEf=T">
                                      <field name="OID">javascript.0.NoNo.Zonen_Reinigung</field>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="math_number" id="=ef#+88ApoWQv2F(soI)">
                                      <field name="NUM">1</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <statement name="DO0">
                                <block type="control" id="rvU:D+8+T0=}aFHB4Y_,">
                                  <field name="OID">mihome-vacuum.0.control.X_send_command</field>
                                    <block type="variables_get" id="OrN{Ji``zx:c+,GIQ%V~">
                                    </block>
                                  </value>
                                </block>
                              </statement>
                              <next>
                                <block type="controls_if" id="p@4RtG#w?*ZfeQh-DhW=">
                                  <value name="IF0">
                                    <block type="logic_compare" id="]ML3dK+K%Ss*PP1C6}.I">
                                      <value name="A">
                                        <block type="get_value" id="A[L@C_egi[F/oVMQW^_/">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="math_number" id=":t3k=z={gtWBjX9%+oDY">
                                          <field name="NUM">2</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="control" id="Fj!_{m.PvLy[ZCTt69Ai">
                                        <block type="variables_get" id="cs^jf5ppROjO7t=DIc:W">
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="controls_if" id="522b~?+NAKvD,dErnt,l">
                                      <value name="IF0">
                                        <block type="logic_compare" id="b3T-%fupbfET7[^%D{gz">
                                          <value name="A">
                                            <block type="get_value" id="DciAT#,TJm)AFKPl,ZKU">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="math_number" id="Mtrun}#MK=5#js?MQLDP">
                                              <field name="NUM">3</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="hP#DYCrpD6@t+ZCj4K}t">
                                            <block type="variables_get" id="d6tpE4/.-l@yw(k6Op:h">
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                      <next>
                                        <block type="controls_if" id="wSNWFV(=oe3*Wq;f*@BI">
                                          <value name="IF0">
                                            <block type="logic_compare" id="Amc2r/~*m=c94}A/ex2x">
                                              <value name="A">
                                                <block type="get_value" id="^2CFEG{SfmYy#-cI{L{a">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="math_number" id="@{Af3%,R_U}B/_]Qnf!j">
                                                  <field name="NUM">4</field>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            <block type="control" id="2OX9HjBTIzS|;/.x7Evs">
                                                <block type="variables_get" id="!aKr!M;)d[~lIFQEW:Rv">
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="controls_if" id="sFsn,FsK/.lHM#d!zPu{">
                                              <value name="IF0">
                                                <block type="logic_compare" id="sV!{?%?M[3~@{WX[desv">
                                                  <value name="A">
                                                    <block type="get_value" id="jUehj--)Ra/*Fa_!-kBh">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="KC(quv,.gF*^p+@UY[f/">
                                                      <field name="NUM">5</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="YO.z!X!:4Bz}]iBb(jhf">
                                                    <block type="variables_get" id="hhG2Xi:Ge;lTOZ`k]ta-">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </statement>
    </block>
    Ausgelöst wird das ganze durch den entsprechenden Wert im Datenpunkt javascript.0.NoNo.Zonen_Reiningung
    0 = Aus
    1 = Raum 1
    2 = Raum 2
    ect.
    G
    G
    gfrene
    #61
    @Kuddel Dickes danke :-) wegen dem javascript.0.NoNo.Zonen_Reiningung steht in diesen Datenpukt was ? ist das noch ein JAVA-Srcipt ? Gruß und danke für deine Hilfe.
    K 1 Antwort Letzte Antwort
    • K
      K
      Kuddel
      #62
      @haschel
      Uptime WIndows 10 (Powershell):
      windows_10_uptime_umwandeln.txt windows_10_uptime_abfrage.txt
      Uptime Unifi-Controller (Shell):
      Voraussetzung: auf dem ioBroker einen SSH Key erstellen und auf den Unifi-Controller kopieren, sonst funktioniert die Abfrage nicht ohne PW
      unifi_uptime_umwandelntxt.txt unifi_uptime_abfrage.txt
      Festplattensepicher WinNAS (Powershell):
      WinNAS_Festplattenauslastung.txt
      WOL WinNAS (JavaScript):
      WinNAS_WOL.txt
      P 1 Antwort Letzte Antwort
      • G gfrene
        K
        K
        Kuddel
        #63
        @gfrene
        In dem Datenpunkt steht eine Zahl.
        Über meine VIS wird über das entsprechende Raum Widget eine Zahl riengeschrieben.
        Beispiel: Ich drücke in der VIS auf "Büro". Dann setzt das Widget eine 2 in das Datenobjekt.
        Über diese 2 werden dann per Blockly die entsprechenden Koordinaten ausgewählt und der Saugvorgang gestartet
        G 2 Antworten Letzte Antwort
        • K Kuddel
          @wendy2702:
          Ein Frage.
          Sind die Bilder von unterschiedlichen Tagen?
          Einmal Vollmond und einmal Neumond wie es aussieht. `
          damit man das besser erkennen kann habe ich auf der Startseite einen Vollmond genommen. diese Bild ändert sich nicht
          EDIT: habs mal eben geändert:
          M
          M
          maxpd
          schrieb am zuletzt editiert von maxpd
          #64
          @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
          Mhhh, lässt sich im neuen Forum nicht mehr im Thread selber filtern?
          Bei dem Astro Modul sind JavaScripte hinterlegt. Wie finde ich diese denn? Bei mir steht nur NaN oder null wo Zahlen stehen sollten.
          maxpd
          Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
          • M maxpd
            K
            K
            Kuddel
            #65
            @maxpd
            Da ich keine Ahnung von Java habe, habe ich alles mit Blockly umgesetzt:
            Tages und Nachtzeit
            Tages_und_Nachtlaenge.txt
            Fortschritt
            Fortschritt.txt
            • M
              M
              maxpd
              #66
              @Kuddel
              Ich auch nicht :)
              ich sehe nur unter Allgemein im Widget: javascript.0.zeiten.tageslaenge_fortschritt
              maxpd
              • K
                K
                Kuddel
                schrieb am zuletzt editiert von Kuddel
                #67
                @maxpd
                Wenn du alle Datenojekte die ich so verwende haben möchtest, erstelle ein JavaScript und kopiere folgendes rein:
                createState('javascript.0.zeiten.sonnenuntergang', false, {type: 'string',name: 'sonnenuntergang'});
                createState('javascript.0.zeiten.sonnenaufgang', false, {type: 'string',name: 'sonnenaufgang'});
                createState('javascript.0.zeiten.sonnenaufgang_stunde', false, {type: 'string',name: 'sonnenaufgang_stunde'});
                createState('javascript.0.zeiten.sonnenaufgang_minute', false, {type: 'string',name: 'sonnenaufgang_minute'});
                createState('javascript.0.zeiten.nachtlaenge', false, {type: 'string',name: 'nachtlaenge'});
                createState('javascript.0.zeiten.nachtlaenge_in_minuten', false, {type: 'string',name: 'nachtlaenge_in_minuten'});
                createState('javascript.0.zeiten.nachtlaenge_keinlicht', false, {type: 'string',name: 'nachtlaenge_keinlicht'});
                createState('javascript.0.zeiten.nachtlaenge_fortschritt', false, {type: 'string',name: 'nachtlaenge_fortschritt'});
                createState('javascript.0.zeiten.tageslaenge', false, {type: 'string',name: 'tageslaenge'});
                createState('javascript.0.zeiten.tageslaenge_differenz', false, {type: 'string',name: 'tageslaenge_differenz'});
                createState('javascript.0.zeiten.tageslaenge_fortschritt', false, {type: 'string',name: 'tageslaenge_fortschritt'});
                createState('javascript.0.zeiten.tageslaenge_in_minuten', false, {type: 'string',name: 'tageslaenge_in_minuten'});
                createState('javascript.0.zeiten.tageslaenge_tageslicht', false, {type: 'string',name: 'tageslaenge_tageslicht'});
                createState('javascript.0.zeiten.tageslaenge_tageslicht_in_minuten', false, {type: 'string',name: 'tageslaenge_tageslicht_in_minuten'});
                createState('javascript.0.zeiten.tageslaenge_timer_restart', false, {type: 'boolean',name:'tageslaenge_timer_restart'});
                G 1 Antwort Letzte Antwort
                • M
                  M
                  maxpd
                  #68
                  @maxpd
                  Die Astro Anzeige fand ich ganz interessant, da ich die Angaben auch manchmal google.
                  Aber am meisten versuche ich erst mal Zusammenhänge und Funktionsweisen in iobroker und VIS zu verstehen.
                  Ha, jetzt haben sich NaN und null auf false geändert :D Aber der Import von Fortschrifft funktioniert auch nicht. Da kommt eine Fehlermeldung:
                  TypeError: Cannot read property 'appendChild' of null
                  maxpd
                  • M maxpd
                    @maxpd
                    K
                    K
                    Kuddel
                    #69
                    @maxpd
                    Ja stimmt, ich kann es nach einem neuen Export aucht nicht importieren. Beim Fortschritt für die Nacht liegt irgendwo der Fehler.
                    Hier ist der Fortschritt für Tagsüber:
                    <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="(zB*eILS0}lC]4feO;NQ" x="-287" y="-12">
                      <field name="SCHEDULE">* * * * *</field>
                        <block type="comment" id="F@)g%-I%DLPUO?NKxC~p">
                          <field name="COMMENT">Tageslicht</field>
                          <next>
                            <block type="controls_if" id="cggsDF/*JY)o.]T!zs:|">
                              <value name="IF0">
                                <block type="logic_compare" id="neWt`yuwThe[})R*v;ua">
                                  <value name="A">
                                    <block type="time_get" id="3o?IF#+zk%NF)7tdrZF)">
                                      <mutation format="false" language="false"></mutation>
                                      <field name="OPTION">hh:mm</field>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="get_value" id="pn0]=@}Q6ypxVSk)x_ky">
                                      <field name="OID">javascript.0.zeiten.sonnenaufgang</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                <block type="control" id="FhF0Pwtrp.dFfW%SAmMK">
                                  <field name="OID">javascript.0.zeiten.tageslaenge_fortschritt</field>
                                    <block type="text" id="]EO6n@[7[C{)s_~D3VgB">
                                      <field name="TEXT">100</field>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="control" id="zF!boiV!!!f{]?n0baQ=">
                                      <field name="OID">javascript.0.zeiten.tageslaenge_tageslicht_in_minuten</field>
                                        <block type="convert_tostring" id=".]Q`EYCiV@we[rPrLSY1">
                                            <block type="math_arithmetic" id="!2*6Vi%`h}LN!_|`1@8(" inline="false">
                                              <value name="A">
                                                <shadow type="math_number" id="B3|V_Ljn[~%Q+HHiV?_~">
                                                </shadow>
                                                <block type="convert_from_date" id="7*E(LC8fHz2pU;ssHht,">
                                                  <field name="OPTION">mid</field>
                                                    <block type="time_astro" id="yS6(Fn=S5sB4/ATrUahy">
                                                      <field name="TYPE">sunset</field>
                                                      <field name="OFFSET">0</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow type="math_number" id="(c6`X/y~y*sa=f+,g)#y">
                                                </shadow>
                                                <block type="time_get" id="j:5w/cmmi!1JI;lj77Pn">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                              <next>
                                <block type="controls_if" id="(^^D^mu@vrKf*MzEai,n">
                                  <value name="IF0">
                                    <block type="logic_compare" id="OBaCAYbHt;;UM#v(xeQN">
                                      <field name="OP">GT</field>
                                      <value name="A">
                                        <block type="get_value" id="aqm]}h[z_`dAS]2;:t;n">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="math_number" id="k(G3Y:Tu)=yEFQ5yp2eS">
                                          <field name="NUM">0</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="control" id="Rd6@e{hWV62YiKLLY/%X">
                                      <comment pinned="false" h="80" w="160">Rechnung:
                    (aktueller Zeitpunkt in Minuten *100)/ Tagseslänge in Minuten
                                      </comment>
                                        <block type="convert_tostring" id="h!Y]I%GI10@a.jL{6tok">
                                            <block type="math_round" id="ygBOxsic4R5t?UbA@}-~">
                                              <field name="OP">ROUND</field>
                                              <value name="NUM">
                                                <shadow type="math_number" id="]:,s32?5@NfsE]u6dQ,H">
                                                  <field name="NUM">3.1</field>
                                                </shadow>
                                                <block type="math_arithmetic" id=".5pSNur])MV]f@qp4{i:" inline="false">
                                                  <field name="OP">DIVIDE</field>
                                                  <value name="A">
                                                    <shadow type="math_number" id="G`UN:3+p%7/kxBEol_%a">
                                                    </shadow>
                                                    <block type="math_arithmetic" id="uP/zc2;9gJbD1lYM.oaE" inline="false">
                                                      <field name="OP">MULTIPLY</field>
                                                      <value name="A">
                                                        <shadow type="math_number" id="i,38}R*oiUl1Om7!vYyI">
                                                        </shadow>
                                                        <block type="math_arithmetic" id="?~2A?%.eh#xtWJCztS@{" inline="false">
                                                          <value name="A">
                                                            </shadow>
                                                            <block type="convert_from_date" id="b)so8-M#4Y2YR:rb8:d8">
        <block type="time_astro" id="_13-93yo_*T4j%L]p!fj">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                            <block type="time_get" id="s9}ko*Y3GcHi[IQk4G6!">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <shadow type="math_number" id="9ci?a^NEeRpDmWT/.fJq">
                                                          <field name="NUM">100</field>
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <shadow type="math_number" id="WJCqhHA]_5|(VSXL)c|q">
                                                    </shadow>
                                                    <block type="get_value" id="ZCwsVW~Ji2=d3_=6BFpz">
                                                      <field name="OID">javascript.0.zeiten.tageslaenge_in_minuten</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="control" id="]zc;(b~L*|]iI!G,)m~G">
                                            <block type="convert_tostring" id="XbTV|L},^Tdv^f,~_g2#">
                                                <block type="math_arithmetic" id="pu^#PKi=UWTlp26L*~`x" inline="false">
                                                  <value name="A">
                                                    </shadow>
                                                    <block type="convert_from_date" id="X]N4(s*fnW7_jxGUUifu">
                                                        <block type="time_astro" id="iTZiG%s}DR)?Sy6`;5rj">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                    <block type="time_get" id=")sbT91k10eU/}HPQ~ylz">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="comment" id="Y1N3R)La8(53qWH.V?a9">
                                              <next>
                                                <block type="variables_set" id="ET}/!,v^cU1/5jyE}eGQ">
                                                  <field name="VAR">tageslicht_stunden</field>
                                                    <block type="math_round" id="t?v^j0B).zQX+H~}=N(L">
                                                      <field name="OP">ROUNDDOWN</field>
                                                      <value name="NUM">
                                                        <shadow type="math_number" id="E5^T=-p[{Skz]^7aPJ+F">
                                                        </shadow>
                                                        <block type="math_arithmetic" id="QwUu#.n:s-Nt)d@Q@o%[" inline="false">
                                                          <value name="A">
                                                            <shadow type="math_number" id="1A!||Q4Q9fXwNB5L_|J*">
                                                            </shadow>
                                                            <block type="get_value" id="yQr4N;rn6xI;oAW_T2Nl">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <shadow type="math_number" id="`sFASt]W(*oo7d%O%hwn">
                                                              <field name="NUM">60</field>
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="variables_set" id=")}DYs.qo/qSk_T|Y5Htz">
                                                      <field name="VAR">tageslicht_minuten</field>
                                                        <block type="math_arithmetic" id="=lynCq7?+TJh%a5B?Ntt" inline="false">
                                                          <value name="A">
                                                            <shadow type="math_number" id="WD~!+d%3~wqM=kmHzDlk">
                                                            </shadow>
                                                            <block type="get_value" id="J=0k:+OoU6)^14p}FGfQ">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <shadow type="math_number" id=")).0/8sID@I9|,f|pKo?">
                                                            </shadow>
                                                            <block type="math_arithmetic" id="(_3*6w96%s1oQHYJ16ko" inline="false">
                                                              <value name="A">
        <shadow type="math_number" id="fc]gQz4gNGA*T6;VLb5l">
        </shadow>
        <block type="variables_get" id="y/1C[b{KCV}@cR!6WO-7">
        </block>
                                                              </value>
                                                              <value name="B">
        <shadow type="math_number" id="TL6V{F/fJM57]O?xKm_i">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                        <block type="controls_if" id=".ZRuC~F66A;*aLrdlC+v">
                                                          <value name="IF0">
                                                            <block type="logic_compare" id="HTm~#EmdyULx?`/NKXZp">
                                                              <field name="OP">LT</field>
                                                              <value name="A">
        <block type="variables_get" id="4fiBgAwIQ;48sw[.9QH?">
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="math_number" id="KWPSYMzD`d4?F_7y=]lo">
        <field name="NUM">10</field>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                            <block type="variables_set" id="528hrX[=)+b)a0kl@Kle">
        <block type="text_join" id="9]x8h0aiY)OmCU:_ohg(">
        <value name="ADD0">
        <block type="text" id="qef:q5saO(ccR;^IVVD:">
        <field name="TEXT">0</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="vuQYs.,C2y*esJOU8:~v">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                          <next>
                                                            <block type="controls_if" id="73j.SvxF#,oZbvhipBNI">
                                                              <value name="IF0">
        <block type="logic_compare" id="w*q*5{z3E|#q*c~,B;h0">
        <value name="A">
        <block type="variables_get" id="BM)8Wr*ds{sP!z-)Y+*K">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="[mr@FAqLcBz%[rHF58Qv">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="variables_set" id="uPPa@wz([53N3kGW[(RJ">
        <block type="text_join" id="-^:=WQ_=Ie8:buhh*).u">
        <value name="ADD0">
        <block type="text" id="pz8#`YTfV:=P_8]](/#i">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="Mq~(xp1l-t:Jj1B*l#Dc">
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </statement>
                                                              <next>
        <block type="control" id="gYZcm^-jUxihTef2X^gk">
        <field name="OID">javascript.0.zeiten.tageslaenge_tageslicht</field>
        <block type="convert_tostring" id="q[zG5-(W%PeQIJ,nTg|c">
        <block type="text_join" id="{Ln%z*ZgfT1HwU@xZF-m">
        <value name="ADD0">
        <block type="variables_get" id="3D+c0Y!fe1n5AJ^#K`wY">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="7M}EySWGm^xwZHhEY=#M">
        <field name="TEXT">:</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="variables_get" id="vC7GN1uRdzm)YkW.c_]Y">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="controls_if" id="|)SKV{5+KIllIIw!(T:v">
                                      <value name="IF0">
                                        <block type="logic_operation" id="YKkKg7bAvjKaj7mV+F3S" inline="false">
                                          <field name="OP">AND</field>
                                          <value name="A">
                                            <block type="logic_compare" id=")y}[Y5d^Zj|lcW.]g-~y">
                                              <value name="A">
                                                <block type="get_value" id="An.K@#d]()Gk^lL9g].G">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="text" id="pDv3@EH6gt^e:IixA}XP">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_compare" id="(CUNsRMks#.%3?oIjQ%l">
                                              <field name="OP">NEQ</field>
                                              <value name="A">
                                                <block type="get_value" id="%2wrh+-Rt%Qh]bYf^dD|">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="text" id="{wbkp39a3O]Q6zjD15i`">
                                                  <field name="TEXT">00:00</field>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="cU?u,@73HT#~~0Ub=(uZ">
                                            <block type="convert_tostring" id="O-5R5~#q|eT@0T8c}_?0">
                                                <block type="text" id="2r6?Z7W|^({ea)3h03OY">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                    • M
                      M
                      maxpd
                      #70
                      Danke dir @Kuddel
                      vielleicht kannst du dein Blockly für die Fenster oder Lampenübersicht zumindest als Screen mal zeigen? Denn eine solche Übersicht wollte ich mir auch bauen, habe aber das Gefühl, dass ich mein Blockly zu kompliziert konzipiere.
                      maxpd
                      • M maxpd
                        Danke dir @Kuddel
                        K
                        K
                        Kuddel
                        #71
                        @maxpd
                        Fenster_EG
                        • M
                          M
                          maxpd
                          #72
                          OK ja, mache ich auch so. Hatte gehofft, dass man alle Fenster in einer Liste oder Case abfragen kann
                          maxpd
                          • haschelH
                            haschelH
                            haschel
                            schrieb am zuletzt editiert von haschel
                            #73
                            @Kuddel
                            Danke erstmal für Scripte. Klappt alles soweit. Nur weiß ich gerade nicht, ob und wenn wo, ich auf dem Schlauch stehe. Bei dem Speicherplatzscript wird mir im Datenpunkt bei der Systemplatte der belegte Speicher angezeigt, und bei den anderen der verfügbare - soweit alles gut. Leider zeigt er mit den Wert in TB an - sprich 15GB frei zeigt er mit im Objekt als 0.015 an. Normalerweise habe ich mit Code nicht das Problem - kenne mich aber zu wenig mit der Power-Shell Syntax aus um sie dahingehend zu verändern. Oder hast du dafür noch ein Script im ioBroker um die Daten umzuwandeln? - Eher nicht, oder?
                            Danke dir! :)
                            • haschelH haschel
                              @Kuddel
                              Danke dir! :)
                              K
                              K
                              Kuddel
                              #74
                              @haschel
                              der Wert wird direkt im Powershellskript umgerechnet
                              haschelH G 2 Antworten Letzte Antwort
                              • K Kuddel
                                @haschel
                                haschelH
                                haschelH
                                haschel
                                #75
                                @Kuddel ja, so meine ich das auch verstanden zu haben. Da scheint ja eine Bedingung für das Anzeigen/Berechnen von GB oder TB zu sein - richtig? Will mich da jetzt ein wenig reinfuchsen, deswegen die Fragen - hoffe es stört dich nicht... :)
                                • D
                                  D
                                  derrapf
                                  #76
                                  Hi
                                  Da sind ein paar spannende Widgets dabei.
                                  Wie hast Du denn den Wecker realisiert und welche Widgets dazu verwendet`? Ist das ein einzelnes Widget oder eine Kombination aus Mehreren?
                                  Gruss Ralf
                                  • D derrapf
                                    Hi
                                    Gruss Ralf
                                    K
                                    K
                                    Kuddel
                                    #77
                                    @derrapf
                                    Die Weckzeit besteht aus 3 Widgets.
                                    1. Anzeige der Uhrzeit (Stunde:Minute)
                                    2. Steuerung der Stunde
                                    3. Stuerung der Minunte
                                    Auf Grund der Weckzeit wird dann entsprechend ein Skript zur ausgewählten Zeit gestartet, was Lampen, Echos etc. anschaltet
                                    • D
                                      D
                                      derrapf
                                      schrieb am zuletzt editiert von derrapf
                                      #78
                                      Und das Widget schreibt die eingestellten Stunden und Minuten wohin?
                                      Im Script trigegrst Du dann auf beide Datenpunkte? Oder wie machst Du das?
                                      Und wie geht das mit den Adapterstatus und den ganzen Netzwerkdaten? Alles über Scripts?
                                      • K Kuddel
                                        @gfrene
                                        G
                                        G
                                        gfrene
                                        schrieb am zuletzt editiert von gfrene
                                        #79
                                        @Kuddel ... Super gelesen verstanden und umgesetzt :-) Danke dir ... ich möchte nicht wissen was das an Zeit gekostet hat alles so umzusetzen wie du das gemacht hast ... Hut ab. So ich frage mal vorsichtig ✌ wenn man die Zonenrein. umsetzten möchte brauch man ja von jeden Raum die Koordinaten ist das immer noch so kompliziert wie früher oder wie hast du die einzelne Räume umgesetzt ? Und zu guter letzt die Betriebsstunden werden ja eigentlich nur in Min. im Datenpunkt geschrieben hast du dafür ein Srcipt was die Min. in Stunden umrechnet, falls ja könntest du das auch noch posten. Ich hofffffeeee wir nerven dich alle nicht mit den fragen :-) Gruß und DICKES Danke für deine Hilfe.
                                        M K 2 Antworten Letzte Antwort
                                        • G gfrene
                                          M
                                          M
                                          mehrwiedu
                                          schrieb am zuletzt editiert von mehrwiedu
                                          #80
                                          @gfrene said in [Vorstellung] Meine zweite Visualisierung:
                                          Ja, das würde mich auch interessieren. Zumal ich kein Androiden habe, sondern ausschließlich iOS und macOS Geräte und ich mich mit dem Sideload von APKs überhaupt nicht auskenne und letztlich nach Anleitung an meinem macOS scheitere, weil es die ganzen Windows-Tools dafür nicht gibt. ;) Mit einem Galaxy Tab A (aus der Zeit vom iPad2 oder so) kann ich nichts mehr anfangen, oder?
                                          Das ist auch der Grund, warum ich bisher meinen Roboter noch nicht upgedatet habe. Der fährt weiterhin mit der Firmware vom Kaufdatum, weil ich Angst habe, den Token zu verlieren. Das war aus meiner Erinnerung ein Krampf den auszulesen mit iOS.
                                          Vielleicht gibt es ja jetzt noch eine einfachere Möglichkeit, denn eine Zonenreinigung hätte ich auch verdammt gerne. ;)
                                          83.9k
                                          1.4m
